Golf 6 1.4 tsi strange code after fixing G188
Fredrick Awuor
Kenya
C?ID=309834
Hello guys,after finally fixing G188 issues on this car after it had been through many garages in Nairobi,....before i could celebrate during a test drive:banghead:....EPC blinked on trying to press accelerator hard to overtake....light went off,reappeared again when i tried to drive aggressively.....this car is petrol engined code CAXA....and i am wondering where this diesel ghost code has come from.....any hints are greatly welcome
 Monday,05,November,2018,13:43:33:48669
VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
Dealer/Shop Name: VAG AUTO-XRAY
VIN: WVWZZZ1KZAW218486   License Plate:
Mileage: 105180km-65355mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAW218486   Mileage: 105180km-65355miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 AJ    HW: 03C 907 309 A
   Component: MED17.5.5           8546
   Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 55455 002 1048576
   VCID: 6788B271B36635EF3FC-8032
012398 - Glow Ignition
               P306E - 000 - Short Output Reduction - Intermittent
                    Mileage: 105179 km
                    Date: 2013.03.28
                    Time: 01:38:58
                    RPM: 2462 /min
                    Load: 87.4 %
                    Speed: 112.0 km/h
                    Temperature: 87.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 13.843 V
Readiness: 0010 0001
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501311095470
   Shop #: WSC 44132 000 1048576
   VCID: 392C24099552731F998-806C
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B400D11230002C80F02EC881F0080310000
   VCID: 7AAEFB05DCD4B807D02-802E
18020 - Engine Control Module Incorrectly Coded
            P1612 - 000 -  - Intermittent
                    Reset counter: 20
                    Mileage: 105013 km
                    Date: 2013.03.24
                    Time: 00:00:17
                    Count: 2
                    Count: 2
                    Count: 28928
                    Count: 8197
                    Count: 44288
                    Count: 255
                    Count: 85
03366 - Vacuuum Sensor
                    Fault Status: 00101100
                    Reset counter: 23
                    Mileage: 104680 km
                    Date: 2013.03.11
                    Time: 19:58:49
                    Count: 16384
                    Count: 32768
                    Count: 13056
                    Count: 213
                    Count: 49449
                    Count: 65533
                    Count: 585
                    Fault Status: 00101101
                    Reset counter: 32
                    Mileage: 105013 km
                    Date: 2013.03.24
                    Time: 00:00:17
                    Count: 2
                    Count: 2
                    Count: 28928
                    Count: 8193
                    Count: 44288
                    Count: 255
                    Count: 85
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   VCID: 7DA4F019CD7A8F3FF50-8028
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 E    HW: 5K0 959 655 E
   Component: AirbagVW10G   037 0606
   Serial number: 003FLR00211R
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C223D1D96E0463782E-8068
   Serial number: 3572MSME1E43244DZZZ
   Serial number: 3582MSME2D2A644CZZZ4
   Serial number: 3512QSME04263E09ZZZT
   Serial number: 3522QSME0E2D3A28ZZZ1
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           853 0111
   Coding: 0001004
   VCID: 025E83E5B804F0C7882-8056
   Part No SW: 5K0 920 860 H    HW: 5K0 920 860 H
   Component: KOMBI         H04 0308
   Coding: 570B00
   VCID: 313C1C2941A2BB5F218-8064
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 101109F1001090
   Coding: ED807F06000202000003
   VCID: 698CB449A572039F298-803C
                    Reset counter: 197
                    Mileage: 103873 km
                    Date: 2013.03.03
                    Time: 00:09:36
   Component: IMMO          H04 0308
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECB45ACF40887202-803E
   Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
   Component: Tuer-SG         009 2140
   Coding: 0004790
   VCID: 3432153DB2308E774AE-8060
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 313C1C294D22BB5F218-8064
Address 46: Central Conv.
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Component: Tuer-SG         009 2114
   Coding: 0005046
   VCID: 33301621B73E894F534-8066
Address 56: Radio
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 35342839B94A977F7D0-8060
End----------(Elapsed Time: 00:57, VBatt start/end: 13.7V/13.4V)-----------
Fredrick Awuor
Kenya
C?ID=309834
Have you coded/re-coded your engine module?
Oh ignore the fault on 03....I tried a different ECU to rule out bad wiring or Throttle valve and only erased errors on 01.......the other ECU was for manual transmission but still with CAXA,coding was 0000072.......but you can see this is 0000077 which is correct for 7speed dsg
myounus
Northwest UK
C?ID=321059
I'm dubious about that scan as it's not captured all modules. Try erasing all faults and re-running an autoscan with the ignition on and all doors shut.
Fredrick Awuor
Kenya
C?ID=309834
Hello,this is the latest scan i did today and G188 seems to be coming back....i had installed an overlay wiring harness which seemed to have fixed it for sometime.....but my concern is on GLOW IGNITION error.....any leads welcome
Saturday,17,November,2018,11:43:12:48669
VIN: WVWZZZ1KZAW218486   License Plate: MRG
Mileage: 105600km-65616mi   Repair Order:
VIN: WVWZZZ1KZAW218486   Mileage: 105600km-65616miles
   Coding: 0000077
                    Mileage: 105542 km
                    Date: 2013.04.06
                    Time: 19:28:50
                    RPM: 1886 /min
                    Load: 80.4 %
                    Speed: 72.0 km/h
                    Temperature: 87.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 820.0 mbar
                    Voltage: 13.843 V
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 000 - Implausible Signal - Intermittent
                    Mileage: 105300 km
                    Date: 2013.04.01
                    Time: 18:56:40
                    RPM: 1028 /min
                    Load: 20.0 %
                    Speed: 5.0 km/h
                    Temperature: 33.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 810.0 mbar
                    Voltage: 14.224 V
   Revision: 00H30001
                    Reset counter: 34
                    Mileage: 105204 km
                    Date: 2013.03.29
                    Time: 08:28:42
                    Count: 16384
                    Count: 32768
                    Count: 12800
                    Count: 213
                    Count: 48392
                    Count: 768
                    Count: 337
                    Reset counter: 42
                    Mileage: 105300 km
                    Date: 2013.04.01
                    Time: 18:56:41
                    Count: 16384
                    Count: 12800
                    Count: 8193
                    Count: 51205
                    Count: 62971
                    Count: 255
                    Count: 82
   Revision: 00003001
   Coding: 0000001002
   Part No SW: 1K0 937 086 E    HW: 1K0 937 086 E
   Component: BCM PQ35  M   103 0573
   Revision: 00103 AF
   Coding: 40180A3A98251AC0440000803400812443510088536D8960648000200000
   VCID: 323E132544248047582-8066
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 21100  21  0512
   Coding: 009795
   Component: RLS 101109 05  54  0402
   Coding: 0B30AD
   Coding: 00003133
   Coding: 0001004
   Coding: 570B00
                    Reset counter: 248
                    Mileage: 105185 km
                    Date: 2013.03.29
                    Time: 02:00:31
   Coding: 0004790
   Revision: 00H17000
   Coding: 0005046
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 00:58, VBatt start/end: 13.6V/13.7V)-----------
