2018 Golf R removing NAR headlight restrictions
Tac
C?ID=316947
Hello, I'm trying to remove the NAR restrictions on my 18 Golf R. It does not have a module 55, but instead 4B that seems to contain lights. I found ability to toggle off the NAR restriction in long coding, as expected the AFS warning came on and I went to basic settings to follow the tried and true things that worked on my 17 GTI with module 55:
Select "Basic Headlamp Setting" and "Go" - headlamps will automatically self-level the aim and you'll see 'Running' in the window. It will settle around 1 to 1.5" higher than original setting - if you view against a wall you'll see better. Once it's finished self-align press 'Stop'.
Then from the same pull-down menu select "Acknowledge Basic Setting" and 'Go'. The new Basic setting has now been stored. Press 'Stop' and 'Done, Go Back'
This is where my problem begins, trying to "Basic Headlamp Setting" gives me a Not Running, also lights don't move. "Acknowledge Basic Setting" also says Not Running, but it does make the AFS Error go away. Unfortunately if I turn the car off, let it sit for a bit, and turn it back on, I get a christmas lights worth of errors. Below is an autoscan with all the errors that came up.
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU2JW2   Mileage:
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: Malfunction 0010
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P_VW37.rod
   VCID: 4DC461CDED59B24F253-8018
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 211CED7DC141462FB1B-8074
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60518000001916
   Coding: 01FA6BA1542121714577030960CB6980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
   VCID: 035087F57B9DB43F837-8056
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0472298748
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C223C0946E30BC782D-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500401211140A
   VCID: 6D84C14D4D19524F453-8038
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001805700259
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06569EE148AF8117A49-8052
   Component: WWS    180201  043 0551
   Serial number:         180210123856
   Component: RLHS  047 0105
   Serial number: S8Y18M02D28H17M49S10
   Coding: 00A8DD
566550 - Databus
          [LCM links - unplausibler Datensatz]
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:38:11
566806 - Databus
          [LCM rechts - unplausibler Datensatz]
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:38:11
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:58:48
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:58:48
   Serial number: 000308418018053
   Coding: 0471155811
   VCID: 4BC06FD5134DBC7F3B7-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330040C159FFC728949C810580401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E26360150FF19D7AC9-806A
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 61
                    Mileage: 48 km
                    Date: 2018.09.08
                    Time: 13:34:16
                    Control Module temperature: 49 °C
                    Voltage terminal 15: 13.0 V
                    Velocity_vehicle_reference: 12.10 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.77 m/s²
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 73
                    Mileage: 670 km
                    Date: 2018.10.25
                    Time: 17:33:39
                    Control Module temperature: 51 °C
                    Voltage terminal 15: 14.0 V
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 78
                    Mileage: 670 km
                    Date: 2018.10.25
                    Time: 17:33:39
                    Voltage terminal 15: 14.1 V
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 78
                    Mileage: 670 km
                    Date: 2018.10.25
                    Time: 17:33:39
   Serial number: 10021841350419
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382A201972DB27E7665-806C
   Serial number: 003GCR09VJK8
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47C853E50F25581F1FF-8012
   Occupant Detection:
   Serial number: IBH000000000008LJ45H
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 002 402 18
   Serial number: 357000000006AB79BC2/
   Subsystem 3 - Part No SW: -----------    HW: 480 002 802 18
   Serial number: 35800000000A2468BC2S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 702 18
   Serial number: 3510001AB28F9E51751C
   Subsystem 5 - Part No SW: -----------    HW: 480 402 402 18
   Serial number: 3520001BB293E204B3B6
   Subsystem 6 - Part No SW: -----------    HW: 480 402 802 18
   Serial number: 35500019D28F9E53153F
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 802 18
   Component: FrontSensor_P  000 6149
   Serial number: 35600019B28F9E56858T
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18021808491243
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 094C95DD59B1EE6FC9B-805C
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         407 3193
   Coding: 0BAD301A7F88CF0502887B0B54010000A0000000
   VCID: 2B000F55B38D9C7F1B7-807E
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007455119
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002784760057493
   Coding: 35FFFF
   Serial number: 7223206704
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00025.01.18
   Coding: 0001
   VCID: 4CC26CC91643BB4732D-8018
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0019 - Headlamp Type
          C119F 00 [009] - Implausible
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:38:07
   Revision: 00000000    Serial number: 18000057734003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343214296EB3C3874AD-8060
                    Reset counter: 38
                    Mileage: 723 km
                    Date: 2018.10.26
                    Time: 18:38:07
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 73
                    Mileage: 608 km
                    Date: 2018.10.24
                    Time: 09:08:10
   Component: HRE_Master    H12 0080
   Serial number: 0471302682
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D24310D5DF902CFB53-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0470453345
   Coding: 020111
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B203F1543ED0CFF8B7-806E
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01VBXC
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E060641809FE9573C9-807A
   Serial number: 13021811600559
   Coding: 000000050100165206703F01020000000000000000000000000000000000
   VCID: 72BED23154278DB7981-8026
66678 - Databus
          U1123 00 [137] - Received Error Message
          [LCM_Datensatz_Fehler_L received error value]
                    Reset counter: 38
                    Mileage: 733 km
                    Date: 2018.10.27
                    Time: 14:18:12
66679 - Databus
          [LCM_Datensatz_Fehler_R received error value]
                    Reset counter: 38
                    Mileage: 733 km
                    Date: 2018.10.27
                    Time: 14:18:12
   Serial number: 180218EBH24134
   Coding: 003E13208000040000800000
   VCID: 42DE42F124077D37C81-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000019604903
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 333017356BBDC4BF537-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJV0396592
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   VCID: 43D047F53B1D743FC37-8016
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 05021812P21453
   Coding: 0003070000000201002213548150890084000E200120
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 73
                    Mileage: 670 km
                    Date: 2018.10.25
                    Time: 17:33:39
                    Control Module temperature: 43 °C
                    Outside air temperature: 13.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 1215.2 s
                    mid: 01 F0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 180127202574
   VCID: 2F381B458795E05F37F-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392C251D49D13EEF99B-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 12.3V/12.2V)-----------
Fortunately long coding the NAR restriction back on, running through "Basic Headlamp Setting" and "Acknowledge Basic Setting" (that still return Not Running? Maybe doesn't even really do anything?), and restarting the car clears the faults.
Thanks!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Welcome to the forum!
What specifically are you trying to change that's against this restriction?
29 and 39 don't much care for what they were asked to do, and they're sharing that feeling with lots of downstream components. It appears to be a factory dataset (parameterization) issue with either 29/39 or 4B. VW uses the same range control and LED power controllers worldwide and tweaks them for local regulatory schemes. However, there are also minor but definite hardware differences in parts of the overall LED headlight assembly, like cornering lamps, amber markers, and DLA shutters.
I have some experience with this on my own 2018 Golf R. I've been through the basic settings / acknowledge procedure several times. The immediate "Not Running" response appears to be normal.
As for not moving, when you trigger the Basic Headlamp Setting process, you'll see the LED headlights move to the basic setting adjustment position if they weren't already there. What's happening is they're moving to that position the moment you recode them, whether that new coding is valid or not. If you triggered it right now without recoding, like you just wanted to make physical aiming tweaks, you'd see them move at that point.
If you're trying to enable DLA, let me save you some time, because I went through it already. ;) You can actually make it appear to work, with no apparent faults, and the headlights do some of the nifty DLA aiming stuff while driving. But, we don't have the shutter hardware, so the most important part is missing, and therefore you're blinding drivers in front of you. DLA is super freaking awesome so I want to get some Euro LED assemblies at some point.
Tac
C?ID=316947
Thanks!
Nothing crazy, at least I hope not. Was just trying to turn off NAR restrictions so they can raise at highway speeds and also allow me to use the rain/highway/city/all_weather light settings.
I'm still a VCDS newbie, and I figure out you already knew this, but I'll note that I did only touch 4B.
This is reassuring, as I wasn't sure if VCDS the software didn't fully support this module yet.
Was not after DLA, but I do appreciate the insight.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I haven't tried the city or all weather lighting, but I can tell you the intersection lighting (based on predictive route data from navigation) works pretty well, I run with it turned on.
Yeah, with the modern LED setup, 4B seems to be in charge of 29/39 and D6/D7.
D-Dub
US 2014 GTI Drivers Edition/DSG
C?ID=272151
I figured out city lights and all weather lights, but what the vag is intersection lighting?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Great question. It seems to be a mechanism to increase your visibility to crossing traffic, or increase your ability to spot crossing pedestrians. It was a coding checkbox and I turned it on for S&Gs, and it most definitely Does Stuff. I could not find, and still cannot find, a reference that describes it or feedback from anyone else trying it.
When you're approaching an intersection, it will turn on BOTH cornering LEDs when you get close, and then fade them out after you pass through. It activates consistently through certain intersections in the subdivision where I live (with or without stop signs) and in various other driving conditions. It DOES NOT require braking or turn signaling. It's learning about upcoming intersections based on predictive route data coming from your onboard navigation. It only happens at lower speeds, I believe, and possibly only on certain classes of road.
D-Dub
C?ID=272151
thats pretty cool.
i wonder if, or when that will be integrated with pedestrian detection, and EV noise makers.
this related video was pretty funny.
Tac
C?ID=316947
Appreciate the insight, but in an attempt to refocus the thread, can anyone provide any suggestions on making 29 and 39 less angry? Thanks!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It's not entirely clear if this can be done without complete Euro LED assemblies.
It appears the LCMs at 29/39 would have to have the Euro "parameterization" loaded. Think of it like a low level EEPROM write. That isn't something you can do with VCDS, and probably not even with dealer ODIS since it'll want to load up the correct data for your NAR VIN. There exists another tool that permits deliberate foot-shooting of this sort, but you need to know exactly what you're doing, and I'm not sure if they have data for these LCMs, and I'm not going to get into it on Ross-Tech's forum.
Even if you successfully did that, the LCMs may just turn around and be pissed off that they're plugged into NAR LED assemblies with stuff added/missing from what they now expect, like the amber side markers. Parameterization is not a directly reversible thing, and there's no real way to take a backup, so if you don't have NAR data too, you'd be screwed.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Following up to myself... I spent some time farting around in PL24 tonight, because I want DLA. :o Out of all the normal worldwide headlight variants (this is only one of three pages), exactly one pair of them is specially crippled just for NAR.
PRCode: AV0 = Driving on the left
PRCode: AV1 = Driving on the right
PRCode: AV2 = Driving on the right (NAR)
We're missing a range control motor, and judging by the special non-serviceable cap, I'm guessing you can't install one. I'm not exactly sure what that's about, since the NAR headlights can clearly point up/down/left/right. It's possible that's just turning selected LED chips on/off. I'll further guess the range control motor is needed for the highway light function.
TL;DR: Pretty sure you're screwed unless you want to order Euro assemblies. In which case, try to get DLA equipped ones, not from this screenshot.
Tac
C?ID=316947
Awesome information, thanks so much!
quailallstar
Florida & the Nation's Capital
C?ID=53119
@TAC
Mind sharing the coding on how you enabled the rain/highway/city/all_weather lights? I have a 2019 GTI Rabbit and I too am looking to unlock some NAR settings and enable these hidden features.
Thanks!
Michael
DV52
C?ID=194404
Michael: Just guessing - but perhaps this (Byte0, Bit 0) in the RLS/RLHS/RLFS on older model BCM s ?
Or, on newer style BCM s,
MAS08228-ENG142230-Light sensor HMI_Exterior_light_on_highway > set to active?
quailallstar
C?ID=53119
Hey Don!
Let me give this a look sometime today and report back on what I find.
quailallstar
C?ID=53119
I suspect the NAR headlamps on an MK7.5 GTI or Golf-R do not have the required hardware for the DLA option. Am I correct on this assumption? I've been reading this in-depth thread posted by Arteon owners in the USA who have discovered their NAR Arteon models do have the necessary hardware and successfully enabled DLA. :thumbs:
