Hello, I'm trying to remove the NAR restrictions on my 18 Golf R. It does not have a module 55, but instead 4B that seems to contain lights. I found ability to toggle off the NAR restriction in long coding, as expected the AFS warning came on and I went to basic settings to follow the tried and true things that worked on my 17 GTI with module 55:
Fortunately long coding the NAR restriction back on, running through "Basic Headlamp Setting" and "Acknowledge Basic Setting" (that still return Not Running? Maybe doesn't even really do anything?), and restarting the car clears the faults.
Thanks!
This is where my problem begins, trying to "Basic Headlamp Setting" gives me a Not Running, also lights don't move. "Acknowledge Basic Setting" also says Not Running, but it does make the AFS Error go away. Unfortunately if I turn the car off, let it sit for a bit, and turn it back on, I get a christmas lights worth of errors. Below is an autoscan with all the errors that came up.Select "Basic Headlamp Setting" and "Go" - headlamps will automatically self-level the aim and you'll see 'Running' in the window. It will settle around 1 to 1.5" higher than original setting - if you view against a wall you'll see better. Once it's finished self-align press 'Stop'.
Then from the same pull-down menu select "Acknowledge Basic Setting" and 'Go'. The new Basic setting has now been stored. Press 'Stop' and 'Done, Go Back'
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU2JW2 Mileage:
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DJJA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 P HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 092500122466010E3004
ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
ROD: EV_ECM20TFS0208V0906259P_VW37.rod
VCID: 4DC461CDED59B24F253-8018
Part No SW: 0GC 300 012 A HW: 0GC 927 711 G
Component: GSG DQ381 H06 1403
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: 211CED7DC141462FB1B-8074
Part No SW: 5Q0 614 517 CR HW: 5Q0 614 517 AD
Component: ESC H25 0523
Revision: 00000000 Serial number: 60518000001916
Coding: 01FA6BA1542121714577030960CB6980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 035087F57B9DB43F837-8056
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0472298748
Coding: 032C0C
VCID: 3C223C0946E30BC782D-8068
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000110500401211140A
VCID: 6D84C14D4D19524F453-8038
Air quality sensor:
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001805700259
ROD: EV_BCMBOSCH_018.rod
VCID: 06569EE148AF8117A49-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180201 043 0551
Serial number: 180210123856
Component: RLHS 047 0105
Serial number: S8Y18M02D28H17M49S10
Coding: 00A8DD
566550 - Databus
[LCM links - unplausibler Datensatz]
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:38:11
566806 - Databus
[LCM rechts - unplausibler Datensatz]
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:38:11
568086 - Databus
[LCM links - Blinker defekt]
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:58:48
568342 - Databus
[LCM rechts - Blinker defekt]
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:58:48
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018053
Coding: 0471155811
VCID: 4BC06FD5134DBC7F3B7-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 330040C159FFC728949C810580401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E26360150FF19D7AC9-806A
1236 - Databus
[FAULT_TIMEOUT_BV1_POSITION]
Reset counter: 61
Mileage: 48 km
Date: 2018.09.08
Time: 13:34:16
Control Module temperature: 49 °C
Voltage terminal 15: 13.0 V
Velocity_vehicle_reference: 12.10 m/s
Longitudinal_acceleration_vehicle_reference: 1.77 m/s²
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 73
Mileage: 670 km
Date: 2018.10.25
Time: 17:33:39
Control Module temperature: 51 °C
Voltage terminal 15: 14.0 V
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 78
Mileage: 670 km
Date: 2018.10.25
Time: 17:33:39
Voltage terminal 15: 14.1 V
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Reset counter: 78
Mileage: 670 km
Date: 2018.10.25
Time: 17:33:39
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 10021841350419
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 382A201972DB27E7665-806C
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR09VJK8
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47C853E50F25581F1FF-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008LJ45H
Coding: 303344
Subsystem 2 - Part No SW: ----------- HW: 480 002 402 18
Serial number: 357000000006AB79BC2/
Subsystem 3 - Part No SW: ----------- HW: 480 002 802 18
Serial number: 35800000000A2468BC2S
Subsystem 4 - Part No SW: ----------- HW: 480 402 702 18
Serial number: 3510001AB28F9E51751C
Subsystem 5 - Part No SW: ----------- HW: 480 402 402 18
Serial number: 3520001BB293E204B3B6
Subsystem 6 - Part No SW: ----------- HW: 480 402 802 18
Serial number: 35500019D28F9E53153F
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 802 18
Component: FrontSensor_P 000 6149
Serial number: 35600019B28F9E56858T
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 18021808491243
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 094C95DD59B1EE6FC9B-805C
Part No SW: 5G1 920 891 A HW: 5G1 920 891 A
Component: KOMBI 407 3193
Coding: 0BAD301A7F88CF0502887B0B54010000A0000000
VCID: 2B000F55B38D9C7F1B7-807E
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007455119
Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170002784760057493
Coding: 35FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7223206704
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00025.01.18
Coding: 0001
VCID: 4CC26CC91643BB4732D-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
0019 - Headlamp Type
C119F 00 [009] - Implausible
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:38:07
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000057734003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 343214296EB3C3874AD-8060
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Reset counter: 38
Mileage: 723 km
Date: 2018.10.26
Time: 18:38:07
0033 - Supply voltage
[Supply voltage - lower limit exceeded]
Reset counter: 73
Mileage: 608 km
Date: 2018.10.24
Time: 09:08:10
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0471302682
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D24310D5DF902CFB53-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0470453345
Coding: 020111
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B203F1543ED0CFF8B7-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD01VBXC
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E060641809FE9573C9-807A
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 13021811600559
Coding: 000000050100165206703F01020000000000000000000000000000000000
VCID: 72BED23154278DB7981-8026
66678 - Databus
[LCM_Datensatz_Fehler_L received error value]
Reset counter: 38
Mileage: 733 km
Date: 2018.10.27
Time: 14:18:12
66679 - Databus
[LCM_Datensatz_Fehler_R received error value]
Reset counter: 38
Mileage: 733 km
Date: 2018.10.27
Time: 14:18:12
Component: TSG BFS 020 0041
Serial number: 180218EBH24134
Coding: 003E13208000040000800000
VCID: 42DE42F124077D37C81-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000019604903
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027310020000000051220002001808009F0507F401200405C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 333017356BBDC4BF537-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJV0396592
Subsystem 2 - Part No SW: 3G0 919 866 BP HW: -----------
Component: NAR 2018 --- 0715
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43D047F53B1D743FC37-8016
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 05021812P21453
Coding: 0003070000000201002213548150890084000E200120
1122664 - Databus
[TIMEOUT_PSD_04]
Reset counter: 73
Mileage: 670 km
Date: 2018.10.25
Time: 17:33:39
Control Module temperature: 43 °C
Outside air temperature: 13.0 °C
Vehicle speed: 0.00 km/h
System run time: 1215.2 s
mid: 01 F0
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180127202574
VCID: 2F381B458795E05F37F-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392C251D49D13EEF99B-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 12.3V/12.2V)-----------
Thanks!
