Cannot learn aux heater remotes...?
darkchina811
ITALY
C?ID=333184
I am into module 18 and want my T91 receiver, which I bought used, to forget all prevois remotes.
so I go into BASIC SETTINGS and try the "adapt remote by barcode", and try to put hex code 00 00 00 for all four position. it does not work and I get a popup window saying something like "please type 3 hex digits separated by space".
I get the popup all the time, no matter what hex values I type.
so I learned my only remote four times (by radio tx) to fill all the slots... but why doesn't the barcode procedure work?
PetrolDave
Westbury, UK
C?ID=1423
Got an Auto-Scan? You don't say what car you have, what year it is, etc. - the Autocan will answer those questions and more we need to know to help you.
darkchina811
ITALY
C?ID=333184
Saturday,20,October,2018,00:44:47:06888
VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Mileage: 23180km-14403mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 42 44 52 5F 65
VIN: WVWZZZAUZHW0xxxxx   Mileage: 23180km-14403miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003223241D082000
   Shop #: WSC 21385 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDF5B4-803E
   CAN Converter 01:
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E2608294730020500A400203
   Shop #: WSC 131071 102 209715
   VCID: 74B120C35E3A81278AE-8020
   Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
   Revision: 00001K08
   Coding: 00020004104111011005004000101022
   Shop #: WSC 00028 028 00068
   VCID: 73B323DF5B34861F934-8026
   Serial number: 01061633700891
   Coding: 00000846C20102FB0B244080B11407281400000000000000000000000000
   Shop #: WSC 00028 028 00069
   ROD: EV_BCMBOSCH_015.rod
   VCID: 045170030E9AB1A7BAE-8050
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Component: RLHS  042 0105
   Serial number: S5Y17M06D01H13M38S50
   Coding: 06A8DD
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0042
   Revision: --------    Serial number: 61131402901978
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 40D9BC135A026D87DE6-8014
   Serial number: 003F6R1V1W4Y
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DFB9175108648FD18-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D4755275DD0F0EFE50-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 03A501802290000D02083B041400000000000000
   VCID: 26150A8BD866A3B7C4A-8072
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   VCID: 3537DDC715C0D82F7D0-8060
   Component: R64 D208L  004 0401
   Serial number: 00000000000000180382
   Revision: --------    Serial number: 0004271482
   Coding: 030100043F085700FB000248080F00010001050000000000000000000000
   Shop #: WSC 12345 123 28888
   VCID: 7CA108E3766AC967C2E-8028
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001142480026234
   Coding: 28FFFF
   Serial number: 8442320304
1029 - invalid data record
          B2005 00 [009] -  -
          [ung¸ltiger Datensatz: Funktion "erweiterte Anzeige StartStopp"]
                    Reset counter: 242
                    Mileage: 23045 km
                    Date: 2018.10.18
                    Time: 18:04:54
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
   Serial number: 300516EEU02971
   Coding: 003B0220D000040100001000
   VCID: 43D3B31F4B14769FC34-8016
   Coding: 8307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE3757902-806E
   Serial number: 280516EER24731
   Coding: 003B0020DE00040100801000
   VCID: 42DDB61B540E7F97C82-8016
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0200D40120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C01F8A3C68A99E712E-8078
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJT00QNA
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000018766
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E0C31EBAC1274AE-8060
End----------(Elapsed Time: 01:47, VBatt start/end: 12.4V/12.3V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Confirmed. Doesn't seem to work.
It's NTH feature, because You could always learn via pressing buttons.
darkchina811
ITALY
C?ID=333184
just out of curiosity, I will try with ODIS and report back.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
#1 The barcode is used during production, to learn remotes without having to press buttons. It is NOT used in later service/workshop environments.
#2 The service/workshop approach is learning the remotes by initiating the process and then pressing the button on the remote.
#3 The proper procedure can be found in basic settings under IDE06650 "Adapting RF transmitter".
darkchina811
ITALY
C?ID=333184
ok, good to know, thanks :)
