Is it possible to use full functionally on VCDS mobile without internet?
Vasco Ferraz
Portugal
C?ID=288561
Regarding the HEX-NET on VCDS mobile is it possible to access "Coding", "Adaptation"... without internet?
Thank you.
No, not possible.
PetrolDave
Westbury, UK
C?ID=1423
Will it be in the future?
If not, why? Just curious :)
My guess - consider the install size of the PC install of VCDS and read that across to how much storage would be needed in the HEX-NET to have full functionality without "contacting base"?
It just wasn't designed to do that.
I'm not sure why it should be necessary either. The functionality available stand-alone is sufficient to do trouble-shooting in the on the road, where you might not have internet access, but even then, there are not many locations left where one cannot get internet access via a phone's hotspot.
TBAx
C?ID=287144
People would like to do coding on the go without using a laptop. Something OBD11 does for example...
TBAx
C?ID=287144
Sorry for the misinformation. :(
But the use-case remains, if you add „in rural areas without proper data connection“.
Vasco Ferraz
Portugal
C?ID=288561
The main reason of my question is because my current Android phone (Nougat 7.0) has a major bug regarding the hotspot.
To get the hotspot to work, first the Android phone needs to connect to an Wireless network with internet access.
Only after that, I can switch the phone to hotspot mode and it will connect fine to the HEX-NET.
The problem is that not always I have access to a Wireless network with internet access.
Scratching head. My phone is also on Android 7.0 and has no such bug. If this bug is peculiar to your particular phone, well...
Vasco Ferraz
Portugal
C?ID=288561
No idea... I also tried a custom ROM (7.1.2) but it also has the same issue.
Mashrock
Australia
C?ID=313534
also awesome when you cant make a wifi hotspot on a iphone when without mobile reception too..
