Sondre
New Member
Hi! I changed the clockspring yesterday on my passat and got some new codes on the engine and steering wheel that I can`t figure out. I haven`t done much adaption and coding earlier, only used the VCDS for scans. Is this something I can fix myself or do I need to go to the VW workshop for coding the new part? Thanks!
VIN: WVWZZZ3CZAE101542 License Plate:
Mileage: 143880km-89402mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 52 53 55 56
62 69 72
VIN: WVWZZZ3CZAE101542 Mileage: 143880km-89402miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QE HW: 03L 907 309
Component: R4 2.0l TDI G000SG 9983
Revision: 13H03--- Serial number: VWZCZ000000000
Coding: 0000172
Shop #: WSC 36520 001 104857
VCID: 78FF1F530BEA00841C-802C
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 143881 km
Date: 2013.02.16
Time: 00:00:60
(no units): 0.00
(no units): 0.00
(no units): 0.0
Bin. Bits: 00000110
(no units): 0.0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000104021362
Coding: 0002320
Shop #: WSC 05311 000 00000
VCID: 62CB5D3BBD76FA5452-8036
Part No SW: 5K0 907 044 CD HW: 5K0 907 044 CD
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 05311 115 00000
VCID: 6FED240FB6A4473CCD-803A
Part No SW: 3C8 937 049 F HW: 3C8 937 049 F
Revision: 00H54000 Serial number: 00000003592762
Coding: EF8A8F4701041A00470A00000F000000000F5D435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 3467EB63570224E4F0-8060
Subsystem 1 - Part No: 3C1 955 419 B Labels: 1KX-955-119.CLB
Component: Wischer 141209 006 0208
Coding: 00046997
Shop #: WSC 05124
Component: RLS 260110 054 0402
Coding: 00208936
Shop #: WSC 05124
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591002028721
Coding: 110006
Shop #: WSC 05314 000 00000
VCID: 408FB7B3D3BA884464-8014
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__00H VW10 HI 1916
Revision: 20013000 Serial number: 003E2P0WK7P%
Coding: 0012360
VCID: 4487BBA307A2946440-8010
Subsystem 1 - Serial number: 6332MTS661330210
Subsystem 2 - Serial number: 6342MTS691700210
Subsystem 3 - Serial number: 6351HTS6D5VS76KR
Subsystem 4 - Serial number: 6361HTS6N86T76KR
Part No SW: 5K0 953 569 AS HW: 5K0 953 569 AS
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20151117301646
Coding: 7982A10000
Shop #: WSC 01286 386 08256
VCID: 09196A97A800090C73-805C
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000007982
Coding: E20000
0516 - Databus
Reset counter: 91
Mileage: 143885 km
Date: 2018.09.26
Time: 15:03:30
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Fault Frequency: 6
Reset counter: 91
Mileage: 143885 km
Date: 2018.09.26
Time: 15:03:30
227355 - Windshield Wiper/Washer Switch
B1149 13 [009] - Open Circuit
Reset counter: 91
Mileage: 143885 km
Date: 2018.09.26
Time: 15:03:30
Part No SW: 3C0 920 872 G HW: 3C0 920 872 G
Component: KOMBI H03 0305
Coding: 161F00
Shop #: WSC 05314 115 00000
VCID: 29590A1748C0690C53-807C
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 5K0 963 272 E
Component: Standheizer 043 4709
Revision: 00043000 Serial number: 09021534000000
Coding: 0031012
Shop #: WSC 06939 001 1048576
VCID: 326BED7BAD162AD4E2-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P101230190
Coding: F9A37F46400A02002002
VCID: 2F6DE40FBE24073C8D-807A
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 7AFB055B35E612946A-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H04 2680
Revision: AB001001 Serial number: VWZ6Z7K5014074
Coding: 040004020400008000
VCID: 2E53F90B792E0E3486-807A
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0000335270
Coding: 0000FD
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW32.rod
VCID: 65C1462764588D6CB7-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001236167
Coding: 0000D0
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.148 0703
Revision: 1AH03726 Serial number: 00093170109302
Coding: 0000258
VCID: 3A7BC55B7566D2942A-806E
Component: KSG PQ46 ELV 043 0612
Coding: 0091020051030E763004941570084F0B607C01
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0305
Revision: 15101005 Serial number: 0000334523
Coding: 0000FC
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 66C3412B995E8674BE-8032
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001248132
Coding: 0000D0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000137138
Coding: 0000057
VCID: 2C57F3038F327C24A8-8078
Component: AFS-Steuergeraet 0142
Coding: 2344129
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Part No SW: 1K0 907 383 F HW:4 1K0 907 383 F
Component: Anhaenger H07 0070
Revision: 3A001001 Serial number: 00000125941041
Coding: 410D000100000000
VCID: 306FE773631A18C494-8064
End-------------------------(Elapsed Time: 03:09)--------------------------
