Blank Codes on 2018 7.5 GolfGTi
jasons6930
C?ID=304798
Hi all,
Just picked up a new golf and wanted to look for tweaks however, the cent elecs module comes up with all 0's?
Scan attached.
Monday,24,September,2018,14:23:44:35443
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZAUZJW235518   License Plate: GOLF
Mileage: 456km-283mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
VIN: WVWZZZAUZJW235518   Mileage: 456km-283miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 091900122444050B2000
   ROD: EV_ECM20TFS0205G0906259C_VW37.rod
   VCID: 2E0607E4309FE247D3B-807A
   Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
   Component: ESC           H25 0423
   Revision: 00000000    Serial number: 50718000003774
   Coding: 01FA93A134232171477C0601E0CBA980C92C84E26007957734405078C009430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
   VCID: 025E8354D487B627673-8056
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012000420011001100500000010102A
   VCID: 6D84C0E8FD19595FAA1-8038
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001809302583
   ROD: EV_BCMCONTI.rod
   VCID: 084A917CF2BB9C77397-805C
   Component: WWS    180306  042 0551
   Serial number:         180312101612
   Component: RLHS  047 0105
   Serial number: S9Y18M04D03H21M58S31
   Coding: 00A8DD
   Serial number: 000000000ZY180572KNP
   Serial number: 00000000000099742075
   Serial number: 000308418018086
   Coding: 0471051801
   VCID: 4BC06E70A34DB76FD45-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B00608159FFC728949C810560400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E2637A4E0FF12C743B-806A
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Serial number: 003VWR40P9HJ
   Coding: 98CCC000000000005C0000CF008800000065
   VCID: 094C9478E9B1E57F269-805C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E26031830782
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E27031830797
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 404 18
   Serial number: 3570000000002C9D0C2M
   Subsystem 4 - Part No SW: -----------    HW: 480 003 103 18
   Serial number: 35800000000B993D1C2X
   Subsystem 5 - Part No SW: -----------    HW: 480 402 603 18
   Serial number: 3510001A529633C2B24-
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 18
   Serial number: 3520001A329633C5541V
   Subsystem 7 - Part No SW: -----------    HW: 480 400 304 18
   Serial number: 3550001A329B7D43C26A
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 01041804400928
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D44A0689DD9F95F0A1-8058
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3195
   Coding: 27AD11002F80060001886B011401000000000000
   VCID: 2A0E0BF40C778E670F3-807E
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007655850
   Coding: 030100047F085900FB00027E080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 382A21BCC2DB2CF7897-806C
   Serial number: 29180000468740068097
   Coding: 2CFFFF
   Serial number: 5305497304
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47C85240BF25530FF0D-8012
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 45
                    Mileage: 11 km
                    Date: 2018.09.13
                    Time: 11:19:59
                    Reset counter: 45
                    Mileage: 12 km
                    Date: 2018.09.13
                    Time: 12:08:56
   Serial number: 200318ECK04572
   Coding: 003F0220D001048000001000
   VCID: 43D046508B1D7F2F2C5-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000020321747
   Coding: 0D0000
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B203EB0F3ED07EF645-806E
   Serial number: 21031810522064
   Coding: 000000050100164E01100F01020000000000000000000000000000000000
   VCID: 72BED394E42786A7773-8026
   Serial number: 210318ECL05837
   Coding: 003F0020DE01048000801000
   VCID: 42DE435494077627273-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000020335145
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02731001FF00000051110101008808001F0503E601200000CF
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 323E139424A7C6A7B73-8066
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV0861245
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Serial number: 180216201596
   VCID: 6B80CEF0C30D576FB45-803E
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392C24B8F9D135FF769-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----(Elapsed Time: 01:34, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Normal. Everything that used to be in Coding has moved to Adaptation channels, of which there should be roughly 2000. :eek:
jasons6930
C?ID=304798
Oh jeez.
Any idea what to look for if I want to change coming home leaving home lights behaviour,
My German is non existent
:D
myounus
Northwest UK
C?ID=321059
On this particular car you should have the option to change the duration through the screen. What exactly do you want to change?
jasons6930
C?ID=304798
Yes i have changed the timing via the set up menu on the car, however, i want to change the coming home function to auto, and to use fog lights instead of headlights.
hadez16
C?ID=289891
German guy to the rescue.
I cannot quote the exact channel names at the moment, but regarding "Coming Home to Auto":
Enter "Verbaustatus" in the search text box. There is one channel that tells about Coming Home Verbaustatus. Set it from manual to automatic.
When you enter "coming" in the search box, there is one other channel that tells about the lights being used..."Leuchten" should be in the name...
jasons6930
C?ID=304798
Thanks everyone, very much appreciated!
jasons6930
C?ID=304798
Quick update.
All sorted so thanks for the help.
