Friday,21,September,2018,17:58:08:38221
VCDS Version: 18.2.1.2 (x64)
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRM71K29M177936 Mileage: 129740km-80616miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 P HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H03--- Serial number: VWX7Z0I524I05R
Coding: 0000075
Shop #: WSC 25152 444 101320
VCID: 3B751DED7AF0ED9C32-806E
012408 - Throttle Control
P3078 - 000 - Airflow at Idle too Low
Mileage: 129717 km
Time: 16:05:26
RPM: 658 /min
Load: 33.7 %
Speed: 2.0 km/h
Temperature: 84.0°C
Temperature: 55.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
Readiness: 0000 0100
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 7DF1D3F5246423AC4C-8028
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 78FFC2E1CB4606841F-802C
Reset counter: 194
Mileage: 129698 km
Count: 3
Count: 12
Count: 29184
Count: 320
Count: 48128
Reset counter: 193
Count: 7
Count: 12
Count: 29184
Count: 195
Count: 47616
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 75E1CBD51C547BEC04-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009456452
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: 326B30C9ADBA2CD4E1-8066
Component: Wischer 150609 021 0501
Coding: 00038805
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7J0552958
Coding: 0000100
VCID: 336535CD52A025DCEA-8066
02617 - Satellite Antenna (R170)
Reset counter: 192
Mileage: 129691 km
Time: 15:52:58
Reset counter: 192
Mileage: 129691 km
Time: 15:52:58
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM00F3WY
Coding: 0012340
VCID: 6ED3E4B979024834C5-803A
Subsystem 2 - Serial number: 6332MSME4733663BE
Subsystem 3 - Serial number: 6342MSME47336870A
Subsystem 4 - Serial number: 6351HSME0025572D1
Subsystem 5 - Serial number: 6361HSME00224A5B2
Subsystem 6 - Serial number: 63727SME1C3B32192
Subsystem 7 - Serial number: 63827SME1C3C62726
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001031
VCID: 020BA0095D9A5C5431-8056
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0I524I05R
Coding: 0023203
Shop #: WSC 00066 067 57207
VCID: 3C771EF17FFEEAA43B-8068
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 030609F2000337
Coding: ED807F07000702001002
VCID: 377D01DD46D8C9FCD6-8062
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000911298606
Coding: 0001205
VCID: 6FEDF9BD7E08413CCE-803A
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
VCID: 2C572EB18F9E7A24AB-8078
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 72EBF0C96D3A6CD421-8026
00532 - Supply Voltage B+
Reset counter: 231
Mileage: 129679 km
Time: 19:51:20
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 09020322415502
Coding: 0001204
VCID: 70EFFAC163365EC4D7-8024
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7J2289513
Coding: 0042401
VCID: 2959D7A5806C6F0C50-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003965932
Coding: 0001168
VCID: 76E3CCD9015270F40D-8022
Fault Status: 01111000
Reset counter: 194
Mileage: 129691 km
Fault Status: 01111100
Reset counter: 194
Mileage: 129691 km
Component: RDK 0453
Coding: 0100100
Shop #: WSC 45446 001 104856
Mileage: 129696 km
Time: 16:07:23
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003958455
Coding: 0001168
VCID: 77FDC1DD065809FC16-8022
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 B HW: 1K8 035 730 B
Component: Telefon H08 5400
Revision: 00008000 Serial number: 20389520103565
Coding: 401100
VCID: 285FD2A15B6656044F-807C
End-------------------------(Elapsed Time: 02:09)--------------------------
