Sharan MY15 rear LED retrofit coding byte 18
lopat84
C?ID=125676
Hi I have VW Sharan 2015, we changed headlights to xeonon with DRL which works fine. Now we replaced rear lights to LED and we get m4 and m8 light bulbs fault - which are position lights. We run 2 more wires (as old lamps had brake light and position light in one bulb).
All works fine but we eed to do coding on byte 18 to change it for sharan lift model. When we change value to "30" which is passat I think, it doesnt give you that warning light but still no position LED but brake lights.
Thanks for any help
langers2k
C?ID=224085
You might want to start with an autoscan lopat84 :)
lopat84
C?ID=125676
Hi
I done a retrofit on Sharan 2015
Got 2 wires pin 3 and 4 from bordnetz to the rear so braek lights and position lights can be separated.
But we have a problem with coding, I dont know what should be in byte 18
We had borrowed bordnetz and LED strip start working, lights were fine but coding is showing 00 so we cant recode our bordnetz to the right value if that makes sense.
I hope someone will be able to help.
Kris
lopat84
C?ID=125676
Thursday,20,September,2018,08:15:37:24411
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ7NZFV037808   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56
          61 62 69 6C 72 77 BE BF
VIN: WVWZZZ7NZFV037808   Mileage: 48710km-30266miles
BE-Slid. Door Rear Left -- Status: Malfunction 0010
BF-Slid. Door Rear Right -- Status: Malfunction 0010
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2,0L EDC   H28 9957
   Revision: 44H28---    Serial number:
   Coding: 001D001A043501080000
   Shop #: WSC 57613 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003010
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 79F9D34CF886098C63-802C
   Part No SW: 02E 300 062     HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4002
   Revision: 05653104    Serial number: 00001502060047
   Shop #: WSC 00020 000 90108
   VCID: 52AB44E0CDB01AD4C2-8006
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 S    HW: 7N0 614 109 S
   Component: J104   C3 450M VDBB 0040
   Revision: --H07---    Serial number: 00000008716177
   Coding: 0028186
   Shop #: WSC 00020 790 00000
   VCID: 3D71075C642EF5AC0F-8068
   Part No SW: 7N0 907 044 AG    HW: 7N0 907 044 AG
   Component: Clima-Sharan  H02 0606
   Revision: 00001K02
   Coding: 021000C449
   Shop #: WSC 00020 999 00000
   VCID: 75E1DF7CD49E6DEC07-8020
   Part No SW: 5K0 937 084 K    HW: 5K0 937 084 K
   Component: BCM PQ35 B    122 0174
   Revision: BA122001
   Coding: 40180A3F8125F1C0408800C01400086C43D13008426D2922E480872400C1
   Shop #: WSC 00020 790 12345
   VCID: 3A7B0C40B500C2942A-806E
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    150117  033 0044
   Serial number:         150128073842
   Coding: 004D9D
   Component: RLHS  037 0059
   Serial number: S4Y15M02D25H07M52S49
   Coding: 0228BB
   Subsystem 3 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261504703091
   Coding: 318101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3979134CB806C98C23-806C
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H13 0014
   Serial number: 003LGP38Q3X9
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3F8D7D54A622E7BC1D-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS602B79201BDD-
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS6032C2211BDDJ
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS607DB3201BDDY
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60E1AC201B9DY
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS607440B317DDE
   Part No SW: 5K0 953 521 DF    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150221300345
   Coding: 1882240000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 73E5E164DAEA73DC29-8026
   Component: E221__MFL-TK6  H07 0023
   Serial number: 70000000000000866075
   Coding: E20000
   Part No SW: 7N0 920 970 L    HW: 7N0 920 970 L
   Component: KOMBI         H04 0905
   Coding: 440F01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 3C770A58B734FCA438-8068
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:33
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 387F16484B0CD084DC-806C
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 210215F1002244
   Coding: 468003
   Shop #: WSC 00000 288 09283
   VCID: 7F0D3D54EEA227BC5D-802A
   Component: IMMO          H04 0905
   VCID: 6ADBFC008D20B2149A-803E
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000134526378
   Coding: 01102E208001411011
   VCID: 45816FBCCCFEBD6C57-8010
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
Address 44: Steering Assist        Labels: None
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 275    3501
   Revision: 00H21000
   VCID: 428B74A01DD08A5472-8016
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000136834564
   Coding: 01102C208001411011
   VCID: 448772B8C7C4846440-8010
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000550222
   Coding: 0024167
   Part No SW: 3C8 035 190 C    HW: 3C8 035 190 C
   Component: Radio RCD510  053 0213
   Revision: 00000001    Serial number: VWZ1Z3R0971765
   Coding: 0100040004000D
   VCID: 2345D124228AA35C19-8076
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1653
   Coding: 030F7859
   VCID: 71E9EB6CA8F641CCDB-8024
   Component: J367-BDM  H07 0180
   Serial number: 42054I00321491581034
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 J    HW: 7N0 959 794 H
   Component: TSG HL        H01 0556
   Revision:             Serial number: 0000137843597
   Coding: 01006C200001411001
   VCID: 4A9B5C80E5E05214BA-801E
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000366684366
   Coding: 0100000101000000
   VCID: 326B24606D703AD4E2-8066
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525 PA8JA13303
   Coding: 0020011
   VCID: 6ED3F01079C85E34C6-803A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 61
                    Mileage: 37382 km
                    Date: 2018.04.17
                    Time: 14:31:38
                        Reverse OFF
                    Count: 3
                    Reset counter: 226
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:30
                        Term 15 Off
                        Reverse OFF
                    Count: 3
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H01 0556
   Revision:             Serial number: 0000137842397
   Part No SW: 5N0 035 729 D    HW: 5N0 035 729 D
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666865477
   Coding: 0A01000080010101
   ROD: EV_UHVUMI.rod
   VCID: 31692B6C607601CC9B-8064
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 15079494
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 387F1648830CD084DC-806C
51715 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
                    Voltage terminal 30: 12.1 V
                    Sliding_Door_Motor_Current: 0.0 A
                    Sliding_Door_Clutch_Current: 0 A
                    Sliding_Door_Locking_Pawl_Motor_Current: 0 A
                    Front button for automatic sliding door: not activated
                    Rear button for automatic sliding door: not activated
                    Installed on left side: Yes
                    Installed on right side: No
                    Pinch protection sensor: not activated
                    Latch_Ajar: operated
                    Latch_Pawl: operated
                    Sliding door indicator lamp: not active
                    Sliding door indicator lamp 2: not active
                    Activation: motor for automatic sliding door: not active
                    Automatic sliding door coupling motor activation: not active
                    Motor activation for enabling ratchet release: not active
                    Sliding_Door_Feedback_Motor_Opening: not active
                    Sliding_Door_Feedback_Motor_Closing: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: not active
                    Sliding_Door_Feedback_Clutch_In: not active
                    Sliding_Door_Feedback_Clutch_Out: not active
                    Sliding_Door_Feedback_Indicator_Light_Front: not active
                    Sliding_Door_Feedback_Indicator_Light_Rear: not active
                    AD-Value clamping_Protection_Seal: 100
                    Position of automatic sliding door: 0
                    Status_Sliding_Door: latch secondary position
                    Play protection: motor for automatic sliding door: not active
                    Play protection: motor for enabling ratchet release: not active
                    Play protection: automatic sliding door coupling motor: not active
                    Status_Locking_Pawl_Motor: closed
                    Status_Clutch_Motor: closed
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 15077941
   ROD: EV_AST.rod
41221 - Motor for Sliding Door Opening
          B115A 19 [008] - Current Too High
                    Reset counter: 208
                    Mileage: 47443 km
                    Date: 2018.07.13
                    Time: 18:40:46
                    Voltage terminal 30: 10.9 V
                    Sliding_Door_Motor_Current: 45.0 A
                    Rear button for automatic sliding door: operated
                    Installed on left side: No
                    Installed on right side: Yes
                    Latch_Ajar: not activated
                    Latch_Pawl: not activated
                    Sliding_Door_Feedback_Motor_Opening: active
                    Sliding_Door_Feedback_Motor_Closing: active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: active
                    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing: active
                    Sliding_Door_Feedback_Clutch_In: active
                    Sliding_Door_Feedback_Clutch_Out: active
                    AD-Value clamping_Protection_Seal: 99
                    Position of automatic sliding door: 120
                    Status_Sliding_Door: is opened
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
                    Voltage terminal 30: 12.0 V
                    Position of automatic sliding door: 812
                    Status_Sliding_Door: Fully open
End-------------------------(Elapsed Time: 04:40)--------------------------
lopat84
C?ID=125676
   Coding: 0028186
   Revision: 00001K02
   Coding: 021000C449
   Revision: BA122001
   Coding: 004D9D
   Coding: 0228BB
   Coding: 318101
   Coding: 00304D
   Coding: 1882240000
   Coding: E20000
   Coding: 440F01
          U1111 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
          U1111 00 [008] - -
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:33
   Coding: 0000041
   Coding: 468003
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
   Revision: 00H21000
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
   Coding: 0024167
   Coding: 030F7859
   Coding: 0020011
                    Reset counter: 61
                    Mileage: 37382 km
                    Date: 2018.04.17
                    Time: 14:31:38
                        Reverse OFF
                    Count: 3
                    Reset counter: 226
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:30
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   ROD: EV_UHVUMI.rod
   ROD: EV_AST.rod
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
   ROD: EV_AST.rod
                    Reset counter: 208
                    Mileage: 47443 km
                    Date: 2018.07.13
                    Time: 18:40:46
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
lopat84
C?ID=125676
   Coding: 0028186
   Revision: 00001K02
   Coding: 021000C449
   Revision: BA122001
   Coding: 004D9D
   Coding: 0228BB
   Coding: 318101
   Coding: 00304D
   Coding: 1882240000
   Coding: E20000
   Coding: 440F01
          U1111 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
          U1111 00 [008] - -
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:33
   Coding: 0000041
   Coding: 468003
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
   Revision: 00H21000
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
                    Reset counter: 225
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:34
   Coding: 0024167
   Coding: 030F7859
   Coding: 0020011
                    Reset counter: 61
                    Mileage: 37382 km
                    Date: 2018.04.17
                    Time: 14:31:38
                        Reverse OFF
                    Count: 3
                    Reset counter: 226
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:30
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   ROD: EV_UHVUMI.rod
   ROD: EV_AST.rod
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
   ROD: EV_AST.rod
                    Reset counter: 208
                    Mileage: 47443 km
                    Date: 2018.07.13
                    Time: 18:40:46
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 48704 km
                    Date: 2018.09.15
                    Time: 10:54:31
hadez16
C?ID=289891
Your byte 18 has value 30, not 00.
I'd highly recommend not to start try&error with VCDS as it is not sure that there might exist a value that does fit your needs.
The best way is taking a look around who else did this and how they solved it. (if they solved it with VCDS...)
lopat84
C?ID=125676
With 00 Value its showing error message with m2 and m4 bulb with code 30 fault is not showing and lights are working exactly the same way.
hadez16
C?ID=289891
It seems like you have no idea how Byte 18 works and what it does.
I'd recommend to chase someone who has the VCDS competitor product in order to change the lighting configuration manually.
lopat84
C?ID=125676
Well this is why I've asked here ?
Simple question and expecting simple answer.
What is 18byte for sharan after 2016
langers2k
C?ID=224085
There might not be a valid byte 18 for a sharan in this configuration...
Instead you might need to manually tweak the lighting configuration which isn't something VCDS can do. I've done it for 1K0 BCM's but never a 5K0 BCM.
lopat84
C?ID=125676
Which software would be able to tweak it?
As I've said. When I change BCM to a different one form new sharan it all worked fine.
langers2k
C?ID=224085
Did you check byte 18 on the new BCM?
- If it wasn't 00, try copying it.
- If it was 00, then I don't think VCDS will help.
VCP (Vag Can Pro) includes a PQ35 programmer that's popular, not 100% sure it supports 5K0 BCM's.
Dana
Western PA, USA
lopat84
C?ID=125676
lopat84, both of those scans have the same 09 coding including HEX 30 in Byte 18. Do you have a scan in the factory condition? If so please post it.
If not, please post the contents of the CodingLog.CSV located in the Debug folder. https://forums.ross-tech.com/showthread.php?1029-CodingLog-and-AdpLog-little-safety-nets-for-you
Address 09	5K0 937 084 K	from	40180A3F8125F1C0408800C01400087C43D11308426D2902E480872400C1	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	11:04:04:24411
Address 09	5K0 937 086 Q	from	60590A3B89251AC4508804C87400116443D51408776D2DB0E4800020A2C8	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	08:39:41:24411
Address 09	5K0 937 086 Q	from	60590A3B89251AC4508804C87400116443D51408776D2DB0E4800020A2C8	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	08:39:52:24411
Address 09	5K0 937 086 Q	from	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	to	60590A3B89251AC4508804C87400116443D51408776D2DB0E4800020A2C8	08:42:19:24411
Address 09	5K0 937 086 T	from	60180A3B80251AC4408800C0340009644BD5AB08636D8D20E48487000041	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	08:44:09:24411
Address 09	5K0 937 086 T	from	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	to	60180A3B80251AC4408800C0340009644BD5AB08636D8D20E48487000041	08:46:59:24411
Address 09	5K0 937 086 T	from	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	08:49:54:24411
Address 09	5K0 937 086 T	from	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	to	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	08:51:45:24411
Address 09	5K0 937 086 T	from	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	to	40590A3F8125E1C0508800C89400897403D5C008666D2DB26484C720A2C1	08:54:49:24411
Address 09	5K0 937 086 T	from	40590A3F8925F3C0508800C81400116443D51408666D29B2E4808720A2C9	to	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	09:00:19:24411
Address 09	5K0 937 086 T	from	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	to	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	09:01:11:24411
Address 09	5K0 937 086 T	from	40180A3F8125F1C0408800C01400086C43D11308426D2922E480872400C1	to	40180A3F8125F1C0408800C01400086C43D113F8426D2922E480872400C1	09:03:57:24411
Address 09	5K0 937 086 T	from	40180A3F8125F1C0408800C01400086C43D113F8426D2922E480872400C1	to	40180A3F8125F1C0408800C01400086C43D11388426D2922E480872400C1	09:04:36:24411
Address 09	5K0 937 086 T	from	40180A3F8125F1C0408800C01400086C43D11388426D2922E480872400C1	to	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	09:06:01:24411
Address 09	5K0 937 086 AA	from	611A0A3A8025082D08800082900001640181000852020820648000000040	to	40590A3F8125E1C0508800C89400897403D50008666D2DB26484C720A2C1	09:11:27:24411
Address 09	5K0 937 086 M	from	40590A3B8925F3C0508804C85400116443D51408666D2DB2E4808720A2C9	to	40D90A3B8925F3C0508804C85400116443D51408666D2DB2E4808720A2C9	09:14:16:24411
here attached
