DPF regen
Matt k
C?ID=345211
Hi guys anything I’m missing with the Dpf regen I plug in my lead go to engine , measuring , then service regen press go put my foot on the brake pedal like it said then accelerator it says hold them and it just says it’s timed out
Cheers Matt
Matt k
C?ID=345211
 Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
          77
VIN: WAUZZZ8K2AA109768   Mileage: 138180km-85861miles
Here is my autoscan
cheers matt
^^^ That's just a Gateway Installation List, not an Auto-Scan.
Matt k
C?ID=345211
 Tuesday,18,September,2018,17:35:05:53128
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8K2AA109768   License Plate: JK04MAT
Mileage: 138180km-85861mi   Repair Order:
          77
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H03 9981
   Revision: 11H03---
   Coding: 0104002C02072120
   Shop #: WSC 52502 002 1048576
   ASAM Dataset: EV_ECM20TDI03L906022MK A01016
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AADF1B74C53A1573F0-802E
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H04 0007
   Revision: --H04---    Serial number: 0000000684
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: 77ABE8837F41BC3F40E-8022
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 170500
   VCID: 025D89572403E997670-8056
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0327
   Coding: 011200
   VCID: 015F865B2105F28F7EA-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000073087012
   Serial number: 0209000100182007
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01151220090358
   Coding: 34040000
   VCID: 76B5E58778CBC5375B8-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000538272
   Coding: 260050914034AF010001000000001D0D001D470800010141000000
   VCID: 3A2D31B70C5361577F0-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 091008  H05 0070
   Serial number: SWF08100090531
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10713876
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000512091290
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39990932200105
   Coding: 100103
   Shop #: WSC 06335 123 12345
   VCID: 3E253DA7107B4D77438-806A
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD08CDD5
   Coding: 30363435363030303030554A3052384B3053
   VCID: 41DF465B6105328F3EA-8014
   Serial number: 6334MSME4D42540BG
   Serial number: 6344MSME4D430579J
   Serial number: 6352QSME39482138F
   Serial number: 6362QSME34480A3AK
   Serial number: 63732SME31482E3A1
   Serial number: 63832SME3148442E/
   Revision: --------    Serial number: 90319ILE000AH
   Coding: 000037
   VCID: 3D273AAB1D7D566F5A2-8068
   Part No SW: 8K0 920 980 N    HW: 8K0 920 980 N
   Component: KOMBIINSTR.   H20 0255
   Revision: 00100000    Serial number: CIZ58ZFD9
   Coding: 2F07100002002600010000
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G09C0982D6
   Coding: 00C303
   VCID: 50F9731FBAEFCB07A14-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Serial number: 1909FB12021209
   Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000102522562
   Coding: 011002204001410001
   VCID: 47CB58434FA10CBFF0E-8012
   Revision: 00002001    Serial number: 0124837903
   Coding: 013B0622203904000020023280000000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
   Component: DSP STD       H11 0440
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 2F3B10E3C711B4FFD8E-807A
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000102541394
   VCID: 46D5554748AB15B70B8-8012
   Revision: 00000003    Serial number: 10000000397315
   VCID: 34311F8F2E379727A5C-8060
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77ABE88373C1BC3F40E-8022
   Part No SW: 8T2 035 195 AA    HW: 8T2 035 195 AA
   Component: Symphony3     H04 0310
   Revision: 00000007    Serial number: AUZ5Z4I1163640
   Coding: 0502008201028D00035B070000
   VCID: 77ABE8837FC1BC3F40E-8022
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102533325
   Coding: 010002204001210001
   VCID: 42DD495764832997270-8016
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102533328
   Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
   Component: FSE_256x BT     H39 0600
   Revision: 00000000    Serial number: 00000005145707
   Coding: 0010320
   VCID: 3B2334B30F69585F646-806E
End----------(Elapsed Time: 01:35, VBatt start/end: 14.2V/14.2V)-----------
Matt k
C?ID=345211
Sorry this should be better
You've got no fault codes in your ECU. Why do you want to do a regen?
Matt k
C?ID=345211
Not sure if it’s even been done , isn’t it good to keep the carbon down ??
No, it's not particularly good unless there's a specific reason to do it. In principle, it should never be needed if the car is driven in a manner appropriate to a diesel, and the engine and various sensors are healthy.
Matt k
C?ID=345211
Ok cheers for that I will just leave it . any other little tweaks I can do
myounus
Northwest UK
C?ID=321059
Depends on what you want to do and how much you want to spend.
Matt k
C?ID=345211
Ah I see kinda thinking little tweaks like I have done the needle sweep and reverse screen etc wanted to activate green menu but don’t think I can on my car
Cheers Matt
myounus
Northwest UK
C?ID=321059
The ability to make 'enjoyable' or 'useful' changes to your car are dependant on your imagination and need. The limitations you will find of your car will be many unless you venture down the road of retrofitting, i.e. Adding things to your car that it didn't come with. E.g. On another model it may have heated seats or climate control, led lights, etc You may purchase some heated seats for example from a damaged car and want to make them work.
Matt k
C?ID=345211
Ok I see cheers might look at that maybe folding mirrors that would be handy . Can I bring hidden green menu up on mine ?
myounus
Northwest UK
C?ID=321059
What headunit have you got? Is it a 2G or a 3G MMI - multimedia interface? If you have neither then you won't have a green menu.
Matt k
C?ID=345211
Got a symphony head unit not sure what that one is ?
myounus
Northwest UK
C?ID=321059
Symphony is generation 1 I'm afraid.
myounus
Northwest UK
C?ID=321059
But there is a generation 2 also in Symphony but it depends on your car's production date. Generally 2002 onwards is generation 2
Matt k
C?ID=345211
Ok mines a 2010 a4 b8 s line
