Need help with the code for the above car. VCDS help is not able to do this as looks like I need the later interface? Tried a search of the forum but nothing coming back. All the sensors have had basic setting done and no fault codes now. Just 0413 control module not coded.
Any help appreciated.
VIN: WVWZZZAAZDD043516 License Plate: LC63 WSX
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZAAZDD043516 Mileage: 27340km-16988miles
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 HW: 04C 907 309
Component: 1.0l R3 MPI H01 6462
Revision: U7H01--- Serial number:
Coding: 00110012020400000000
Shop #: WSC 06594 002 1048576
ASAM Dataset: EV_ECM10MPI01104C906020 001014
ROD: EV_ECM10MPI01104C906020.rod
VCID: 58BBDED3230A49843C-800C
Readiness: 0110 0100
Address 03: ABS Brakes (J104) Labels:. 1S0-614-517.clb
Part No SW: 1S0 614 517 E HW: 1S0 614 517 E
Component: EBC 460 ESP H08 0012
Serial number: A00H9FQ
ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
ROD: EV_Brake1ESPMP1TRWVW120.rod
VCID: 316D4377603078CC9B-8064
0360 - Steering angle sensor
0361 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
0362 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
0363 - Turn Rate Sensor
C107D 54 [137] - Missing Calibration / Basic Setting
0413 - Control module not coded
U1013 00 [137] - -
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 1S0 937 086 B HW: 1S0 937 086 B
Component: PQ25 BCM H28 0555
Revision: -A------ Serial number: --------------
Coding: 64B82B0000010000000008042C28AC800040400C60020000200000400000
Shop #: WSC 31414 790 00001
VCID: 37797D6F8654A6FCD5-8062
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag00R H03 0006
Revision: -------- Serial number: 003MY005MWSH
Coding: 000000000000000000000000000000003052
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: 3D756F47AC688CAC0F-8068
Serial number: 3495RRB401G50OV0QP47
Serial number: 3505RRB401C50PGE69GE
Serial number: 3555NRB405V28LHUA8UU
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 960 R HW: 1S0 920 960 R
Component: KOMBI H08 0021
Revision: X0008005 Serial number: 00000000000000
Coding: 414200
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 408B16B3DB9AE14464-8014
Part No SW: 6N0 909 901 HW: 1S0 937 086 B
Component: GW-K-CAN TP20 H28 0555
Revision: -A------
Coding: 001300
VCID: 70EB8673A3BA31C4D4-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 960 R
Component: IMMO H08 0021
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADF941B8D66CB149A-803E
Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 L HW: 1S2 909 144 G
Component: EPS_ECU H45 1503
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssisNSK_009.rod
Part No SW: 1S0 035 156 H HW: 1S0 035 156 H
Component: Radio H36 0063
Revision: R0000000 Serial number: VWZAZ1N0618041
Coding: 0000020001
VCID: 306B4673633A71C494-8064
End-------------------------(Elapsed Time: 01:52)--------------------------
