Helloo. I'm having a odd fault with my 2005 3.0 v6 Touareg. Its starts perfectly when cold but when upto temp it sounds like a flat battery when trying to start. Always starts second or third time but it's getting a little annoying now. I've scanned several times and while I don't have a log to post up at the moment (I will update with one) the appears to be no stand out codes that suggest starting faults. There is a fault about low voltage which I'll add the code as follows -
00668 - supply voltage terminal 30. 02 lower limit exceeded - intermittent. I'd suspect the battery to be fine tho as starting cold is no issues.
My question was mainly to establish how others on here would approach such an issue and the best way to diagnose starting it voltage faults with the use of vcds? I have read posts about Q7s and other touaregs with the same problem and it pointed to a temp sensor, presume I could check these through live data/measuring blocks?
Apologies I'm a bit of a novice.
Kevin
Kevin
