Hi
I have a Seat Leon mk2 from 2009. I have three alarms on my instrument panel. ABS, ESP and Tire pressure.
My initial idea was that the ABS sensor was faulty, so I tried to change it - no luck. I then tried to change the wheel bearing to rule out the magnetic strip on the wheel bearing back side - again no luck. I again went back to the ABS sensor and measured the resistance. Around 760 ohm. I googled to find a value for these sensors. I did not find something specific for the brand (Topran) but old random threads in different forums suggested the value to be in between 1000-2000 ohm. So I went back to the shop and got a replacement sensor. Measured this one and got the same value ~760 ohm.
For fun, I tried to exchange the ABS sensor with a 1000ohm resistance and the fault went away.
Does anybody know the resistance value of these sensors?
At this moment I'm a bit lost in terms of fixing the problem. I have not tried to buy a new sensor from another supplier. But is that the best way? Any ideas? The sensor is not cheap.
Friday,10,August,2018,14:11:14:41737
VCDS Version: 18.2.1.2 (x64)
VIN: VSSZZZ1PZ9R011550 License Plate: FH94173
Mileage: 222210km-138074mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 77
VIN: VSSZZZ1PZ9R011550 Mileage: 222210km-138074miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 056 AA HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 2898
Revision: --H08--- Serial number: SEX7Z0H531B0DT
Coding: 0050071
Shop #: WSC 06402 785 00200
VCID: 66C7E6E351C4C474BD-8032
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B2012092300FB881004E9901900413400
Shop #: WSC 13213 002 1048576
VCID: 76E7B6A3C16434F40D-8022
Fault Status: 01101100
Reset counter: 191
Mileage: 222214 km
Count: 16387
Count: 12800
Count: 80
Count: 50432
Count: 60416
Count: 1536
Part No: 1P0 907 044 E
Component: ClimatronicPQ35 011 0702
VCID: 2E575EC3B9B44C3485-807A
Revision: 00H54000 Serial number: 00000005844811
Coding: E98A8F2F00041000431D00000000000000017F075C400000000000000000
VCID: 33614FB7529661DCEA-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 300508 022 0601
Coding: 00056208
Shop #: WSC 06402
Subsystem 2 - Part No: 1P0 955 559 Labels: 1P0-955-559.CLB
Component: REGENLICHTSENSORH04 0090
Coding: 00152622
Shop #: WSC 06402
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A02 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPB76SEU
Coding: 0012338
VCID: 3B7167977AC6A99C32-806E
Subsystem 1 - Serial number: 6333FTS613511648
Subsystem 2 - Serial number: 6343FTS648331648
Subsystem 3 - Serial number: 6353ETS6NRIHTVNP
Subsystem 4 - Serial number: 6363ETS6NJQITVNP
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002042
VCID: 78FBB89B0B7042841F-802C
Component: E0221 002 0010
00576 - Terminal 15
Part No: 1P0 920 847 B
Component: KOMBIINSTRUMENT VO3 0750
Coding: 0002101
Shop #: WSC 00011 888 96745
VCID: 316D45BFA88A53CC98-8064
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086040091
Coding: E9807F460006020202
Shop #: WSC 00114 204 84141
VCID: 356571AF5CE27FECC4-8060
Component: IMMO VO3 0750
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000830388504
Coding: 0004272
VCID: 408B107B1320CA4467-8014
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 988000005283CC7F0006850560084F01207C00
VCID: 0301DF7742B6115C3A-8056
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000766788508
Coding: 0004272
VCID: 418D157F182AC34C68-8014
Fault Status: 00101100
Reset counter: 231
Mileage: 195644 km
Part No: 1P1 035 186 B
Component: Radio BVX 0006
Coding: 0042424
VCID: 2B5157D78AA6391CA2-807E
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000003178037
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 191
Mileage: 195644 km
Address 69: Trailer
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000003180927
Coding: 0000144
VCID: 3C73648B7FC8AEA43B-8068
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Reset counter: 191
Mileage: 195644 km
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H26 0110
Revision: 00000001 Serial number: 00000005029798
Coding: 0000555
VCID: 326F4AB3AD8C68D4E1-8066
End-------------------------(Elapsed Time: 02:02)--------------------------
