Hello!
First time poster, thanks for having me!
I own a 2011 Exeo ST 2.0 143HP CAGA engine code, manual transmission.
I've replaced the factory gearbox, code MPA, with a shorter geared HCK one. Since then the gear suggestion on the MFD rarely displays something, and when it does it's wrong. EX: telling me to change into 6'th when i'm already in it.
The cruise control will only engage IF the gear suggestion is displayed.
I'm guessing there must be a table somewhere based on wheel speed and engine rpm.
Otherwise the car is much more flexible with this gearbox. I can now overtake on the highway in 6'th and the engine doesn't sound like a truck going uphill anymore.
MPA: 3.30:1 differential, 78 Mph at 2000 revs in 6'th
HCK: 3.75:1 differential, 68 Mph at 2000 revs in 6'th.
How can it be fixed?
Thank you!
Thank you!
