- Joined
- Oct 8, 2014
- Messages
- 19
- Reaction score
- 11
- Location
- Netherlands
- VCDS Serial number
- C?ID=222658
Dear members,
I have a 2010 Polo 1.2 TDI (75bhp) with a strange A/C error.
Once you start the car and the HVAC is in AUTO mode with A/C ON, the A/C starts up but disengages the compressor within a few seconds. VCDS Compressor Shut-Off code is then #16 = Compressor activation faulty.
In the error memory it is mentioned that the communication with the Engine ECU is lost for a while. Funny thing is,
Once you turn the AUTO mode OFF and A/C OFF and then start the car, wait a few seconds and put it back to AUTO mode with A/C ON. No issues are involved -> fine working A/C.
Other modules like instrument cluster do not report similar error codes about engine control module communication so I doubt engine controller is faulty. I do get communication errors with VCDS while logging or checking parameters when reading the HVAC module.
A little history is,
Once the weather went hotter here the owner indicated that the A/C wasn't working properly. He went to the garage who mounted a new compressor which was faulty according to them. From this moment problems were detected by the owner. I don't know if the compressor is genuine or from a 3rd party supplier.
Car was chip-tuned after the summer and we are now checking if the tuning could be involved.
Next plan is,
flash back original S/W and check if symptoms stay away. If not flash back tuned software and troubleshoot further.
Maybe some of you have had such issue before.
Currently a 21W lamp is fitted in the interior to visually monitor the A/C clutch activity.
Other data from the HVAC:
Tuesday,31,July,2018,12:41:56:20481
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ6RZBY083303 License Plate: 90-NLD-2
Mileage: 258700km-160748mi Repair Order: Johannes
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61 69
VIN: WVWZZZ6RZBY083303 Mileage: 258700km-160748miles
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 906 021 B
Component: R3 1.2l TDI H04 9979
Revision: 12004001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 49310 002 1048576
ASAM Dataset: EV_ECM12TDI03103P906021B 001042
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 275A7E2E5EBD157C45-8072
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210224E3417500B5842824E282D400521300
Shop #: WSC 00788 648 00255
VCID: 060413AAB5772C741E-8052
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 0305
Revision: V0000000
VCID: 326C9F7A6D7F60D4E2-FFFE
Fault Status: 00101101
Reset counter: 92
Mileage: 258021 km
Date: 2012.12.16
Time: 12:50:47
00898 - Control Circuit A/C compressor
Reset counter: 92
Mileage: 258021 km
Date: 2012.12.16
Time: 12:50:47
Reset counter: 92
Mileage: 258021 km
Date: 2012.12.16
Time: 12:50:47
Reset counter: 92
Mileage: 258021 km
Date: 2012.12.16
Time: 12:50:47
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0355
Revision: BU046001 Serial number: 0328 224100354
Coding: 22B02BBF08A10000202009B02E2B0CD05F80612F7E860441200000000000
Shop #: WSC 23324 000 1048576
VCID: 418EC0B6D8D9CB4C6B-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU020.08.1012597
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU018.08.1013212
Coding: 48BC30
03789 - Terminal 75 Limp Mode Active
Reset counter: 93
Mileage: 258396 km
Date: 2012.12.18
Time: 16:44:24
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag00G H09 0020
Revision: -------- Serial number: 003GX00686UG
Coding: 003047
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9CE79AEDEF0814BA-801E
Serial number: 3572SRB40000C814C151
Serial number: 3582SRB40000C8D5010+
Serial number: 3515RRB405H6THNCNH1I
Serial number: 3525RRB405H6THNC5GON
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H04 0304
Coding: 140A00
VCID: 3878AD5283038A84DC-806C
Address 19: CAN Gateway Labels:. 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 070710F2001758
Coding: 7D0A1D00080000000002
Shop #: WSC 46532 001 1048576
VCID: 326C9F7AAD7F60D4E2-8066
Component: IMMO H04 0304
VCID: 6ADC471A8D2FE8149A-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F6A960EEA4D4D3C8D-807A
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2N1633380
Coding: 01000400020001
VCID: 33629A7E926569DCE9-8066
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 030B1A5A
VCID: 74E05962D7EB2EE430-8020
Component: J367-BDM H07 0125
Serial number: 00000000002790000491
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ÀÁ006789,-(00(
Coding: 0100000100000000
VCID: 30689572637352C494-8064
End-------------------------(Elapsed Time: 02:05)--------------------------
Next plan is,
Advanced Identification
Identification: VD1-999
Revision: V0000000
Date: 29.08.10
Manufacturer number: 0004
Test stand number: 8579
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 0000.00.00
Flash Tool Code: 39734 111 12345
Misc.
Hardware number: 6R0 907 044 B
Workshop System Name: J255
VCDS Info:
VCID: 326C9F7A6D7F60D4E2-8066
