Update to 18.5.4 Beta, strange message
Al Bundy
Bucharest, Romania
C?ID=80804
After succesfuly update including firmware, when accessing some module into Golf MKVI, I received this message.
https://ibb.co/kp0mhT
Into 18.2 release does not exist this problem.
Eric
HC800000
I will need to look at that next week. Having your autoscan would be best.
Al Bundy
Bucharest, Romania
C?ID=80804
I will send autoscan when the car will be in garage.
MasterTommy
Amsterdam
C?ID=295586
Nice feature!
*Runs to garage to have a look*
NEtech
C?ID=56995
Strange, if I test this Controller, there is no problem, only if I rename EV_SMLSNGKUDS_A05.rod and EV_SMLSNGKUDS_A04.rod, I get the above screenshot.
Do you have the file EV_SMLSNGKUDS_A05.rod in C:\Ross-Tech\VCDS-Beta\UDS_EV ?
Was it only [16-Steering wheel] Controller, where there was a problem ?
This is screen I get with that controller.
Al Bundy
Bucharest, Romania
C?ID=80804
Today, into a SEAT LEON 2014, the same message appear in every scanned module.
Autoscan with Beta and with release.
Monday,09,July,2018,13:47:35:49483
VCDS Version: 18.2.1.2  HEX-V2 CB: 0.4427.4
Dealer/Shop Name: Al Bundy Garage
Workshop Code: 973 01973 001973
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZFR044961   Mileage: 57342km-35630miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 DA    HW: 04E 907 309 AC
   Component: 1.4l R4 TSI   H21 8078
   Revision: R7H21---
   Coding: 01190032232419080000
   Shop #: WSC 01973 973 01973
   ASAM Dataset: EV_ECM14TFS01104E906027DA 001010
   ROD: EV_ECM14TFS01104E906027DA.rod
   VCID: 6696BF0F28EBD987EBB-8032
   CAN Converter 01:
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 62284000001202
   Coding: 20EE6A92242429700080060641C4240456249400608224F200210070C002
   Shop #: WSC 00049 770 00107
   VCID: 44D245877E17CB9715F-8010
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 53
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:42:00
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00000004200100011005004000101000
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2708F20BEF61008F10D-8072
590081 - Control Circuit for A/C Compressor
          B10A9 11 [008] - Short to Ground
                    Reset counter: 48
                    Mileage: 56933 km
                    Date: 2018.07.01
                    Time: 13:58:52
                    Outside air temperature: 21.5 °C
                    Engine speed: 800 /min
                    Compressor shut-off requirement: Compressor activation: malfunction in activation path
                    Compressor current: specified value: 0.000 A
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011423003924
   Coding: 08000A42424102FB4BE44000400403281000000000000000000000000000
   Shop #: WSC 00049 770 00124
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005A89972A8F17B7717-8054
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140721  041 0574
   Serial number:         140730225318
   Coding: 0BC5FD
   Component: RLHS  037 0059
   Serial number: S5Y14M08D15H12M51S16
   Coding: 00095D
0531 - Footwell Illimunation
          B11FF 01 [009] - Electrical Failure
                    Reset counter: 13
                    Mileage: 1048574 km
                    Time: 00:00:00
10506 - Bulb for Left Tail Light
          B12BE 15 [008] - Open or Short to Plus
                    Reset counter: 53
                    Mileage: 1048574 km
                    Time: 00:00:00
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
                    Reset counter: 53
                    Mileage: 1048574 km
                    Time: 00:00:00
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Reset counter: 215
                    Mileage: 55706 km
                    Date: 2018.06.04
                    Time: 16:57:48
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331412601805
   Coding: 0031050001
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 3E26376F10FBA14743B-806A
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 13
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:31:43
1111316 - Speaker for Front Parking Aid
          B10F5 14 [009] - Open or Short to Ground
                    Reset counter: 13
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:30:30
1113875 - Parking Aid Indicator Lamp
          B10FF 13 [009] - Open Circuit
                    Reset counter: 13
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PGVG977
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F580A6B5771684F08D-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 008 14
   Serial number: 3576U00000071625E011
   Subsystem 2 - Part No SW: -----------    HW: 454 001 108 14
   Serial number: 3586U00000098365E01C
   Subsystem 3 - Part No SW: -----------    HW: 454 802 008 14
   Serial number: 3516R4E1C37040000001
   Subsystem 4 - Part No SW: -----------    HW: 454 802 008 14
   Serial number: 3526R2A1C3704000000$
   Subsystem 5 - Part No SW: -----------    HW: 454 801 108 14
   Serial number: 3556VAAB56C04000000M
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 29081404401568
   Coding: 1400
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 77A8E24B7F41500F40D-8022
   Part No SW: 5F0 920 862     HW: 5F0 920 862
   Component: KOMBI         202 4270
   Coding: 07AD02002980000800082A001000000000000000
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 21081410800042
   Coding: 030100F42B085700EF0002C8080F00010001000000000000000000000000
   ROD: EV_GatewConti_011_SE37.rod
   VCID: 42DE439F6403C5A7273-8016
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0211070714
   Coding: 002000
   Serial number: 0373214203
131594 - Parallel Parking Assistance Control Module
          U104E 00 [008] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 53
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:24:50
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 53
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:26:22
                    Terminal 15: OFF
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000116201926
   Coding: 00100320DE00040000001000
   Serial number: 00000000000003554863
   Coding: 310000
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DC4C936105DEBF3E9-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000113518523
   VCID: 43D0469B7B19CCAF2C5-8016
   Serial number: 00000000000003526116
   Coding: 290000
   Coding: 048A000009000000
   VCID: 75B4E843654D221F521-8020
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 5F0 035 824 A    HW: 5F0 035 824 A
   Component: MU-S--ER      041 0480
   Serial number: E1E00209140388
   Coding: 04730000FF0A000021110001000800002F0101040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002029
   ROD: EV_MUStd6C3PASE.rod
   VCID: 221EE31F8443E5A7473-8076
   Subsystem 1 - Part No SW: 5F0 919 603     HW: 5F0 919 603
   Component: ABTmin_Std_Rd  H60 0032
   Serial number: SEZ8Z9PT800510
End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Monday,09,July,2018,13:49:45:49483
VCDS Version: 18.5.4.2  HEX-V2 CB: 0.4427.4
Data version: 20180518 DS291.0
VIN: VSSZZZ5FZFR044961   License Plate:
   Revision: R7H21---
   VCID: 6696BF0F28EBD9871F1-8032
   CAN Converter 01:
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D245877E17CB97E15-8010
   Revision: 00001K07
   VCID: 2708F20BEF61008FE47-8072
                    Reset counter: 48
                    Mileage: 56933 km
                    Date: 2018.07.01
                    Time: 13:58:52
   VCID: 005A89972A8F17B785D-8054
   Coding: 0BC5FD
   Coding: 00095D
                    Reset counter: 13
                    Time: 00:00:00
                    Reset counter: 53
                    Time: 00:00:00
                    Reset counter: 53
                    Time: 00:00:00
                    Reset counter: 215
                    Mileage: 55706 km
                    Date: 2018.06.04
                    Time: 16:57:48
   Coding: 0031050001
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 3E26376F10FBA147B71-806A
                    Reset counter: 13
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:31:43
                    Reset counter: 13
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:30:30
                    Reset counter: 13
   VCID: 7F580A6B5771684FFC7-802A
   Coding: 1400
   ROD: EV_SMLSKLOMQB_014_AU37.rod
   VCID: 77A8E24B7F41500FB47-8022
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   ROD: EV_GatewConti_011.rod
   VCID: 42DE439F6403C5A7D39-8016
   Coding: 002000
                    Reset counter: 53
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:24:50
                    Terminal 15: On
                    Reset counter: 53
                    Mileage: 57342 km
                    Date: 2018.07.09
                    Time: 13:26:22
                    Terminal 15: OFF
   Coding: 310000
   Coding: 8103
   VCID: 41DC4C936105DEBFCA3-8014
   VCID: 43D0469B7B19CCAFD8F-8016
   Coding: 290000
   VCID: 75B4E843654D221FA6B-8020
   VCID: 221EE31F8443E5A7B39-8076
End----(Elapsed Time: 01:19, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
https://ibb.co/g4Pyz8
https://ibb.co/gOSU6o
https://ibb.co/c7WTz8
Al Bundy
Bucharest, Romania
C?ID=80804
Not only adress16, the problem is with all controlers.
And, YES, I have that file:
https://ibb.co/cfo2Ro
Yes, that's a bug. There should be a fix for it shortly.
