VW t5 and t6 security access problem
milanocito
Middle East
C?ID=322802
i have problem with vw t5 and t6 security access
vcds show security access 27971 i add it vcds show accepted security access but when i need to do some adaptation like dpf reset vcds say security access requride
Thursday,28,June,2018,17:55:55:08971
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WV2ZZZ7HZFH142260   License Plate:
Mileage: 232320km-144356mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 0B
VIN: WV2ZZZ7HZFH142260   Mileage: 232320km-144356miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H45 6303
   Revision: 26H45---    Serial number: 00000000000000
   Coding: 01194012230400080000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: F7BE832B4EEECFFC96-80A2
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
          P0135 00 [039] - Malfunction
                    Mileage: 232324 km
                    Date: 2018.06.28
                    Time: 16:50:14
                    Coolant temperature: 56 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 12.380 V
4968 - Fuel Temp. Sensor A (G81)
          P0182 00 [039] - Short to GND
                    Fault Frequency: 11
                    Mileage: 232324 km
                    Date: 2018.06.28
                    Time: 16:50:10
                    Fuel consumption: 0.00 l/h
                    Engine oil temperature: 50.0 °C
                    Oil warning threshold: 0.000 mm
                    Control Module temperature: 41.2 °C
                    Oil fill level: 63.200 mm
                    Outside air temperature: 31.5 °C
                    Fuel temperature: 160.0 °C
5253 - Diesel Particle Filter; Differential Pressure Sensor
          P2452 00 [039] - Elect. Malfunction
                    Mileage: 232324 km
                    Date: 2018.06.28
                    Time: 16:50:09
                    Sensor for particle filter differential press: raw value: 1057 hPa
                    Particle filter: difference pressure: -6 hPa
                    Particle filter: offset for differential press.: 3 hPa
                    Particle filter: differential pressure: dynamic offset: 6 hPa
                    Particle filter: soot mass measured: 13.53 g
                    Particle filter: soot mass calculated: 3.18 g
4911 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [167] - Malfunction
                    Mileage: 232324 km
                    Date: 2018.06.28
                    Time: 16:50:09
                    Exh.gas temp.sen 1: 58.8 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 1000.0 °C
                    Exh.gas temp.sen 4: 33.2 °C
                    Shut-off timer: last engine shut-off time: 4552 s
5257 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [039] - Malfunction
                    Mileage: 232324 km
                    Date: 2018.06.28
                    Time: 16:50:09
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 108724AD09A8089724A490773A5E12
   Shop #: WSC 02757 790 49152
   VCID: BB365F1B3A462B9CB2-80EE
03159 - TPMS Functionality in ESP
                    Reset counter: 148
                    Count: 16512
                    Count: 257
                    Count: 142
                    Count: 766
   Component: LENKW.SENSOR  H07 0070
   Serial number: 31071613470076
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEB0960F61D4FEB4D5-80AA
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 H    HW: 7E5 907 040 H
   Component: ClimatronicT5 H10 0101
   Coding: 0004001102
   ASAM Dataset: EV_ClimatronicT5 A01002
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: AD126143FC32B52C3C-80F8
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010704150015093
9473649 - Motor for Rear Temperature Flap
          B108E 71 [008] - Actuator stuck
                    Fault Frequency: 246
                    Reset counter: 232
                    Mileage: 229921 km
                    Date: 2018.06.13
                    Time: 12:43:03
9479185 - Signal Line for Air Quality Sensor
          B10A4 11 [009] - Short to Ground
                    Reset counter: 194
                    Mileage: 206907 km
                    Date: 2018.02.14
                    Time: 00:59:25
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 089150260
   Coding: 62B0F93A0A212012002008106C2B8DD40000612F60840000320000000800
   Shop #: WSC 02739 790 12345
   VCID: C1CA2DF358AA414CE8-8094
   Subsystem 1 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU030031550891772
   Coding: 0000A1
   Subsystem 2 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU030031550890346
   Coding: 1000A1
03428 - Activation of Left Adaptive Light
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 50
                    Mileage: 204231 km
                    Date: 2012.06.09
                    Time: 09:27:16
03429 - Activation of Right Adaptive Light
                    Reset counter: 52
                    Mileage: 204253 km
                    Date: 2012.06.10
                    Time: 08:20:53
03304 - Response Closing Status of Rear Right Door
                    Reset counter: 234
                    Mileage: 204231 km
                    Date: 2012.06.09
                    Time: 10:22:13
03020 - Local databus 2
                    Fault Status: 00101100
                    Reset counter: 228
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00WAJ1H
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02754 790 50316
   VCID: B52249231462FDEC44-80E0
   Part No SW: 7E0 920 870 A    HW: 7E0 920 870 A
   Component: KOMBI         H15 0111
   Coding: 160A00
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: A71E936BDECE9F7CC6-80F2
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 042200
   VCID: F0ACB837238098C457-80A4
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H15 0111
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H55 0107
   Revision: R0000000    Serial number: VWZAZ1R6885063
   Coding: 0000020002
   Shop #: WSC 02754 790 00000
   VCID: A208827FBDEC7A5491-80F6
End----------(Elapsed Time: 01:07, VBatt start/end: 12.4V/12.3V)-----------
This doesn't strike me as a HEX-NET specific question. Moving to VCDS Support for now.
milanocito
Middle East
C?ID=322802
heloo anyobe here from suport ,,,,
27971 is the only Security Access code I'm aware of for that ECU.
milanocito
Middle East
C?ID=322802
i know it is 27971 and ecu accepted the code but if i need to do adaptaion it say security acess requrid ..
this happened in all 2.0 tdi engines... vw t6 crafter yeti nad more ,,
i will make video now
milanocito
Middle East
C?ID=322802
where is the suport ?
NEtech
C?ID=56995
Have you tried the other SA that is showed (12233) ?
What are you trying to do, is a new particulate filter installed ?
And the stored value is already 0 (Tkm).
milanocito
Middle East
C?ID=322802
It was working perfect with 27971
milanocito
Middle East
C?ID=322802
hello where is the support ,,, ,,,,,
PetrolDave
Westbury, UK
C?ID=1423
VW don't publish lists of SA codes, so unless another VCDS user has found an SA code to allow dpf reset with your particular ECU (and told Ross-Tech what it is) then the only options are Google and brute force testing of SA codes.
Andy
Sector 7G
HC424490
We received your email as well but as stated above we are not aware of any other documented Security Access codes for this specific engine.
milanocito
Middle East
C?ID=322802
It is not SA problem ..it is sw bug becuase it was working before in same cars that i have in for service..it was working before 18.2 i think.. do u have older ver to tray ...will not be problem to downgrade the firmware ?
I have hex net
Andy
Sector 7G
HC424490
Your video and AutoScan are from two different vehicles. What happens if you try 17575 as suggested in the popup in the video?
milanocito
Middle East
C?ID=322802
I will tray
but 27971 was working
PetrolDave
Westbury, UK
C?ID=1423
I believe that's the first time you have posted that information here?
Might have been helpful if you had said this sooner as without this information it appeared to be an SA problem rather than a possible software bug.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Hint, a security access code does not circumvent stored error codes. Meaning, address the errors first and then you should be able to take care of the DPF related settings.
milanocito
Middle East
C?ID=322802
i,m saying it again i,m not new in this i know all this ,,, the reset was working before and now not work ,,,,do u wanna more proof videos ,,,,
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Let's go step by step here...
#1 Please make sure to update to Release 18.9 and the latest firmware for your HEX-NET before you proceed.
#2 Which cars/engines have you experienced this with? Please post an Auto-Scan from each of them. The error shown in the video can have several causes, sadly we don't see the full picture because we're missing the Auto-Scan from that specific case.
#3 The video already shows a value of 0, which indicates that it had been reset already. In order to get a clearer picture, please include maps (meas. values & adaptation) from the specific ECM you're having problems with.
FWIW, I am not aware of reports like this from other customers - though I'll be happy to reproduce this next week, once I am back home and got hands on my own T6.
