05.5 Jetta TDI Not Running
CAMski
C?ID=293032
Hi All,
I am new to the Ross-Tech forum so if there are already threads that cover my issues please feel free to re-direct me towards those post so I can read up on them.
I have an a 2005 Mk5 Jetta TDI that began to have computer module issues a few month's back. Initially the wheel speed sensor light would come on at the same time as my air conditioner would stop working. When I read codes what came up for those systems were as follows:
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A55CFC5751A17969F-806E
013 - Check DTC Memory
-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
VCID: 6CF9399D4FCE79265D-8038
009 - Open or Short to Ground
The wheel speed sensor light would occasionally go out on it's own and when it did the AC would start working again, but those stints were always short lived. I started digging around and found a diagram for the fuses in the engine compartment since the plastic encased part of the fuse's all looked like they had surface corrosion. At the same time I began cleaning up grounds (assuming the two systems shared a ground). These attempts made no effective difference; I had begun by targeting the grounds by the ecu and the ones shared by the wheel speed sensor system and the AC system. Then I expanded to all the body grounds as they all looked fairly corroded. On the last ground cleaning, I fired the car and took it down the road. As I was coasting down the hill the car stopped running. I pulled over tried to restart (it cranked but did not fire). I towed the car home, and have begun inspecting the harness for wire breaks and the car has not fired since. In the mean time I have read codes from the ecu and most of the computer systems no longer seem to work, here is the summary:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72 7D
VIN: 3VWST71KX5M645975 Mileage: 446980km-277740miles
46-Central Conv. -- Status: Malfunction 1010
I can include full log files to better detail the codes associated with each malfunction. I am looking for direction in case this is a common error. I am curious if it seems likely that the ECU failed, or if it is a wiring failure and what are some common direction to go. Thanks for any and all help.
Connor
CAMski
C?ID=293032
Wednesday,09,May,2018,20:11:38:17806
VCDS Version: 17.8.1.0 (x64)
VIN: 3VWST71KX5M645975   License Plate:
Mileage: 444340km-276100mi   Repair Order:
VIN: 3VWST71KX5M645975   Mileage: 444340km-276100miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E1673303
   Coding: 0050071
   VCID: 63EB52A1A210365EEC-8036
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
                    Mileage: 444076 km
                    Time: 16:42:14
                    RPM: 798 /min
                    Voltage: 14.36 V
                    Bin. Bits: 00001011
                    Temperature: 54.0°C
                    (no units): 0.0
   Coding: 0021122
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000064338
   Coding: F4098E02400418000014000000140000002077035C
   VCID: 2F43EE91BE58C23E38-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD027DM1
   Coding: 0012627
   VCID: 2E7DF395B952CB3633-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME087519089
   Subsystem 3 - Serial number: 6342MSME085C187DQ
   Subsystem 4 - Serial number: 6351HSME06691F79K
   Subsystem 5 - Serial number: 6361HSME0675597BI
   Subsystem 6 - Serial number: 63727SME06380B480
   Subsystem 7 - Serial number: 63827SME06380431T
   Part No SW: 1K0 953 549 L    HW: 1K0 953 549 L
   Component: Lenksäulenmodul 013 0040
   Coding: 0000041
   VCID: 3B5BCAC17A202E9E84-806E
00888 - Wiper Switch for Intermittent Operation (E22)
   Part No: 1K0 920 971 D
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   VCID: 2C79F99D8F4EB9261D-8078
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001053220E46
   Coding: 3D3F0B420F1002
   VCID: 2977008980BCAC0EE6-807C
01304 - Radio
                    Fault Frequency: 18
                    Reset counter: 115
                    Mileage: 437977 km
                    Time: 10:21:01
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TP9W303
   VCID: 78D115CD0B96C586A9-802C
   Component: IMMO            3HL 2120
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 364DDBF54102F3F67B-8062
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.2       1502
   VCID: 3041EDEDA366DDC621-8064
00573 - Steering Torque Sensor (G269)
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   VCID: 022577255D4A9F5687-8056
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 250
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000030070
   VCID: 69F74089403C6C0E26-803C
00420 - Front Right DSP Midrange Speaker (R104)
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 3753D6F146080AFE60-8062
   Part No SW: 1K0 035 180 A    HW: 1K0 035 180 A
   Component: Radio DE2       008 0115
   Revision: 00008000    Serial number: VWZ4Z7E3035778
   Coding: 0010010
   VCID: 1E1D2355C9F25BB683-804A
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 3147E8E9A86CD4CE2E-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 3245E7E5AD6AEFD657-8066
   Revision: 00800000    Serial number:
   VCID: 2D7FF499B454B02E0A-8078
            014 - Defective
End-------------------------(Elapsed Time: 01:18)--------------------------
CAMski
C?ID=293032
Friday,22,June,2018,11:30:26:17806
VCDS Version: 18.2.1.2 (x64)
Mileage: 446980km-277740mi   Repair Order:
   Coding: 0050071
   VCID: 63EB52A1A210365C5A-8036
               P1641 - 000 -
                    Fault Frequency: 59
                    Mileage: 446734 km
                    Time: 01:12:54
                    Voltage: 12.16 V
                    Bin. Bits: 00001100
                    Temperature: 52.2°C
                    (no units): 16.0
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit - Intermittent
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit - Intermittent
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit - Intermittent
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit - Intermittent
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
Readiness: 0 4 0 0 0
   Coding: 0021122
   VCID: 3A55CFC5751A179429-806E
   VCID: 6CF9399D4FCE7924EB-8038
   VCID: 2F43EE91BE58C23C8E-807A
   Coding: 00065493
   Coding: 00217125
01049 - Supply Voltage Term 50
   Coding: 0012627
   VCID: 2E7DF395B952CB3485-807A
   Coding: 0000041
   VCID: 3B5BCAC17A202E9C32-806E
   Coding: 0023203
   VCID: 2C79F99D8F4EB924AB-8078
   VCID: 2977008980BCAC0C50-807C
                    Reset counter: 179
                    Mileage: 446369 km
                    Time: 00:01:29
                    Reset counter: 188
                    Mileage: 446729 km
                    Time: 00:04:19
   VCID: 78D115CD0B96C5841F-802C
                    Reset counter: 188
                    Mileage: 446368 km
                    Time: 07:42:52
   Coding: 0001271
   VCID: 364DDBF54102F3F4CD-8062
   VCID: 3041EDEDA366DDC497-8064
                    Mileage: 6720 km
                    Temperature: 18.0°C
                    Voltage: 12.00 V
                    Voltage: 11.90 V
   VCID: 022577255D4A9F5431-8056
                    Fault Status: 01110011
                    Reset counter: 139
                    Reset counter: 183
   VCID: 69F74089403C6C0C90-803C
   Coding: 0001271
   VCID: 3753D6F146080AFCD6-8062
   Coding: 0010010
   VCID: 1E1D2355C9F25BB435-804A
   Coding: 0000144
   VCID: 3147E8E9A86CD4CC98-8064
   Coding: 0000144
   VCID: 3245E7E5AD6AEFD4E1-8066
   VCID: 2D7FF499B454B02CBC-8078
            014 - Defective
End-------------------------(Elapsed Time: 01:20)--------------------------
CAMski
C?ID=293032
This should be from before it was having the issues described:
Saturday,10,March,2018,14:04:09:17806
Mileage: 435480km-270594mi   Repair Order:
VIN: 3VWST71KX5M645975   Mileage: 435480km-270594miles
   Coding: 0050071
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Fault Status: 00110000
                    Mileage: 435008 km
                    Time: 07:30:04
                    RPM: 2037 /min
                    Speed: 95.0 km/h
                    Load: 71.8 %
                    Voltage: 14.74 V
                    Bin. Bits: 00101000
                    Absolute Pres.: 1968.6 mbar
                    Absolute Pres.: 1550.4 mbar
Readiness: 1 1 0 0 0
   Coding: 0021122
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0000041
   Coding: 0023203
01304 - Radio
                    Fault Frequency: 16
                    Reset counter: 220
                    Mileage: 431567 km
                    Time: 18:56:31
   Coding: 0001271
                    Reset counter: 112
                    Reset counter: 152
                    Mileage: 416126 km
                    Time: 11:37:16
   Coding: 0001271
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
            014 - Defective
End-------------------------(Elapsed Time: 01:15)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Hi!
Welcome to forum! Does car still is in no start condition? Clear all fault codes and make a new autoscan. (uncheck "use CAN command" before pressing button "Clear all faults" in autoscan window). then cycle ignition (do not attemt to start engine) and make another autoscan, then try to start engine and make third autoscan. Post all three scans here.
What ground points did You unscrewed for cleaning? Are You sure You put ALL the ring terminals back and tightened ALL nuts?
CAMski
C?ID=293032
Hi MartinsX, sorry for the delayed response, I have been out of town for a few days.
The car is still in a no run condition. The grounds I cleaned include the 4 down on the driver's bumper support, the main negative connection to the body, the ground in the window troth closest to the computer connectors on the harness, and the grounds underneath the kick panels. I had checked the grounds for tightness, but always worth an additional check. I will post the scans in a moment
CAMski
C?ID=293032
Clear All:
Monday,02,July,2018,20:57:09:17806
VIN: 3VWST71KX5M645975   License Plate: CLEARALL-AUTOSCAN
   Coding: 0050071
               P1641 - 000 -
                    Fault Frequency: 60
                    Mileage: 446734 km
                    Time: 01:12:54
                    Voltage: 12.16 V
                    Bin. Bits: 00001100
                    Temperature: 52.2°C
                    (no units): 16.0
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
   Coding: 0021122
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0000041
   Coding: 0023203
                    Reset counter: 179
                    Mileage: 446369 km
                    Time: 00:01:29
                    Reset counter: 188
                    Mileage: 446729 km
                    Time: 00:04:19
                    Reset counter: 188
                    Mileage: 446368 km
                    Time: 07:42:52
   Coding: 0001271
                    Mileage: 6720 km
                    Temperature: 18.0°C
                    Voltage: 12.00 V
                    Voltage: 11.90 V
                    Reset counter: 139
                    Reset counter: 188
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
            014 - Defective
CAMski
C?ID=293032
Key Cycle:
Monday,02,July,2018,20:59:18:17806
VIN: 3VWST71KX5M645975   License Plate: KEYCYCLE-AUTOSCAN
   Coding: 0050071
               P1641 - 000 -
                    Fault Frequency: 60
                    Mileage: 446734 km
                    Time: 01:12:54
                    Voltage: 12.16 V
                    Bin. Bits: 00001100
                    Temperature: 52.2°C
                    (no units): 16.0
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
   Coding: 0021122
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0000041
   Coding: 0023203
                    Reset counter: 179
                    Mileage: 446369 km
                    Time: 00:01:29
                    Reset counter: 188
                    Mileage: 446729 km
                    Time: 00:04:19
                    Reset counter: 188
                    Mileage: 446368 km
                    Time: 07:42:52
   Coding: 0001271
                    Mileage: 6720 km
                    Temperature: 18.0°C
                    Voltage: 12.00 V
                    Voltage: 11.90 V
                    Reset counter: 139
                    Reset counter: 188
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
            014 - Defective
End-------------------------(Elapsed Time: 01:17)--------------------------
CAMski
C?ID=293032
Attempt to Start:
Monday,02,July,2018,21:01:31:17806
VIN: 3VWST71KX5M645975   License Plate: ATTEMPTSTART-AUTOSCAN
   Coding: 0050071
               P1641 - 000 -
                    Fault Frequency: 60
                    Mileage: 446734 km
                    Time: 01:12:54
                    Voltage: 12.16 V
                    Bin. Bits: 00001100
                    Temperature: 52.2°C
                    (no units): 16.0
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
                    Mileage: 446985 km
                    Time: 00:00:16
                    Voltage: 12.01 V
                    Bin. Bits: 00001111
                    Temperature: 19.8°C
                    Bin. Bits: 00110000
   Coding: 0021122
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0000041
   Coding: 0023203
                    Reset counter: 179
                    Mileage: 446369 km
                    Time: 00:01:29
                    Reset counter: 188
                    Mileage: 446729 km
                    Time: 00:04:19
                    Reset counter: 188
                    Mileage: 446368 km
                    Time: 07:42:52
   Coding: 0001271
                    Mileage: 6720 km
                    Temperature: 18.0°C
                    Voltage: 12.00 V
                    Voltage: 11.90 V
                    Reset counter: 139
                    Reset counter: 188
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
            014 - Defective
The wire harness under the VC to the Injectors and glow plugs is kaput, & maybe even back to ECU
Isolate all and to main connector and correct the condition of chafe........very common!
Check or replace all blown fuses!
Get a new battery!
CAMski
C?ID=293032
I had started to look for chafe under the battery as I had heard that was a common area, I had also checked all the fuses in the engine harness bay and in the dash and replaced those. The battery is 2 years old I think. You are saying the section of harness that runs to the injectors is chafe prone?
CAMski
C?ID=293032
Ok good to know, what are some of the other common points external to the valve cover? I am hoping to have some time this weekend to check.
Remove ECU and tone generate and qualify every track under the VC for load test & ability to carry current using WD.
No magic!
Work .....time to RTFB & work!
You better check fuses and consumer B+ supply!
Check car and ECU for FOD water ingress!
CAMski
C?ID=293032
Took a quick glance last night and found chafed wires on the back side of the head running to the turbo. Will complete more extensive check this weekend
