help i need English language for steering control module if possible please
Kill All Wipers
St Helens, UK
C?ID=309327 (?)
hey guys not been doing much lately but ive got a 2010 vw scirocco thats got some steering wheel coding issues the last owner has replaced the slip ring and it was not coded correctly but the coding options are in german or Spanish so im struggling with it
ive done a full scan from the car ignore the suspension faults as its bagged so i cant remove them im working on the steering wheel issue and the 3rd brake light faults at the moment
Monday,21,May,2018,21:00:32:49877
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ13ZBV001483   License Plate: VO05 COT
Mileage: 164330km-102109mi   Repair Order:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 52 56 77
VIN: WVWZZZ13ZBV001483   Mileage: 164330km-102109miles
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LC    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000SG  9977
   Revision: 13H07---    Serial number:
   Coding: 0001072
   Shop #: WSC 45411 002 1048576
   VCID: 71BCDDEAADA537DF8E9-8024
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 763B60F5492200FB6E0F06EC921C0082350000
   Shop #: WSC 00020 790 00000
   VCID: 0452843E8E17327755F-8050
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 7EA6F6D6E07B58A703B-802A
   Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
   Component: BCM PQ35 M    011 0035
   Revision: BC011001
   Coding: 40100A388027E10040880080340000EE43503B88536D85605C8000000040
   Shop #: WSC 00020 790 12345
   VCID: 372823F28F41A9EF80D-8062
   Subsystem 1 - Part No: 1K8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 07041  22  0614
   Coding: 009795
   Component: RLS 140510 05  54  0403
   Coding: 0330ED
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
01503 - Bulb for 3rd Brake Light (M25)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 134
                    Mileage: 164336 km
                    Date: 2012.10.11
                    Time: 20:28:36
                    Voltage: 13.70 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 100001
   VCID: 3A2E3AC6BC53B4877F3-806E
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 18051004190002
   Coding: 000180
   VCID: 2708F3B25FE1396F10D-8072
8 Faults Found:
00144 - Rear Left Dampening Adjustment Valve (N338)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 211
                    Bin. Bits: 00000000 00100000
00774 - Level Control System Sensor; Rear Left (G76)
                    Fault Status: 00100011
                    Reset counter: 173
                    Mileage: 140000 km
                    Date: 2011.07.19
                    Time: 17:32:44
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
00143 - Front Right Dampening Adjustment Valve (N337)
                    Reset counter: 148
                    Mileage: 140314 km
                    Date: 2011.07.23
                    Time: 16:15:37
03264 - Functionalty Shut Off
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 134
                    Mileage: 140314 km
                    Date: 2011.07.23
                    Time: 16:15:41
                    Error Code: 8
                    Bin. Bits: 00000000
00142 - Left Front Dampening Adjustment Valve (N336)
                    Reset counter: 148
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 211
                    Reset counter: 168
                    Mileage: 163983 km
                    Date: 2012.10.04
                    Time: 12:36:60
                    Bin. Bits: 00000001 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Reset counter: 171
                    Mileage: 163986 km
                    Date: 2012.10.04
                    Time: 21:00:40
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D02JJVF
   Coding: 0012360
   VCID: 6FB8DB92BB91212F98D-803A
   Subsystem 1 - Serial number: 6332MSME516238556
   Subsystem 2 - Serial number: 6342MSME5162567AE
   Subsystem 3 - Serial number: 6352QSME105E40089
   Subsystem 4 - Serial number: 6362QSME62603A308
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010017    Serial number: 20120929300357
   Coding: 118A100000
   Shop #: WSC 00046 790 12345
   VCID: 392C25CAB9D5BF9F769-806C
   Coding: 820000
335876 - Powertrain Databus
          U0002 00 [009] - No Communications
                    Reset counter: 134
                    Mileage: 164336 km
                    Date: 2018.05.21
                    Time: 20:32:58
   Part No SW: 1K8 920 972 A    HW: 1K8 920 972 A
   Component: KOMBI         H03 0406
   Coding: 170901
   Shop #: WSC 00020 999 12345
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 323E12E664A34CC7B73-8066
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 160510F2000126
   Coding: E9A81F0600061200004001
   VCID: 6D84C19AB19DD33FAA1-8038
   Component: IMMO          H03 0406
   VCID: 6A8ECA868CF3C407CF3-803E
   Revision: A1001003    Serial number: 7668093559
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2130
   Coding: 0016949
   VCID: 392C25CAB555BF9F769-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 178    3001
   Revision: 00H17000
   VCID: 313C1DEA6D2577DFCE9-8064
            000 -  -  - MIL ON
                    Mileage: 164336 km
                    Date: 2012.10.11
                    Time: 20:27:53
                    Battery Volts: 13.9 V
                        DU
                    Temperature: 28.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016948
   VCID: 3A2E3AC6B053B4877F3-806E
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K6391942
   Coding: 0100040004
   VCID: 6594B9BA656DEB7FE21-8030
   Part No SW: 3C8 035 730 A    HW: 3C8 035 730 A
   Component: Telefon       007 0078
   Revision: --------    Serial number: 35909603004268
   Coding: 020000000100000000010000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 211CEDAA3145C75F5E9-8074
End----------(Elapsed Time: 01:28, VBatt start/end: 12.4V/12.3V)-----------
Are you sure that steering wheel control module is appropriate for this car?
Kill All Wipers
St Helens, UK
C?ID=309327 (?)
it does work perfectly i changed the coding
multi function steering wheel dimming the buttons with can information
last night and the buttons now light up as they should and everything works
i just have the error in the log i was going to double check the coding but its a pain typing everything into google translate each time lol
Dana
Western PA, USA
This may be sorted already but 8X0-953-569.clb has an English coding chart. I suspect you might be choosing [Yes] to the Experimental Coding selection.
http://www.ross-tech.com/vcds/tour/recode_screen.php#experimental
If so, that coding chart is hard to read and cannot be translated.
I agree with Uwe on the Audi specific 16 module. That would not be found a VW from the factory and it may not be compatible with this car.
