RE: Thanks for the files. You may want to create a thread.
Autoscan below....
Autoscan below....
> Friday,11,May,2018,07:35:41:36672
> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
> VCDS Version: 18.2.0.3 (x64)
> Data version: 20180212 DS287.0
> www.Ross-Tech.com
> Chassis Type FF-AU37 (3Q0)
> Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 4B
> 52 5F 6C A5 BB BC CF
> Mileage: 435km-270miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: Malfunction 0010
> 09-Cent. Elect. -- Status: Malfunction 0010
> 10-Park/Steer Assist -- Status: OK 0000
> 13-Auto Dist. Reg -- Status: Malfunction 0010
> 14-Susp. Elect. -- Status: OK 0000
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 22-AWD -- Status: OK 0000
> 2B-Steer. Col. Lock -- Status: OK 0000
> 3C-Lane Change -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 47-Sound System -- Status: OK 0000
> 4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
> 52-Door Elect, Pass. -- Status: OK 0000
> 5F-Information Electr. -- Status: OK 0000
> 6C-Back-up Cam. -- Status: OK 0000
> A5-Frt Sens. Drv. Assist -- Status: OK 0000
> BB-Door Rear Drv -- Status: OK 0000
> BC-Door Rear Pass -- Status: OK 0000
> CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
> Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
> Part No SW: 8V0 907 404 G HW: 07K 907 309 E
> Component: R5 2.5l TFSI H22 0004
> Revision: 53H22000
> Coding: 0A250032246600053600
> Shop #: WSC 06385 790 00016
> ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
> ROD: EV_ECM25TFS0118V0907404G.rod
> VCID: 3D71007FACFEEEAC33-8068
> No fault code found.
> Readiness: 0000 0000
> Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
> Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
> Component: GSG DQ500 H06 2112
> Revision: 00H06V07
> Coding: 0014
> Shop #: WSC 00000 000 00000
> ASAM Dataset: EV_TCMDQ500021 001001
> ROD: EV_TCMDQ500021_AU21.rod
> VCID: 2E53373371980534BA-807A
> Address 03: ABS Brakes (J104) Labels: None
> Part No SW: 8V0 614 517 E HW: 8V0 614 517 C
> Component: ESC H25 0625
> Revision: 00000000 Serial number: 60228000000134
> Coding: 2EAA6B7DD4990BAE89980B67819A6974D62BD091D0819636184150D482A812
> ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
> ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
> VCID: 3B750E67B2EAE09C0D-806E
> Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
> Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
> Component: VWKESSYMQB 021 0803
> Revision: 00021000 Serial number: 0463989379
> Coding: 030C0C
> ASAM Dataset: EV_KessyHellaMQBAB 002020
> ROD: EV_KessyHellaMQBAB_002.rod
> VCID: 3C770D7BB7E4E7A404-8068
> Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
> Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
> Component: AC Automat H03 0130
> Revision: 20002000 Serial number: 00000001465887
> Coding: 03000015010000000000000000001400
> ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
> ROD: EV_AirCondiFrontVaAU37X.rod
> VCID: 408F798BDB0C834458-8014
> Relative humidity sensor in fresh air intake duct:
> Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
> Component: AQ_Hum_Sensor H02 0007
> Serial number: 43809E0900PAG0MUFU03
> 1 Fault Found:
> 65544 - Button(s) or Switch(es) in Operating Device
> B1312 07 [008] - Mechanical Failure
> Intermittent - Confirmed - Tested Since Memory Clear
> Freeze Frame:
> Fault Status: 00000001
> Fault Priority: 2
> Fault Frequency: 3
> Reset counter: 53
> Mileage: 87 km
> Date: 2018.05.03
> Time: 17:02:31
> Voltage terminal 30: 13.1 V
> Outside air temperature: 28.5 °C
> Pressing a button-Defrost: not activated
> Pressing a button-Recirculating air: not activated
> Pressing a button-Rear window defogger: not activated
> Pressing a button-AC: not activated
> Pressing a button-Left heated seat: not activated
> Pressing a button-Right heated seat: not activated
> Pressing a button-OFF: not activated
> Pressing a button-AUTO: not activated
> Pressing a button-Footwell air distribution: not
> activated
> Pressing a button-Upper body vent air distribution:
> operated
> Pressing a button-Air distribution up: operated
> Pressing a button-Left cabin heater: not activated
> Pressing a button-Right cabin heater: not activated
> Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
> Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
> Component: BCM MQBAB MNA H36 0253
> Serial number: 01001802700173
> Coding: 000000000000000000000000000000000000000000000000000000000000
> ASAM Dataset: EV_BCMMQB 018001
> ROD: EV_BCMCONTI.rod
> VCID: 0603AF93B9A86D7422-8052
> Control Unit For Wiper Motor:
> Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A
> Labels: 5QX-955-119-V1.CLB
> Component: WWS371 180106 043 0585
> Serial number: 180113223424
> Coding: 0A47F7
> Rain Light Recognition Sensor:
> Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
> Component: G397_RLFS H06 0002
> Serial number: 21171101X81A955547A0
> Coding: 00006C
> Light switch:
> Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
> Component: E1 - LDS MQB H06 0032
> Serial number: 17 11 2017 00000016
> Alarm horn:
> Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
> Component: Sirene, DWA 005 0314
> Serial number: 00000000000099860804
> Sun Roof:
> Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
> Component: J245 PS73.404 H04 0005
> Serial number: 0000FST001Y7EG000000
> Coding: 101F00
> 1 Fault Found:
> 204293 - Remote key 1
> B1479 54 [008] - Missing Calibration / Basic Setting
> Freeze Frame:
> Fault Priority: 4
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 329 km
> Date: 2018.05.08
> Time: 12:11:23
> Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
> Part No SW: 5QA 919 294 B HW: 5QA 919 294
> Component: PDC 8 KanalH07 0044
> Serial number: 000308418018024
> Coding: 0470155811
> ASAM Dataset: EV_EPHVA18AU3700000 009035
> ROD: EV_EPHVA18AU3700000_009_AU37.rod
> VCID: 4B955EA7E24A501CBD-801E
> Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
> Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
> Component: ACC BOSCH MQB H10 0571
> Coding: B50087C119FFC42474988055000026
> ASAM Dataset: EV_ACCBOSCHVW416 001005
> ROD: EV_ACCBOSCHVW416_001_VW37.rod
> 2 Faults Found:
> 1088 - Databus
> U1121 00 [008] - Missing Message
> [New feature! Extended UDS fault detail is only supported by
> current gen. interfaces]
> Freeze Frame:
> Fault Priority: 4
> Fault Frequency: 3
> Reset counter: 57
> Mileage: 315 km
> Date: 2018.05.07
> Time: 21:04:06
> Control Module temperature: 38 °C
> Voltage terminal 15: 12.1 V
> Velocity_vehicle_reference: 0.00 m/s
> Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
> Status_ACC_System: ACC_Off_MainSwitch_Off
> 2065 - Databus
> U1122 00 [008] - Implausible Message
> Freeze Frame:
> Fault Priority: 4
> Fault Frequency: 3
> Reset counter: 57
> Mileage: 315 km
> Date: 2018.05.07
> Time: 21:04:07
> Status_ACC_System: ACC_reversible_error
> Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
> Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
> Component: DAEMPFUNGS-SG H11 0082
> Serial number: 200118048
> ASAM Dataset: EV_AudiMagneRide 002008
> ROD: EV_AudiMagneRide.rod
> VCID: 4581689FC42EA66C6B-8010
> Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
> Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
> Component: AirbagVW20 010 0830
> Serial number: 003GCR09UX56
> Coding: 9DCCFCC0008000005000001AC24800000065
> ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
> ROD: EV_AirbaVW20SMEVW37X_VW37.rod
> VCID: 479D6297FE22B47C99-8012
> Belt Pretensioner left:
> Belt Pretensioner right:
> Occupant Detection:
> Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
> Component: BF-Gewichtss. H10 0046
> Serial number: 694000000000001PPJ36
> Coding: 303337
> Side Sensor Driver Front:
> Subsystem 4 - Part No SW: ----------- HW: 480 003 101 18
> Component: SideSensor_Df 001 0887
> Serial number: 35700000000B99B86B2$
> Coding: 2D2D2D
> Side Sensor Passenger Front:
> Subsystem 5 - Part No SW: ----------- HW: 480 003 101 18
> Component: SideSensor_Pf 001 0887
> Serial number: 35800000000A1951BB2N
> Coding: 2D2D2D
> Side Sensor Driver Rear:
> Subsystem 6 - Part No SW: ----------- HW: 480 402 401 18
> Component: SideSensor_Dr 000 6149
> Serial number: 35100019B28C22E417B7
> Coding: 2D2D2D
> Side Sensor Passenger Rear:
> Subsystem 7 - Part No SW: ----------- HW: 480 402 401 18
> Component: SideSensor_Pr 000 6149
> Serial number: 35200019B28C22E1F2EH
> Coding: 2D2D2D
> Front Sensor Driver:
> Subsystem 8 - Part No SW: ----------- HW: 480 400 301 18
> Component: FrontSensor_D 001 6149
> Serial number: 3550002AB25325B4830-
> Coding: 2D2D2D
> Front Sensor Passenger:
> Subsystem 9 - Part No SW: ----------- HW: 480 400 301 18
> Component: FrontSensor_P 001 6149
> Serial number: 3560002A925325B402C
> Coding: 2D2D2D
> Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
> Part No SW: 8V0 953 521 KT HW: 5Q0 953 549 E
> Component: Lenks. Modul 003 0140
> Revision: -------- Serial number: 31011804220046
> Coding: 6818
> ASAM Dataset: EV_SMLSKLOMQB 020002
> ROD: EV_SMLSKLOMQB_020_AU37.rod
> VCID: 1623FFD3E908DDF4D2-8042
> Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
> Part No SW: 8V0 920 890 A HW: 8V0 920 890 A
> Component: FBenUSA H16 0066
> Coding: 084D18537F88CF050284EC041800001000000000
> ASAM Dataset: EV_DashBoardFPKAU37X 001027
> ROD: EV_DashBoardFPKAU37X.rod
> Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
> Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
> Component: GW MQB High 518 5323
> Serial number: 25011810805016
> Coding: 03010004340860005B00803EB80B00000001010000000000000000000000
> ASAM Dataset: EV_GatewNF 013023
> ROD: EV_GatewNF_VW27.rod
> VCID: 387F116B83DCCB84E0-806C
> Alternator:
> Multi Function Steering Wheel Control Module:
> Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
> Component: J453 MFL H04 0002
> Serial number: 20180127030404 20441
> Battery Monitoring Control Module:
> Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
> Component: J367-BDMHella H10 9070
> Serial number: 2626556704
> Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
> Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
> Component: Haldex4Motion H52 7762
> Serial number: HA1-00011.01.18
> Coding: 0601
> ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
> ROD: EV_AllWheelContrHA1VW37X.rod
> VCID: 4D9150BF1C5E5E2CA3-8018
> Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
> Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
> Component: ELV-MQBA H01 0120
> Revision: 00000000 Serial number: 18000018525002
> Coding: 5D00000000000000
> ASAM Dataset: EV_ELVMarquMQB 004111
> ROD: EV_ELVMarquMQB.rod
> VCID: 3467255B9FB42FE4CC-8060
> Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
> Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
> Component: MRR1Rear H21 0610
> Revision: --------
> Coding: 04C002
> ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
> ROD: EV_RearRadarS1BoschVW48X.rod
> Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
> Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
> Component: TSG FS 020 0041
> Serial number: 201217ELK05598
> Coding: 005D1B205C00048000000003
> ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
> ROD: EV_DCUDriveSideEWMAXCONT.rod
> VCID: 43857687CA1A985C45-8016
> Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
> Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
> Component: EPS_MQB_ZFLS 507 5081
> Coding: 911E0000
> ASAM Dataset: EV_SteerAssisMQB 015157
> ROD: EV_SteerAssisMQB_015.rod
> Address 47: Sound System (J525) Labels:| 81A-035-466.clb
> Part No SW: 81A 035 466 B HW: 81A 035 466
> Component: MIB2_amp_P_A3 H10 0440
> Revision: 00000001 Serial number: AUZ8ZAH5F017UA+
> Coding: 0173030000AAAA2AAA0000010000
> ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
> ROD: EV_AMPMst16C9Gen2ALPI.rod
> VCID: 2447D51B2F54BF645C-8070
> Address 4B: Multifunc. Module
> Interface not compatible.
> Please upgrade to a current Ross-Tech interface.
> Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
> Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
> Component: TSG BFS 020 0041
> Serial number: 011217EL108435
> Coding: 005D13205E00048000000003
> ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
> ROD: EV_DCUPasseSideEWMAXCONT.rod
> VCID: 428B7383D50091544E-8016
> Address 5F: Information Electr. (J794) Labels:* None
> Part No SW: 8V1 035 880 D HW: 8V1 035 880
> Component: MU-P-LNS-US 054 1196
> Serial number: A702A0JS006483
> Coding: 017361020000000011220002041A00102F0028E5017001047E
> ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
> ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
> Data medium:
> Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
> Component: NAR 2017/2018 --- 0060
> Serial number: --------------------
> Display unit 1 for multimedia system:
> Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
> Component: DU High H49 0014
> Serial number: AUZ8Z9H1Y08JYU
> Multimedia Operating Unit:
> Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
> Component: ControlUnit_H H85 0855
> Serial number: ALJAL107121700050727
> Compact Disc Database:
> Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
> Component: Gracenote2 --- 3012
> Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
> Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
> Component: RVC Compact H12 0231
> Coding: 0273010102002001400040
> ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
> ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
> VCID: 3979146FB8D6D28C1F-806C
> Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
> Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
> Component: MQB_B_MFK H07 0272
> Serial number: 13011812K21698
> Coding: 040307010000020101222346814E890080000E200120
> ASAM Dataset: EV_MFKBoschMQBB 001001
> ROD: EV_MFKBoschMQBB_VW36.rod
> Address BB: Door Rear Drv (J388) Labels:* None
> Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
> Component: TSG HFS 020 0041
> Serial number: 211117EKL02601
> Coding: 000C13204000048000000002
> ASAM Dataset: EV_DCURearDriveMINKLO 006003
> ROD: EV_DCURearDriveMAXCONT.rod
> Address BC: Door Rear Pass (J389) Labels:* None
> Component: TSG HBFS 020 0041
> Serial number: 211117EKL02604
> ASAM Dataset: EV_DCURearPasseMINKLO 006003
> ROD: EV_DCURearPasseMAXCONT.rod
> Address CF: Lane Chge Asst 2
> End-------------------------(Elapsed Time: 05:33)--------------------------
