No response from controller with HEX-NET
_Val
Latvia
C?ID=356659
Engine connector:
pin #1 - GND
pin #2 - GND
pin #3 - 15 (12v)
pin #62 - 30 (12v)
pin #43 - W (to instrument cluster) = K ?
Hex-net:
pin #4 - GND
pin #7 - K
pin #15 - L (not needed for this test)
pin #16 - 12v
Need to recheck ^^ two more times and use isolated connectors to not fry something.
You can also check grounds and 12v while ECU is still connected to the car with ignition ON.
Maybe get extra obd2 connector with 10-20cm wires from A4 B5/A6 C5/A4 B6, whatever.
If possible try this at first with 5usd KKL cable and vcds-lite and only then switch cable to hex-net :D
This pdf confirms above pinout i got from Elsa (A6 C5 2004 2.7biT BES):
https://www.audiworld.com/forums/a6...2-7t-ecu-pinout-details-2835703/#post24361114
Zenerdiode
Newcastle, England
C?ID=24330
Engine connector:
Yes, on the bench we use the W-Line as a K-Line for the ECU.
Julian, you haven't inadvertently altered any settings on VCDS Options screen have you? Hmm, I was thinking of 'Bypass CAN Init' or 'Force K on Engine' - but these would have a desirable effect in your case. But all of the other parameters are at their default values?
   #23
Znippie
Norway
C?ID=328489
No i havent touched those settings, but after this started to happen I tried both settings you refer to, just to see if it makes any difference. And no, its doesnt. Also tried a clean install of VCDS, and even a different PC. Im pretty sure that my car is the problem, since the hex-net is working on anything else.
   #24
Znippie
Norway
C?ID=328489
Im delaying the stand-alone ECU test until I recieve this obd pinout from ebay;
Abit safer with the isolated connector and such.
The pinout seems correct _Val
The only 2 modules I cant reach is the Auto HVAC and Engine.. do they share the KWP2000 ? According to the ross-tech page is a little uncertain..
I havent tried to unplug the climate controller, but I do remember working on that one last year when I created this post.
Im so frustrated, since the HEX-NET worked perfectly when I first got it.
   #25
_Val
Latvia
C?ID=356659
HVAC is on K1 for diagnostics. Don't know protocol it's using.
Have you ever tried disconnecting fitted ABS module from K line and then testing Hex-net?
   #26
Znippie
Norway
C?ID=328489
No, I havent. U mean, disconnect the wiring harness from the abs module right? Since the abs have been customized it could be an issue yeah..
   #27
_Val
Latvia
C?ID=356659
Yes, could also just unplug ABS connector from unit in engine bay.
   #28
Znippie
Norway
C?ID=328489
Thats what I meant, but i chose the wrong words I guess :D
Tried to disconnected k-line for the ABS module today. The k-line for ABS and ECU is paired in the ecu poenum box by me, so it was an easy disconnect. But nothing changed..
Note: I think the battery is looking at a retirement.. its 11.6v with the engine off (according to test in vcds)
But it has 14.1v at idle so that wouldnt matter due to communication anyway right?
   #29
Znippie
Norway
C?ID=328489
Still waiting on the obd -> pinout that I bought from ebay, so today I wanted to check out my other theory.
As mentioned my Auto HVAC controller (climate controller) has also been unavailable for scan, in addition to the ECU.
And, since these problems started last year when I installed the climate controller, i wanted to remove the climate controller and see if I could read the ECU.
And guess what, it did
Thats strange..
That means that theres no disfunctionality with the wiring between ecu and obd port, but between ECU and climate I guess ?
   #30
Thats strange..
Not sure exactly what is going on there. The HVAC controller could be loading down the K-Line, or putting some noise on it, or incorrectly responding when it shouldn't. I can't think of a good way to narrow down the cause without putting an oscilloscope and/or a K-line analyzer on this.
Znippie
Norway
C?ID=328489
Okay, bumping this one up again.
The climate controller (hvac) is not the one to blame.
I have now found out whos fault it is. Its the retrofitted RNS-E (which I installed about at the same time these symptoms came..doh)
I recently bought an AUX interface which I wanted to code into the unit, but I didnt get any response from the controller. Thought that was weird, so I fitted my oem ConcertII which came with the car, and then I could access the ECU and Auto HVAC modules in vcds.
Thats pretty odd, and I dont know whats causing it.
The RNS-E is from an Audi A3, but the PIN is confirmed and I have been using the unit as normal ever since I got it..
Why doesnt the car recognize it, and why is it causing the ECU and Auto HVAC to loose communication?
   #32
How is it wired? Where does the K-line to/from the RNS-E go?
PetrolDave
Westbury, UK
C?ID=1423
When you retrofitted the RNS-E what radio did it replace? The later Concert II (and Symphony II) radios have a different pinout (but still use the Quadlock connector) which can result in the K-line being shorted. You need to check the pinouts of both the RNS-E and the Concert II and swap the appropriate pins.
When I retrofitted RNS-E on several cars in the UK (a few years ago so I have lost all the paperwork in a house move) this pin swap was something many people missed, including you possibly?
BTW IIRC the RNS-E isn't on the K-line but on the K2(L)-line, maybe the other controllers that aren't responding are also on the K2(L)-line?
   #34
Znippie
Norway
C?ID=328489
As you and Uwe says, it might be a simple solution as kline wiring for this yeah. I havent done pin swap with the new unit, I will check that out later today! :)
   #35
Znippie
Norway
C?ID=328489
The pinout are different for the ConcertII and RNS-E as mentioned (pin5 on A(green) connector vs pin7 on B(blue) connector in the quadlock connection)
Repinned them, and now everything is working flawlessly like it did before I created this thread.
Thanks for all the help!
   #36
PetrolDave
Westbury, UK
C?ID=1423
You're not the first person to miss out the pin swaps when doing an RNS-E retrofit ..... and I suspect you won't be the last ;)
Glad it's all sorted now :thumbs:
