hey guys so few days ago i got a CEL I did auto scan and got nothing. i did have a issue with one of my O2 sensors which i replaced. i also did data reading on the O2 sensors and got this information per Sensor. what does it mean, and why is it different from sensor to sensor. Based on the information I see, PCM can do a voltage reading on down stream, sensors but not on upstream. it shows a voltage test on both down stream but not on S1.
Monday,16,April,2018,10:11:02:43295
VCDS Release 18.2.0 (x64): Generic OBD2
B2S2
TID 01 - Rich to lean sensor threshold voltage Test:0.625 V
TID 02 - Lean to rich sensor threshold voltage Test:0.625 V
TID 03 - Low sensor voltage for switch time calculation N/A
TID 04 - High sensor voltage for switch time calculation N/A
TID 05 - Rich to lean sensor switch time N/A
TID 06 - Lean to rich sensor switch time N/A
TID 07 - Minimum sensor voltage for test cycle Test:0.205 V - Min:0.000 V - Max:0.625 V
TID 08 - Maximum sensor voltage for test cycle Test:0.700 V - Min:0.625 V - Max:1.000 V
TID 09 - Time between sensor transitions N/A
TID 10 - Sensor period N/A
Monday,16,April,2018,10:12:06:43295
B2S1
TID 01 - Rich to lean sensor threshold voltage N/A
TID 02 - Lean to rich sensor threshold voltage N/A
TID 07 - Minimum sensor voltage for test cycle N/A
TID 08 - Maximum sensor voltage for test cycle N/A
B1S1
Monday,16,April,2018,10:12:51:43295
B1S2
Monday,16,April,2018,10:13:17:43295
Monday,16,April,2018,10:20:06:43295
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WAULT68E14A008323 License Plate:
Mileage: 282280km-175400mi Repair Order:
67 69 75 76 77
VIN: WAULT68E14A008323 Mileage: 282280km-175400miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 L HW: 8E0 909 059
Component: 3.0L V6/5V G 0010
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 3E25C0691C6D2407404-5160
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04495
VCID: 26150809E1FD9CC7284-51F2
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 6393511DD24F29EF0FA-5160
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 3537DF452C5BE75F91E-4B00
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
VCID: 372BD54D3357154F832-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
VCID: 3E25C069196D2407404-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
Shop #: WSC 42336
VCID: 323DE459DD35F067B4C-5160
WAULT68E14A008323 AUZ6Z0C0185488
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: 71BF2B5518838B7F8D6-4B3C
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72BD24591DB5B06774C-4B00
Component: Tõrsteuer.FS BRM 0003
Component: Tõrsteuer.BF BRM 0003
13 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
01559 - Drivers Door
59-00 - Can't Unlock
01560 - Passenger Door
80-00 - Single-Wire Operation
01561 - Rear left door
01562 - Rear right door
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 0451728137318ED7560-4B3C
28-10 - Short to Plus - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01005
Shop #: WSC 85504
VCID: 2C01FA21FF21A697FE0-5066
End----(Elapsed Time: 05:18, VBatt start/end: 14.2V/14.2V. VIgn 0.0V)------
Address 01: DTCs cleared
