iamdieter
New Member
- Apr 6, 2018
- 8
- 7
- South Africa
- hex1cef-01da18-d1af48-b2f469-tqhahh-5fb1
Thank you for the forum and the VCDS product. I purchased the original USB cable years ago and it serves me well, how do I become a approved member here?
Now my issue:
Battery does not charge properly, leading to battery depletion over time, i.e. vehicle will not start. Battery is brand new (Varta OEM), same behavior with the older battery. I replaced the battery as it was 6 years old anyway, and was hoping for an easy fix; no luck. I get no battery depletion warnings whatsoever.
Model: Audi A4, B8, 2.0TDI Multitronic - 2008 Engine Code CAGA
VCDS read out as follows:
Items in Address 19 are my concern.
These faults return immediately despite clearing them.
So far I have checked all the LIN BUS wiring from J533 to J367 and from J533 to alternator/generator. Continuity is ok on those lines. I'm using the proper wiring diagrams for the vehicle.
After starting and just idling I get only 12.5 volt at the generator directly. As soon as I increase RPM a bit and then let it idle again, the alternator puts out 14.3 (even at idle then).
Can anyone shed some light please.
Now my issue:
Sunday,08,April,2018,10:55:45:44872
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8K38A041877 License Plate:
Mileage: 132070km-82064mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8K38A041877 Mileage: 132070km-82064miles
Address 01: Engine (J623-CAGA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 022 BE HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3292
Revision: --H01---
Coding: 0104000202072120
ASAM Dataset: EV_ECM20TDI03L906022BE A01007
ROD: EV_ECM20TDI03L906022BE.rod
VCID: 69DF047688D6AA0CAF-803C
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [047] - -
Mileage: 132076 km
Date: 2018.04.07
Time: 14:18:05
Engine speed: 848.50 /min
Normed load value: 34.1 %
Coolant temperature: 80 °C
Intake air temperature: 31 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 13.680 V
Crankshaft speed (RPM): 848.5 /min
Vehicle speed: 0.00 km/h
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 13680 mV
Coolant temperature: 80.4 °C
Generator power: 308822 W
Engine torque: 47.0 Nm
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K0 927 155 B HW: 0AW 927 156 E
Component: 0AW 20TDI RdW H05 0004
Revision: --H05--- Serial number: 0000000147
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A01014
ROD: EV_TCMVL381_A01.rod
VCID: 326DA31A658029D4DE-8066
Part No SW: 8K0 907 379 T HW: 8K0 907 379 T
Component: ESP8 front H03 0210
Coding: 170500
VCID: 4A9DDBFAE510411486-801E
Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
Component: BCM2 1.1 H71 0134
Coding: 011100
VCID: 7AFD4B3AF570119456-802E
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000013202017
Component: ELVAUDIB8 H35 0039
Serial number: 0208000013117004
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 K HW: 8T2 820 043 K
Component: KLIMA 1 ZONE H05 0120
Revision: B0000000 Serial number: 0104.04.080243
Coding: 34040000
VCID: 3A7D8B3AB5F0D19416-806E
Reset counter: 147
Mileage: 132076 km
Date: 2018.04.07
Time: 14:17:05
Part No SW: 8K0 907 063 A HW: 8K0 907 063 A
Component: BCM1 1.0 H21 0253
Revision: 02021001 Serial number: 00000000115979
Coding: 6900C0B10014A7000001000000005F5F0F1D420800000101000000
VCID: 2D57B06674BE762C83-8078
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 070408 H05 0060
Serial number: SWFBIE 0000247
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10094483
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 C HW: 8K0 941 531 C
Component: E1 - LDS H07 0070
Serial number: 00000000000204080097
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD14C44P
Coding: 30363434363030303030554A3052384B3053
VCID: 3C718D22B7C4EFA404-8068
Serial number: 6334MSME26542C5BK
Serial number: 6344MSME3B732C38N
Serial number: 6352QSME59130C4DO
Serial number: 6362QSME5D4D2F07.
Serial number: 63732SME5E2235490
Serial number: 63832SME5A562E39B
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HD8000B8
Coding: 000036
VCID: 3D778026A4DEE6AC33-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 900 C HW: 8K0 920 900 C
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7VL26N748
Coding: 2306080002000008010001
Shop #: WSC 06325 123 12345
VCID: 2A5DBB7A4550611466-807E
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G083128732
Coding: 000303
VCID: 4685EFCAF108A57462-8012
02071 - Local Databus
Fault Status: 01101100
Reset counter: 107
Mileage: 132076 km
Date: 2018.04.08
Time: 10:48:59
02252 - Generator
Reset counter: 107
Mileage: 132076 km
Date: 2018.04.08
Time: 10:49:59
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 107
Mileage: 132076 km
Date: 2018.04.08
Time: 10:49:59
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007014262
Coding: 011C02204001410001
VCID: 3F8BFA2EAED2F4BC21-806A
Revision: 00002001 Serial number: 0110754432
Coding: 011A062200390000012001
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 107
Mileage: 132076 km
Date: 2018.04.07
Time: 15:44:47
02616 - Fuel Tank Cap; Unlock
Reset counter: 107
Mileage: 132076 km
Date: 2018.04.07
Time: 15:45:01
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007007073
VCID: 3E75872AA9D8FDB42A-806A
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 10000000014659
VCID: 3069A912638C1BC4A8-8064
Address 56: Radio (J503) Labels:. 8Tx-035-152-56.clb
Part No SW: 8T2 035 152 HW: 8T2 035 152
Component: Chorus3 H19 0020
Revision: 00000001 Serial number: AUZ1Z2H6188624
Coding: 00000480040108000159070000
VCID: 6ED5776AB9384D34FA-803A
Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603
Component: Display H09 X017
Serial number: AUZ1Z2H5087243
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007004945
Coding: 010C02204001210001
VCID: 7F0BBA2EEE5234BC61-802A
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007010242
VCID: 7EF5472AE9583DB46A-802A
End-------------------------(Elapsed Time: 02:51)--------------------------
