J533 J367 and Generator problem Audi A4, B8, 2.0TDI Multitronic - 2008 Engine CAGA
iamdieter
New Member
South Africa
hex1cef-01da18-d1af48-b2f469-tqhahh-5fb1
Thank you for the forum and the VCDS product. I purchased the original USB cable years ago and it serves me well, how do I become a approved member here?
Now my issue:
Battery does not charge properly, leading to battery depletion over time, i.e. vehicle will not start. Battery is brand new (Varta OEM), same behavior with the older battery. I replaced the battery as it was 6 years old anyway, and was hoping for an easy fix; no luck. I get no battery depletion warnings whatsoever.
Model: Audi A4, B8, 2.0TDI Multitronic - 2008 Engine Code CAGA
VCDS read out as follows:
Sunday,08,April,2018,10:55:45:44872
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8K38A041877   License Plate:
Mileage: 132070km-82064mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8K38A041877   Mileage: 132070km-82064miles
Address 01: Engine (J623-CAGA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 BE    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3292
   Revision: --H01---
   Coding: 0104000202072120
   ASAM Dataset: EV_ECM20TDI03L906022BE A01007
   ROD: EV_ECM20TDI03L906022BE.rod
   VCID: 69DF047688D6AA0CAF-803C
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [047] - -
                    Mileage: 132076 km
                    Date: 2018.04.07
                    Time: 14:18:05
                    Engine speed: 848.50 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 13.680 V
                    Crankshaft speed (RPM): 848.5 /min
                    Vehicle speed: 0.00 km/h
                    Accelerator position: 0.00 %
                    Vehicle voltage terminal 30: 13680 mV
                    Coolant temperature: 80.4 °C
                    Generator power: 308822 W
                    Engine torque: 47.0 Nm
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 B    HW: 0AW 927 156 E
   Component: 0AW 20TDI RdW H05 0004
   Revision: --H05---    Serial number: 0000000147
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A01014
   ROD: EV_TCMVL381_A01.rod
   VCID: 326DA31A658029D4DE-8066
   Part No SW: 8K0 907 379 T    HW: 8K0 907 379 T
   Component: ESP8 front    H03 0210
   Coding: 170500
   VCID: 4A9DDBFAE510411486-801E
   Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
   Component: BCM2 1.1      H71 0134
   Coding: 011100
   VCID: 7AFD4B3AF570119456-802E
   Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
   Serial number: 0508000013202017
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000013117004
   Part No SW: 8T2 820 043 K    HW: 8T2 820 043 K
   Component: KLIMA 1 ZONE  H05 0120
   Revision: B0000000    Serial number: 0104.04.080243
   Coding: 34040000
   VCID: 3A7D8B3AB5F0D19416-806E
                    Reset counter: 147
                    Mileage: 132076 km
                    Date: 2018.04.07
                    Time: 14:17:05
   Part No SW: 8K0 907 063 A    HW: 8K0 907 063 A
   Component: BCM1 1.0      H21 0253
   Revision: 02021001    Serial number: 00000000115979
   Coding: 6900C0B10014A7000001000000005F5F0F1D420800000101000000
   VCID: 2D57B06674BE762C83-8078
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 070408  H05 0060
   Serial number: SWFBIE 0000247
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10094483
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 C    HW: 8K0 941 531 C
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000204080097
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD14C44P
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C718D22B7C4EFA404-8068
   Serial number: 6334MSME26542C5BK
   Serial number: 6344MSME3B732C38N
   Serial number: 6352QSME59130C4DO
   Serial number: 6362QSME5D4D2F07.
   Serial number: 63732SME5E2235490
   Serial number: 63832SME5A562E39B
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HD8000B8
   Coding: 000036
   VCID: 3D778026A4DEE6AC33-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
   Component: KOMBIINSTR.   H15 0221
   Revision: 00000000    Serial number: 7VL26N748
   Coding: 2306080002000008010001
   Shop #: WSC 06325 123 12345
   VCID: 2A5DBB7A4550611466-807E
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G083128732
   Coding: 000303
   VCID: 4685EFCAF108A57462-8012
02071 - Local Databus
                    Reset counter: 107
                    Mileage: 132076 km
                    Date: 2018.04.08
                    Time: 10:48:59
02252 - Generator
                    Reset counter: 107
                    Mileage: 132076 km
                    Date: 2018.04.08
                    Time: 10:49:59
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 107
                    Mileage: 132076 km
                    Date: 2018.04.08
                    Time: 10:49:59
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007014262
   Coding: 011C02204001410001
   VCID: 3F8BFA2EAED2F4BC21-806A
   Revision: 00002001    Serial number: 0110754432
   Coding: 011A062200390000012001
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 107
                    Mileage: 132076 km
                    Date: 2018.04.07
                    Time: 15:44:47
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 107
                    Mileage: 132076 km
                    Date: 2018.04.07
                    Time: 15:45:01
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007007073
   VCID: 3E75872AA9D8FDB42A-806A
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 10000000014659
   VCID: 3069A912638C1BC4A8-8064
Address 56: Radio (J503)       Labels:. 8Tx-035-152-56.clb
   Part No SW: 8T2 035 152     HW: 8T2 035 152
   Component: Chorus3       H19 0020
   Revision: 00000001    Serial number: AUZ1Z2H6188624
   Coding: 00000480040108000159070000
   VCID: 6ED5776AB9384D34FA-803A
   Subsystem 1 - Part No SW: 8T0 919 603     HW: 8T0 919 603
   Component: Display  H09 X017
   Serial number: AUZ1Z2H5087243
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007004945
   Coding: 010C02204001210001
   VCID: 7F0BBA2EEE5234BC61-802A
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007010242
   VCID: 7EF5472AE9583DB46A-802A
End-------------------------(Elapsed Time: 02:51)--------------------------
Items in Address 19 are my concern.
These faults return immediately despite clearing them.
So far I have checked all the LIN BUS wiring from J533 to J367 and from J533 to alternator/generator. Continuity is ok on those lines. I'm using the proper wiring diagrams for the vehicle.
After starting and just idling I get only 12.5 volt at the generator directly. As soon as I increase RPM a bit and then let it idle again, the alternator puts out 14.3 (even at idle then).
Can anyone shed some light please. :thanks:
Welcome to our forum. Thanks for posting a detailed problem description and an Auto-Scan.
Please see: How to Get Verified. You are in Category 2 there, and it looks like you are using an "older interface" so you'll need to fill out the web-based product registration form.
Well, if the wiring checks out, it's possible that one of the modules connected to that LIN bus is NFG and causing the "Electrical Fault in Circuit" that the Gateway is reporting.
Mika_M
C?ID=183725
My guess is broken voltage regulator in generator. Try removing LIN bus wire from generator and see if J533 starts to communicate with J367. Communication status should be seen in CAN gateway MVB 006.
J533 - J367 - Generator all share the same LIN bus and one broken device can pull down the whole bus.
Also, if the problem is at the generator as I suspect, don't go for cheapest chinese aftermarket voltage regulator, they are useless...
iamdieter
New Member
South Africa
Thank you Uwe, I will follow the verification process.
Assume it's one of the components, just cannot gamble and replace on suspicion only. Need a way to diagnose further.
iamdieter
New Member
South Africa
Thank you Mika_M.
Interestingly, via ODIS (I know this is VCDS forum LOL), if I unplug the generator LIN wire, then ODIS recognizes the generator as present, and even tries to run the generator diagnostics (but fails). I need to try unplugging the LIN BUS from the generator again and see what VCDS says then, have not tried that with VCDS. If I don;t get wiser, then perhaps replacing the voltage regulator is the best way forward.
It seems strange to me that one component can pull the everything on that LIN BUS down, but thank you for confirming that this is indeed possible. Hope/pray the faulty component is not the Gateway.
iamdieter
New Member
South Africa
Update on this. If I remove the LIN wire from the generator, then indeed via VCDS the battery regulator and the gateway are happy again.
Based on this I decided to replace the voltage regulator (what a nightmare to find the right part within the hundreds of variations Valeo has). I'm not even convinced I have the right part as the part numbers embedded on the regulator don't match, but apparently this supersedes the one I had... It fits perfectly. Are there variations in LIN communication protocols, i.e. incompatibilities?
Bottom line, even with the new voltage regulator, I still get: 02252 - Generator 004 - No Signal/Communication. The other errors are gone though. Valeo part numbers must be the biggest mess produced by mankind.
Mika_M
C?ID=183725
As I tried to suggest in my previous post, best thing would have been to go visit local Audi dealer and buy a new regulator from them... I bet it will cost more, but it will also be the right part for your car.
alesypalsy
New Member
HC843859 (2nd hand?)
code 02252 generator, 004 no signal/communication intermittent
Hi , I have just scanned my mk6 2010 1.6 tdi tech golf and had this code come up, I wonder if you may tell me where the wires/part you are talking of are exactly? maybe picture if you could as I have no idea and it sounds technical , one thing I have been noticing is that the start stop is not working as much as it was a few months ago,, the car went in garage for new dual mass fly wheel, the start stop was working fine for a around a week afterwards but has since been hardly cutting in, would this be related?
what and where is the generator located please? any idea how I look to find this fault physically
thanks
alesypalsy
New Member
Great , what a helpful bunch
PetrolDave
Westbury, UK
C?ID=1423
thanks
We'll need to see a full Auto-Scan to be able to help you.
BTW for the wiring diagrams you'll need to logon to ErWin, as they are copyright and cannot be posted here.
If the generator is faulty then the start/stop won't work properly as the battery won't be charged enough for the battery management system to think there is enough battery capacity to safely restart the car.
Mr...
C?ID=306962
Hi everyone
Here is my auto-scan:
Monday,14,May,2018,20:19:17:34336
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZ7NZCV034539 License Plate:
Mileage: 119030km-73961mi Repair Order:
Gateway Installation List: 7N0 907 530 N
My problem is very similar, long short story.
Two years ago I brought sharan 2.0tdi 2012, after about one year alternator not charging - replace regulator from vw dealer- problem solved, but in May this year battery blows up. Replace battery ( Varta E39) and coded as new , now not charging again.
Take out alternator and tested, all ok.
Problem is that when engine start, alternator is charging ( 13.8-14.2) but after some driving going to 12.5-12.0
any ideas?
Thanks in advance
PetrolDave
Westbury, UK
C?ID=1423
Once the battery is fully charged, the alternator will stop charging (to avoid gassing due to over charging) so those voltages don't seem too far out to me?
Did you recode the 61 module when the battery was changed? If that wasn't done it will still think you have the old (knackered?) battery fitted.
What isn't working on your Sharan? Does it start reliably?
Mr...
C?ID=306962
Thank for quick reply PetrolDave
Yes, I did recoded module 61, battery keep 12.5 V over night and start with no issues, only my worry is about drooping charging current to 12 V, is that ok ?
Mr...
C?ID=306962
I'll check for fault codes latter today
Mr...
C?ID=306962
Properly coded battery
Hello everyone
I just been very curious about this coding using VCDS :popcorn::confused:, in my opinion Ross-Tech should update their database to properly code battery for European users (no offense).
After long searching I found this : https://batteryworld.varta-automotive.com/en-be/car-battery-replacement , maybe some people do not take seriously coding the battery, for me is just the battery as well, but battery Serial Number is ETN number :) , maybe I'm wrong but this what I receive from Vatra :
"Dear Customer,
Thank you for contacting the Customer Service Office.
In order to code the battery properly, enter the sequence of 10 digits - 9 digits from the ETN number preceded by the number 0. Battery Serial Number.
The second number of Battery Part Number should be written down from the code, which is stamped (dotted) on the battery, the first 10-11 digits / letters (characters) as much as you will need this introduction."
I guess the second number is on the bottom flange of the battery.
The BEM codes are different to this codes!!!!
No wonder why faults code appear and battery is dying.!
Regards
MR...:thanks:
How about you show us what fault codes you have? All you've posted so far is a Gateway Installation List, which doesn't tell us much.
iamdieter
New Member
South Africa
Final update on this thread. I managed to solve the entire problem by replacing with the EXACT CORRECT voltage regulator on the alternator/generator. There are many different versions of the Valeo part, make sure you get the exact replacement.
