I'm looking for help with my 06 Jetta TDI 5 speed manual. I have been having problems with boost after accelerating in fifth gear I will feel a loss of power and immediately after this I have hard times accelerating. After I slow down or stop and then I try to go again it will take a very long time to gain speed. I have looked at the EGR and intake manifold before and cleaned out most of the residue build up in the EGR but didn't really wanna deal with the hassle of removing the manifold. There have been no upgrades to this vehicle so far and I just need help finding the issue. The only thing that resets this issue is turning off the vehicle and then turning it back on. I have attached the complete auto scan below. Please help.
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65 72
7D
VIN: 3VWCT71KX6M853862 Mileage: 184560km-114680miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H06--- Serial number: VWZ7Z0F9026232
Coding: 0050071
Shop #: WSC 09215 444 92444
VCID: 63865D04A232D25C65-8036
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Fault Status: 00110000
Mileage: 183600 km
Time: 18:42:34
RPM: 2268 /min
Speed: 105.0 km/h
Load: 88.2 %
Voltage: 14.29 V
Bin. Bits: 00001000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 1581.0 mbar
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73A62D4412D242DC15-8026
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BB605643A820A9C4D-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000524383
Coding: 14018E234004150007140000001400000028770B5C0000
VCID: 6C9436384FEC9D24D4-8038
Component: Wischer 071206 020 0501
Coding: 00065535
Shop #: WSC 00066
Reset counter: 131
Mileage: 183658 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.60 V
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F0026124
VCID: 2A18F0208598431466-807E
Reset counter: 31
Mileage: 180186 km
Time: 05:59:10
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M00EH6-
Coding: 0013889
Subsystem 2 - Serial number: 6332MSME13181B703
Subsystem 3 - Serial number: 6342MSME146A6D3BQ
Subsystem 4 - Serial number: 6351HSME0B6506364
Subsystem 5 - Serial number: 6361HSME0B4C1A4AK
Subsystem 6 - Serial number: 63727SME0B35714A1
Subsystem 7 - Serial number: 63827SME0B354C589
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002021
VCID: 014A778C586E604C17-8054
Component: E0221 002 0010
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F9026232
Coding: 0023203
VCID: 2E10FC30B9702F34BA-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106A101790
Coding: 3DBF0B620F001002
VCID: 2C14F6388F6C5D2494-8078
Reset counter: 131
Mileage: 183658 km
Time: 14:07:52
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T2GEF04
Coding: 0000003
VCID: 393ADF6C703EF88C1F-806C
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 32008001 Serial number: 00000543069202
Coding: 0001205
VCID: 3B36C5647A02CA9C0D-806E
Fault Status: 00111000
Reset counter: 146
Mileage: 184325 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Fault Frequency: 94
Reset counter: 152
Mileage: 170320 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3424EE58575C05E4CC-8060
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
VCID: 04447E98477C75643C-8050
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000105801
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1519
Revision: 71009005 Serial number: 00000766888901
Coding: 0041204
Shop #: WSC 12336 024 394758
VCID: 72A828406DC84BD41E-8026
Fault Status: 01100101
Reset counter: 112
Mileage: 73448 km
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Fault Status: 00101100
Reset counter: 152
00121 - Outside Warning Light/Door exit Light Passenger Side
Reset counter: 152
Mileage: 170681 km
Reset counter: 152
Mileage: 184302 km
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio ZSW 017 0023
Revision: 00017000 Serial number: VWZ5Z7F6047148
Coding: 0010011
VCID: 24041E18E7BC95645C-8070
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12005001 Serial number: 00000000758822
Coding: 0001168
VCID: 3E30CC706910DFB42A-806A
Component: RDK 0440
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 01111000
Reset counter: 58
Mileage: 179825 km
Time: 14:27:28
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000005113264
Coding: 0001168
VCID: 77BE195406AA2EFC29-8022
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D12FB3CB476542C83-8078
End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
