Translation to VCDS?
troystg
C?ID=159051
Hi All,
Car: 2008 VW Passat 3.6L wagon 4motion w/ 140K miles.
I purchased a trailer hitch from Germany and had it shipped to the US.
I installed the hardware and then came back and installed the electronics.
The trailer hitch works great (day use only where car lights are visible over the load) however I have not been successful in getting the ECU programmed to operate the lights.
This is the directions in the manual and even though they say "GB" I still can't seem to figure out what the steps are.
I can't add the scanned image of the document here at work so I will try to do it tonight from home along with the auto-scan.
Any help on the correct procedure would be appreciated.
Thank you in advance,
Troy
troystg
C?ID=159051
- This Ross-Tech wiki page may be helpful...
Trailer Hitch Retrofitting (3C)
Hope this helps,
drpeter
I did see that but not being a VCDS ninja I have no idea how you "update" a module.
Attached is the scanned page of the procedure from the product manufacturer.
QVgZn80C7Y5RAiWm1
Here is the URL if the pic doesn't make it:
https://photos.app.goo.gl/QVgZn80C7Y5RAiWm1
Please post an Auto-Scan from your car so people can see how it is equipped and how the various modules are currently coded.
The instructions state things like: "Update such-and-such a module's coding".
The coding function is is described here in the VCDS manual.
troystg
C?ID=159051
Last scan I have:
Sunday,25,February,2018,14:38:09:48198
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 18.2.0.3 (x64)
VIN: WVWRU73C68E103691   License Plate:
Mileage: 225350km-140025mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 47 52 53
          55 56 62 65 69 6D 72 76
VIN: WVWRU73C68E103691   Mileage: 225350km-140025miles
Address 01: Engine (BLV)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 BR    HW: 03H 906 032 AB
   Component: P3.6-FSI-LEV2   G   1411
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 00000
   VCID: 73EFF16712096EDC15-8027
               P0300 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Mileage: 225209 km
                    Date: 2018.02.24
                    Time: 13:55:11
                    RPM: 2055 /min
                    Load: 20.4 %
                    Temperature: 84.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.716 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - Intermittent
                    Mileage: 225209 km
                    Date: 2018.02.24
                    Time: 13:55:11
                    RPM: 2055 /min
                    Load: 20.4 %
                    Temperature: 84.0°C
                    Temperature: 56.0°C
                    Voltage: 13.716 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - Intermittent
                    Mileage: 225209 km
                    Date: 2018.02.24
                    Time: 13:55:11
                    RPM: 2055 /min
                    Load: 20.4 %
                    Temperature: 84.0°C
                    Temperature: 56.0°C
                    Voltage: 13.716 V
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 HK
   Component: AQ 250 6F           1091
   Revision: 00H69000    Serial number:
   Coding: 0000584
   VCID: 0103ABAF58B54C4C17-8055
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000776394731
   Coding: 0000375
   VCID: 1F47CDD7CE019ABC01-804B
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CJ    HW: 3C0 907 044 CJ
   Component: ClimatronicPQ46 132 0811
   Revision: 00132022    Serial number: 00000000000000
   VCID: 6BDFE9074A39B61CDD-803F
   Revision: 00H54000    Serial number: 01000007691693
   Coding: E78C8F0340041A00470000000F000000002A5D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71E3FB6F68155CCCE7-8025
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 210907 003  0205
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     181007 046  0204
   Coding: 00208933
   Shop #: WSC 05124
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0178357
   VCID: 2E592013B9AB0334BA-807B
                    Fault Frequency: 25
                    Reset counter: 130
                    Mileage: 223809 km
                    Date: 2018.02.07
                    Time: 09:37:32
01304 - Radio
                    Reset counter: 194
                    Mileage: 225353 km
                    Date: 2018.02.25
                    Time: 13:59:25
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 18 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2PMWQ8HH
   Coding: 0012600
   VCID: 31633B6FA8951CCCA7-8065
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003PDRX
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME18070D5DIÿ†63
   Subsystem 5 - Serial number: 70D5DIÿ†6342MSME180716465ÿ†63
   Subsystem 6 - Serial number: 716465ÿ†6351HTS6L4I8D3572ÿ†63
   Subsystem 7 - Serial number: 8D3572ÿ†6361HTS6L4ICQ1L6Xÿ†63
   Subsystem 8 - Serial number: CQ1L6Xÿ†63727TS6L4ICEO56Kÿ†63
   Subsystem 9 - Serial number: CEO56Kÿ†63827TS6LNF4B5H6Jÿ
   Subsystem 10 - Serial number: 4B5H6Jÿ
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AR
   Coding: 0001212
   VCID: 6DDBE71F742DB82CC3-8039
   Part No SW: 3C0 920 971 F    HW: 3C0 920 971 F
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 09016 444 85761
   VCID: 2855D60B9B4F5D0470-807D
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07A220B3A
   Coding: FD83FF4F1213022002
   Shop #: WSC 05311 123 12345
   VCID: 234FC127E269BE5C25-8077
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1339817TQDGC03
   VCID: 55ABAFFFBCBD10EC1B-8001
No Faults Found
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 09144 444 82784
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F673D17BEA10A3CB1-807B
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1131
   Revision: 31008001    Serial number: 00000034479004
   Coding: 0001463
   VCID: 3C7D1A5B7FD7E1A404-8069
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 000    3201
   Revision: 00H20000
   VCID: 346D327B578729E4CC-8061
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13900E80D1032E5210041414F08A8F0E085800
   Shop #: WSC 08379 444 101274
   Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000006408
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1131
   Revision: 31008001    Serial number: 00000058678921
   Coding: 0001462
   VCID: 3D7B175F64CDE8AC33-8069
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000217160
   Coding: 0000057
   VCID: 2953D30F8045640C6F-807D
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 2338817
   VCID: 32613463AD9327D4DE-8067
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
Address 56: Radio
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1119
   Revision: 12006001    Serial number: 00000002449560
   Coding: 0001168
   VCID: 3E79105369CBF3B42A-806B
   Coding: 0100101
   Shop #: WSC 12345 444 12345
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 30653E6B639F15C4A8-8065
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 E
   Component: J605  HECKDECKEL    0600
   Revision: 00H21001
   Shop #: WSC 23250 384 715754
   VCID: 30653E6BA39F15C4A8-8065
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0600
   Subsystem 2 - Serial number: 0700H21001001B0266ÿ
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1119
   Revision: 12006001    Serial number: 00000002435936
   Coding: 0001168
   VCID: 3F876D576EC1FABC21-806B
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
   Component: Parkhilfe 8-Kan 004 0013
   Revision: 00004000    Serial number: 90640728800728
   Coding: 0011124
   Shop #: WSC 05311 000 08193
End-------------------------(Elapsed Time: 04:43)--------------------------
Jef
HQ
Two things come to mind...
  1. Are there LEDs for the trailer lights?
  2. Try coding trailer module to 010D000100000000.
troystg
C?ID=159051
I can't add the pictures here so I emailed them directly.
It appears the trailer module IS working correctly with my voltmeter. However there is an interface issue between the 13 pin Jeager plug and the 5 to 4 wire converter. I ordered a new 13 pin plug( I destroyed the old one opening it) and will buy a new 5 to 4 converter to see if I had a defective converter. The converter looks to be the logical issue now.
PetrolDave
Westbury, UK
C?ID=1423
To post pictures here you must copy them to a hosting site (such as imgur) and then copy & paste the direct link (preferably between IMG tags).
