Cannot Perform SRI on Lamborghini Huracan
SHARDUL
C?ID=248471
Hex-Net controller being used with USB connection
Copy of auto scan
Saturday,10,February,2018,15:18:25:55582
VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
VIN: ZHWUC1ZF7FLA01704   License Plate:
Mileage: 26540km-16491mi   Repair Order:
Chassis Type: ZF-LB72 (4S0)
Scan: 01 02 03 05 08 09 11 31 14 15 16 17 19 1B 22 3B 42 44 46 52
          53 55 56 5F 65 6C C2 D0
VIN: ZHWUC1ZF7FLA01704   Mileage: 26540km-16491miles
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine (------CSJC)       Labels: None
   Part No SW: 4T0 907 552 A    HW: 4T0 907 552 A
   Component: 5.2l V10HDZ / H55 0004
   Revision: NHH55---
   Coding: 1E2500320506000D2000
   Shop #: WSC 47382 001 1048576
   ASAM Dataset: EV_ECM52FSI1114T0907552A 001005
   ROD: EV_ECM52FSI1114T0907552A.rod
   VCID: 3522C3D0949868ED56-8060
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 4T0 927 155 A    HW: 0BH 927 711 D
   Component: 0BZ_52FSI_NAR H09 0813
   Revision: 00H09V01
   ASAM Dataset: EV_TCMDL800041 001009
   ROD: EV_TCMDL800041.rod
   VCID: 3620C4DC899E63F55F-8062
   Part No SW: 4S0 907 379     HW: 4S0 907 379
   Component: ESP PREMIUM   H09 0087
   Coding: 218AC141845183824B00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004041
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 7AB810ECFD064795FB-802E
   Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
   Component: BCM2 2.0      H36 0560
   Coding: 09803006000000000000
   VCID: 70AC32C4A37A0DC545-8024
   Serial number: 3214000145060008
00955 - Key 1
                    Reset counter: 239
                    Mileage: 25495 km
                    Date: 2017.08.05
                    Time: 04:58:15
   Part No SW: 4T0 820 043 A    HW: 4T0 820 043 A
   Component: KLIMA 1 ZONE  H03 0130
   Revision: A1013000    Serial number: 01061120140019
   Coding: 4A02208000
   VCID: 2A18E0AC45263715CB-807E
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00000954903101
   Coding: 00E90090402001303D01C8C300202800001C47C8020602C10000081C0440100000400034010000
   VCID: 76A004DCC11E23F59F-8022
   Subsystem 1 - Part No SW: 4T1 955 113     HW: 955 113
   Component: WWS72x 140803  041 0015
   Serial number:         ????????????
   Coding: 0000F7
   Serial number: 23449666
   Coding: 02005D
   Subsystem 3 - Part No SW: 4T1 941 531 D    HW: 4T1 941 531 D
   Component: LCU  H02 0012
   Serial number: BC288A57000000000001
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 137
                    Mileage: 25063 km
                    Date: 2017.06.12
                    Time: 08:09:44
Address 11: Engine II (-----)       Labels: None
   Revision: NHH55---
   ASAM Dataset: EV_ECM52FSI2114T0907552A 001005
   ROD: EV_ECM52FSI2114T0907552A.rod
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 4S0 907 376 A    HW: 4S0 907 376 A
   Component: DAEMPFUNGS-SG H03 0043
   Serial number:       051114020
   ASAM Dataset: EV_AudiMagneRide 002004
   ROD: EV_AudiMagneRide.rod
   VCID: 383CCAE4838A95854D-806C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001LP5S
   Coding: 303333343033303030364A55304C34543053
   ROD: EV_AirbaAU10BPAAU64X_AU72.rod
   VCID: 3424FED49FE271E561-8060
   Serial number: 6940000Y1400017VPS0L
   Serial number: 3575HRB40532MV3CEHK-
   Serial number: 3585HRB40532MV3CEH4L
   Serial number: 3515JRB404P32020CG8I
   Serial number: 3525JRB405932020C9F4
   Serial number: 3554VRB405J3201SH193
   Serial number: 3564VRB405L3201SL1NO
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4T0 953 513     HW: 4T0 953 513
   Component: Lenks.Modul   H02 0080
   Revision: C0068719    Serial number: 90815NKI0004S
   VCID: 72A838CCAD763FD5B3-8026
   Subsystem 1 - Part No SW: 18G 959 542 B    HW: 18G 959 542 B
   Component: E221__MFL-TAS  H05 0012
   Serial number: 0003498 TAT 20140918
Address 17: Instruments (J285)       Labels:. 4T0-920-xxx-17.clb
   Part No SW: 4T0 920 900 B    HW: 4T0 920 900 B
   Component: KOMBIINSTR.   013 0159
   Revision: AA001001    Serial number: 40400107013MOC
   Coding: 01F80094B3B1C3F0020000
   VCID: 2E10ECBC79CE5B3517-807A
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 250
                    Mileage: 25063 km
                    Date: 2017.06.12
                    Time: 08:12:03
   Part No SW: 4S0 907 468     HW: 4S0 907 468
   Revision: --------    Serial number: 00000001635556
   Coding: 0009071600
   VCID: 79BA0FE0F8004C8DF2-802C
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Component: J367-BDM  H08 0190
   Serial number: 51297K21463371983582
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14323003317011200410
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 050000
   VCID: 393ACFE0B0808C8DB2-806C
Address 22: AWD (J492)       Labels: 4T0-907-160.clb
   Part No SW: 4T0 907 160     HW: 4T0 907 160
   Component: 4 Wheel Drive H02 0006
   Revision: 00001002    Serial number: BBKR545
   ASAM Dataset: EV_AllWheelContrBORGLB724 004010
   ROD: EV_AllWheelContrBORGLB724_004.rod
   VCID: 6FAE31B8B644123D5C-803A
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E018YM.
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373EC9D88E949AFD44-8062
   Part No SW: 4T0 959 793 H    HW: 4T0 959 793 H
   Component: TSG FA        H07 0801
   Revision: --------    Serial number: 0000116743510
   Coding: 010C4B025000620100080102
   VCID: 4AD8802CE56617152B-801E
   Part No SW: 4S0 909 144 D    HW: 4S0 909 144 B
   Component: EPS           H12 0901
   Revision: 00000000    Serial number:      L00061902
   Coding: 09
   ASAM Dataset: EV_EPSZFAU72X 001001
   ROD: EV_EPSZFAU72X_001.rod
   Revision: 00002001    Serial number: 0350994060
   Coding: 011E029A18F20081A0B0C800008503470000000000000000000000000000
   Subsystem 1 - Part No: 8J0 951 177
   Component: DWA-Sensor  H03 0030
   Part No SW: 4T0 959 792 H    HW: 4T0 959 792 H
   Component: TSG BF        H07 0801
   Revision: --------    Serial number: 0000126793503
   Coding: 010C4B825000620100080100
   VCID: 49DABF20E0601C0D22-801C
   Part No SW: 4S0 907 801     HW: 8K0 907 801
   Component: EPB-4         H02 0001
   Revision: --------    Serial number: 00000000000250
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70AC32C4AB7A0DC545-8024
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4T0 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0003
   Serial number: 141119-0004-045
   Coding: 72846F6118020200
   ASAM Dataset: EV_AFSLEDHELLALB72X 006131
   ROD: EV_AFSLEDHELLALB72X.rod
   Subsystem 1 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Subsystem 2 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156K60E8115975
   Coding: 020007020100000001
   VCID: 24040E942702E165F1-8070
   Part No SW: 4T0 035 664     HW: 4T0 035 664
   Component: H-BN-NA       H40 0795
   Revision: --------    Serial number: 325K 0E7500717
   Coding: 010200000001A16F0100820600000001FD0000020000000000
   Subsystem 1 - Part No: 4T0 919 859 D
   Component: NAR 2014  0801
   Subsystem 3 - Part No SW: 4T0 919 609 A    HW: 4T0 919 609 A
   Component: E380 BDT LB2  H01 0011
   Serial number: 00000000002217
   Component: CD-Database  5571
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000011490
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A18E0AC4D263715CB-807E
   Part No SW: 4T0 907 441     HW: 5Q0 907 441 A
   Component: LB72x RVC Mid H07 0030
   Coding: 080004010A01000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 71AA37C0A07004CD4A-8024
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4T0 927 109     HW: 4T0 927 109
   Component: DL800 ZSG     H28 0006
   Revision: --H28---    Serial number: 0000000098
   ASAM Dataset: EV_TCMDL800421 001019
   ROD: EV_TCMDL800421_001001.rod
   VCID: 74A43ED4DF6231E5A1-8020
Address D0: Frt Axle Lift
End-----(Elapsed Time: 02:07, VBatt start/end: 12.3V/0.0V. VIgn 0.0V)------
Check your PMs.
SHARDUL
C?ID=248471
Thank you.
SHARDUL
C?ID=248471
Once more question I tired to change the setting in the Instrument cluster to display tire pressure in PSI. The long coding saved but still the cluster displays the tire pressure in Bar.
Well, we'll just run right out and try to duplicate that in our Huracan.
Oh wait. We don't have Huracan (or any other Lambo) to test anything on...
