2006 TDI Jetta Steering angle problem after dead battery
They all read ok when I’m moving. Logically speaking in the output boxes. That red one is screwed up on the graph. The measuring block reads 0. The graph reads moving.
Is the scaling for all four the same? It would be good if you posted a proper screen shot rather than a photo of the screen.
Which color goes with which wheel? I want to make sure I’m looking at the correct sensor.
Do the colors follow the order from left to right same as the measuring block values for g46,47, etc?
Yes, the data boxes in VC-Scope are in the same order as the four fields in the measuring block, so red should be front, left.
rabbitpower
C?ID=310688
I wasn’t aware scaling could be changed per sensor value. I haven’t changed anything from the default it was set at from Ross tech. I guess I thought all 4 sensors shared the same global scaling factor?
I’ll try to get a screen shot of it next time.
By front left, you mean passenger front correct?
Sorry for the confusion I just want to make sure if I’m out sitting in the snow in working on the correct wheel lol.
First order is to check scaling
Second order is to check the bearing/sensor/wire for damage.
Thanks!!
   #23
If you haven't changed it, I would think so to0, but like I said, your picture doesn't show the Y-axis values, so I can't be sure.
No, left/right is defined form the perspective of the car's direction of travel. So that would be the driver's side in a US-model car.
rabbitpower
C?ID=310688
The values are all 250kmh if I remember correctly. One for each color.
As soon as I start scope the red line just takes off, while I’m sitting still.
rabbitpower
C?ID=310688
I checked the scaling and it is the same for all 4 wheels. What should I try next?
   #26
Log it and post actual log data?
rabbitpower
C?ID=310688
**********************LATEST AUTOSCAN:******************
Friday,16,February,2018,19:07:57:45755
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
VIN: 3VWST71KX6M783890   License Plate:
Mileage: 303230km-188418mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: 3VWST71KX6M783890   Mileage: 303230km-188418miles
0F-Digital Radio -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
   Part No SW: 03G 906 016 AC    HW: 028 101 223 9
   Component: R4 1,9L EDC G000DG  7551
   Revision: --H02---    Serial number: VWZ7Z0F3428799
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 64844C78A7E904649C-8030
   Part No SW: 02E 300 043     HW: 02E 927 770 AE
   Component: GSG DSG         070 1126
   Revision: 04507000    Serial number: 00000601121333
   VCID: 51EA95ACC85B81CCC7-8004
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71AA352C681BA1CCE7-8024
01487 - System Function Test
            000 -  -  - Intermittent
            000 -  -
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 699A5D4C40CB590CAF-803C
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000275564
   Coding: 14018E234004150000140000001400000008730B5C
   Shop #: WSC 02415 444 57278
   VCID: 2A18E240854D921466-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 02415
02381 - Windshield Wiper Motor; Overload
                    Fault Status: 00100011
                    Fault Frequency: 171
                    Reset counter: 13
                    Mileage: 303221 km
                    Voltage: 14.20 V
Address 0F: Digital Radio
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 39 AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD04TWK
   Coding: 0013113
   VCID: 393ACD0C70EB298C1F-806C
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0E461277C
   Subsystem 3 - Serial number: 6342MSME0F0334524
   Subsystem 4 - Serial number: 6351HSME0924213F3
   Subsystem 5 - Serial number: 6361HSME09284A5AG
   Subsystem 6 - Serial number: 63727SME08794A053
   Subsystem 7 - Serial number: 63827SME0B161071V
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0010021
   VCID: 78BC08080B61F08420-802C
   Part No: 1K0 920 953 D
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023203
   Shop #: WSC 03083 444 83886
   VCID: 2C14E4588FB98C2494-8078
   Revision:   H10       Serial number: 28001061020206
   Coding: 3F3F0B62071002
   Shop #: WSC 00066 123 12345
00463 - Control Module for Digital Sound Package (J525)
                    Fault Frequency: 42
                    Reset counter: 229
                    Mileage: 303205 km
                    Time: 02:42:53
02649 - Digital Radio Tuner
                    Fault Frequency: 42
                    Reset counter: 229
                    Mileage: 303205 km
                    Time: 02:42:53
   Component: IMMO            3HL 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 3620C63041F5C6F4F2-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3326FF245287D3DCD5-8066
02546 - Steering Limit Stop
                    Mileage: 3200 km
                    Temperature: 11.0°C
                    Voltage: 14.00 V
                    Voltage: 13.80 V
            000 -  -
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   Shop #: WSC 02415 444 66564
   VCID: 74A43C38170994E40C-8020
Address 47: Sound System
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 373ECB3446FF3FFCE9-8062
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio DE2       011 0014
   Revision: 00011000    Serial number: VWZ4Z7E2036123
   Coding: 0040400
   Shop #: WSC 02415 444 84652
   VCID: 200C0068F371584438-8074
02218 - Satellite Radio (R146)
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 312AF52CA89BE1CCA7-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 3228FA20AD9DDAD4DE-8066
   VCID: 2D12E95CB4A3852C83-8078
            014 - Defective
End----------(Elapsed Time: 01:11, VBatt start/end: 14.3V/14.4V)-----------
*********************ABS MEASURING BLOCK STATUS****************
*********************ACTUAL GRAPH OF MEASURING BLOCK 1***********
It never changes. If I turn off the drivers side front [red] the line goes away. As soon as I click on "graph" the horizontal line takes off. The other 3 sensors graph correctly. Changing the scale will shift the red line but will not change its behavior. The live dynamic output of the sensor corresponding to the red line appears to keep up with the other 3 when driving, but the graph and the actual output do not in any way match as far as I can see? Am I doing something wrong?
Again, please do an actual log while driving slowly in a straight line (starting from 0 km/h) and post the raw log data.
Using VC-Scope, the scaling you have seems a bit inappropriate for the purpose at hand. Try -5 as the min and 50 as the max for all four items, or maybe even -2 and 20. We're looking for small differences at low speeds.
