Hey All,
Long time VCDS user but new to the forums. Trying to get verified so that I can post on the MFSW retrofit thread for the E-Golf.
Here is a log from back in September after a few minor mods (seatbelt warning off, windows down with remote, reverse mirror dip) and right after it came back from dealer with JX1 module being replaced at 1800miles
And more recently after attempting to add MFSW (19 CAN GATEWAY edit) and ESC/ASR option mod
Thursday,07,September,2017,19:27:21:56927
VCDS Version: 17.8.0.1
VIN: WVWKP7AUXGW9xxxxx License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
C6
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAGA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 C HW: 0EA 907 309 A
Component: E-Vehicle H23 8344
Revision: WMH23---
Coding: 000D0012000400007000
ASAM Dataset: EV_VCU00XXX0110EA906016C 002006
ROD: EV_VCU00XXX0110EA906016C_002.rod
VCID: 2F6D7CEF76C3133E23-807A
25439 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [032] - -
Mileage: 483 km
Date: 2017.09.05
Time: 13:53:51
Engine speed: 16383.75 /min
Normed load value: 100.0 %
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Voltage terminal 30: 12.627 V
CAN status - engine control module-Bit 0: 64
CAN status - transmission control module-Bit 0: 64
CAN status - brake control module 1-Bit 0: 0
CAN status - brake control module 2-Bit 0: 0
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 62216000000256
Coding: 01FA40A12C2121718580020581CC2980023484A14081943200810058C24203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
VCID: 7CF79BA3F73538A6D6-8028
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0415844148
Coding: 032C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B7558BFB2BBFF9E9F-806E
Part No SW: 5GE 907 044 AG HW: 5GE 907 044 AG
Component: Climatronic H04 1501
Revision: 00001K07
Coding: 0002220020011000040500021211102A
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 0109EA5790D7554E85-8054
Subsystem 3 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LM162503003810000093
H02
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 BK HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061624300090
Coding: 00011866434182E169EC4000001407201800000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 0305E05F8ACB475E97-8056
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160824 043 0551
Serial number: 160902012252
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M09D15H23M40S01
Coding: 00A8DD
204293 - Remote key 1
B1479 54 [008] - Missing Calibration / Basic Setting
Reset counter: 40
Mileage: 23 km
Date: 2017.07.21
Time: 15:24:27
Component: AirbagVW20 010 0830
Serial number: 003GCR05PN3S
Coding: 8CCCFC00002000005000001AC24800000065
VCID: 479D344FFE73AB7E0B-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005ORMTO
Coding: 303230
Subsystem 2 - Part No SW: ----------- HW: 480 000 809 16
Serial number: 3570000000024461FC1H
Subsystem 3 - Part No SW: ----------- HW: 480 000 909 16
Serial number: 35800000000C9A24ED1
Subsystem 4 - Part No SW: ----------- HW: 480 403 008 16
Serial number: 3510002C5215E1E5D120
Subsystem 5 - Part No SW: ----------- HW: 480 403 008 16
Serial number: 3520002C1215E1E2C07/
Subsystem 6 - Part No SW: ----------- HW: 480 402 908 16
Serial number: 355000299215E1E17361
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 403 008 16
Serial number: 3560002C521FBE81619F
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HM HW: 5Q0 953 549 E
Revision: -------- Serial number: 17081608490446
Coding: 0610
VCID: 081FF773B3ED6406C2-805C
Address 17: Instruments (J285) Labels:* None
Part No SW: 5GE 920 855 B HW: 5GE 920 855 B
Component: KOMBI 304 8315
Coding: 0B34181A2380CF05020828001700032000000000
VCID: 408F2F53DB5D9C46CA-8014
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 F HW: 5QE 907 530 A
Component: GW MQB EV 312 3265
Revision: -------- Serial number: 30081610521363
Coding: 0200001706F81000FB001200081D00000001050100030000000300000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 49993277E8675D0E1D-801C
Subsystem 1 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8710051404
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 E HW: 5QE 909 059 B
Component: EBKV H14 0200
Serial number: 085430010498
Coding: 01720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 50AF1F130B3D6CC65A-8004
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861050816135552
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000152986006
Coding: 7900000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 346773839FE530E65E-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 270816EHR02099
Coding: 003013208000040000000000
VCID: 41892A57D057954EC5-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011529152
Coding: 111000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: C102
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 45813E47C47FB96EF9-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 G HW: 5QE 907 080 G
Component: VW370E2615020 H08 2480
Revision: 00H08000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115QE907080G 001022
ROD: EV_DMCM09550115QE907080G.rod
VCID: 4A9B0D7BED61561614-801E
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 070816EH606385
Coding: 003013208C00040000000000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011472308
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02737000FF00000051220001001808009F0105D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D5166E77CCF612E11-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9S2130013
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB_VW37.rod
VCID: 4385205FCA4B875ED7-8016
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 5QE 915 227 M HW: 5QE 915 227 H
Component: K8C H13 0722
Serial number: VWADGIG00T
ASAM Dataset: EV_BECM08820215QE915227M 003016
ROD: EV_BECM08820215QE915227H.rod
VCID: 52AB151B05311ED66C-8006
Address BD: Hi Volt. Batt. Charg. (J966) Labels:* Redir Fail!
Part No SW: 5QE 915 022 L HW: 12E 915 022 C
Component: LMSG H10 1084
Serial number: 01131063250162
Coding: 4A4914040400
ASAM Dataset: EV_HVChargManagVWMQB 002002
ROD: EV_HVChargManagVWMQB_002.rod
Address C0: Act. for Ext. Noise (----) Labels:* None
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN163406850000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007.rod
VCID: 4B95087FE21B4F1E2F-801E
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H52 1560
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:40)--------------------------
Monday,29,January,2018,13:47:24:56927
VCDS Version: 17.8.1.0
C6
Revision: WMH23---
VCID: 2F6D7CEF76C3133E38-807A
Coding: 01FA40A12C2121718580020581CC2980023484A14081943200810058C24703
VCID: 7CF79BA3F73538A6CD-8028
Coding: 032C0C
VCID: 3B7558BFB2BBFF9E84-806E
Revision: 00001K07
Coding: 0002220020011000040500421211102A
VCID: 0109EA5790D7554E9E-8054
H02
VCID: 0305E05F8ACB475E8C-8056
Coding: 064DFD
Coding: 00A8DD
VCID: 479D344FFE73AB7E10-8012
Occupant Detection:
Coding: 303230
Coding: 0610
VCID: 081FF773B3ED6406D9-805C
VCID: 408F2F53DB5D9C46D1-8014
Coding: 0201001706F81000FB001200081D00000001050100030000000300000000
VCID: 49993277E8675D0E06-801C
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2021415131101277AC1B
Coding: 290000
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
VCID: 50AF1F130B3D6CC641-8004
VCID: 346773839FE530E645-8060
VCID: 41892A57D057954EDE-8014
Coding: 111000
Coding: C102
VCID: 45813E47C47FB96EE2-8010
Revision: 00H08000
Shop #: WSC 50518 001 1048576
VCID: 4A9B0D7BED6156160F-801E
Coding: 091000
Coding: 02738000FF00000051220001001808009F0100D40120010002
VCID: 2D5166E77CCF612E0A-8078
VCID: 4385205FCA4B875ECC-8016
VCID: 52AB151B05311ED677-8006
Address BD: Hi Volt. Batt. Charg. (J966) Labels:* None
Part No SW: 5QE 915 022 Q HW: 12E 915 022 C
Component: LMSG H10 1086
VCID: 4FAD1C6F1603733E58-801A
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Coding: 04
VCID: 4B95087FE21B4F1E34-801E
End-------------------------(Elapsed Time: 04:41)--------------------------
