2016 E-Golf SE logs
ultim8gamr
C?ID=270297
Hey All,
Long time VCDS user but new to the forums. Trying to get verified so that I can post on the MFSW retrofit thread for the E-Golf.
Here is a log from back in September after a few minor mods (seatbelt warning off, windows down with remote, reverse mirror dip) and right after it came back from dealer with JX1 module being replaced at 1800miles
Thursday,07,September,2017,19:27:21:56927
VCDS Version: 17.8.0.1
VIN: WVWKP7AUXGW9xxxxx   License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
          C6
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
   Component: E-Vehicle     H23 8344
   Revision: WMH23---
   Coding: 000D0012000400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016C 002006
   ROD: EV_VCU00XXX0110EA906016C_002.rod
   VCID: 2F6D7CEF76C3133E23-807A
25439 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [032] - -
                    Mileage: 483 km
                    Date: 2017.09.05
                    Time: 13:53:51
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Voltage terminal 30: 12.627 V
                    CAN status - engine control module-Bit 0: 64
                    CAN status - transmission control module-Bit 0: 64
                    CAN status - brake control module 1-Bit 0: 0
                    CAN status - brake control module 2-Bit 0: 0
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 62216000000256
   Coding: 01FA40A12C2121718580020581CC2980023484A14081943200810058C24203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 7CF79BA3F73538A6D6-8028
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0415844148
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B7558BFB2BBFF9E9F-806E
   Part No SW: 5GE 907 044 AG    HW: 5GE 907 044 AG
   Component: Climatronic   H04 1501
   Revision: 00001K07
   Coding: 0002220020011000040500021211102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 0109EA5790D7554E85-8054
   Subsystem 3 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LM162503003810000093
   Air quality sensor:
   Air Conditioning Compressor Sub:
H02
   Part No SW: 5Q0 937 085 BK    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061624300090
   Coding: 00011866434182E169EC4000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 0305E05F8ACB475E97-8056
   Component: WWS    160824  043 0551
   Serial number:         160902012252
   Component: RLHS  042 0105
   Serial number: S5Y16M09D15H23M40S01
   Coding: 00A8DD
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Mileage: 23 km
                    Date: 2017.07.21
                    Time: 15:24:27
   Serial number: 003GCR05PN3S
   Coding: 8CCCFC00002000005000001AC24800000065
   VCID: 479D344FFE73AB7E0B-8012
   Occupant Detection:
   Serial number: IBH000000000005ORMTO
   Coding: 303230
   Subsystem 2 - Part No SW: -----------    HW: 480 000 809 16
   Serial number: 3570000000024461FC1H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 909 16
   Serial number: 35800000000C9A24ED1
   Subsystem 4 - Part No SW: -----------    HW: 480 403 008 16
   Serial number: 3510002C5215E1E5D120
   Subsystem 5 - Part No SW: -----------    HW: 480 403 008 16
   Serial number: 3520002C1215E1E2C07/
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 16
   Serial number: 355000299215E1E17361
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 403 008 16
   Serial number: 3560002C521FBE81619F
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HM    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17081608490446
   Coding: 0610
   VCID: 081FF773B3ED6406C2-805C
Address 17: Instruments (J285)       Labels:* None
   Part No SW: 5GE 920 855 B    HW: 5GE 920 855 B
   Component: KOMBI         304 8315
   Coding: 0B34181A2380CF05020828001700032000000000
   VCID: 408F2F53DB5D9C46CA-8014
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3265
   Revision: --------    Serial number: 30081610521363
   Coding: 0200001706F81000FB001200081D00000001050100030000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 49993277E8675D0E1D-801C
   Subsystem 1 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 8710051404
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430010498
   Coding: 01720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 50AF1F130B3D6CC65A-8004
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861050816135552
   Revision: 00000000    Serial number: 16000152986006
   Coding: 7900000000000000
   VCID: 346773839FE530E65E-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 270816EHR02099
   Coding: 003013208000040000000000
   VCID: 41892A57D057954EC5-8014
   Serial number: 00000000000011529152
   Coding: 111000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: C102
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45813E47C47FB96EF9-8010
   Part No SW: 5QE 907 080 G    HW: 5QE 907 080 G
   Component: VW370E2615020 H08 2480
   Revision: 00H08000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080G 001022
   ROD: EV_DMCM09550115QE907080G.rod
   VCID: 4A9B0D7BED61561614-801E
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 070816EH606385
   Coding: 003013208C00040000000000
   Serial number: 00000000000011472308
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02737000FF00000051220001001808009F0105D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D5166E77CCF612E11-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S2130013
   Component: OCULowMQBUS   007 0568
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB_VW37.rod
   VCID: 4385205FCA4B875ED7-8016
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0722
   Serial number: VWADGIG00T
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52AB151B05311ED66C-8006
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* Redir Fail!
   Part No SW: 5QE 915 022 L    HW: 12E 915 022 C
   Component: LMSG          H10 1084
   Serial number: 01131063250162
   Coding: 4A4914040400
   ASAM Dataset: EV_HVChargManagVWMQB 002002
   ROD: EV_HVChargManagVWMQB_002.rod
Address C0: Act. for Ext. Noise (----)       Labels:* None
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN163406850000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4B95087FE21B4F1E2F-801E
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H52 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:40)--------------------------
And more recently after attempting to add MFSW (19 CAN GATEWAY edit) and ESC/ASR option mod
Monday,29,January,2018,13:47:24:56927
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
          C6
   Revision: WMH23---
   VCID: 2F6D7CEF76C3133E38-807A
   Coding: 01FA40A12C2121718580020581CC2980023484A14081943200810058C24703
   VCID: 7CF79BA3F73538A6CD-8028
   Coding: 032C0C
   VCID: 3B7558BFB2BBFF9E84-806E
   Revision: 00001K07
   Coding: 0002220020011000040500421211102A
   VCID: 0109EA5790D7554E9E-8054
   Air quality sensor:
H02
   VCID: 0305E05F8ACB475E8C-8056
   Coding: 064DFD
   Coding: 00A8DD
   VCID: 479D344FFE73AB7E10-8012
   Occupant Detection:
   Coding: 303230
   Coding: 0610
   VCID: 081FF773B3ED6406D9-805C
   VCID: 408F2F53DB5D9C46D1-8014
   Coding: 0201001706F81000FB001200081D00000001050100030000000300000000
   VCID: 49993277E8675D0E06-801C
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2021415131101277AC1B
   Coding: 290000
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   VCID: 50AF1F130B3D6CC641-8004
   VCID: 346773839FE530E645-8060
   VCID: 41892A57D057954EDE-8014
   Coding: 111000
   Coding: C102
   VCID: 45813E47C47FB96EE2-8010
   Revision: 00H08000
   Shop #: WSC 50518 001 1048576
   VCID: 4A9B0D7BED6156160F-801E
   Coding: 091000
   Coding: 02738000FF00000051220001001808009F0100D40120010002
   VCID: 2D5166E77CCF612E0A-8078
   VCID: 4385205FCA4B875ECC-8016
   VCID: 52AB151B05311ED677-8006
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* None
   Part No SW: 5QE 915 022 Q    HW: 12E 915 022 C
   Component: LMSG          H10 1086
   VCID: 4FAD1C6F1603733E58-801A
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Coding: 04
   VCID: 4B95087FE21B4F1E34-801E
End-------------------------(Elapsed Time: 04:41)--------------------------
