Guys my next project is to try to fit the passenger Airbag Deactivation Switch in the glovebox of my polo.
I have the Switch and the dash light and looms but I'm wondering how easy would it be to code this extra feature in?
Has anyone in the UK got this feature from factory in there polo?or would it not matter if its LHD or RHD?
Any help with this would be great.
Here is a full scan of what I’ve got!!!(not the latest scan but will add it tomorrow)
Scott
Friday,06,October,2017,20:23:58:48600
VCDS Version: 17.8.0.1
Dealer/Shop Name: VCDS
Workshop Code: 444 03743 000001
VIN: WVWZZZ6RZFU042052 License Plate: SP15MDO
Mileage: 108345km-67322mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFU042052 Mileage: 108345km-67322miles
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 HW: 04C 907 309 J
Component: R3 1.0l MPI H23 8071
Revision: 31H23000
Coding: 01110052022401080000
Shop #: WSC 34575 001 1048576
ASAM Dataset: EV_ECM10MPI01104C906057 001012
ROD: EV_ECM10MPI_VW26.rod
VCID: 62C0BA9975F26956FC-8036
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08510702140901
Coding: 23DD2485492733C20914106E0053C42492CC90080005C7090C00
Shop #: WSC 03743 444 00001
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
VCID: 6CDCD4A187362F2646-8038
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1408251B-0159
Coding: 200000001000100000
Shop #: WSC 31414 790 50316
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1D3AC9650C0C16AE81-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009458005500
Coding: 03000840425300530BA44080B107038800005B0257010000000000000000
ASAM Dataset: EV_BCMA0 004003
ROD: EV_BCMA0_004_VW26.rod
VCID: 2E581EA971AA9D3628-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 802 CH HW: 6R0 959 801 CF
Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9610
Serial number: KU0KU030011550301321
Coding: 1400A1
Subsystem 2 - Part No SW: 6R0 959 801 CF HW: 6R0 959 802 CH
Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 9610
Serial number: KU0KU003031550625640
Coding: 0400A1
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150640SRX
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000060144761
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU015101442885103
Coding: 1400A0
Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU019091442622788
Coding: 0400A0
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391510504043
Coding: 0031051041
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 3D7A29E5ACCC76AEA1-8068
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag011 001 0330
Revision: -------- Serial number: 003LM004JBD7
Coding: 88C0C000000000005C000000008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 316205D5609482CE35-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009915C41F2101B
Subsystem 2 - Part No SW: ----------- HW: 410 820 808 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00B716376A1930G
Subsystem 3 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A116C1CE473EP
Subsystem 4 - Part No SW: ----------- HW: 442 151 508 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009B16C1CE5E2D+
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0290
Coding: 232D09002180260001083A001000000000000000
VCID: 2240FA9935722956BC-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009458005500
Coding: 030100046F0A640071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65CAA18564DC1E6E19-8030
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 2181614230501676AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61247F40302821697543
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE8M0038
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 336E0FDD9A88B0DE47-8066
Part No SW: 3Q0 035 820 HW: 3Q0 035 820
Component: MU-S-D-ER H11 0140
Serial number: VWZAZ2P4561909
Coding: 02620000BE00000011111201000808001F0100C60120010000
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 66C8A68999DA157610-8032
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H41 1017
Serial number: VWZ8Z9PH000VF3
End-------------------------(Elapsed Time: 03:02)--------------------------
Scott
