Wednesday,24,January,2018,22:35:03:46724
VCDS Version: 17.8.1.0 (x64)
VIN: 3VW217AU2GM033067 License Plate:
Mileage: 18378km-11419mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: 3VW217AU2GM033067 Mileage: 18378km-11419miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F0000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3F8D8226A6CB38BEA8-806A
17178 - Databus
U1123 00 [047] - Received Error Message
Mileage: 18376 km
Date: 2018.01.23
Time: 19:27:45
Coolant temperature: 78 Í
Intake air temperature: 18 Í
Voltage terminal 30: 12.890 V
Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
Drivetrain coordinator: brake fault status-ESP: no error
Drivetrain coordinator: brake fault status-Deceleration controller: Available
Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
Drivetrain coordinator: brake fault status-Bit 1: no error
Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
Drivetrain coordinator: brake fault status: 4
Drivetrain coordinator: brake function status-Parking Brake: not active
Drivetrain coordinator: brake function status-ACC: Not braking
Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
Drivetrain coordinator: brake function status-Driver: Not braking
Drivetrain coordinator: brake function status-Hill descent control: passive
Drivetrain coordinator: brake function status-ASR: no intervention
Drivetrain coordinator: brake function status-MSR: no intervention
Drivetrain coordinator: brake function status-ADS: no intervention
Drivetrain coordinator: brake function status-ABS: no intervention
Drivetrain coordinator: brake function status-EDL: no intervention
Drivetrain coordinator: brake function status-ASP: no intervention
Drivetrain coordinator: brake function status-AWV2: No warning pressure
Drivetrain coordinator: brake function status-Bit 4: no intervention
Drivetrain coordinator: brake function status-Bit 11: not passively cycled
Drivetrain coordinator: brake function status-Bit 12: not passively cycled
Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Readiness: 0010 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW25.rod
VCID: 071D5AC6BE9BB07ED0-8052
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52785000001419
Shop #: WSC 01383 790 50316
VCID: 4B95A6F6E273941E34-801E
8 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 145
Date: 2018.01.23
Time: 19:07:05
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 145
Date: 2018.01.23
Time: 19:07:05
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 145
Date: 2018.01.23
Time: 19:07:05
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 145
Date: 2018.01.23
Time: 19:07:05
0295 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 185
Date: 2018.01.23
Time: 19:07:05
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 185
Mileage: 18376 km
Date: 2018.01.23
Time: 19:27:10
4161 - Coding invalid
U10DA 00 [008] - -
Reset counter: 186
Mileage: 18376 km
Date: 2018.01.24
Time: 21:16:14
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 145
Mileage: 18376 km
Date: 2018.01.23
Time: 19:07:10
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 E HW: 5GM 907 426 E
Component: AC Manuell H03 1801
Revision: 00001K04
Coding: 00020004200100000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004134
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4A9BA3F2ED098D160F-801E
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86581409152197
Coding: 000018464041804149E44000091407001000000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 7AFB3332FD69DD96DF-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150611 043 0581
Serial number: 151031112846
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM02SJYI
VCID: 51A9B49E005FBECE4E-8004
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003JRJO0Y
Coding: 303132
Subsystem 2 - Part No SW: ----------- HW: 480 000 709 15
Serial number: 35700000000DC630461H
Subsystem 3 - Part No SW: ----------- HW: 480 002 008 15
Serial number: 35800000000F324D661N
Subsystem 4 - Part No SW: ----------- HW: 480 400 709 15
Serial number: 35100029F1CB0C2393BD
Subsystem 5 - Part No SW: ----------- HW: 480 400 709 15
Serial number: 3520002A11CB0C2381C%
Subsystem 6 - Part No SW: ----------- HW: 480 402 108 15
Serial number: 35500029B1CF2D83430A
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 108 15
Serial number: 35600029B1CF2D85538M
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151101400456
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB_VW37.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 242 6420
Coding: 0BB4190AA180880902086A001000000000000000
VCID: 24472D4A2F6D7B66D5-8070
16776973 - Databus
Reset counter: 144
Mileage: 18376 km
Date: 2018.01.23
Time: 18:55:25
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2223
Revision: -------- Serial number: 08091510800285
Coding: 0101000830085900FB0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti_013_VW37.rod
VCID: 74E71D0ADF0DABE685-8020
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29160003393410066495
Coding: 30FFFF
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 111015060501I5
Coding: 003003200000040000000000
VCID: 418984DED03F4E4EDE-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002070368
Coding: 011000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0102
ROD: EV_SteerAssisMQB.rod
VCID: 44878DCACF2D5B66F5-8010
19204 - Databus
Reset counter: 146
Mileage: 18376 km
Date: 2018.01.23
Time: 19:04:17
Motor status: 02
System status: Driving mode
Supply voltage: 14.75 V
Temperature: 5.0 Í
KFC: 4B
KFA: 00 04
Environmental conditions: 7F
uioUdNotFilt_xdu16: 14.88 V
uAdSensI_SwitchedKl30_xdu16: 14.88 V
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 05101506050704
VCID: 408F81DADB354746D1-8014
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002108099
Coding: 091000
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 186
Mileage: 18376 km
Date: 2018.01.23
Time: 18:55:25
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730000FF00000051220001001828001F0100D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CD7056A873D73265D-8038
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9TJW01ZXG
B201A 00 [009] - -
Reset counter: 145
Mileage: 18376 km
Date: 2018.01.23
Time: 19:08:58
Voltage terminal 30: 14.8 V
Status_Software_Version_Management-module_name: C
B11CF 53 [009] - Deactivated
Reset counter: 145
Mileage: 18376 km
Date: 2018.01.23
Time: 19:09:57
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 133 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 145
Mileage: 18376 km
Date: 2018.01.23
Time: 19:09:01
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 145
Mileage: 18376 km
Date: 2018.01.23
Time: 19:09:01
End-------------------------(Elapsed Time: 03:15)--------------------------
About the car... stock 2016 Golf Trendline with the exception of HVAC controls and Display screen which came from a 2017 Golf. The car interior was vandalized so I replaced the dash and seats. I disconnected the battery as I was disconnecting/connecting airbags and when I finally got it all back together, I realized that ABS/traction control lights were all flashing. (Might have been flashing before, but I didn't really run the car until I fixed up the interior)
Auto-Scan revealed that the ABS module is not coded. I looked around the "stock auto-scan section" and found a couple which seemed to match my module. The problem is that I get "Request out of range" error. I've changed the ident setting (WSC,importer, equipt number) from zeros to numbers that match the module infobut it, but I still get the error.
Here are two codings that I tried:
Revision: 00000000 Serial number: 52345000001819
Coding: 01FA6AA124220975007E020681C9298056249000408194B400430050C002
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: CBD96461627C201B5E-809E
Revision: 00000000 Serial number: 52345000002434
Coding: 01FA6BA134220974007B020181C42980D62C9000408194B400430050C009
Any help will be much appreciated!
