Looking for a way to disable ACT system on Golf VII 1.5 Tsi
armin63
New Member
France
C?ID=270135 (NRRT)
I am looking for a way to disable the ACT system (Active Cylinder Technology) with VCDS program on Golf VII 1.5 Tsi 150hp.
Is somebody know how to proceed?
I think that we can manage something with the speed step of activation (in my memory, system is active when speed is > 80kph).
Thank you for your help
Kind regards
armin63
New Member
France
C?ID=270135 (NRRT)
Here the log file
Thursday,04,January,2018,14:41:34:33889
VCDS Version: 16.8.4.2 (x64)
VIN: WVWZZZAUZHW363341   License Plate: ES-910-CL
Mileage: 716km-444mi   Repair Order: N126
Chassis Type  AU (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F A5
VIN: WVWZZZAUZHW363341   Mileage: 716km-444miles
Address 01: Engine (J623-DADA)       Labels: None
   Part No SW: 05E 906 018 A    HW: 05E 907 309
   Component: R4 1.5l TFS   H21 4937
   Revision: 81H21000
   Coding: 0119003223441D0830000000000000000000000000000000
   Shop #: WSC 03630 995 00000
   ASAM Dataset: EV_ECM15TFS01105E906018A 003006
   ROD: N/A
   VCID: 234587312A51995AF4-8076
No ASAM data for: "EV_ECM15TFS01105E906018A" (VW37)
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 50877000003094
   Coding: 01FA6AA12426216F477A060440C42980562484E26002947334205078C0A2430000000012121212B835351919323200
   VCID: 76E38E65C9435CF2E3-8022
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0437372823
   Coding: 032C0C
   VCID: 3B755F51B2E1C19ADC-806E
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 00020004200110011105000000101022
   VCID: 6CD7AC0D870F962205-8038
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001708900175
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EF39645E17314B2BB-802A
   Component: WWS    170304  043 0551
   Serial number:         170318024559
   Component: RLHS  042 0105
   Serial number: S9Y17M04D10H18M29S47
   Coding: 00A8DD
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417617092
   Coding: 0271167041
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 4FAD1B8116594D3A00-801A
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Coding: 2B00604159FFC728949C810560400600000000000000000000
   ROD: N/A
   VCID: 3C775C4DB7EFC6A2D5-8068
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
0836 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 19
                    Reset counter: 55
                    Mileage: 205 km
                    Date: 2017.12.05
                    Time: 15:58:24
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0318
   Serial number: 003TDR2ULH1E
   Coding: 98CCC000000000005C0000CF000800000065
   VCID: 102FD8FDCBE712C259-8044
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30031740957
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31031750250
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35700000000A777D622Q
   Subsystem 4 - Part No SW: -----------    HW: 480 000 604 17
   Serial number: 358000000000A6D4422E
   Subsystem 5 - Part No SW: -----------    HW: 480 403 003 17
   Serial number: 3510001A9257C444273-
   Subsystem 6 - Part No SW: -----------    HW: 480 403 003 17
   Serial number: 3520001AF257C441E39B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 903 17
   Serial number: 3550001A72527B23F844
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02041708490169
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 0919F599A8BD230A9E-805C
   Part No SW: 5G1 920 791     HW: 5G1 920 791
   Component: KOMBI         409 2180
   Coding: 07A401106F8C000801886A0B5401000000000000
   VCID: 69D9D51988FD830A7E-803C
   Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
   Component: GW MQB High   515 5286
   Serial number: 26031710522108
   Coding: 030100047F085700FA000248080F00010001050000000000000000000000
   ROD: N/A
   VCID: 2F6D7B0176992D3A60-807A
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Serial number: 46170000881480077125
   Coding: 2CFFFF
   Serial number: 0926723504
No ASAM data for: "EV_GatewNF" (VW37)
   Revision: 00000000    Serial number: 17000088233010
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3467746D9FBF0EE21D-8060
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0433893078
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   Serial number: 170217EBG02933
   Coding: 003B1320D000048000001000
   VCID: 438527B1CA11B95A94-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000013953868
   Coding: 110000
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 1307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458139A9C425876ABA-8010
   Serial number: 110217EBA21615
   Coding: 003B1120DE00048000801000
   VCID: 428B22B5D50BB0529F-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000014038663
   Coding: 090000
   Part No SW: 3Q0 035 864 B    HW: 3Q0 035 864 B
   Component: MU-S-N-ER     840 0753
   Coding: 02731001FF0000005111000100080A001F0500F4012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 306F787D6BA732C279-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H41 8077
   Serial number: VWZ6ZHT0980133
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 06041712P11594
   Coding: 000307000000040100221354C040A90094000E300040
   ROD: EV_MFKBoschMQBB.rod
1275 - Camera Interference
          C1104 00 [024] -  -
                    Reset counter: 11
                    Mileage: 94 km
                    Date: 2017.11.23
                    Time: 10:34:49
                    Outside air temperature: 18.5 °C
                    Vehicle speed: 43.35 km/h
                    System run time: 77.6 s (second)
                    Voltage terminal 15: 14.5 V
                    mid: 01 62
                    Camera_state: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End-------------------------(Elapsed Time: 04:21)--------------------------
Please update your VCDS. This car is too new for 16.8.4.
armin63
New Member
France
C?ID=270135 (NRRT)
I made the update but nothing more with the new version of the software
You still have "No ASAM data for: EV_ECM15TFS01105E906018A" with t17.8.1 or 17.12.0?
armin63
New Member
France
C?ID=270135 (NRRT)
Hi, sorry for my late answer.
Here the .log with the updated version :
Thursday,25,January,2018,16:08:19:33889
VCDS Version: 17.8.1.0 (x64)
Mileage: 1072km-666mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
VIN: WVWZZZAUZHW363341   Mileage: 1072km-666miles
   Revision: 81H21000
   ROD: EV_ECM15TFS01105E906018A_003_VW37.rod
   VCID: 234587312A51995EAC-8076
   Coding: 01FA6AA12426216F477A060440C42980562484E26002947334205078C004430000000012121212B835351919323200
   VCID: 76E38E65C9435CF6BB-8022
16401 - Tire Pressure Warning
          C102D 00 [137] -  -
                    Reset counter: 23
                    Mileage: 825 km
                    Date: 2018.01.16
                    Time: 15:06:08
   Coding: 032C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B755F51B2E1C19E84-806E
   Revision: 00001K08
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 6CD7AC0D870F96265D-8038
   Air quality sensor:
          B10CD 00 [008] -  -
                    Reset counter: 57
                    Mileage: 716 km
                    Date: 2018.01.05
                    Time: 11:36:52
                    Dynamic environmental data: 02 86
                    Voltage terminal 30: 10.7 V
                    CAN input signal(s) status-Back-up light: OFF
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7EF39645E17314B6E3-802A
   Coding: 00A8DD
   Coding: 0271167041
   VCID: 4FAD1B8116594D3E58-801A
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3C775C4DB7EFC6A68D-8068
0836 - Databus
                    Fault Frequency: 19
                    Reset counter: 55
                    Mileage: 205 km
                    Date: 2017.12.05
                    Time: 15:58:24
                    Dynamic environmental data: 02 8D
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 14.4 V
                    Velocity_vehicle_reference: 2.67 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.74 m/s²
                    Status_ACC_System: ACC_Off_MainSwitch_Off
   VCID: 102FD8FDCBE712C601-8044
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: 0919F599A8BD230EC6-805C
   VCID: 69D9D51988FD830E26-803C
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6D7B0176992D3E38-807A
   Coding: 2CFFFF
   ROD: EV_ELVMarquMQB_004_VW37.rod
   VCID: 3467746D9FBF0EE645-8060
   Coding: 02011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 438527B1CA11B95ECC-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Coding: 110000
   Coding: 1307
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 458139A9C425876EE2-8010
   VCID: 428B22B5D50BB056C7-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Coding: 090000
   VCID: 306F787D6BA732C621-8064
   ROD: EV_MFKBoschMQBB_VW36.rod
          C1104 00 [024] -  -
                    Reset counter: 11
                    Mileage: 94 km
                    Date: 2017.11.23
                    Time: 10:34:49
                    mid: 01 62
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
End-------------------------(Elapsed Time: 04:16)--------------------------
OK, now there's a ROD file.
I don't see anything in there that would allow for a change to the speed at which ACT is active.
armin63
New Member
France
C?ID=270135 (NRRT)
Ok, so do you think that an other way to disable ACT exist?
Can I please ask why you want to disable ACT?
armin63
New Member
France
C?ID=270135 (NRRT)
as I made handling tests (I am test driver for tires), jerking, when ACT system switch off and restart cylinders activity, is very disturbing (yaw acceleration variations).
sannder
New Member
Switzerland
I joined the forum to confirm the armin63 observation on ACT.
While in the city is probably effective, it's a PITA on country roads and highways when the surface is anything but flat.
I'd really use a configuration that could disable the ACT. Any suggestions for a workaround ?
Amarton
Europe - Hungary
C?ID=338434
Is there any news about deactivate 2 cylinder mode?
I hate this function because there is an engine resonance when ACT is working. This rattle noise disturb me.
I really doubt this is possible via the diagnostic API.
If you really want to change this, I suggest you contact a tuner who can adjust the firmware and maps in your ECU.
sam1754
France
C?ID=324989
Yes, I also think it's the only way to disable ACT but in France it's forbidden... in case of big crash, insurer should control firmware version and leave you alone to solve your BIG problem!!! I think it's not normal but it's the FRENCH WAY of life... rules rules rules and more rules!!!
sam1754
France
C?ID=324989
I come bak with good news!
Finally, if there's no power increasing, my insurer is ok with a new firmware. As I'm at the end of VW guarantee, it's time to do it!
I'll go to Shiftech Luxembourg to shut off the COD/ACT technology and make the car smoother. It's expensive but I think is it worth it. :)
sam1754
France
C?ID=324989
YES!
For 490€, SHIFTEC Luxembourg made a very good job. Really serious and the car is really really smooth, it's a great pleasure to find a new car. ACT/COD is not just a shut down system, it make engine really rough when preparing the shut down by fuel feeding regulation. So even when it's not on ACT/COD mode, your engine is not as pleasant as it can be. I haven't noticed any consumption increasing but I'll test it on long highway trip...
sam1754
France
C?ID=324989
After more than 500kms trip, I can consider there's no consumption increasing. 5.5l/100km... whith air conditionner at 22°C (35°C out temp). All is fine!
I replenished the fuel tank to be sure and ODB's consumption is realistic.
sam1754
France
C?ID=324989
Always no consumption increasing after more than 2000kms except in city trafic where ACT shuts down cylinders in low speed cruise... but I don't mind, it's not a city car.
Kifirko
New Member
Helsinki, Finland
Your car with DSG?
It was stage1 or only some ecological remap?
How is your car now, any problem?
sam1754
France
C?ID=324989
Your car with DSG?
No my car isn't DSG but my parents' passat is the same car but sedan with DSG with the same result (CZEA engine).
More than 35000kms after removing ACT. 100% satisfied. Quick response, no consumption increasing, really smooth and quiet.
Not really a remap, no more power or anything else, just always on 4 cylinders like with CZDA engines. It was a bit expensive but honestly, before removing ACT I was looking to sell the car. Now I really love it.
The expert paid by the insurance said "yes, it's not normal, running with 2 cylinder can't be smooth but it's the solution found by VW and you don't like it, VW says it's normal and there's no way to make VWsolve the problem. Make the ECU don't use this technology and it'll be ok for the insurance..."
I sent the bill to my insurance to be sure that they are awared of ECU modification.
Some people are OK with ACT but I tested more than 20 cars from VW and Audi dealers, brand new and used cars, ...all are working with ennoying vibrations, not huge but really annoying. When you buy a petrol engine, you don't want diesel vibrations!
