Golf Mk6 cluster to Golf Mk5!?
prako
Zagreb Cro
C?ID=116509
Is it possible to retrofit Mk6 cluster to Mk5? I know there are diferent protocol... I have idea on my mind, but is it possible? First replace CCM unit with CCM unit from Passat 3C and try to bridge that uses the immo from CCM, pobably gateway must be replaced...? Is that variant posible?
golfi_vend
Tartu, Estonia
C?ID=195131
Spacewalker, your reply is needed here. :)
Anyways it does work, but no Convience or was it comfort menu will appear.
But didn't understand your immo stuff, Passat 3C has Electronic Steering lock, with immobiliser in it, it connects to CCM via serial line - stuff that golf doesn't have.
prako
Zagreb Cro
C?ID=116509
Yes, you're right, I predicted that, but that's just one idea, many have told me that it is not possible to put Mk6 cluster on Mk5....
golfi_vend
Tartu, Estonia
C?ID=195131
It's possible and it has been done many times. There are just setbacks(ie. missing comfort menu)
Spacewalker
Poland
C?ID=159607
Possible
CCM, BCM ect have nothing with Cluster
is only show extra MENU options .
This same like Radio / Satnav.
You can swap cluster w/o CCM remove.
prako
Zagreb Cro
C?ID=116509
Is cluster may be new or can be used?
golfi_vend
Tartu, Estonia
C?ID=195131
Doesn't matter if correct tools are available for immobilizer configuration.
If you send/drive your cluster to Spacewalker in Poland i think he can help you with immo. Also he has had some clusters for sale. If you do go for g6 cluster, maybe a premium one. Looks nicer in my opinion.
cbx750p
Singapore
C?ID=101445
Been there ! Done that ! No need to change any other modules except the cluster itself. You will loose the Convenience Menu though since it is a different protocol.
Don't believe the Ross Tech folks would approve of these mods though.....as this is totally out of what VCDS can do.
Spacewalker
Poland
C?ID=159607
Sorry, but who is blame Ross Tech ?
Ross tech is not a company who recommend DIY project.
All DIY project you are doing on your own.
Lot of people do cluster swap like this, over a 2 years now.
If you will go to VW dealer for online coding , they will reject it , because incompatibile devices .... and you will blame VW too ?
Come one, I am sure you are very gratefull because you can use VCDS.
DIY is always on your own :cool:
golfi_vend
Tartu, Estonia
C?ID=195131
I don't think it's because protocol, as far as i've searched and i understand it's because golf5 has CCM and CECM seperate. Golf6 has BCM with integrated CECM and CCM.
Altough i may be wrong. :)
cbx750p
Singapore
C?ID=101445
You are right !
cbx750p
Singapore
C?ID=101445
Missing Comfort menu can be partly replaced using the POLAR FIS+ Advanced module. Some compromise....
Spacewalker
Poland
C?ID=159607
People dont have money for TFT , so how they can spend extra for PolarFIS ;D
cbx750p
Singapore
C?ID=101445
When mod is concerned....people are known to go to great length to get it done......take a loan, sell the wife/children, rob the bank.... *^*
PS : Good way to start a new family and yet get to drive a great car ! :o
Spacewalker
Poland
C?ID=159607
BTW - how is your immo now ? Disable or Enable ?
cbx750p
Singapore
C?ID=101445
Know of some folks who disable their immo just to replace the cluster. I am not prepared to forego the Anti-Theft system just to get a different cluster. I got mine replaced with two new immo chips from Germany. Tried starting with the old chip.....there was a "Key Not Found" error ! So, mine cluster still have the immo installed but don't understand why they need new chips.
golfi_vend
Tartu, Estonia
C?ID=195131
Red mkv cluster uses id48 can vw chip and white cluster uses regular id48
Spacewalker
Poland
C?ID=159607
..... I got mine replaced with two new immo chips from Germany. .....
I was think you have closer China then Germany . ;)
cbx750p
Singapore
C?ID=101445
You got a reliable contact there ? I heard alot of horror stories. Germans more reliable I would believe .
