Coding problem ABS 5.7 Passat 3B
floflo001
Belgium
C?ID=37501
We replaced the ABs module. The correct login according to the sticker in the boot is 08555 (see attached photo of sticker) The correct coding should be 04255
When we login with 08555 VCDS suddenly takes a long time to do anything(it s stuck) and then says "no response from controller" and throws us out back to the main screen.Then we have to cycle the ignition to get comms again
When we login with the standard 40168 for steering wheel adaptation it doesnt do this. However this obviously not the correct login for coding. Has anybody encountered this before?
We also tried to do this with a different ABS module and we have the same problem. Attached also a full scan.
Thank you for your input,
Floris
Monday,27,November,2017,13:44:29:07138
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: Floris
Workshop Code: 123 12345 034566
VIN: WVWZZZ3BZ5E071732   License Plate:
VIN: WVWZZZ3BZ5E071732   Mileage: 211260km-131270miles
Address 01: Engine        Labels: 038-906-019-AVB.lbl
   Part No: 038 906 019 KC
   Component: 1,9l R4 EDC G000SG  4896
   Coding: 00002
   Shop #: WSC 02763
   VCID: 62C027E5EE545356FC-4B00
   WVWZZZ3BZ5E071732     VWZ7Z0D0681421
16955 - Brake Switch (F)
            P0571 - 35-00 - Implausible Signal
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 00000
   VCID: 254A7CF9BFFAE46ED9-513C
            66-10 - Not Matched - Intermittent
            35-00 -  -
   Part No: 3B1 907 044 K
   Component: CLIMATRONIC B5GP    0010
   Coding: 17000
   Shop #: WSC 05311
   VCID: 295270C9D3E2C00EFD-515A
00603 - Footwell/defroster Flap Positioning Motor (V85)
            35-10 -  -  - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
00532 - Supply Voltage B+
   Part No: 1C0 909 605 B
   Component: 0R AIRBAG VW51 04   0008
   Coding: 12370
   Shop #: WSC 05311
   VCID: 234E62E1B1CE1A5EB7-513C
   Part No: 3B0 920 829 A
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 05115
   VCID: 244C61FDB4C01D66CE-5120
01316 - ABS Control Module
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70E45DAD30B8F1C67A-513C
   Part No: 1C0 959 799 B
   Component: 8S Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 05311
   VCID: 3668ABB5125C9FF660-4B18
   Subsystem 1 - Part No: 1C0959801
   Component: 8S Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959802A
   Component: 8S Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 8S Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 8S Tõrsteuer.HR KLO 0202
7 Faults Found:
01359 - Internal Central Locking Switch; Passenger Side (E198)
End-------------------------(Elapsed Time: 05:20)--------------------------
floflo001
Belgium
C?ID=37501
Hi Uwe,
Thank you for your quick reply! Would you believe me if I said I overlooked this twice. I doublechecked the coding and failed 2 times to spot the mistake....:banghead: Just went to the car and coded everything. Job done in 5 min.
Thanks again for your much appreciated help!
Greeting from Belgium!
Floris
BBoriskg
Serbia
C?ID=372253
paasat b5 3b abs bosch 5.7 coding
hello team I'm new to the forum because someone can help me encode abs vw passat 1.9 tdi 96 kw variant manual transsmision, I don't know what my login and coding is for my car
Saturday,14,December,2019,08:06:35:01603
Dealer/Shop Name: Milosavljevic Boris
VIN: WVWZZZ3BZ4E221308   License Plate:
Mileage: 183510km-114027mi   Repair Order:
PHOTO https://mega.nz/#!YQhVXQjB!hCJrAOlcv-5gnM5m3Fn-fQJZ5DjoqqSfxacdYboUjyQ
VIN: WVWZZZ3BZ4E221308   Mileage: 183510km-114027miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 KE
   Component: 1,9l R4 EDC 0000SG  4898
   Coding: 00005
   Shop #: WSC 05314
   VCID: 6484BB46F65DFC6F23-4B1E
   WVWZZZ3BZ4E221308     VWZ7Z0C8634622
18263 - Powertrain Data Bus
            P1855 - 35-00 - Software Version Monitoring
Readiness: 0 0 0 1 1
   Coding: 00000
   VCID: 2502E642BDE74567F4-51CE
            35-00 - -
   Coding: 17000
   Shop #: WSC 05311
   VCID: 291AEA72D1FF6107D0-5184
   Part No: 1C0 909 605 C
   Component: 0E AIRBAG VW61 04   0003
   Coding: 12357
   Shop #: WSC 05311
   VCID: 2404FB46B6DDBC6FE3-513C
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 05115
   Shop #: WSC 00050
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70ACC71632A550CF57-513C
   Component: 7X Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 05311
   VCID: 3620310E10413EFF4D-4B1E
   Subsystem 1 - Part No: 1C1959801
   Component: 7X Tőrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 7X Tőrsteuer.BF KLO 0202
   Component: 7X Tőrsteuer.HL KLO 0202
   Component: 7X Tőrsteuer.HR KLO 0202
   Part No: 1J0 035 186 E
   Component:  Radio BNO         0006
   Coding: 05401
   Shop #: WSC 05311
   VCID: 271EEC4AC7EB5777C6-4B00
End----(Elapsed Time: 04:29, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
_Val
Latvia
C?ID=356659
Have you ever opened wiki ross tech?
Try 09595 and 04295
BBoriskg
Serbia
C?ID=372253
will not try it myself
BBoriskg
Serbia
C?ID=372253
accept me only coding login 09555, coding04255 but when i exit the abs module and re-enter abs it returns the coding to 00000. Because you have some solution
Did you ever consider installing the correct parts and remove FOD and fix the communication error?
_Val
Latvia
C?ID=356659
Yes, my bad. Didn't notice T9J+1ZC combination
engine 038906019KE (PR-0GZ; match)
abs 4B0614517G => 4B0614517J (PR-1AT; match)
cluster 3B0920829A => 3B0920829AX (for AVB, AVF, AWX; match)
@Jack, I give up. Can't see FOD.
Things are not as they may appear with FOD lurking are they Val?
AIB Wolfgang
"accept me only coding login 09555, coding04255 but when i exit the abs module and re-enter abs it returns the coding to 00000."
Reading the wiki is very helpfull!
After login and coding switch directly to the basic settings for steering angle sensor
