Always ON Auto High Beam Feature
   #21
hadez16
C?ID=289891
Did you use the login 20113 for creating the map? It seems you didn't because there are too few channels.
   #22
cakasky
C?ID=64899
I did, but can certainly do it again. I will post back results.
   #23
cakasky
C?ID=64899
Here they are again:
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect. --- SA: 20113
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0690CCD051751199CAE98B9110B3D080000000000000000200016010A69012B025709
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018.rod
;Monday,13,November,2017,17:24:36:43776
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: 025E83F40485A1118EED-8057
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00957,Resulting distance of front sensors,infinite,
IDE00958,Resulting distance of rear sensors,infinite,
IDE00974,Outside air temperature internally calculated,6.50, �C
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123,Distance of left rear park assist sensor,infinite,
IDE01124,Distance of left rear center park assist sensors,infinite,
IDE01125,Distance of right rear center park assist sensors,infinite,
IDE01126,Distance of right rear park assist sensor,infinite,
IDE01127,Distance sensor for left front park assist,infinite,
IDE01128,Distance sensor for left front center park assist,infinite,
IDE01129,Distance sensor for right front center park assist,infinite,
IDE01130,Distance of right front park assist sensors,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.00, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.00, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.00, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.00, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.00, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.00, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.00, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.00, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 6,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 4,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164-MAS06614,Park assist button-Version,Local data bus: operating unit 1,
IDE01164-MAS07693,Park assist button-Button Status,Not operated,
IDE01164-MAS07694,Park assist button-Button status on CAN,Not operated,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,OFF,
IDE01166,Supply voltage for park assist sensor,12.40, V
IDE01171-IDE01167,Convertible factory setting offset for volume level 1-Convertible offset for volume level 1,not installed,
IDE01172-IDE01168,Factory setting for increment for convertible volume levels-Increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01174,Factory setting: visual display for park assist,OPS display,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,33,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,On,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,not active,
IDE01411-MAS12596,Personalization 1 for park assist-Park brake assistant,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,active,
IDE01412-MAS12596,Personalization 2 for park assist-Park brake assistant,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12596,Personalization 3 for park assist-Park brake assistant,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12596,Personalization 4 for park assist-Park brake assistant,not activated,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,49, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,49, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,45.00, �C
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,45.00, �C
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,45.00, �C
IDE01540-MAS07052,Left front heated seat-Setting,Stage 6,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,3.71, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,45.00, �C
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,45.00, �C
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,Bang-bang control active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,Bang-bang control active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,23.70, �C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,8.64, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.01, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,87 86 74 18,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02486,Data logger triggering,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS08785,Number of requested start processes-Parking aid,0,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,91, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,not coded/not installed,
IDE03111-MAS06987,Interior light-Footwell illumination front,not coded/not installed,
IDE03111-MAS09295,Interior light-ambient light.chan. 1,not coded/not installed,
IDE03111-MAS09297,Interior light-Ambient illumination power supply,100, %
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),5, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),not coded/not installed,
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),not coded/not installed,
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),504, mA
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,320, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,0, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start-stop conditions,Stop release,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,Measured value not available,
IDE03620,Front jounce travel,-5, mm
IDE03621,Rear jounce travel,-15, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,-46.00, mm
IDE03631,Right headlight beam adjusting motor: specified value,-46.00, mm
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.00, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.00, %
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,13.17, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,13.11, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,13.21, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,13.13, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,13.12, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,13.15, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,13.15, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,13.19, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,13.15, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03784,Temporary function limitation due to environmental influences,No,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,17.10, �C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,17.00, �C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,69, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,1.30, �C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,3,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,3,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,not active,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,Not operated,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Not operated,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,On,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,15 FF 36 83,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,25, �C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,0, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,25, �C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,0, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,24, �C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,0, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,27, �C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,0, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,0, %
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,0, %
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,0, %
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,100.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),1545, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,100.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),1502, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light bulb-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light bulb-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light bulb-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,no error,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),42, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,no error,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),30, mA
IDE08402-IDE05742,Light switch-Light switch position,AUTO,
IDE08402-IDE07956,Light switch-redundant signal line,Medium,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,AUTO,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,2.23, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,8.50, �C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Intermittent operation,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,29, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,289, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),291, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,04,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,05 F3 1A,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,00,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 3,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,0F,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,05 F3 36,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,FF,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,Yes,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Channel 3,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01010000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,04,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,05 F3 38,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Channel 3,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,01000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,13.27, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,13.22, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,2.20, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,46.28, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),212, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),236, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),238, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09421-IDE09359,Installation informat multicolor ambient and contour lighting-Drink holder ambient lighting,00000000 ,
IDE09421-IDE09360,Installation informat multicolor ambient and contour lighting-Instrument cluster contour lighting,00000111 ,
IDE09421-IDE09361,Installation informat multicolor ambient and contour lighting-Contour lighting of control unit for multimedia system,00000000 ,
IDE09421-IDE09362,Installation informat multicolor ambient and contour lighting-Center console ambient lighting,00000011 ,
IDE09421-IDE09363,Installation informat multicolor ambient and contour lighting-Roof contour lighting,00000000 ,
IDE09421-IDE09364,Installation informat multicolor ambient and contour lighting-Door contour lighting front left,00000001 ,
IDE09421-IDE09365,Installation informat multicolor ambient and contour lighting-Door contour lighting front right,00000001 ,
IDE09421-IDE09366,Installation informat multicolor ambient and contour lighting-Door contour lighting rear left,00000001 ,
IDE09421-IDE09367,Installation informat multicolor ambient and contour lighting-Door contour lighting rear right,00000001 ,
IDE09421-IDE09368,Installation informat multicolor ambient and contour lighting-Door ambient lighting front left,00000101 ,
IDE09421-IDE09369,Installation informat multicolor ambient and contour lighting-Door ambient lighting front right,00000101 ,
IDE09421-IDE09370,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear left,00000101 ,
IDE09421-IDE09371,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear right,00000101 ,
IDE09421-MAS11066,Installation informat multicolor ambient and contour lighting-Foot well lighting,00001111 ,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not active,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not faulty,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,OK,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,100, %
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not active,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not faulty,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,OK,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not active,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown,
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,48, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,48,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,2,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,48.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,48.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),43, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,43, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,48, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),28, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),38, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,-46.00, mm
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,-46.00, mm
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,12.90, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,25, �C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,110, �C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,255, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,255, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,7, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,Unknown,
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,Unknown,
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,255, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Short circuit to ground,
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,4.51, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.20, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10645,Status of optical display park assist,OFF,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m�
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m�
IDE11979,Parking distance control secure condition: cause,00 00,
IDE12156,Parking aid: system status master module,00000000 00000000 00000000 11111111 ,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,ERROR,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG02613-ENG02881,Activation_counter-Frequency_of_operation_of_climatic_clutch,0,
ENG02613-ENG02876,Activation_counter-Frequency_of_operation_of_heating_lock_valve,150,
ENG02613-ENG02879,Activation_counter-Frequency_of_operation_of_horn,69,
ENG02613-ENG02877,Activation_counter-Frequency_of_operation_PTC_relais_1,0,
ENG02613-ENG02878,Activation_counter-Frequency_of_operation_PTC_relais_2,0,
ENG02613-ENG02880,Activation_counter-Frequency_of_socket_relais,2243,
ENG02613-ENG02875,Activation_counter-Number_of_active_fail_save_flashing,0,
ENG02613-ENG02882,Activation_counter-Number_of_retrais_xenon_left,0,
ENG02613-ENG02883,Activation_counter-Number_of_retrais_xenon_right,0,
ENG02614-MAS00106,Activation_Singalhorn-Year,2000,
ENG02614-MAS00107,Activation_Singalhorn-Month,0,
ENG02614-MAS00108,Activation_Singalhorn-Day,0,
ENG02614-MAS00109,Activation_Singalhorn-Hours,0,
ENG02614-MAS00110,Activation_Singalhorn-Minutes,0,
ENG02614-MAS00111,Activation_Singalhorn-Seconds,0,
ENG02614-ENG28812,Activation_Singalhorn-Event_signal,not active,
ENG08010-ENG101382,actual_abort_reason_APS_PLA-System_state,00 00,
ENG08009-ENG101382,APS_PLA_error_message-System_state,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF,
ENG02625-ENG03043,automatic_static_headlight levelling control-locking_counter_scg_automatic_static_headlight levelling control,0,
ENG02625-ENG03042,automatic_static_headlight levelling control-scg_counter_automatic_static_headlight levelling_control,0,
ENG02609,average_Voltage_terminals,13.10, V
ENG02620-ENG02925,buttons-Voltage_difference_button_0,98, %
ENG02620-ENG02926,buttons-Voltage_difference_button_1,not coded/not installed,
ENG02620-ENG02935,buttons-Voltage_difference_button_10,not coded/not installed,
ENG02620-ENG02936,buttons-Voltage_difference_button_11,not coded/not installed,
ENG02620-ENG02927,buttons-Voltage_difference_button_2,not coded/not installed,
ENG02620-ENG02928,buttons-Voltage_difference_button_3,not coded/not installed,
ENG02620-ENG02929,buttons-Voltage_difference_button_4,not coded/not installed,
ENG02620-ENG02930,buttons-Voltage_difference_button_5,not coded/not installed,
ENG02620-ENG02931,buttons-Voltage_difference_button_6,not coded/not installed,
ENG02620-ENG02932,buttons-Voltage_difference_button_7,not coded/not installed,
ENG02620-ENG02933,buttons-Voltage_difference_button_8,not coded/not installed,
ENG02620-ENG02934,buttons-Voltage_difference_button_9,not coded/not installed,
ENG02623-ENG03033,climatic-locking_counter_magnetic_clutch_for_air_condition_deactivations,0,
ENG02623-ENG03014,climatic-locking_counter_scg_air_conditioner_compressor_regulating_valve,0,
ENG02623-ENG03020,climatic-locking_counter_scg_coolant_circulation_pump,0,
ENG02623-ENG03018,climatic-locking_counter_scg_coolant_shutoff_valve,0,
ENG02623-ENG03024,climatic-locking_counter_scg_high_heat_output_relay,0,
ENG02623-ENG03022,climatic-locking_counter_scg_low_heat_output_relay,0,
ENG02623-ENG03016,climatic-locking_counter_scg_magnetic_clutch_for_air_condition,0,
ENG02623-ENG03026,climatic-locking_counter_scg_seat_backrest_heating_left,0,
ENG02623-ENG03030,climatic-locking_counter_scg_Seat_backrest_heating_right,0,
ENG02623-ENG03028,climatic-locking_counter_scg_seat_cushion_heating_left,0,
ENG02623-ENG03032,climatic-locking_counter_scg_Seat_cushion_heating_right,0,
ENG02623-ENG03013,climatic-scg_counter_air_conditioner_compressor_regulating_valve,0,
ENG02623-ENG03019,climatic-scg_counter_coolant_circulation_pump,0,
ENG02623-ENG03017,climatic-scg_counter_coolant_shutoff_valve,0,
ENG02623-ENG03023,climatic-scg_counter_high_heat_output_relay,0,
ENG02623-ENG03021,climatic-scg_counter_low_heat_output_relay,0,
ENG02623-ENG03015,climatic-scg_counter_magnetic_clutch_for_air_condition,0,
ENG02623-ENG03025,climatic-scg_counter_seat_backrest_heating_left,0,
ENG02623-ENG03029,climatic-scg_counter_seat_backrest_heating_right,0,
ENG02623-ENG03027,climatic-scg_counter_seat_cushion_heating_left,0,
ENG02623-ENG03031,climatic-scg_counter_seat_cushion_heating_right,0,
ENG02626-ENG03045,common-locking_counter_terminal_58xs,0,
ENG02626-ENG03047,common-locking_counter_terminal_58xt,0,
ENG02626-ENG03048,common-scg_counter_power_sockets_supply,0,
ENG02626-ENG03044,common-scg_counter_terminal_58xs,0,
ENG02626-ENG03046,common-scg_counter_terminal_58xt,0,
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,��,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,��,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,��,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,��,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,��,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,��,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,��,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,��,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,��,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,��,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,��,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,��,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,��,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,��,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,��,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,��,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,��,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,��,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,��,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,��,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,��,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,��,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,��,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,��,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,��,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG02663-ENG03526,exception_handling-address_access_violation,757935405, s
ENG02663-ENG03527,exception_handling-address_caller,757935405, s
ENG02663-ENG03528,exception_handling-detail_information,757935405,
ENG02663-ENG03525,exception_handling-exception_type,45,
ENG02621-ENG02950,function_LEDs-locking_counter_scg_LED0,0,
ENG02621-ENG02952,function_LEDs-locking_counter_scg_LED1,0,
ENG02621-ENG02954,function_LEDs-locking_counter_scg_LED2,0,
ENG02621-ENG02956,function_LEDs-locking_counter_scg_LED3,0,
ENG02621-ENG02958,function_LEDs-locking_counter_scg_LED4,0,
ENG02621-ENG02960,function_LEDs-locking_counter_scg_LED5,0,
ENG02621-ENG02962,function_LEDs-locking_counter_scg_LED6,0,
ENG02621-ENG02964,function_LEDs-locking_counter_scg_LED7,0,
ENG02621-ENG02949,function_LEDs-scg_counter_LED0,0,
ENG02621-ENG02951,function_LEDs-scg_counter_LED1,0,
ENG02621-ENG02953,function_LEDs-scg_counter_LED2,0,
ENG02621-ENG02955,function_LEDs-scg_counter_LED3,0,
ENG02621-ENG02957,function_LEDs-scg_counter_LED4,0,
ENG02621-ENG02959,function_LEDs-scg_counter_LED5,0,
ENG02621-ENG02961,function_LEDs-scg_counter_LED6,0,
ENG02621-ENG02963,function_LEDs-scg_counter_LED7,0,
ENG101323,Headlight leveling control state,static,
ENG02610,interior_temperature,27.50, �C
ENG107366,Left headlight leveling motor position,54.00, %
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,94,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,94,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,31,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,47,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,65,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,0, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,63,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG03698-ENG02972,lightning_interior-locking_counter_scg_ambiente_lightning_front,0,
ENG03698-ENG02974,lightning_interior-locking_counter_scg_ambiente_lightning_modul,0,
ENG03698-ENG02970,lightning_interior-locking_counter_scg_footwell_illumination_front,0,
ENG03698-ENG02968,lightning_interior-locking_counter_scg_footwell_illumination_rear,0,
ENG03698-ENG02966,lightning_interior-locking_counter_scg_interior_ligthning,0,
ENG03698-ENG02971,lightning_interior-scg_counter_ambiente_lightning_front,0,
ENG03698-ENG02973,lightning_interior-scg_counter_ambiente_lightning_modul,0,
ENG03698-ENG02969,lightning_interior-scg_counter_footwell_illumination_front,0,
ENG03698-ENG02967,lightning_interior-scg_counter_footwell_illumination_rear,0,
ENG03698-ENG02965,lightning_interior-scg_counter_interior_ligthning,0,
ENG02615-ENG02715,Local_BCM_overrun-Heating_waterpump_motor_cooling_system,not active,
ENG02615-ENG03725,Local_BCM_overrun-Heating_waterpump_park_heating,not active,
ENG02615-ENG03724,Local_BCM_overrun-Heating_waterpump_residual_heat,not active,
ENG02615-ENG03727,Local_BCM_overrun-Inside_light,active,
ENG02615-ENG02622,Local_BCM_overrun-outside_light,not active,
ENG02615-ENG03726,Local_BCM_overrun-Socket_relais,not active,
ENG02619,Operating_temperature,32, �C
ENG02619-ENG02919,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_110,0, s
ENG02619-ENG02923,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_30,146670, s
ENG02619-ENG02922,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_50,0, s
ENG02619-ENG02921,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_70,0, s
ENG02619-ENG02920,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_90,0, s
ENG02619-ENG02924,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_less_30,96039, s
ENG119674-ENG02897,operating_time-Operatin_time_BCM1_on_KL15_is_0_and_CAN_active,42998, s
ENG119674-ENG02898,operating_time-Operatin_time_BCM1_on_KL15_is_0_and_CAN_not_active,29637, s
ENG119674-ENG02896,operating_time-Operatin_time_BCM1_on_KL15_is_1,242760, s
ENG119674-ENG02884,operating_time-Operating_time_counter_horn,70, s
ENG119674-ENG02890,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.4A_and_1.6A,0, s
ENG119674-ENG02891,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.6A_and_1.8A,0, s
ENG119674-ENG02892,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.8A_and_2A,0, s
ENG119674-ENG02893,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_2A_and_2.2A,0, s
ENG119674-ENG02894,operating_time-Operating_time_magnetic_clutch_closed_actual_current_greater_2.2A,0, s
ENG119674-ENG02889,operating_time-Operating_time_magnetic_clutch_closed_actual_current_less_1.4A,0, s
ENG119674-ENG02895,operating_time-Operating_time_magnetic_clutch_open,0, s
ENG119674-ENG02887,operating_time-Operating_time_socket_relais_current_between_10A_and_20A,0, s
ENG119674-ENG02886,operating_time-Operating_time_socket_relais_current_between_3A_and_10A,0, s
ENG119674-ENG02888,operating_time-Operating_time_socket_relais_current_greater_20A,0, s
ENG119674-ENG02885,operating_time-Operating_time_socket_relais_current_less_3A,315443, s
ENG02622-ENG03010,outside_light-locking_counter_scg_daytime_running_light_2_left,0,
ENG02622-ENG03008,outside_light-locking_counter_scg_daytime_running_light_2_right,0,
ENG02622-ENG02986,outside_light-locking_counter_scg_daytime_running_light_left,0,
ENG02622-ENG02984,outside_light-locking_counter_scg_daytime_running_light_right,0,
ENG02622-ENG02994,outside_light-locking_counter_scg_fog_light_left,0,
ENG02622-ENG02992,outside_light-locking_counter_scg_fog_light_right,0,
ENG02622-ENG02982,outside_light-locking_counter_scg_lower_beam_left,0,
ENG02622-ENG02980,outside_light-locking_counter_scg_lower_beam_right,0,
ENG02622-ENG02990,outside_light-locking_counter_scg_main_beam_left,0,
ENG02622-ENG02988,outside_light-locking_counter_scg_main_beam_right,0,
ENG02622-ENG02978,outside_light-locking_counter_scg_side_light_left,0,
ENG02622-ENG02976,outside_light-locking_counter_scg_side_light_right,0,
ENG02622-ENG02998,outside_light-locking_counter_scg_side_marker_front_left,0,
ENG02622-ENG02996,outside_light-locking_counter_scg_side_marker_front_right,0,
ENG02622-ENG03002,outside_light-locking_counter_scg_turn_signal_front_left,0,
ENG02622-ENG03000,outside_light-locking_counter_scg_turn_signal_front_right,0,
ENG02622-ENG03006,outside_light-locking_counter_scg_turn_signal_side_left,0,
ENG02622-ENG03004,outside_light-locking_counter_scg_turn_signal_side_right,0,
ENG02622-ENG03012,outside_light-locking_counter_scg_underfloor_lightning,0,
ENG02622-ENG03009,outside_light-scg_counter_daytime_running_light_2_left,0,
ENG02622-ENG03007,outside_light-scg_counter_daytime_running_light_2_right,0,
ENG02622-ENG02985,outside_light-scg_counter_daytime_running_light_left,0,
ENG02622-ENG02983,outside_light-scg_counter_daytime_running_light_right,0,
ENG02622-ENG02993,outside_light-scg_counter_fog_light_left,0,
ENG02622-ENG02991,outside_light-scg_counter_fog_light_right,0,
ENG02622-ENG02981,outside_light-scg_counter_lower_beam_left,0,
ENG02622-ENG02979,outside_light-scg_counter_lower_beam_right,0,
ENG02622-ENG02989,outside_light-scg_counter_main_beam_left,0,
ENG02622-ENG02987,outside_light-scg_counter_main_beam_right,0,
ENG02622-ENG02977,outside_light-scg_counter_side_light_left,0,
ENG02622-ENG02975,outside_light-scg_counter_side_light_right,0,
ENG02622-ENG02997,outside_light-scg_counter_side_marker_front_left,0,
ENG02622-ENG02995,outside_light-scg_counter_side_marker_front_right,0,
ENG02622-ENG03001,outside_light-scg_counter_turn_signal_front_left,0,
ENG02622-ENG02999,outside_light-scg_counter_turn_signal_front_right,0,
ENG02622-ENG03005,outside_light-scg_counter_turn_signal_side_left,0,
ENG02622-ENG03003,outside_light-scg_counter_turn_signal_side_right,0,
ENG02622-ENG03011,outside_light-scg_counter_underfloor_lightning,0,
ENG02617-ENG02916,overshoot_time-overshoot_time_ECU,00 00 04 01,
ENG02617-ENG02917,overshoot_time-overshoot_time_KCAN,00 00 00 00 00 01 00 01,
ENG02618-ENG02918,overshoot_time_nvm-overshoot_time_KCAN_nvm,00 00 00 00 00 00 00 00,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,0,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,128,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,166,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,6,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,4,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,2,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,20748,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,569,
ENG02664-ENG03529,reason_of_flash_termination-prerequirements_not_complied,0,
ENG108469,Right headlight leveling motor position,54.00, %
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,0,
ENG27122-ENG32023,Setting_seat_ventilation_preconditioning_front-Max_time_of_operation_exceeded,not_exceeded,
ENG27122-ENG33142,Setting_seat_ventilation_preconditioning_front-Time_of_operation,0, min
ENG126436-ENG03041,signal_horn-locking_counter_scg_horn,0,
ENG126436-ENG03040,signal_horn-scg_counter_horn,0,
ENG02616-ENG02912,Subbus_local_active-Status_EVLS,00000000 ,
ENG02616-ENG02915,Subbus_local_active-Status_LDS,00000000 ,
ENG02616-ENG02913,Subbus_local_active-Status_LIM,00000001 ,
ENG02616-ENG02909,Subbus_local_active-Status_pneumatic_system_codriver,00000000 ,
ENG02616-ENG02900,Subbus_local_active-Status_seat_fan_backrest_left_1,00000000 ,
ENG02616-ENG02901,Subbus_local_active-Status_seat_fan_backrest_left_2,00000000 ,
ENG02616-ENG02904,Subbus_local_active-Status_seat_fan_backrest_right_1,00000000 ,
ENG02616-ENG02905,Subbus_local_active-Status_seat_fan_backrest_right_2,00000000 ,
ENG02616-ENG02902,Subbus_local_active-Status_seat_fan_surface_left_1,00000000 ,
ENG02616-ENG02903,Subbus_local_active-Status_seat_fan_surface_left_2,00000000 ,
ENG02616-ENG02906,Subbus_local_active-Status_seat_fan_surface_right_1,00000000 ,
ENG02616-ENG02907,Subbus_local_active-Status_seat_fan_surface_right_2,00000000 ,
ENG02616-ENG02908,Subbus_local_active-Status_seat_pneumatic_system_driver,00000000 ,
ENG02616-ENG02910,Subbus_local_active-Status_switch_panel_1,00000001 ,
ENG02616-ENG02911,Subbus_local_active-Status_switch_panel_2,00000000 ,
ENG02616-ENG02914,Subbus_local_active-Status_Thermocupholder,00000000 ,
ENG02616-ENG02899,Subbus_local_active-Subbus_status_common,active,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,L260,
ENG03701-ENG109174,sw_version_integration_aps-SW_VERSION,3031,
ENG03702-ENG109174,sw_version_integration_wpca-SW_VERSION,0511,
ENG02612-ENG02871,task_run_time-task_run_time_AFS,0, �s
ENG02612-ENG02872,task_run_time-task_run_time_ALM,0, �s
ENG02612-ENG02870,task_run_time-task_run_time_APS,0, �s
ENG02612-ENG02873,task_run_time-task_run_time_ARA,0, �s
ENG02612-ENG02874,task_run_time-task_run_time_gross_10ms,7793, �s
ENG02665-ENG03561,UPIT-Counter_UPIT_shortcut_ground_front,0,
ENG02665-ENG03562,UPIT-Counter_UPIT_shortcut_ground_rear,0,
ENG02665-ENG03560,UPIT-UPIT_system_state,00000000 00000000 ,
ENG02665-ENG03559,UPIT-UPIT_version,00000000 00100011 ,
ENG03699-ENG03728,WakeUp_event_LIN-WakeUp_event_LIN1,0,
ENG03699-ENG03729,WakeUp_event_LIN-WakeUp_event_LIN2,0,
ENG03699-ENG03730,WakeUp_event_LIN-WakeUp_event_LIN3,0,
ENG03699-ENG03731,WakeUp_event_LIN-WakeUp_event_LIN4,0,
ENG03699-ENG03732,WakeUp_event_LIN-WakeUp_event_LIN5,0,
ENG03699-ENG03733,WakeUp_event_LIN-WakeUp_event_LIN6,0,
ENG02624-ENG03039,wish_wash-locking_counter_scg_headlight_washer_system,0,
ENG02624-ENG03035,wish_wash-locking_counter_scg_washer_jet_heating,0,
ENG02624-ENG03037,wish_wash-locking_counter_scg_washer_pump,0,
ENG02624-ENG03038,wish_wash-scg_counter_headlight_washer_system,0,
ENG02624-ENG03034,wish_wash-scg_counter_washer_jet_heating,0,
ENG02624-ENG03036,wish_wash-scg_counter_washer_pump,0,
Elapsed Time: 02:30
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect.
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0690CCD051751199CAE98B9110B3D080000000000000000200016010A69012B025709
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018.rod
;Monday,13,November,2017,18:35:41:43776
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: 025E83F40485A1118EED-8057
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE01164-MAS06614,Park assist button-Version,Local data bus: operating unit 1,
IDE01164-MAS07693,Park assist button-Button Status,Not operated,
IDE01164-MAS07694,Park assist button-Button status on CAN,Not operated,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,OFF,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,33,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,On,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,29.50, �C
IDE01540-MAS07052,Left front heated seat-Setting,Not available,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,6.82, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Not available,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,24.90, �C
IDE01541-MAS07052,Right front heated seat-Setting,Not available,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,8.10, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Not available,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,87 86 74 18,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,cannot be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,cannot be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02486,Data logger triggering,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,0, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,not coded/not installed,
IDE03111-MAS06987,Interior light-Footwell illumination front,not coded/not installed,
IDE03111-MAS09295,Interior light-ambient light.chan. 1,not coded/not installed,
IDE03111-MAS09297,Interior light-Ambient illumination power supply,0, %
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),0, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),not coded/not installed,
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),not coded/not installed,
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),0, mA
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Sleep mode,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Sleep mode,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,460, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,0, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,Measured value not available,
IDE03620,Front jounce travel,not initialized,
IDE03621,Rear jounce travel,not initialized,
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,-46.00, mm
IDE03631,Right headlight beam adjusting motor: specified value,-46.00, mm
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.00, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.00, %
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,12.49, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,12.46, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,12.53, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,0.14, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,12.48, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,12.50, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,12.49, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,12.51, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,12.46, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,17.40, �C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,17.00, �C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,69, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,1.30, �C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,Not operated,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Not operated,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,OFF,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,OFF,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,OFF,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,49 DD D6 00,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,Not available,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,Not available,
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,Not available,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,Not available,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,0.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),0, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,0.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),0, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light bulb-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light bulb-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light bulb-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,0, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,no error,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),0, mA
IDE08397-MAS01580,Headlights left: supply-Activation,0, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,no error,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),0, mA
IDE08402-IDE05742,Light switch-Light switch position,zero position,
IDE08402-IDE07956,Light switch-redundant signal line,OFF,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,OFF,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,OFF,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,OFF,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.71, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,13.50, �C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Not available,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,Not available,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,Not available,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,Not available,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,Not available,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,Not available,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,Not available,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,Not available,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,Not available,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,0, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,0, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,OFF,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),0, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,04,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,05 F3 1A,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,00,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 3,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,0F,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,05 F3 36,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,FF,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,Yes,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Channel 3,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01010000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,04,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,05 F3 38,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Channel 3,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,01000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,12.59, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,OFF,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,0.00, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,2.20, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,45.40, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),0, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),108, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),100, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09421-IDE09359,Installation informat multicolor ambient and contour lighting-Drink holder ambient lighting,00000000 ,
IDE09421-IDE09360,Installation informat multicolor ambient and contour lighting-Instrument cluster contour lighting,00000111 ,
IDE09421-IDE09361,Installation informat multicolor ambient and contour lighting-Contour lighting of control unit for multimedia system,00000000 ,
IDE09421-IDE09362,Installation informat multicolor ambient and contour lighting-Center console ambient lighting,00000011 ,
IDE09421-IDE09363,Installation informat multicolor ambient and contour lighting-Roof contour lighting,00000000 ,
IDE09421-IDE09364,Installation informat multicolor ambient and contour lighting-Door contour lighting front left,00000001 ,
IDE09421-IDE09365,Installation informat multicolor ambient and contour lighting-Door contour lighting front right,00000001 ,
IDE09421-IDE09366,Installation informat multicolor ambient and contour lighting-Door contour lighting rear left,00000001 ,
IDE09421-IDE09367,Installation informat multicolor ambient and contour lighting-Door contour lighting rear right,00000001 ,
IDE09421-IDE09368,Installation informat multicolor ambient and contour lighting-Door ambient lighting front left,00000101 ,
IDE09421-IDE09369,Installation informat multicolor ambient and contour lighting-Door ambient lighting front right,00000101 ,
IDE09421-IDE09370,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear left,00000101 ,
IDE09421-IDE09371,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear right,00000101 ,
IDE09421-MAS11066,Installation informat multicolor ambient and contour lighting-Foot well lighting,00001111 ,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not active,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not faulty,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,OK,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,100, %
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not active,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not faulty,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,OK,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not active,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Not available,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Not available,
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,0, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,48,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,2,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,0.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,0.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),43, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,43, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,0, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),0, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),0, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,ERROR,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,ERROR,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,12.20, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,26, �C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,110, �C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,255, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,255, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,7, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,Unknown,
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,Unknown,
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,255, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Short circuit to ground,
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,4.47, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.27, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m�
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m�
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,OFF,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG02609,average_Voltage_terminals,12.40, V
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,#������,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,#������,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,#������,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,#������,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,#������,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,#������,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,#������,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,#������,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,#������,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,#������,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,#������,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,#������,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,#������,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,#������,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,#������,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,#������,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,#������,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,#������,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,#������,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,#������,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,#������,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,#������,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,#������,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,#������,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,#������,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG101323,Headlight leveling control state,static,
ENG02610,interior_temperature,29.00, �C
ENG107366,Left headlight leveling motor position,ERROR,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,94,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,94,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,31,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,47,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,65,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,0, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,63,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,0,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,127,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,157,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,6,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,4,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,2,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,22024,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,565,
ENG108469,Right headlight leveling motor position,ERROR,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,0,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,L260,
Elapsed Time: 02:32
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect. --- SA: 20113
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0690CCD051751199CAE98B9110B3D080000000000000000200016010A69012B025709
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018.rod
;Wednesday,15,November,2017,18:04:17:43776
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: 025E83F40485A1118EED-8057
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0.00, km/h
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00957,Resulting distance of front sensors,infinite,
IDE00958,Resulting distance of rear sensors,infinite,
IDE00974,Outside air temperature internally calculated,8.50, �C
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123,Distance of left rear park assist sensor,infinite,
IDE01124,Distance of left rear center park assist sensors,infinite,
IDE01125,Distance of right rear center park assist sensors,infinite,
IDE01126,Distance of right rear park assist sensor,infinite,
IDE01127,Distance sensor for left front park assist,infinite,
IDE01128,Distance sensor for left front center park assist,infinite,
IDE01129,Distance sensor for right front center park assist,infinite,
IDE01130,Distance of right front park assist sensors,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.00, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.00, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.00, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.00, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.00, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.00, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.00, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,0.00, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 6,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 4,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164-MAS06614,Park assist button-Version,Local data bus: operating unit 1,
IDE01164-MAS07693,Park assist button-Button Status,Not operated,
IDE01164-MAS07694,Park assist button-Button status on CAN,Not operated,
IDE01164-MAS07699,Park assist button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Park assist button-Indicator light activation,OFF,
IDE01166,Supply voltage for park assist sensor,12.40, V
IDE01171-IDE01167,Convertible factory setting offset for volume level 1-Convertible offset for volume level 1,not installed,
IDE01172-IDE01168,Factory setting for increment for convertible volume levels-Increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01174,Factory setting: visual display for park assist,OPS display,
IDE01236-MAS01580,Coolant recirculation pump-Activation,not coded/not installed,
IDE01236-MAS01634,Coolant recirculation pump-Supply voltage,not coded/not installed,
IDE01236-MAS06707,Coolant recirculation pump-Operating mode,not coded/not installed,
IDE01236-MAS07836,Coolant recirculation pump-Eng. delay. cool. shutdown,not coded/not installed,
IDE01236-MAS07837,Coolant recirculation pump-Last reason for local activity,not coded/not installed,
IDE01236-MAS07839,Coolant recirculation pump-Status feedback,not coded/not installed,
IDE01236-MAS12621,Coolant recirculation pump-Current draw (effective value),not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,OFF,
IDE01266-MAS07806,Coolant shut-off valve-Spec. cond.,Open,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),0, mA
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,41,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,On,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01285,Counter of component protection malfunctions,00 00,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,not active,
IDE01411-MAS12596,Personalization 1 for park assist-Park brake assistant,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,active,
IDE01412-MAS12596,Personalization 2 for park assist-Park brake assistant,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12596,Personalization 3 for park assist-Park brake assistant,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 6,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 4,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12596,Personalization 4 for park assist-Park brake assistant,not activated,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,24.90, �C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,8.08, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not coded/not installed,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,24.90, �C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,8.11, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded/not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded/not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded/not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded/not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded/not installed,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Version,not coded/not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded/not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator light activation,not coded/not installed,
IDE01985-MAS06854,FAZIT identification test sum-Version,81,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,87 86 74 18,
IDE01992-SFT00009,Installation list: current installations-Central Electrics,can be reached,
IDE01992-SFT00041,Installation list: current installations-Light Control Left,can be reached,
IDE01992-SFT00057,Installation list: current installations-Light Control Right,can be reached,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01993-SFT00009,Control module reference number-Central Electrics,Central Electrics,
IDE01993-SFT00041,Control module reference number-Light Control Left,Light Control Left,
IDE01993-SFT00057,Control module reference number-Light Control Right,Light Control Right,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Central Electrics,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Light Control Left,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Light Control Right,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Central Electrics,ERROR,
IDE02384-SFT00041,Status of event memory-Light Control Left,OK,
IDE02384-SFT00057,Status of event memory-Light Control Right,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02486,Data logger triggering,not active,
IDE02711-MAS09598,Rear Window Wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear Window Wiper-Error status via CAN,No error: no wiper activation,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS08785,Number of requested start processes-Parking aid,0,
IDE03111-MAS06885,Interior light-Terminal 30 for interior illumination,91, %
IDE03111-MAS06886,Interior light-Interior light delay (dimmer),0, %
IDE03111-MAS06986,Interior light-Footwell illumination rear,not coded/not installed,
IDE03111-MAS06987,Interior light-Footwell illumination front,not coded/not installed,
IDE03111-MAS09295,Interior light-ambient light.chan. 1,not coded/not installed,
IDE03111-MAS09297,Interior light-Ambient illumination power supply,100, %
IDE03111-MAS12622,Interior light-Terminal 30 for interior lighting: current draw (effect. value),5, mA
IDE03111-MAS12623,Interior light-Foot well illumination: rear: current draw (effective value),not coded/not installed,
IDE03111-MAS12624,Interior light-Foot well illumination: front: current draw (effective value),not coded/not installed,
IDE03111-MAS12625,Interior light-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior light-Supply for ambient illumination: current draw (effective value),498, mA
IDE03111-MAS12627,Interior light-Trunk illumination: front: current draw (effective value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Central Electrics,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Light Control Left,Sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Light Control Right,Sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,460, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,0, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start-stop conditions,Stop release,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03602,Left front level control system sensor,Measured value not available,
IDE03604,Left rear level control system sensor,Measured value not available,
IDE03620,Front jounce travel,-5, mm
IDE03621,Rear jounce travel,-16, mm
IDE03622,Left headlight beam adjusting motor: status,no error,
IDE03623,Right headlight beam adjusting motor: status,no error,
IDE03628,Adjusting motor for variable left front lighting: status,Measured value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measured value not available,
IDE03630,Left headlight beam adjusting motor: specified value,-50.00, mm
IDE03631,Right headlight beam adjusting motor: specified value,-50.00, mm
IDE03632,Left-/right hand driving switch-over,Measured value not available,
IDE03638-IDE03717,static AFS light-Dim static left AFS light,0.00, %
IDE03638-IDE03718,static AFS light-Dim static right AFS light,0.00, %
IDE03662-MAS06614,ASR/ESP button-Version,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator light activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Version,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator light activation,not coded/not installed,
IDE03669,Light distribution status,Measured value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Supply voltage: Terminal 30,13.16, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,13.12, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,13.19, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,13.15, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,13.13, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,13.15, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,13.16, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,13.17, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,13.12, V
IDE03727,Variable left front lighting specified position,Measured value not available,
IDE03728,Variable right front lighting specified position,Measured value not available,
IDE03784,Temporary function limitation due to environmental influences,No,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measured value not available,
IDE04343-SFT00009,Bus identification-Central Electrics,Busmaster,
IDE04343-SFT00041,Bus identification-Light Control Left,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Light Control Right,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04806-MAS06614,Driving profile selection button-Version,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Version,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator light activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Version,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator light activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,not coded/not installed,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),not coded/not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,14.20, �C
IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,14.00, �C
IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,130, %
IDE06091-MAS04647,Humidity sensor: internal-Dew point,7.70, �C
IDE06091-MAS07055,Humidity sensor: internal-Response error,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,3,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,3,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,not active,
IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Version,Local data bus: operating unit 1,
IDE06752-MAS07693,Hill descent control button-Button Status,Not operated,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Not operated,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator light activation,OFF,
IDE07145-MAS06772,Component protection properties-Component protection generation,02,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,08,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
IDE07145-MAS07187,Component protection properties-KS Data version,01,
IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left cabin heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left cabin heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left cabin heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right cabin heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right cabin heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right cabin heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right cabin heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal control-Terminal 75 status,On,
IDE08196-MAS06982,Terminal control-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal control-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal control-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,15 59 9A 72,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,26, �C
IDE08356-MAS01447,Left seat backrest fan 1-Act.val.,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,0, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,27, �C
IDE08358-MAS01447,Left seat cushion fan 1-Act.val.,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,0, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,26, �C
IDE08360-MAS01447,Right seat backrest fan 1-Act.val.,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,0, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,28, �C
IDE08362-MAS01447,Right seat cushion fan 1-Act.val.,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,0, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,0, %
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,0, %
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,0, %
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded/not installed,
IDE08376-MAS01580,Right daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08376-MAS01737,Right daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and parking lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and parking lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and parking lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded/not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded/not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,100.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,no error,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),1466, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,100.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,no error,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),1423, mA
IDE08388-MAS01580,Right high beam headlamp bulb-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light bulb-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light bulb-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light bulb-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light bulb-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light bulb-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light bulb-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,no error,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),36, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,no error,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),30, mA
IDE08402-IDE05742,Light switch-Light switch position,AUTO,
IDE08402-IDE07956,Light switch-redundant signal line,Medium,
IDE08402-MAS03866,Light switch-Head-up display button,Not operated,
IDE08402-MAS03868,Light switch-Position of eye box,0,
IDE08402-MAS06887,Light switch-Light switch position on CAN,AUTO,
IDE08402-MAS06888,Light switch-Fog light button,Not operated,
IDE08402-MAS06889,Light switch-Rear fog light button,Not operated,
IDE08402-MAS06890,Light switch-Night vision system button,Not operated,
IDE08402-MAS06891,Light switch-Control for Eyebox position,no operation,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.81, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,12.50, �C
IDE08408-MAS12845,Hood contact-Switch 1,closed,
IDE08408-MAS12846,Hood contact-Switch 2,closed,
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,OFF,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,33, %
IDE08502-MAS09777,A/C compressor regulator valve-Specified current,328, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),329, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measured value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather lights,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measured value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measured value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,Measured value not available,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,Measured value not available,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,04,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,05 F3 1A,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,00,
IDE08543-MAS04184,Garage door opener: last programming-Cancellation by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 3,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,0F,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,05 F3 36,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,FF,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Cancellation by user,Yes,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Channel 3,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01010000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,04,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,05 F3 38,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,00,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Cancellation by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Channel 3,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,01000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,13.29, V
IDE08795-MAS06614,Button for rear window shade-Version,not coded/not installed,
IDE08795-MAS07693,Button for rear window shade-Button Status,not coded/not installed,
IDE08795-MAS07694,Button for rear window shade-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,not coded/not installed,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,not coded/not installed,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,not coded/not installed,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,not coded/not installed,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,not coded/not installed,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,not coded/not installed,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,not coded/not installed,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,not coded/not installed,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,not coded/not installed,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),not coded/not installed,
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),not coded/not installed,
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,13.21, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,2.20, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,46.06, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),6, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,ready for operation,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control head 2 for driving and comfort functions,not coded/not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Version,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator light activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Version,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator light activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Version,Local data bus: operating unit 1,
IDE08981-MAS07693,Front display open/close button-Button Status,Not operated,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Not operated,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Version,Local data bus: operating unit 1,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,Not operated,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator light activation,OFF,
IDE08983-MAS06614,Driving profile selection button 2-Version,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,no error,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),150, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,no error,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),209, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09421-IDE09359,Installation informat multicolor ambient and contour lighting-Drink holder ambient lighting,00000000 ,
IDE09421-IDE09360,Installation informat multicolor ambient and contour lighting-Instrument cluster contour lighting,00000111 ,
IDE09421-IDE09361,Installation informat multicolor ambient and contour lighting-Contour lighting of control unit for multimedia system,00000000 ,
IDE09421-IDE09362,Installation informat multicolor ambient and contour lighting-Center console ambient lighting,00000011 ,
IDE09421-IDE09363,Installation informat multicolor ambient and contour lighting-Roof contour lighting,00000000 ,
IDE09421-IDE09364,Installation informat multicolor ambient and contour lighting-Door contour lighting front left,00000001 ,
IDE09421-IDE09365,Installation informat multicolor ambient and contour lighting-Door contour lighting front right,00000001 ,
IDE09421-IDE09366,Installation informat multicolor ambient and contour lighting-Door contour lighting rear left,00000001 ,
IDE09421-IDE09367,Installation informat multicolor ambient and contour lighting-Door contour lighting rear right,00000001 ,
IDE09421-IDE09368,Installation informat multicolor ambient and contour lighting-Door ambient lighting front left,00000101 ,
IDE09421-IDE09369,Installation informat multicolor ambient and contour lighting-Door ambient lighting front right,00000101 ,
IDE09421-IDE09370,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear left,00000101 ,
IDE09421-IDE09371,Installation informat multicolor ambient and contour lighting-Door ambient lighting rear right,00000101 ,
IDE09421-MAS11066,Installation informat multicolor ambient and contour lighting-Foot well lighting,00001111 ,
IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,Not operated,
IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,Not operated,
IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,Not operated,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special Purpose Vehicle Control Module-Version,not coded/not installed,
IDE09920-MAS06992,Special Purpose Vehicle Control Module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special Purpose Vehicle Control Module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special Purpose Vehicle Control Module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special Purpose Vehicle Control Module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special Purpose Vehicle Control Module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special Purpose Vehicle Control Module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special Purpose Vehicle Control Module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special Purpose Vehicle Control Module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special Purpose Vehicle Control Module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special Purpose Vehicle Control Module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special Purpose Vehicle Control Module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special Purpose Vehicle Control Module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special Purpose Vehicle Control Module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special Purpose Vehicle Control Module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special Purpose Vehicle Control Module-Suppression of interior illumination request,not coded/not installed,
IDE09921-MAS01632,Automatic high beam assist control module-Status,not active,
IDE09921-MAS02832,Automatic high beam assist control module-Malfunction status,not faulty,
IDE09921-MAS09580,Automatic high beam assist control module-Sensor status,OK,
IDE09921-MAS09581,Automatic high beam assist control module-PWM specs.,100, %
IDE09921-MAS09582,Automatic high beam assist control module-Status on combi,not active,
IDE09921-MAS09583,Automatic high beam assist control module-error status on combi,not faulty,
IDE09921-MAS09584,Automatic high beam assist control module-Sensor status on combi,OK,
IDE09921-MAS09585,Automatic high beam assist control module-Turn up headlights request,not active,
IDE09922-MAS01448,Static headlight range adjustment-Specified value,not coded/not installed,
IDE09922-MAS09527,Static headlight range adjustment-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlight range adjustment-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlight range adjustment-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlight range adjustment-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown,
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Dimming interior rearview mirror-Button Status,Not operated,
IDE09955-MAS09651,Dimming interior rearview mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Dimming interior rearview mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Dimming interior rearview mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,55, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,55,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,2,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,55.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,no error,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,55.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,no error,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),51, %
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),0, %
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),0, %
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,51, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,55, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),31, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),41, mA
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cupholder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cupholder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cupholder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cupholder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cupholder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cupholder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cupholder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cupholder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cupholder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cupholder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cupholder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,-50.00, mm
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,-50.00, mm
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,12.90, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,25, �C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,110, �C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10432,Roof electronics control module: dim. value-Uplight: front,255, %
IDE10343-MAS10433,Roof electronics control module: dim. value-Search rings,255, %
IDE10343-MAS10434,Roof electronics control module: dim. value-indicator lights,8, %
IDE10344-MAS10485,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: dim. value,0, %
IDE10344-MAS10486,Roof electr.ctrl module: read. light/ceiling contour lights-Left front reading lamp: diagnosis,Unknown,
IDE10344-MAS10487,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: dim. value,0, %
IDE10344-MAS10488,Roof electr.ctrl module: read. light/ceiling contour lights-Right front reading lamp: diagnosis,Unknown,
IDE10344-MAS10489,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: dim. value,0, %
IDE10344-MAS10490,Roof electr.ctrl module: read. light/ceiling contour lights-Left rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10491,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: dim. value,0, %
IDE10344-MAS10492,Roof electr.ctrl module: read. light/ceiling contour lights-Right rear reading lamp: diagnosis,Unknown,
IDE10344-MAS10493,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10494,Roof electr.ctrl module: read. light/ceiling contour lights-Left read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10495,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: dim. value,0, %
IDE10344-MAS10496,Roof electr.ctrl module: read. light/ceiling contour lights-Right read. lamp: 3rd seat row: diagnosis,Unknown,
IDE10344-MAS10497,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: dim. value,255, %
IDE10344-MAS10498,Roof electr.ctrl module: read. light/ceiling contour lights-Ceiling contour lights: diagnosis,Short circuit to ground,
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10430,Roof electronics control module: indicator lights-Indicator light for emerg. call,On,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,4.61, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.24, kOhm
IDE10361-MAS07003,Driver information sensor-Sensor 2 for inadequate coolant level display,not coded/not installed,
IDE10482-MAS01632,Release for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Release for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Release for external systems-Installation info.: external system,no system,
IDE10645,Status of optical display park assist,OFF,
IDE10808-MAS06614,Directional stabilization assistance button-Version,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator light activation,OFF,
IDE10810-MAS06614,Button for side view camera-Version,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m�
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m�
IDE11979,Parking distance control secure condition: cause,00 00,
IDE12156,Parking aid: system status master module,00000000 00000000 00000000 11111111 ,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12342-MAS06614,Button engine sound generation-Version,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,ERROR,
IDE12342-MAS08062,Button engine sound generation-Indicator light activation,not coded/not installed,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Version,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Interior temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
ENG02613-ENG02881,Activation_counter-Frequency_of_operation_of_climatic_clutch,0,
ENG02613-ENG02876,Activation_counter-Frequency_of_operation_of_heating_lock_valve,150,
ENG02613-ENG02879,Activation_counter-Frequency_of_operation_of_horn,71,
ENG02613-ENG02877,Activation_counter-Frequency_of_operation_PTC_relais_1,0,
ENG02613-ENG02878,Activation_counter-Frequency_of_operation_PTC_relais_2,0,
ENG02613-ENG02880,Activation_counter-Frequency_of_socket_relais,2482,
ENG02613-ENG02875,Activation_counter-Number_of_active_fail_save_flashing,0,
ENG02613-ENG02882,Activation_counter-Number_of_retrais_xenon_left,0,
ENG02613-ENG02883,Activation_counter-Number_of_retrais_xenon_right,0,
ENG02614-MAS00106,Activation_Singalhorn-Year,2000,
ENG02614-MAS00107,Activation_Singalhorn-Month,0,
ENG02614-MAS00108,Activation_Singalhorn-Day,0,
ENG02614-MAS00109,Activation_Singalhorn-Hours,0,
ENG02614-MAS00110,Activation_Singalhorn-Minutes,0,
ENG02614-MAS00111,Activation_Singalhorn-Seconds,0,
ENG02614-ENG28812,Activation_Singalhorn-Event_signal,not active,
ENG08010-ENG101382,actual_abort_reason_APS_PLA-System_state,00 00,
ENG08009-ENG101382,APS_PLA_error_message-System_state,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF,
ENG02625-ENG03043,automatic_static_headlight levelling control-locking_counter_scg_automatic_static_headlight levelling control,0,
ENG02625-ENG03042,automatic_static_headlight levelling control-scg_counter_automatic_static_headlight levelling_control,0,
ENG02609,average_Voltage_terminals,13.10, V
ENG02620-ENG02925,buttons-Voltage_difference_button_0,98, %
ENG02620-ENG02926,buttons-Voltage_difference_button_1,not coded/not installed,
ENG02620-ENG02935,buttons-Voltage_difference_button_10,not coded/not installed,
ENG02620-ENG02936,buttons-Voltage_difference_button_11,not coded/not installed,
ENG02620-ENG02927,buttons-Voltage_difference_button_2,not coded/not installed,
ENG02620-ENG02928,buttons-Voltage_difference_button_3,not coded/not installed,
ENG02620-ENG02929,buttons-Voltage_difference_button_4,not coded/not installed,
ENG02620-ENG02930,buttons-Voltage_difference_button_5,not coded/not installed,
ENG02620-ENG02931,buttons-Voltage_difference_button_6,not coded/not installed,
ENG02620-ENG02932,buttons-Voltage_difference_button_7,not coded/not installed,
ENG02620-ENG02933,buttons-Voltage_difference_button_8,not coded/not installed,
ENG02620-ENG02934,buttons-Voltage_difference_button_9,not coded/not installed,
ENG02623-ENG03033,climatic-locking_counter_magnetic_clutch_for_air_condition_deactivations,0,
ENG02623-ENG03014,climatic-locking_counter_scg_air_conditioner_compressor_regulating_valve,0,
ENG02623-ENG03020,climatic-locking_counter_scg_coolant_circulation_pump,0,
ENG02623-ENG03018,climatic-locking_counter_scg_coolant_shutoff_valve,0,
ENG02623-ENG03024,climatic-locking_counter_scg_high_heat_output_relay,0,
ENG02623-ENG03022,climatic-locking_counter_scg_low_heat_output_relay,0,
ENG02623-ENG03016,climatic-locking_counter_scg_magnetic_clutch_for_air_condition,0,
ENG02623-ENG03026,climatic-locking_counter_scg_seat_backrest_heating_left,0,
ENG02623-ENG03030,climatic-locking_counter_scg_Seat_backrest_heating_right,0,
ENG02623-ENG03028,climatic-locking_counter_scg_seat_cushion_heating_left,0,
ENG02623-ENG03032,climatic-locking_counter_scg_Seat_cushion_heating_right,0,
ENG02623-ENG03013,climatic-scg_counter_air_conditioner_compressor_regulating_valve,0,
ENG02623-ENG03019,climatic-scg_counter_coolant_circulation_pump,0,
ENG02623-ENG03017,climatic-scg_counter_coolant_shutoff_valve,0,
ENG02623-ENG03023,climatic-scg_counter_high_heat_output_relay,0,
ENG02623-ENG03021,climatic-scg_counter_low_heat_output_relay,0,
ENG02623-ENG03015,climatic-scg_counter_magnetic_clutch_for_air_condition,0,
ENG02623-ENG03025,climatic-scg_counter_seat_backrest_heating_left,0,
ENG02623-ENG03029,climatic-scg_counter_seat_backrest_heating_right,0,
ENG02623-ENG03027,climatic-scg_counter_seat_cushion_heating_left,0,
ENG02623-ENG03031,climatic-scg_counter_seat_cushion_heating_right,0,
ENG02626-ENG03045,common-locking_counter_terminal_58xs,0,
ENG02626-ENG03047,common-locking_counter_terminal_58xt,0,
ENG02626-ENG03048,common-scg_counter_power_sockets_supply,0,
ENG02626-ENG03044,common-scg_counter_terminal_58xs,0,
ENG02626-ENG03046,common-scg_counter_terminal_58xt,0,
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,��,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,��,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,��,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,��,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,��,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,��,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,��,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,��,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,��,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,��,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,��,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,��,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,��,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,��,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,��,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,��,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,��,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,��,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,��,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,��,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,��,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,��,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,��,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,��,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,��,
ENG02611-ENG02852,EVLS-block_counter_axial_in,not coded/not installed,
ENG02611-ENG02851,EVLS-block_counter_axial_out,not coded/not installed,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,not coded/not installed,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,not coded/not installed,
ENG02611-ENG02847,EVLS-drivers_door_open,not coded/not installed,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not coded/not installed,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not coded/not installed,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not coded/not installed,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not coded/not installed,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,not coded/not installed,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,not coded/not installed,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,not coded/not installed,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,not coded/not installed,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,not coded/not installed,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,not coded/not installed,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,not coded/not installed,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,not coded/not installed,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,not coded/not installed,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,not coded/not installed,
ENG02611-ENG02846,EVLS-LSV_EE_switch,not coded/not installed,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not coded/not installed,
ENG02663-ENG03526,exception_handling-address_access_violation,757935405, s
ENG02663-ENG03527,exception_handling-address_caller,757935405, s
ENG02663-ENG03528,exception_handling-detail_information,757935405,
ENG02663-ENG03525,exception_handling-exception_type,45,
ENG02621-ENG02950,function_LEDs-locking_counter_scg_LED0,0,
ENG02621-ENG02952,function_LEDs-locking_counter_scg_LED1,0,
ENG02621-ENG02954,function_LEDs-locking_counter_scg_LED2,0,
ENG02621-ENG02956,function_LEDs-locking_counter_scg_LED3,0,
ENG02621-ENG02958,function_LEDs-locking_counter_scg_LED4,0,
ENG02621-ENG02960,function_LEDs-locking_counter_scg_LED5,0,
ENG02621-ENG02962,function_LEDs-locking_counter_scg_LED6,0,
ENG02621-ENG02964,function_LEDs-locking_counter_scg_LED7,0,
ENG02621-ENG02949,function_LEDs-scg_counter_LED0,0,
ENG02621-ENG02951,function_LEDs-scg_counter_LED1,0,
ENG02621-ENG02953,function_LEDs-scg_counter_LED2,0,
ENG02621-ENG02955,function_LEDs-scg_counter_LED3,0,
ENG02621-ENG02957,function_LEDs-scg_counter_LED4,0,
ENG02621-ENG02959,function_LEDs-scg_counter_LED5,0,
ENG02621-ENG02961,function_LEDs-scg_counter_LED6,0,
ENG02621-ENG02963,function_LEDs-scg_counter_LED7,0,
ENG101323,Headlight leveling control state,static,
ENG02610,interior_temperature,27.00, �C
ENG107366,Left headlight leveling motor position,54.00, %
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,94,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,94,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,31,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,47,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,65,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,0, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,63,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG03698-ENG02972,lightning_interior-locking_counter_scg_ambiente_lightning_front,0,
ENG03698-ENG02974,lightning_interior-locking_counter_scg_ambiente_lightning_modul,0,
ENG03698-ENG02970,lightning_interior-locking_counter_scg_footwell_illumination_front,0,
ENG03698-ENG02968,lightning_interior-locking_counter_scg_footwell_illumination_rear,0,
ENG03698-ENG02966,lightning_interior-locking_counter_scg_interior_ligthning,0,
ENG03698-ENG02971,lightning_interior-scg_counter_ambiente_lightning_front,0,
ENG03698-ENG02973,lightning_interior-scg_counter_ambiente_lightning_modul,0,
ENG03698-ENG02969,lightning_interior-scg_counter_footwell_illumination_front,0,
ENG03698-ENG02967,lightning_interior-scg_counter_footwell_illumination_rear,0,
ENG03698-ENG02965,lightning_interior-scg_counter_interior_ligthning,0,
ENG02615-ENG02715,Local_BCM_overrun-Heating_waterpump_motor_cooling_system,not active,
ENG02615-ENG03725,Local_BCM_overrun-Heating_waterpump_park_heating,not active,
ENG02615-ENG03724,Local_BCM_overrun-Heating_waterpump_residual_heat,not active,
ENG02615-ENG03727,Local_BCM_overrun-Inside_light,active,
ENG02615-ENG02622,Local_BCM_overrun-outside_light,not active,
ENG02615-ENG03726,Local_BCM_overrun-Socket_relais,not active,
ENG02619,Operating_temperature,31, �C
ENG02619-ENG02919,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_110,0, s
ENG02619-ENG02923,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_30,164755, s
ENG02619-ENG02922,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_50,0, s
ENG02619-ENG02921,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_70,0, s
ENG02619-ENG02920,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_greater_90,0, s
ENG02619-ENG02924,Operating_temperature-Operating_time_counter_inside_temperature_BCM1_less_30,105771, s
ENG119674-ENG02897,operating_time-Operatin_time_BCM1_on_KL15_is_0_and_CAN_active,44992, s
ENG119674-ENG02898,operating_time-Operatin_time_BCM1_on_KL15_is_0_and_CAN_not_active,30355, s
ENG119674-ENG02896,operating_time-Operatin_time_BCM1_on_KL15_is_1,270577, s
ENG119674-ENG02884,operating_time-Operating_time_counter_horn,73, s
ENG119674-ENG02890,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.4A_and_1.6A,0, s
ENG119674-ENG02891,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.6A_and_1.8A,0, s
ENG119674-ENG02892,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_1.8A_and_2A,0, s
ENG119674-ENG02893,operating_time-Operating_time_magnetic_clutch_closed_actual_current_between_2A_and_2.2A,0, s
ENG119674-ENG02894,operating_time-Operating_time_magnetic_clutch_closed_actual_current_greater_2.2A,0, s
ENG119674-ENG02889,operating_time-Operating_time_magnetic_clutch_closed_actual_current_less_1.4A,0, s
ENG119674-ENG02895,operating_time-Operating_time_magnetic_clutch_open,0, s
ENG119674-ENG02887,operating_time-Operating_time_socket_relais_current_between_10A_and_20A,0, s
ENG119674-ENG02886,operating_time-Operating_time_socket_relais_current_between_3A_and_10A,0, s
ENG119674-ENG02888,operating_time-Operating_time_socket_relais_current_greater_20A,0, s
ENG119674-ENG02885,operating_time-Operating_time_socket_relais_current_less_3A,345975, s
ENG02622-ENG03010,outside_light-locking_counter_scg_daytime_running_light_2_left,0,
ENG02622-ENG03008,outside_light-locking_counter_scg_daytime_running_light_2_right,0,
ENG02622-ENG02986,outside_light-locking_counter_scg_daytime_running_light_left,0,
ENG02622-ENG02984,outside_light-locking_counter_scg_daytime_running_light_right,0,
ENG02622-ENG02994,outside_light-locking_counter_scg_fog_light_left,0,
ENG02622-ENG02992,outside_light-locking_counter_scg_fog_light_right,0,
ENG02622-ENG02982,outside_light-locking_counter_scg_lower_beam_left,0,
ENG02622-ENG02980,outside_light-locking_counter_scg_lower_beam_right,0,
ENG02622-ENG02990,outside_light-locking_counter_scg_main_beam_left,0,
ENG02622-ENG02988,outside_light-locking_counter_scg_main_beam_right,0,
ENG02622-ENG02978,outside_light-locking_counter_scg_side_light_left,0,
ENG02622-ENG02976,outside_light-locking_counter_scg_side_light_right,0,
ENG02622-ENG02998,outside_light-locking_counter_scg_side_marker_front_left,0,
ENG02622-ENG02996,outside_light-locking_counter_scg_side_marker_front_right,0,
ENG02622-ENG03002,outside_light-locking_counter_scg_turn_signal_front_left,0,
ENG02622-ENG03000,outside_light-locking_counter_scg_turn_signal_front_right,0,
ENG02622-ENG03006,outside_light-locking_counter_scg_turn_signal_side_left,0,
ENG02622-ENG03004,outside_light-locking_counter_scg_turn_signal_side_right,0,
ENG02622-ENG03012,outside_light-locking_counter_scg_underfloor_lightning,0,
ENG02622-ENG03009,outside_light-scg_counter_daytime_running_light_2_left,0,
ENG02622-ENG03007,outside_light-scg_counter_daytime_running_light_2_right,0,
ENG02622-ENG02985,outside_light-scg_counter_daytime_running_light_left,0,
ENG02622-ENG02983,outside_light-scg_counter_daytime_running_light_right,0,
ENG02622-ENG02993,outside_light-scg_counter_fog_light_left,0,
ENG02622-ENG02991,outside_light-scg_counter_fog_light_right,0,
ENG02622-ENG02981,outside_light-scg_counter_lower_beam_left,0,
ENG02622-ENG02979,outside_light-scg_counter_lower_beam_right,0,
ENG02622-ENG02989,outside_light-scg_counter_main_beam_left,0,
ENG02622-ENG02987,outside_light-scg_counter_main_beam_right,0,
ENG02622-ENG02977,outside_light-scg_counter_side_light_left,0,
ENG02622-ENG02975,outside_light-scg_counter_side_light_right,0,
ENG02622-ENG02997,outside_light-scg_counter_side_marker_front_left,0,
ENG02622-ENG02995,outside_light-scg_counter_side_marker_front_right,0,
ENG02622-ENG03001,outside_light-scg_counter_turn_signal_front_left,0,
ENG02622-ENG02999,outside_light-scg_counter_turn_signal_front_right,0,
ENG02622-ENG03005,outside_light-scg_counter_turn_signal_side_left,0,
ENG02622-ENG03003,outside_light-scg_counter_turn_signal_side_right,0,
ENG02622-ENG03011,outside_light-scg_counter_underfloor_lightning,0,
ENG02617-ENG02916,overshoot_time-overshoot_time_ECU,00 00 00 19,
ENG02617-ENG02917,overshoot_time-overshoot_time_KCAN,00 00 01 80 00 01 00 23,
ENG02618-ENG02918,overshoot_time_nvm-overshoot_time_KCAN_nvm,00 00 00 00 00 00 00 00,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,0,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,0,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,165,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,0,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,8,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,1,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,36616,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,537,
ENG02664-ENG03529,reason_of_flash_termination-prerequirements_not_complied,0,
ENG108469,Right headlight leveling motor position,54.00, %
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,0,
ENG27122-ENG32023,Setting_seat_ventilation_preconditioning_front-Max_time_of_operation_exceeded,not_exceeded,
ENG27122-ENG33142,Setting_seat_ventilation_preconditioning_front-Time_of_operation,0, min
ENG126436-ENG03041,signal_horn-locking_counter_scg_horn,0,
ENG126436-ENG03040,signal_horn-scg_counter_horn,0,
ENG02616-ENG02912,Subbus_local_active-Status_EVLS,00000000 ,
ENG02616-ENG02915,Subbus_local_active-Status_LDS,00000000 ,
ENG02616-ENG02913,Subbus_local_active-Status_LIM,00000000 ,
ENG02616-ENG02909,Subbus_local_active-Status_pneumatic_system_codriver,00000000 ,
ENG02616-ENG02900,Subbus_local_active-Status_seat_fan_backrest_left_1,00000000 ,
ENG02616-ENG02901,Subbus_local_active-Status_seat_fan_backrest_left_2,00000000 ,
ENG02616-ENG02904,Subbus_local_active-Status_seat_fan_backrest_right_1,00000000 ,
ENG02616-ENG02905,Subbus_local_active-Status_seat_fan_backrest_right_2,00000000 ,
ENG02616-ENG02902,Subbus_local_active-Status_seat_fan_surface_left_1,00000000 ,
ENG02616-ENG02903,Subbus_local_active-Status_seat_fan_surface_left_2,00000000 ,
ENG02616-ENG02906,Subbus_local_active-Status_seat_fan_surface_right_1,00000000 ,
ENG02616-ENG02907,Subbus_local_active-Status_seat_fan_surface_right_2,00000000 ,
ENG02616-ENG02908,Subbus_local_active-Status_seat_pneumatic_system_driver,00000000 ,
ENG02616-ENG02910,Subbus_local_active-Status_switch_panel_1,00000000 ,
ENG02616-ENG02911,Subbus_local_active-Status_switch_panel_2,00000000 ,
ENG02616-ENG02914,Subbus_local_active-Status_Thermocupholder,00000000 ,
ENG02616-ENG02899,Subbus_local_active-Subbus_status_common,not active,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I266,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,L260,
ENG03701-ENG109174,sw_version_integration_aps-SW_VERSION,3031,
ENG03702-ENG109174,sw_version_integration_wpca-SW_VERSION,0511,
ENG02612-ENG02871,task_run_time-task_run_time_AFS,0, �s
ENG02612-ENG02872,task_run_time-task_run_time_ALM,0, �s
ENG02612-ENG02870,task_run_time-task_run_time_APS,0, �s
ENG02612-ENG02873,task_run_time-task_run_time_ARA,0, �s
ENG02612-ENG02874,task_run_time-task_run_time_gross_10ms,7793, �s
ENG02665-ENG03561,UPIT-Counter_UPIT_shortcut_ground_front,0,
ENG02665-ENG03562,UPIT-Counter_UPIT_shortcut_ground_rear,0,
ENG02665-ENG03560,UPIT-UPIT_system_state,00000000 00000000 ,
ENG02665-ENG03559,UPIT-UPIT_version,00000000 00100011 ,
ENG03699-ENG03728,WakeUp_event_LIN-WakeUp_event_LIN1,0,
ENG03699-ENG03729,WakeUp_event_LIN-WakeUp_event_LIN2,0,
ENG03699-ENG03730,WakeUp_event_LIN-WakeUp_event_LIN3,0,
ENG03699-ENG03731,WakeUp_event_LIN-WakeUp_event_LIN4,0,
ENG03699-ENG03732,WakeUp_event_LIN-WakeUp_event_LIN5,0,
ENG03699-ENG03733,WakeUp_event_LIN-WakeUp_event_LIN6,0,
ENG02624-ENG03039,wish_wash-locking_counter_scg_headlight_washer_system,0,
ENG02624-ENG03035,wish_wash-locking_counter_scg_washer_jet_heating,0,
ENG02624-ENG03037,wish_wash-locking_counter_scg_washer_pump,0,
ENG02624-ENG03038,wish_wash-scg_counter_headlight_washer_system,0,
ENG02624-ENG03034,wish_wash-scg_counter_washer_jet_heating,0,
ENG02624-ENG03036,wish_wash-scg_counter_washer_pump,0,
Elapsed Time: 02:25
;SW:8W0-907-063-CG   HW:8W0-907-063-BG ---  Cent. Elect. --- SA: 20113
;Component:BCM1 MLBevo   H13 0267, Coding:07500363E0690CCD051751199CAE98B9110B3D080000000000000000200016010A69012B025709
;EV_BCM1BOSCHAU736,018006,EV_BCM1BOSCHAU736_018.rod
;Monday,13,November,2017,17:27:06:43776
;VCDS Version: Beta 17.10.0 (x64)  Data version: 20171026 DS283.3
;VCID: 025E83F40485A1118EED-8057
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10845-Production mode-Headlight cleaning system: activate changed activation,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio reduction request,On ,1
IDE01170-Visual display for park assist,OPS display ,1
IDE01550-Service position,168.49 ,2
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,installed ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE03782-Switch-off speed for parking assist,5 ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,65 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE07356-Position during interval mode,38.49 ,2
IDE10296-upper turn position,168.49 ,2
IDE10297-lower turn position,38.49 ,2
IDE10298-Alternating park position 1,30.00 ,2
IDE10299-Alternating park position 2,32.00 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 �C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 �C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 �C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE11055-Headlight cleaning system: activation time in production mode,2.56e+006 ms,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
IDE80251-MAS09644-Head area heater-Vent temperature,0 ,1
IDE80251-MAS10293-Head area heater-Fan speed,0 ,1
MAS01426-Speaker volume for rear park assist,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Speaker volume for front park assist,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12129-Customer-oriented off-road trip,not activated ,1
MAS12843-Maneuvering brake function,activated ,1
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
Elapsed Time: 00:56
;Monday,13,November,2017,18:39:02:43776
Elapsed Time: 00:41
;Wednesday,15,November,2017,18:06:42:43776
Elapsed Time: 00:55
   #24
hadez16
C?ID=289891
I apologize!
You can see in the first line of the adpmap that security access was used in your first map post...I just didn't notice that :facepalm:
   #25
cakasky
C?ID=64899
No worries at all, just could use a pointer to configure the system to not reset my last setting for the Auto High Beam.
   #26
hadez16
C?ID=289891
It seems that this is still not possible / not discovered. No adaptation channel points to such a function
   #27
Dana
Western PA, USA
I agree with hadez16. I searched you maps and our files and cannot locate anything. It is possible this platform doesn't support it.
P.S. That new line in the maps were the SA code is shown is new. I forget when we added it but that's very handy for situations like this.
cakasky
C?ID=64899
I certainly do not mind being a guinea pig here to "discover'? ;-)
   #29
Klaus Ludwig
C?ID=227092
I have a 2017 Audi A4 Allroad (UK) with Matrix Headlights and would like the Auto Matrix to be always on instead of having to activate it by pushing the stalk every time I get in the car. Has anyone got any nearer to finding out how to do this yet? 20113 works for me as security code for 09, but cannot see any relevant parameters.
Monday,18,February,2019,22:07:25:27553
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUZZZF47HA152503   License Plate:
Mileage: 14020km-8711mi   Repair Order:
Chassis Type: F4-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 2B 39 42 44 46 47 52 5F
          69 6C 6D 74 81 8B A5 BB BC CA D6 D7
VIN: WAUZZZF47HA152503   Mileage: 14020km-8711miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYRB)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8W0 906 259 D    HW: 06L 907 425
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 326500322376050B34180000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208W0906259D 001004
   ROD: EV_ECM20TFS0208W0906259D.rod
   VCID: 42DE43B2E4096B07C89-8016
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 G    HW: 0CJ 927 156
   Component: 0CJ 20TFSIRdW H03 0003
   Revision: --H03---    Serial number: 0000002276
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 2D04000E4D97847F05B-8078
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071170056001135
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 H    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0719
   Coding: 14AA409928A72A9891A34891208052A2E6A592280214548912044A4567A549
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 001001
   ROD: EV_ESP9BOSCHCMP_001.rod
   VCID: 4ACE6B92DC39B347009-801E
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0090
   Coding: 240808095544440D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 37282266BFCB3EAF6F7-8062
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001365114
   Serial number: D0788B9880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143C13900CD051587155B3F00B9130B31080000000000000000600016810A4502AB22B60A
   VCID: 025E83B2A489AB07889-8056
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 170120  043 0813
   Serial number: 89425300301702003822
   Coding: 5BC7F7
   Serial number: 20314225X81A955555A0
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 05 07 2016  00728608
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE111011723310757
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 AT    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00298144
   Subsystem 6 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2616000199543002
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3473FFEB58FFEC0A949880A0
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D24304E9DF714FFB5B-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0106
   Serial number: 003UP003D6JD
   Coding: AACCF0C00C800000985400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006015
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC26D8AD64DAD77325-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 060 903 17
   Serial number: 3577Y00C721922F351E0
   Subsystem 2 - Part No SW: -----------    HW: 442 060 903 17
   Serial number: 3587Y00C721922F4635$
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 302 17
   Serial number: 35177000C2A58D2A878M
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 302 17
   Serial number: 3527700022A55168376-
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 803 17
   Serial number: 3557500BD21FBF14A1AX
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 803 17
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500BD21FBF1531AS
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 203 17
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500A521FBF13041%
   Subsystem 8 - Part No SW: -----------    HW: 442 431 003 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B91FD7521E1BW
   Subsystem 9 - Part No SW: -----------    HW: 442 431 003 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00B91FD7523051F
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015C8CBEA18FB01F913-8054
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
   Component: FBenRDW       H17 0313
   Coding: 248481D2FC90060001A3E9601000600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
   Component: Gateway       H16 0108
   Revision: 4W020004    Serial number: 0444W031017303
   Coding: 0301000100008640290700000059003258B20007100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 392C245E89DF28DF993-806C
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20170306092341 01094
   Serial number: 7667883204
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W9 927 755     HW: 0CJ 927 749
   Component: B9_DL3_H_SD5  H01 0004
   Serial number: 1627218093
   Coding: 11040000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 0B40AE9693C3EA4FFBF-805E
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   Component: LCM_MLBevoH05 0024
   VCID: 79ACE45EC95FE8DFD93-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000057571014
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323E137254A9DB87589-8066
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   Part No SW: 8W0 959 593 E    HW: 8W0 959 593
   Component: TSG FS        005 0057
   Serial number: 0000246992342
   Coding: 005F9A215001000000001082
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 0D888380008080
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 41DC4CBEE10F701FD13-8014
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0344
   Coding: 013500006F110040630980006E00480033004010004702502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F580A46D77BC6EFE77-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY170523FQR
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000068824057
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0904
   Serial number: >1057819
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA01DJYQ
   Coding: 0194420800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
   VCID: 76B6EF62F84187A7B41-8022
   Part No SW: 8W0 959 592 E    HW: 8W0 959 592
   Component: TSG BFS       005 0057
   Serial number: 0000247202345
   Coding: 005F9A215C01000000001080
   VCID: 4BC06E96D343AA4F3BF-801E
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035     HW: 8W5 035 035
   Component: MU-P-LND-EU   033 0917
   Serial number: A829C0HB015766
   Coding: 019442010000000013111102000A00332F0003E7017001009E
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 74B2D56AEE3D95B78A5-8020
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Subsystem 2 - Part No SW: 8W2 919 605     HW: 8W2 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9GBK00ERZ
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Serial number: APVAK111021700040012
   Component: Gracenote2  --- 1015
Address 69: Trailer
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG014213
   Coding: 02940201BF0FA10008404080
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3432156AAEBDD5B74A5-8060
Address 6D: Trunk Elect.
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H35 1214
   Serial number: 1603170515
   Coding: 9051486158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 8W2 713 041 L    HW: 8W2 713 041 J
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20170313001402
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B203E5683E31ACF8BF-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H15 0042
   Coding: 0404090200000402024023A5CD0000FCB0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736.rod
   Part No SW: 8W0 959 595 E    HW: 8W0 959 595
   Component: TSG HFS       005 0057
   Serial number: 0000247086289
   Coding: 000F98200001000000001080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 4EC6678220519F675C1-801A
   Component: TSG HBFS      005 0057
   Serial number: 0000247421983
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     012 0003
   Coding: 508000049202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 73B0D676EB33928F93F-8026
   Part No SW: 7PP 941 571 BC    HW: 7PP 941 571 B
   Component: LED1L         H09 0008
   VCID: 1768C2E6DF0B1EAF4F7-8042
   Component: LED1R         H09 0008
End----(Elapsed Time: 02:37, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
   #30
Dana
Western PA, USA
There is an EXP coding bit labeled high_beam_functions - head_light_assistant which would turn on/off the function entirely and there are IDE09921 advanced measuring values that show the status but I don't see anything related to Adaptation in our current VCDS versions (Release or Beta).
I'm under the impression this isn't supported by that module type.
   #31
Klaus Ludwig
C?ID=227092
Still keeping my fingers crossed!
   #33
jay.ing
C?ID=162429
Any Updates on this??
   #34
DV52
C?ID=194404
hmmm........... wild guess (based on a smidgen of logic but much more hope):
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam.
On the admap posted earlier, the channel currently has the value "OFF". Maybe flipping the setting will auto-request High -beam assist @ each ignition switch-on - perhaps?
As I said, highly speculative suggestion - but it's an easy try, so worth a shot IMO of course!!
PS: @Dana Why are the TAG numbers CSV separated from the adaptation channel names on this BCM? On MQB admaps, the separator between these 2 x fields is "-" (don't get me wrong - I think this is a much better arrangement)
wuplur
C?ID=247333
I am very interested in this for my 2016 A6, anyone have any ideas, would this be the same as the Q5?
   #37
wuplur
C?ID=247333
Here is the last scan I posted of just a couple modules (trying to figure out how to get hba in the MMI because I retrofitted it). Let me know if there is a specific module you want to see and I can update it.
Address: 0055 System name: 55 - Headlamp Range Control (LED) Log versions: UDS/ISOTP (Results: 0)
-Identification:
Data source:
Vehicle
Hardware part number:
7P6907357B
Part number:
4H4907357E
Hardware version number:
001
Software version number:
0100
Production date:
19.06.2015
Coding:
Coding:
04FA021122600400
Ability to flash:
Unknown
System name:
MxB-ECU
ASAM base version:
BV_HeadlRegulUDS
ASAM 2D/ODX data set:
EV_HeadlRegulAUDIMXBAU64X
ASAM 2D/ODX data set version:
005009
ASAM/ODX control module version being used:
EV_HeadlRegulAUDIMXBAU64X_005
Target data container:
4G0909865D
Version of the target data container:
0017
Equipment code:
00 00 00 00 00 00 00 00 00 69 04 89
System abbreviation:
J745
Address: 0009 System name: 09 - Vehicle elec. system w/headlamp range ctrl/parking aid Log versions: KWP2000/TP20 (Results: 0)
-Identification:
Data source:
Vehicle
4H0907063AM
Part number:
4H0907063DM
H20
0311
Production date:
11.06.2015
Coding:
Coding:
0105001104FC9FE08100408780003800CF9CD208A608022180000814F110150200600034030000
Ability to flash:
flashable
System name:
BCM1 2.0
0024
Equipment code:
E9D530DCEAFF1523
Address: 005F System name: 5F - Information electronics 1 (MIB) Log versions: UDS/ISOTP (Results: 2)
-Identification:
Data source:
Vehicle
4G1035025
Part number:
4G1035025J
042
1426
Production date:
24.06.2015
Coding:
Coding:
017501020000000013220002041A00102F0006E5F1700104FE
Ability to flash:
Unknown
System name:
MU-H-LNS-US
ASAM base version:
BV_InforContrUnit1UDS
EV_MUHig6C3Gen2HBAS
001115
EV_MUHig6C3Gen2HBAS_001
4G1909545VD
0003
Equipment code:
00 00 00 0D F6 8B C3 62 A9 35 62 0F
J794
   #39
That looks like a few chunks from an ODIS scan rather than a VCDS Auto-Scan.
Indeed. @wuplur has done that previously as well. There's nothing wrong with having access to ODIS, but this is not an ODIS forum. ;)
wuplur
C?ID=247333
Sorry, my Odis log was just easily available online. Here is my newest full scan.
Thursday,25,March,2021,10:47:27:59771
VCDS Version: 20.4.2.0 (x64)
VIN: WAUFMAFC1GN044315   License Plate:
Mileage: 36310km-22561mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 3C 42 44 46 52
          53 55 5F 62 6C 72 8F 90 AC
VIN: WAUFMAFC1GN044315   Mileage: 36310km-22561miles
10-Park/Steer Assist -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 AA    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0012
   Revision: 58H14---
   Coding: 0A2A4012052601050000
   Shop #: WSC 48812 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401AA 002011
   ROD: EV_ECM30TDI0114G0907401AA_002.rod
   VCID: 62CBEE0D75A6CA9665-8036
   Part No SW: 4G0 927 158 AQ    HW: 0BK 927 156 AM
   Component: 0BK 30TDIUSA  H19 1006
   Revision: --H19---
   Coding: 000001
   VCID: 7DF1BD71EC18156E78-8028
   Coding: 47A79641E2E569829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41890181D060B18E5C-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DA86F4E000000000000
   VCID: 7F0D4779EE14077E6A-802A
   Serial number: 3215000104981001
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 23061500041829
   Coding: 36013178480000
   Shop #: WSC 02592 005 1048576
   VCID: 63C5EB096ABCC39E6E-8036
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00001100701701
   Coding: 01050011043C9FE0C100408780003800CF9CD208A608022180000894F110150200600034030000
   Shop #: WSC 44079 002 104857
   VCID: 76E3A25DC12E463639-8022
   Component: WWS57X 150531  H37 0080
   Serial number:         150616052211
   Coding: 0045F7
   Serial number: 24044822
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 18 06 2015  00001116
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01FA4865
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA121037000013741817
   Coding: 020300
   Serial number: F16885B7000000000001
Address 10: Park/Steer Assist
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G00028K4A
   Coding: 303331343135303334394A55304C34473053
   VCID: 346758559FD21426C7-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y150001D17500
   Serial number: 3575HRB405J3DASA4100
   Serial number: 3585HRB40553DV8QFGSF
   Serial number: 3515JRB400Q54SDQE1EY
   Serial number: 3525JRB400Q54SDQCORQ
   Serial number: 3554VRB40593F0KQ2ODZ
   Serial number: 3564VRB405L3F0KQF01P
   Revision: C0068538    Serial number: 91560TA30000T
   Coding: 000034
   VCID: 3B757369BA8CDB5E06-806E
   Serial number: 10 06 2015  G0028216
   Part No SW: 4G8 920 986 R    HW: 4G8 920 986 R
   Component: TDieUsa   Nv  H10 0106
   Revision: 06001087    Serial number: 658220615596042
   Coding: 03EF0A040B41D705020000
   Shop #: WSC 42403 001 104857
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 479D1F99FE448FBE92-8012
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001900500
   Coding: C0CD078110
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B757369B28CDB5E06-806E
   Serial number: 3705017003
   Voltage stabilizer:
   Serial number: 15040200000000000391
5271 - No Communications with Parking Assist Control Module A
          U0159 00 [009] - -
                    Reset counter: 210
                    Mileage: 36021 km
                    Date: 2021.03.19
                    Time: 11:18:14
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 12.3 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 67DDFF199684AFBEB2-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 25061500040754
   Coding: 00
   VCID: 3D717D71AC98D56E38-8068
   Revision: AA000000    Serial number: 00000145760815
   VCID: 77FDAF59C6243F3E22-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720J8AEB
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33655B499ADC131EDE-8066
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H06 0060
   Serial number: 0372927037
   Coding: 040211
   VCID: 39796961B8B0E94E14-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0060
   Serial number: 0371975844
   Coding: 040211
   Coding: 011F17015E00628002000012
   VCID: 479D1F99F6448FBE92-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0012933979
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0371680308
   Coding: 0106063A00FA418583A0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000296508
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000DCACB00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93569235
   Coding: 011F17015E00628002000002
   VCID: 4683129DF14E96B669-8012
   Revision: --------    Serial number: 00000001511441
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D514D317CF845EE88-8078
   Coding: 04FA021122600400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 J    HW: 4G1 035 025
   Component: MU-H-LNS-US   042 1426
   Serial number: A278F0F7504982
   Coding: 017501020000000013220002041A00102F0006E5F1700104FE
   VCID: 2541B51124087DAE40-8070
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY801TCZ
   Serial number: 90349SLH0000Q
   Component: Gracenote2---  --- 3006
          B201A 00 [009] - -
                    Reset counter: 210
                    Mileage: 36021 km
                    Date: 2021.03.19
                    Time: 11:18:22
                    Voltage terminal 30: 12.5 V
                    Status_Software_Version_Management-module_name: MDUA009/Front
   VCID: 499919A1E05079CE84-801C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027501010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326B5E4D65C61A16D5-8066
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 3169514160C0210EAC-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 151561097
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 06:07)--------------------------
