Retrofit Active Info Display on Passat B8
donnib
New Member
I would like to add AID on a 2017 Passat B8. I have few questions :
My VIN is WVWZZZ3CZHE159005
- What is the exact parts that i need ?
- Can i buy a used part e.g can the ODOMETER be adjusted to match the one in the ECU ?
- I understand there are some things needed like programming keys, immobilizer, component protection etc. how much is needed and how much does it cost approx. ?
Thanks in advance
/donnib
Spacewalker
Poland
C?ID=159607
- I understand there are some things needed like programming keys, immobilizer, component protection etc. how much is needed and how much does it does approx. ?
Thanks in advance
/donnib
ask your local dealer, only ODIS can do
donnib
New Member
Umm ask what? Your answer is for my second question or ?
I did ask my local dealer to retrofit AID and they said nope.
I was kind of hoping that if i buy a new OEM part i don't need dealer but since i am newbie what do i know.
drennie599
Northern Ireland
C?ID=109519
changed my mind - post removed
donnib
New Member
That's a shame, i know you have done it ;)
I know it's not plug and play but i have a feeling that mounting is not the worst part, it's more the coding or whatever it's required with that or ? How much did you end up paying or was is it because you knew somebody at a shop ?
@DRI@N
Romania
C?ID=317777
@donnib
I made this RETROFIT on my Passat B8 2.0 BiTDI from 2015 here in Romania .
If you want to made this retrofit with second hand parts you need to buy an AID from 2017 (year of your car manufacture and km closer to those shown by the odometer of your car) because if you buy an AID from another year is possible to have compatibility problem with your car, and km from a second AID can not be changed .
I buy my AID from ALLEGRO.PL with less of 300 Euro .
After that you need an fiber optic cable (type POF - Plastic Optic Fiber) and this connectors 4E0973702 (ONE piece if your car have DYNAUDIO or TWO piece if your car don't have DYNAUDIO) .
You need two or four pin with number N10540101 necesary to make the fiber optic connection (the POF cable will be made in the vw representative by the auto electrician, because is necesary a special VAS TOOL for fiber optic cutting and pin clipping) .
Once these have been done and AID is mounted on the car, the VW electrician has to code ONLINE AID.
Coding means removing Component Protection and mating IMMO with car keys.
Unfortunately to my car the coding was made in proportion of 60 procent in VW SERVICE, because to make the AID to show me the correctly quantity of fuel, was necesare to made myself this coding with VCDS at home.
Unfortunately at this moment my AID do not show me the NAVIGATION MAP and I think that coding to my car is made in proportion of 90 procent .
I think my problem with displaying the map on AID is from DISCOVER PRO, that has an old firmware and that does not support the coding / adaptation of map display on AID .
If there is an colleague with an Passat B8 2.0 BiTDI whose car came from the factory with AID + DISCOVER PRO + DYNAUDIO and is disponible to help me with an VCDS FULL SCAN of his car I would be very grateful for his help .
Best regards from Romania .
@DRI@N
Romania
C?ID=317777
If on this forum is a better colleague in coding with VCDS I attach here a COMPLETE SCAN of my car .
Maybe he knows what to modify when coding from addresses 17 and 5F to display the map on AID .
Saturday,01,September,2018,18:21:54:62612
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ3CZFE400297   License Plate: GL-08-RMN
Mileage: 60544km-37620mi   Repair Order: 01.09.2018
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47
          52 55 5F 69 6C 6D A5 BB BC CA CF
01-Engine -- Status: Malfunction 0000
13-Auto Dist. Reg -- Status: Malfunction 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026     HW: 03N 907 309
   Component: R4 2,0L EDC   X22 0948
   Revision: A1X22---
   Coding: 01250032047605083000
   Shop #: WSC 08601 003 1048576
   ASAM Dataset: EV_ECM20BTD01103N906026 001008
   ROD: EV_ECM20BTD01103N906026.rod
   VCID: 688AB06D52FC9207D94-803C
   Part No SW: 0DL 300 011     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 4701
   Revision: 00H10V01
   VCID: 6594B959A5EE8F6FE22-8030
   Part No SW: 3Q0 907 379 H    HW: 3Q0 907 379 H
   Component: ESC           H34 0906
   Revision: 00000000    Serial number: 42044000000257
   Coding: 0EEC6B8F54200B6C0779070941CA6970D62AD0E0E08296F5B86250F8CAA9
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 3FD84B3167F2F5BF48E-806A
   Part No SW: 3Q0 959 435 A    HW: 3Q0 959 435 A
   Component: VWKESSYMQB    033 0523
   Revision: 00033000    Serial number: 0338858352
   Coding: 0F00000703
   Shop #: WSC 05311 115 00084
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 382A202D42DCC287894-806C
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8000020
   Part No SW: 5G1 907 044 B    HW: 5G1 907 044 B
   Revision: 00001K10
   Coding: 11020114202100012115504E00101102
   Shop #: WSC 00015 115 08193
   ROD: EV_ACClimaBHBVW37X_003_VW48.rod
   VCID: 2708F3519F625D7F10E-8072
   Part No SW: 5Q0 937 086 G    HW: 5Q0 937 086 G
   Component: BCM PQ37BOSCH 028 0112
   Revision: --------    Serial number: 86582307141678
   Coding: 00939E66C2410AFF13844084B118172C1880000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 3E26363560F8FCB7438-806A
   Component: WWS    140725  042 0607
   Serial number:         140728125216
   Component: RLHS  037 0059
   Serial number: S4Y14M07D22H06M13S09
   Coding: 06A8DD
   Light switch:
   Serial number: 21 05 2014  00000097
   Serial number: 000000000ZY1416304FJ
   Serial number: 00000000000030345385
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  012 X025
   Serial number: ESE0001317
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0002060
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0000985
   Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0002055
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00107.08.14
   Coding: 0471267151
   Shop #: WSC 05311 123 08193
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008_VW37.rod
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC Bosch MQB H04 0128
   Coding: 326167DB14FFC728949C804C
   Shop #: WSC 05311 115 00171
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 333017015BBA21DFBC6-8066
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 15071441350001
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 76B6EE15084874F75B8-8022
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PFWE7B6
   Coding: 98FCC0C0008000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015C8DC95186434F7EA-8054
   Belt Pretensioner left:
   Component: BeltPretRevFL  105 1032
   Serial number: 3G1857705E0226O00499
   Coding: 80000A
   Belt Pretensioner right:
   Component: BeltPretRevFR  105 1032
   Serial number: 3G1857706E0223O00099
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 001 107 14
   Serial number: 3576U000000574C46014
   Subsystem 4 - Part No SW: -----------    HW: 454 001 107 14
   Serial number: 3586U000000295C46015
   Subsystem 5 - Part No SW: -----------    HW: 454 801 407 14
   Serial number: 3516R0B8E2C040000007
   Subsystem 6 - Part No SW: -----------    HW: 454 801 407 14
   Serial number: 3526R23812C04000000W
   Subsystem 7 - Part No SW: -----------    HW: 454 800 107 14
   Serial number: 3556V12A00304000000R
   Part No SW: 3Q0 953 521 AL    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0185
   Revision: FF033033    Serial number: 20140731500365
   Coding: 0810
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7AAEFA253C5010973F0-802E
   Part No SW: 3G0 920 798 A    HW: 3G0 920 798 A
   Component: KOMBI         F15 0460
   Coding: 00F40019FFAC000801897E2B7003000000000000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009041
   VCID: 2E060675B0980C37D38-807A
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 16081410801367
   Coding: 0B0300344F017300FF00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 42DE42C514009857270-8016
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140001517680084292
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 3792203703
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0000652
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1607201400010091
   Component: Haldex4Motion H52 7081
   Serial number: HA1-00022.03.14
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
   VCID: 46D65ED53828A4770B8-8012
   Serial number: 14000082601003
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDD09612653CF8EA-8024
   Part No SW: 3Q0 959 760 A    HW: 3Q0 959 760 A
   Component: Sitzmemory    H03 0011
   Serial number: Y0006NGU10039
   Coding: 001010020000010081A080808080000000008181000000F4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 392C252979D6DB8F76A-806C
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 A    HW: 3Q0 907 566
   Component: MRR1Rear      H15 0227
   Revision: --------
   Coding: 14C002
   Shop #: WSC 38071 001 104857
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 36362E1548C834F79B8-8062
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 03071406070479
   Coding: 003F1A20D200028000001000
   Coding: 9703
   VCID: 372823114FC2CDFF80E-8062
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 B    HW: 3Q0 035 466 B
   Component: MIB2_amp_P_VW H40 0170
   Revision: 00000001    Serial number: VWZ8Z1EAT00087
   Coding: 1284010A01FF0F33AA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 06081404081132
   Coding: 003F1020DE00028200001000
   VCID: 41DC4DC91106834F3EA-8014
   Coding: 03A203004F210200
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 044     HW: 3G0 035 044
   Component: MU-H-TN-EU    H33 0199
   Serial number: A293G0EB001148
   Coding: 02840101FF0F000071110002000808101F0100A4C120A20FDF
   VCID: 5AEE9AA59C9030975F0-800E
   Component: ABT_High  H61 0031
   Serial number: VWZ8Z9PS100J72
   Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0343446109
   Coding: 0100000202000000
Address 6C: Back-up Cam. (J123)       Labels:* None
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: TopView       H11 0328
   Serial number: C854706JG000107
   Coding: 01840101E70F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   Part No SW: 5Q0 959 107 H    HW: 5Q0 959 107
   Component: HDSG-Modul    H11 0253
   Revision: --------    Serial number: 29486950100000
   Coding: 0108
   Shop #: WSC 44873 002 1048576
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 3D2431396DFEE7AF5A2-8068
   Part No SW: 3Q0 980 653 C    HW: 3Q0 980 653
   Component: MQB_B_MFK     H07 0061
   Serial number: 13081411P10083
   Coding: 00040801000004010026234FC040A100980086200080
   ROD: EV_MFKBoschMQBB_VW27.rod
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 06081402091458
   Coding: 000E10200100028000001000
   VCID: 44D244DD0E14966715C-8010
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HBFS      020 0025
   Serial number: 10071403110759
   Part No SW: 4M0 907 594 C    HW: 4M0 907 594
   Component: SAD_STG_1     009 0002
   Coding: 608000748101
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 A    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:52, VBatt start/end: 12.1V/12.1V)-----------
Spacewalker
Poland
C?ID=159607
use search button, it was already
@DRI@N
Romania
C?ID=317777
I solved my problem .
@DRI@N
Romania
C?ID=317777
Look for the thread initiated by our colleague "bbusato" .
He explain how made the AID retrofit on his car Vw Golf and in his thread you found attached pictures from VCDS .
But you need to know that for removal Component Protection and mating keys with Immo is necessary VAS-ODIS .
I am NEW here and unfurtunately I don't have permision to attache pictures .
nikolapusonja
Unverified
Bosnia and Herzegovina
LP/IP
Hello! I am new to the forum! Please share some experiences with Active Info Display Passat B8 with me. Passat B8 is the 2015 production, it was my ordinary instrument clock, I purchased an AID a month ago and it was built by the man who sold it to me, everything works on the AID. it just does not show the maps on the AID. Please for help, Passat has MIB discover media II. I also built a cable optical that goes from MIB devices to digital cockpit! Please if you have suggestions to answer me on the forum?
eden
Slovenia
C?ID=217860
Today i made retrofit to AID in my Passat B8. I have some errors and i have no solution. Please see AutoScan. Car work prfect, only full Navigation is not on AID....
And when i give ignition, instrument cluster beep 5 times. i dont know for what :D..
Wednesday,15,May,2019,10:19:19:34340
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ3CZFE447826   License Plate: PO INSTALACIJI
Mileage: 59666km-37074mi   Repair Order:
Chassis Type  3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C BB
          BC CA
VIN: WVWZZZ3CZFE447826   Mileage: 59666km-37074miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1989
   Revision: B5H21---
   Coding: 01190012034405083000
   Shop #: WSC 29121 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026FK.rod
   VCID: 7F0B74BAE67B58B2A4-802A
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63534000003493
   Coding: 0EEC6A8F34240B73077F060241C94970562CD0E0608292F11460F0084009
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 3D774EB2ACF78AA2F6-8068
8299 - Databus
                    Reset counter: 252
                    Date: 2019.05.15
                    Time: 09:55:06
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0357395923
   Coding: 000F3E0603
   Shop #: WSC 05311 115 00300
   VCID: 77FB9C9ACE4B60F2EC-8022
   Part No SW: 5G1 907 044     HW: 5G1 907 044
   Revision: 00001K10
   Coding: 11020114202100012015504C00101802
   VCID: 65C7C6D264E7E2624E-8030
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580301151324
   Coding: 00910C46C24102FF43C0400400180708189E000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DF78EB2EC774AA2B6-8028
   Component: WWS    141213  042 0607
   Serial number:         141219085831
   Serial number: S3Y16M05D12H12M50S47
   Coding: 028877
   Light switch:
   Serial number: 07 11 2014  00000968
   Sun Roof:
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39311500205593
   Coding: 0071151001
   Shop #: WSC 05311 115 00093
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 40893746DB05E74A9D-8014
   Component: ACC BOSCH MQB H04 0130
   Coding: 2A40600110FFC428949C804C
   VCID: 3363688A9AB34CD210-8066
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Revision: --------    Serial number: 003R2P06CC89
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   VCID: 020DFD4E9589355ACB-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 000 401 15
   Serial number: 3576U000000E8C70721G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 301 15
   Serial number: 3586U000000972707211
   Subsystem 3 - Part No SW: -----------    HW: 454 800 701 15
   Serial number: 3516RA0E68E05000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 800 801 15
   Serial number: 3526RE8348B05000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 800 301 15
   Serial number: 3556V36124A05000000
   Part No SW: 5Q0 953 569 B    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: --------    Serial number: 20160203500079
   Coding: 0400
   Shop #: WSC 46287 002 1048576
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         405 2170
   Coding: 0BA509902E00000801886F251000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 28598FE653753F0AB5-807C
10485826 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
                    Mileage: 40034 km
                    Date: 2018.02.11
                    Time: 15:12:23
16776996 - Databus
                    Reset counter: 252
                    Mileage: 59666 km
                    Date: 2019.05.15
                    Time: 09:54:41
16777034 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 37
                    Mileage: 59666 km
                    Date: 2019.05.15
                    Time: 09:54:44
   Revision: --------    Serial number: 19121410803720
   Coding: 030300044F087300FF00025A080F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72EDAD8EA52905DADB-8026
   Serial number: 29160000008240116013
   Coding: 2C0000
   Serial number: 2895365303
   Analog clock:
   Serial number: 1712201400010411
   Serial number: 14000315613005
   Coding: 0000000000000000
   VCID: 71EFA282A02F3EC222-8024
   Serial number: 221214BLL01893
   Coding: 003F1B205400020000001000
   VCID: 428D3D4ED509F55A8B-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000114805
   Coding: 01000010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B7340AAB2E38492C8-806E
   Serial number: 161214BLG08549
   Coding: 003F1120D400020000001000
   VCID: 418F3242D00FEE4292-8014
   Coding: 039A00000F200200
   Shop #: WSC 64272 001 1048576
   VCID: 3F8B34BAA6FB98B2E4-806A
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H10 0140
   Serial number: VWZAZ2P8504048
   Coding: 02840101FF0000001111000100090A001F01008401200100CD
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 6ED5B9FEB111213A3F-803A
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M2300ME3
   Subsystem 2 - Part No SW: V03 825 254 A    HW: -----------
   Component: ECE DL1 19/20  --- 1115
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000005415
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 34616B969FBD4BEA09-8060
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010142002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   Serial number: 181214BLH19573
   Coding: 000E01200100020000001000
   VCID: 44813B56CF1DFB6AB9-8010
   Component: TSG HBFS      020 0028
   Serial number: 181214BLH19576
Address CA: Sunroof
Interface not compatible.
End-------------------------(Elapsed Time: 05:08)--------------------------
Tnx
@DRI@N
Romania
C?ID=317777
Hello colleagues,
I need a little help from you.
After I made retrofit to the AID, I observe that I don't receive information about AdBlue RANGE, as in the picture below :
https://imgur.com/MM5FN01
Is possible to tell me what ADAPTATION to made with VCDS that to show me the AID this information ???
Thanks,
Best regards .
PetrolDave
Westbury, UK
C?ID=1423
We'll need to see a full unedited VCDS Auto-Scan so we can see what car you have, what modules are fitted and what their hardware & software versions are.
@DRI@N
Romania
C?ID=317777
@PetrolDave
You can see below complete VCDS log :
Tuesday,16,July,2019,12:36:45:62612
Mileage: 63191km-39265mi   Repair Order:
VIN: WVWZZZ3CZFE400297   Mileage: 63191km-39265miles
   Revision: A1X22---
   VCID: 688AB06D52FC9207629-803C
   Revision: 00H10V01
   VCID: 6594B959A5EE8F6F59F-8030
   VCID: 3FD84B3167F2F5BFF33-806A
   Coding: 0F00000703
   VCID: 382A202D42DCC287329-806C
   Revision: 00001K10
   VCID: 2708F3519F625D7FAB3-8072
   Coding: 00959E66C2410AFF13844084B118172C1880000000000000000000000000
   VCID: 3E26363560F8FCB7F85-806A
   Coding: 06A8DD
   Light switch:
   Coding: 0471267151
   ROD: EV_EPHVA2CAU3700000_008.rod
   VCID: 333017015BBA21DF07B-8066
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B6EE15084874F7E05-8022
   VCID: 015C8DC95186434FC57-8054
   Coding: 80000A
   Coding: 80000A
   Coding: 0810
   VCID: 7AAEFA253C50109784D-802E
   Coding: 00B40019FFAC000801897E2B7403000000000000
   VCID: 2E060675B0980C37685-807A
   ROD: EV_GatewConti_011.rod
   VCID: 42DE42C5140098579CD-8016
   Coding: 2FFFFF
   Analog clock:
   Coding: 0301
   VCID: 46D65ED53828A477B05-8012
   VCID: 71BCDD09612653CF357-8024
   VCID: 392C252979D6DB8FCD7-806C
   Revision: --------
   Coding: 14C002
   VCID: 36362E1548C834F7205-8062
   Coding: 9703
   VCID: 372823114FC2CDFF3B3-8062
   Coding: 1284010001AA0A2AAA0000000000
   VCID: 41DC4DC91106834F857-8014
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: 028401010000000011110002000808101F0100A4012080009F
   VCID: 5AEE9AA59C903097E4D-800E
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Coding: 0108
   VCID: 3D2431396DFEE7AFE1F-8068
   Coding: 00040801000004010022234FC040A100980086200040
   VCID: 44D244DD0E149667AE1-8010
   Revision: --------
   Coding: 14C002
End----(Elapsed Time: 02:59, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
If software update is required please tell me where I need to go to make updates!
Because Vw dealer in Romania told me when I installed AID in car, this car don't have any software update !
Thanks.
Best regards .
India
Has anyone installed a Used (taken from a donor car) AID yet ? I want to know is it possible to code a used one , or do I need to virginize the same before starting any installation, this also has to anything with component protection?
