- Aug 10, 2016
- 3,768
- 4,182
- Netherlands, eastern part
- C?ID=284912
oh well, try this first. then we'll finetune. the first step is to get the code accepted.
Wednesday,10,January,2018,16:45:04:26663
VCDS Version: 17.8.1.0 (x64)
www.Ross-Tech.com <http://www.Ross-Tech.com>
VIN: WVWED7AJ6AW224978 License Plate:
Mileage: 90150km-56016mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 55 56 77
VIN: WVWED7AJ6AW224978 Mileage: 90150km-56016miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H21--- Serial number:
Coding: 0403010818070160
VCID: 70E4279F63CB34C661-8024
000066 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
P0042 - 000 - Malfunction /Open Circuit - MIL ON
Fault Status: 11100000
Fault Frequency: 116
Mileage: 88672 km
Date: 2012.05.04
Time: 13:39:21
RPM: 5228 /min
Load: 96.0 %
Speed: 179.0 km/h
Temperature: 95.0°C
Temperature: 24.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.970 V
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 000 - Too Lean
Mileage: 90063 km
Date: 2012.05.31
Time: 16:19:20
RPM: 2316 /min
Load: 34.1 %
Speed: 47.0 km/h
Temperature: 60.0°C
Temperature: 4.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
000067 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
P0043 - 000 - Short to Ground - Intermittent
Mileage: 90070 km
Date: 2012.06.01
Time: 07:08:02
RPM: 883 /min
Load: 34.9 %
Temperature: 4.0°C
Temperature: -1.0°C
Voltage: 14.224 V
Readiness: 0010 0001
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492400FE881406EB92210041300800
VCID: 78F41FBFCBBB6C86A9-802C
01487 - System Function Test
Reset counter: 37
Mileage: 90147 km
Date: 2012.06.02
Time: 16:35:53
Count: 4
Count: 4608
Count: 321
Count: 50688
Count: 5376
Reset counter: 37
Mileage: 90146 km
Date: 2012.06.02
Time: 16:32:55
Count: 1
Count: 2
Count: 12800
Count: 320
Count: 50944
03756 - ESP De-Activated
Reset counter: 37
Mileage: 90146 km
Date: 2012.06.02
Time: 16:33:04
Count: 5
Count: 2
Count: 12800
Count: 394
Count: 50944
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75EA168BD4A911EEB2-8020
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AE
Coding: 67180A3E98332A04404A00857400892447E50080435D8D20648828240000
Shop #: WSC 63351 123 12345
VCID: 356AD68B9C2951EE72-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 09110 21 0512
Coding: 009795
Fault Frequency: 8
Reset counter: 233
Mileage: 86159 km
Date: 2012.01.07
Time: 09:42:39
Term 15 On
Voltage: 12.05 V
Term 50 On
02661 - Wire for Speed Signal
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 45
Mileage: 86858 km
Date: 2012.01.23
Time: 15:13:39
Term 15 On
Voltage: 13.80 V
Term 50 On
Fault Status: 00101110
Reset counter: 77
Mileage: 90146 km
Date: 2012.06.02
Time: 16:21:30
Term 15 On
Voltage: 11.60 V
Term 50 On
03384 - Windshield Washer Jet Heating
Reset counter: 79
Mileage: 87284 km
Date: 2012.02.14
Time: 09:43:07
Term 15 On
Voltage: 14.15 V
Term 50 On
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 134
Mileage: 87994 km
Term 15 Off
Voltage: 12.45 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A0GU2
Coding: 00003031
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3972DABBB831B58E96-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004WNYA00
Serial number: 3572MSME2F47614DZZZ2
Serial number: 3582MSME0F04264DZZZ
Serial number: 3512QSME221B3D05ZZZS
Serial number: 3522QSME082D401CZZZW
Serial number: 35527SME3E670E1FZZZ-
Serial number: 35627SME5E5D532BZZZZ
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 38
Mileage: 90146 km
Date: 2018.01.10
Time: 16:29:16
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78F41FBF0BBB6C86A9-802C
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Coding: 170D00
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09B180451
Coding: E9811F06001612000000
VCID: 69D24AFB4011C50E26-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T6MKY04
VCID: 7EF809A7299F52B6E3-802A
Component: IMMO H03 0305
VCID: 6AD035F78D17CE162F-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667670201
VCID: 264801C7518F2A76CB-8072
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 3162E29BA8417DCE2E-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 3260ED97AD4746D657-8066
Component: AFS-Steuergeraet 0142
Coding: 1446940
VCID: 346CEB8F575348E645-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7J1129597
Coding: 0100040004
VCID: 61C252DB78218D4EFE-8034
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 216
Reset counter: 223
Mileage: 86812 km
Date: 2012.01.21
Time: 18:05:15
02633 - Antenna for Satellite Tuner
Fault Status: 00100111
Reset counter: 78
Mileage: 90146 km
Date: 2012.06.02
Time: 16:23:40
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520288527
Coding: 412100
VCID: 29520AFB4091050EE6-807C
End-------------------------(Elapsed Time: 02:04)--------------------------
Prerequisites
The ONLY fault that should be stored in the 03-ABS controller is 01486 and the 44-Steering Assist module should be fault-free.
Vehicle Identification No. WVWED7AJ6AW224978 Model Golf 2,0
GO Date of production 24.11.2009 Year 2010 Sales type 5K19W2 Engine Code CBFA Transmission Code KZS Axle drive 6S Equipment XE Roof color G2 Carpet color code Exterior color / Paint Code G2 / Y3D
x
Exterior ambient lighting E0A Without special action equipment Lockable wheel bolts 1PE Wheel bolts with anti-theft protection
(unlockable) Vehicle class differentiation
units/platform components 0HA Vehicle class differentiation -1K0/5K0- tail pipe 0P1 Rear side exhaust tailpipe drive-off assistance UG3 Comfort driving assist Emission standard 0GT Emission standard SULEV Trailer hitch 1D0 without trailer towing airbag 4UM Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling Aerials 8L6 "diversity" window antenna Exterior mirror setting 6XN Exterior mirrors, power-adjustable/
separately heated Left exterior mirror 5SH Left exterior mirror, flat (US) Right exterior mirror 5RR Right exterior mirror, convex (US) Drive type 1X0 Front-wheel drive "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source Equipment levels A8H Top sports equipment Brake type in rear 1KV Disc brakes in rear (Geomet D) batteries J1L Battery 280 A (60 Ah) Brake type, front 1LV Disc brakes in front Components with special surface 6FF Exterior mirror housing and various attachments
colour coded to vehicle Battery/alternator capacity NY0 Standard battery/alternator capacity Component part sets with
country-specific design requirements B0D Assembly kit, USA corresponding vehicle
version (not California), various parts vehicle tools and jack 1S1 vehicle tools and jack Brake systems 1AT Electronic stability control (ESC)
Owner's manuals 0VM Information kit in American English Operating voltage 9Z0 Operating voltage 12 V brake wear indicator 9U1 brake wear indicator Heated washer nozzles 9T1 Heated washer nozzles in front CD ROM/DVD/SD card 7QA Without CD/DVD for navigation CD changer/CD player 7A0 Without CD changer/CD player "Charism" 2H0 Without "drive select" Chrome package QJ3 Chrome package (version 2) General operating permit, alterations C33 Operating permit, alteration Roof insert/convertible top 3FE Tilting and sliding glass sunroof with
sunbshade Suspension system in rear 1JE Rear sports shock absorption Suspension system in front G05 Shock absorption in front Ski bag 3X0 without load through system Insert for the filling up of unleaded
fuel/fuel type 2G7 Filler neck module 1 with insert Installation differentiation for components 0EN Installation differentiation for
transmission MQ 350
-- vehicle components -- Theft protection system 7AG Electronic immobilizer
with anti-theft alarm system (for USA) Inserts 5MD Decorative aluminum inserts Scuff plates 7M5 Without impact protection film for door sill Park distance control 7X0 Without park distance control Electric interface for external use
UF8 Electric interface for external use
Manufacturing sequence differentiation 0FA Standard manufacturing sequence window regulator 4R4 Power windows with comfort operation and
circuit breaker fire extinguisher 6A0 without fire extinguisher Pedestrian protection VL0 Standard pedestrian protection measures Fußhebelwerk VF1 pedal cluster Headlight activation 8K4 Separate daytime running lights
NAR Vehicle specifications F0A No special purpose vehicle, standard
equipment Alternators 8GU Alternator 140 A Weight category rear axle 0YC Weight range 3
installation control only, no
requirement forecast Weight category front axle L98 Suspension range 98
requirement forecast Base engine TQ2 4-cyl. petrol engine 2.0 l assembly 06J.B Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest Luggage compartment cover 3U4 Luggage compartment cover cruise control system 8T2 Electronic cruise control system (CCS)
Luggage compartment trim 5A7 Comfort luggage compartment trim with
service lid/snap-on cover Transmission specifications G0K 6-speed manual transmission handle for hand brake lever 6PC handbrake lever grip (leather) Rear spoiler 5J4 Body-colored rear spoiler Rear window wiper and washer system 8M1 Rear window wiper washer system with
intermittent wipe Rear seats 3NJ Rear bench seat, not split, split backrest, folding Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic) Headlamps 8JF Twin headlamps for driving on the right
(gas discharge) w/ integrated high beam
(US design) Customized installation FC0 Without individual installation Interior light in footwell 6T1 Interior light in footwell Instrument clusters U5C Instrument cluster, mph speedometer
- USA - Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror,
dimming Sticker (customized or special edition) 0KA Without decals and emblems Body style K8G Hatchback coolbox 1W2 Glove compartment cooling system Climatic zones 0Y2 Tropical zones Compass/road sign display QR1 With compass Booster 3T2 Three rear head restraints Head restraints 3J2 Height-adjustable headrests Fuel tank treatment 2LF Fuel tank with special material
treatment (coextrusion) with changed
protective layer Fuel quantity for initial filling 1Z0 Initial standard fuel filling Fuel systems 1A5 Petrol injector fuel system (FSI) Body measures 5C1 Body measures for increased safety
requirements Radiator grille 6KA Radiator grille Rear license plate bracket 6P2 License plate bracket, rear (NAR) Front license plate bracket 6W3 License plate bracket front (small, NAR) Paint preservative/transit coating 5K4 Full body cover (shape-adapted system)
with additional transport protection
measures Paint coating FB0 standard paint coating Steering system arrangement L0L Left-hand drive Reading lamp 8S4 Two reading lights front, two rear steering 1N3 Speed-related variable steering assist
(Servotronic) Backrest release 3H9 Backrest release for front seats with
Easy Entry feature Air duct, front area VK1 Air duct, type 1 Lumbar support 7P4 Manually adjustable lumbar support in
front seats steering wheels 2FJ Leather-wrapped multi-function sports
steering wheel Speaker installation 8RM 8 speakers (passive) Headlight-range adjustment 8Q5 Headlight range control, autom./dynamic
with cornering light (AFS 1) Center armrest 6E3 Front center armrest Marten repeller UM0 Without marten repeller Multi-function display/trip computer 9Q5 Multi-function display with control Engine cooling 8Z6 Hot country Engine specifications D2L 4-cylinder petrol engine 2.0 L/147 KW (16 V)
Turbo FSI, homogeneous
Basic engine is: T59/T61/TQ2/TU2/TD6/TN6 Left vanity mirror 4SH Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable Right vanity mirror 4TH Vanity mirror, right, illuminated, with
extractable Navigation device 7Q0 without navigation system rear fog lamp 8TA witout rear fog lamp Front fog lamp/additional headlamp 8WD Integrated front fog light Upgrading measures GP1 Vehicles with special upgrade measures
Rear of platform module base 4P0 Rear floor panel module, type 1 Platform group class 7PA Platform group class 1 Hubcaps 1NL Trims for alloy wheels Wheels CG6 Alloy wheels 7.5J x 17 Radios 8AX Radio Premium 8 Smoker's/non-smoker's package 9JF Non-smoking package (NAR) Tire pressure monitoring system 7K4 Tire pressure monitoring system 315 MHz
High tire H7K All-season tires 225/45 R17 91H (NAR) Tire suppliers V0A Tires without specification of tire
brand Spare wheel/breakdown kit 1G1 Space-saving spare wheel Restraint systems, front 4QQ 3-point seat belts in front with
pretensioner and height adjustment,
US label P72 California emission concept P83 Xenon package Side airbag 4X3 Side airbag in front, with curtain
airbag Gearshift knob/handle 6Q6 Gearshift knob/handle in aluminum Special labels/plates 0SS Labels in English and French Tail lamp assemblies 8SD Taillight assembly w/ red colored lens System torque (Nm) 4E0 Tailgate/trunk lid unlocking
from outside Front seat, left 3TG Sports comfort seat in front, left Front seat, right 3SG Sports comfort seat, front, right Nameplates for sales name QD0 Without lettering for sales name Seat belt check 9P7 Visual and acoustic seat belt reminder,
electric contact in buckle Outer rear seat belts 3ZD 3-point seat belts, outer rear with US
label Center rear seat belts 3C8 3-point seat belt, center rear with US
label seat covers N2E Seat trim covers in fabric Seat adjustment 3L3 Manual height adjustment for front seats seat heater 4A3 seat heating for front seats separat controlable Safety head restraint system 3K0 w/o safety head restraint system Side lights 7R4 Side marker lamps and turn signal
repeaters (turn signals with white lens) Start-stop system/regenerative braking 7L3 Without start/stop system without
regenerative braking Horns 8Y1 Two-tone horn Control number (no PR family) S2S Control (in-plant) Control number (no PR family) SA0 Model update, week 45 Side and rear windows 4KC Side and rear windows in heat-insulating
glass power outlet 7B2 12 volt socket in luggage compartment Bumper 2JG bumper in color of vehicle Rear stabilizer 0BF Rear stabilizer Front stabilizer 0AE Front stabilizer Drawers under front seats QN0 Without drawers under front seats Heavy-duty/sports version 2UC Sports version Headlamp washer system 8X0 Without headlamp washer system Windshield wiper intermittent control/
light/rain sensor 8N4 Windshield wiper intermittent control
with potentiometer (four speeds) Special approval measures 3M0 Without special measures Nameplate set 0NH Nameplate set "GTI" Mass damper for steering wheels 1Q0 steering wheel without balance weight Door and lid locking system 4K0 Central locking w/ radio remote control
and interior controls Type approval countries/countries with
special requirements B38 Legal requirements California Carrier frequency for remote control 5D2 Carrier frequency 315 MHz Partition 3CA without partition Door and side trim panels 4AF Door and side trim panel in foam film
and woven fabric doors 0A1 2 doors TV reception/digital radio reception QU4 Satellite radio reception NAR
integrated in device Front underbody guard 1SA Without additional front underbody guard Identification plates 1EB without identification plate Delivery equipment 2A8 Delivery equipment, water border First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle Two-way radio installation preparation 9D0 without prepared for two way radio system Telephone / telematics 9W2 Preparation for telephone Additional warning lights 9TC Additional retro-reflectors (door area) LongLife Service Regime QG0 without service interval extension Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating Windshield Glass 4GF Windshield in heat-insulating glass Washer fluid level indicator 8W1 Washer fluid level indicator Additional tires (snow tires) 2WA without spare tyre floor mats 0TD Front and rear floor mats Additional body panels,
side 6EA Without additional side body covers
(stone guard) Additional child seat anchors 3B8 Child seat anchors as per Australian
requirements and child seat system
ISOFIX auxiliary heater 9M0 Without auxiliary heater/fuel-fired
parking heater
x
