Replaced abs module with used one. Copied coding from old one thought it took but then all went back as before.
Scan before and after:
Any advice and/or assistance appreciated!!!!
Before:
After:
Before:
Friday,18,August,2017,08:52:37:56657
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWAA71K09W005316 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K09W005316 Mileage: 192660km-119713miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 Q HW: 07K 906 055 M
Component: 2,5l R5/4V G 9971
Revision: G6H01--- Serial number: VWX7Z0H43N28H1
Coding: 0000071
Shop #: WSC 59277 001 1048576
VCID: 3C223C9EDA6672F7472-8068
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Fault Frequency: 28
Mileage: 192620 km
Time: 12:20:20
Temperature: 30.0°C
Temperature: 31.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.684 V
Readiness: 0000 0100
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Coding: 113B400D492200FF880E02E5921F00413000
Shop #: WSC 57415 001 1048576
VCID: 76B6EEB6A8CAE8A7716-8022
No Faults Found
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CA2FC9E9AE6B2F7072-8028
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000008262727
Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 01287 785 00200
VCID: 323E12A60822B4879DE-8066
Component: Wischer 090508 021 0501
Coding: 00038805
Shop #: WSC 01287
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0B7TE8
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C82CCDEEA862277972-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME27235322/
Subsystem 3 - Serial number: 6342MSME294173424
Subsystem 4 - Serial number: 6352QSME65702D0DN
Subsystem 5 - Serial number: 6362QSME63421221%
Subsystem 6 - Serial number: 63727SME1638123D/
Subsystem 7 - Serial number: 63827SME1638242D0
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0101
Coding: 0000022
Shop #: WSC 01279 785 00200
VCID: 7F580B928BF0A9EF220-802A
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0003000 Serial number: VWX7Z0H43N28H1
Coding: 0007203
Part No SW: 1K0 907 530 Q HW: cï
Component: J533__Gateway cï 0202
Revision: cï Serial number: 0000K0851510A9
Coding: E9801F070002020000
Shop #: WSC 65536 002 1048824
VCID: 353429BAF94CA3BFB8C-8060
Component: IMMO VDD 1222
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 382A208EEE5E5ED7A3A-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C80
VCID: 0452847EE216CA377F2-8050
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 392C258AD55447DF5C4-806C
Address 56: Radio
Component: RDK 0450
Coding: 0100101
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/14.0V)-----------
After:
Monday,04,September,2017,08:50:04:56657
VIN: WVWAA71K09W005316 Mileage: 192960km-119899miles
Coding: 0000071
Fault Frequency: 28
Mileage: 192620 km
Time: 12:20:20
Temperature: 30.0°C
Temperature: 31.0°C
Voltage: 11.684 V
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
VCID: 75B4E9BAB5CCE3BF78C-8020
10 Faults Found:
01130 - ABS Operation
Reset counter: 5
Mileage: 99519 km
Count: 4416
Count: 4608
Count: 125
Count: 48945
Count: 4391
Count: 512
Fault Status: 00101110
Reset counter: 5
Mileage: 100460 km
Count: 71
Count: 32768
Count: 4608
Count: 104
Count: 50962
Count: 12114
Count: 512
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 5
Mileage: 100472 km
Count: 16391
Count: 32768
Count: 13824
Count: 41
Count: 50255
Count: 65039
Count: 511
Fault Status: 00101101
Reset counter: 5
Mileage: 100472 km
Count: 3
Count: 12
Count: 12544
Count: 8193
Count: 43264
Reset counter: 5
Mileage: 100472 km
Count: 1
Count: 12
Count: 12544
Count: 8213
Count: 42752
Fault Status: 00100101
Reset counter: 5
Mileage: 192963 km
Count: 7
Count: 3
Count: 12288
Count: 212
Count: 38144
Fault Status: 01100101
Reset counter: 220
Mileage: 192963 km
Count: 3
Count: 2
Count: 12288
Count: 279
Count: 44544
Reset counter: 220
Mileage: 192963 km
Count: 3
Count: 2
Count: 12288
Count: 295
Count: 44544
Reset counter: 220
Mileage: 66051 km
Date: 2001.04.03
Time: 00:28:12
Count: 2314
Count: 16
Count: 1280
Count: 270
Count: 768
Count: 32000
Count: 104
Count: 1282
Reset counter: 220
Date: 2001.04.00
Time: 16:01:10
Count: 35093
Count: 256
Count: 195
Count: 8193
Count: 52997
Count: 288
Coding: 00038805
Shop #: WSC 01287
Coding: 0013899
Coding: 0000022
Coding: 0007203
Coding: 0001077
Coding: 0001076
Address 56: Radio
Component: RDK 0450
Coding: 0100101
End----(Elapsed Time: 01:01, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
