13 VW CC Byte 18.. Need help..
HeyRobi
C?ID=60441
So after a couple drinks I figured I would play around with Byte 18 in 09. I thought I was being smart by copying the long code before messing with it so I could get it back to norm. Well as I have learned it's masked so that didn't help. Seems 0B and 0F work ok But the center cluster of LED's are the brake lights now.
Does anyone know the code for a 2103 VW CC?
Here's car info...
13 CC US spec
Led tails
Xenons with Adaptive headlights
Thursday,17,August,2017,12:51:22:52868
VCDS Version: 17.8.0.1 (x64)
VIN: WVWRN7AN6DE506985   License Plate: HEYROBI
Mileage: 160850km-99947mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 55 56 5D 62
          65 72
VIN: WVWRN7AN6DE506985   Mileage: 160850km-99947miles
09-Cent. Elect. -- Status: Malfunction 1010
5D-Operations -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Malfunction 1010
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FE    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2    3952
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010A1C070160
   Shop #: WSC 05245 444 105081
   VCID: 73E5BE19127BACDE87-8026
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
                    Mileage: 160251 km
                    Date: 2017.08.11
                    Time: 17:41:28
                    RPM: 1439 /min
                    Load: 10.2 %
                    Speed: 59.0 km/h
                    Temperature: 99.0∞C
                    Temperature: 39.0∞C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3509
   Revision: 05551213    Serial number: 00001203271443
   Coding: 0000024
   Shop #: WSC 05311 000 00000
   VCID: 25419041EC2F826ED9-8070
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V446 0023
   Revision: --H07---    Serial number: 00000005583097
   Coding: 0004495
   VCID: 71E9B41168679ECE75-8024
                    Reset counter: 22
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:30
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 281
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 J    HW: 3AA 907 044 J
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0010001008
   Shop #: WSC 00015 115 00000
   VCID: 377D4A098E8300FE7B-8062
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 000800006000000000880281B40008C02755000041208D20E486402400C0
   Shop #: WSC 05311 123 12345
   VCID: 418924D1D8474E4EC5-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 200312  010 0604
   Serial number: 200312
   Coding: 00BF95
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M03D29h13m26s42S1
   Coding: 0F008C
18 Faults Found:
00059 - Terminal 30 for Interior Lighting
                    Fault Status: 00101011
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:51
                        Term 15 Off
                    Voltage: 12.20 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:55
                        Term 15 Off
                    Voltage: 12.20 V
00834 - Signal for Activation of Heated Rear Window
                    Fault Status: 00101001
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:52
                        Term 15 Off
                    Voltage: 12.20 V
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 100
                    Mileage: 160391 km
                    Date: 2017.08.12
                    Time: 21:57:46
                    Voltage: 12.05 V
00985 - Right Tail Light (M2)
                    Reset counter: 96
                    Mileage: 160204 km
                    Date: 2017.08.11
                    Time: 13:55:26
                    Voltage: 11.80 V
                    Reset counter: 100
                    Mileage: 160391 km
                    Date: 2017.08.12
                    Time: 21:56:53
                    Voltage: 12.15 V
01259 - Fuel Pump Relay (J17)
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:57
                        Term 15 Off
                    Voltage: 12.20 V
01516 - Terminal 30; Left
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:18:19
                        Term 15 Off
                    Voltage: 12.25 V
                    Reset counter: 95
                    Mileage: 160178 km
                    Date: 2017.08.10
                    Time: 18:18:47
                    Voltage: 12.15 V
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:54
                        Term 15 Off
                    Voltage: 12.20 V
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:54
                        Term 15 Off
                    Voltage: 12.20 V
01800 - Light Switch (E1)
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:18:19
                        Term 15 Off
                    Voltage: 12.25 V
02092 - Enabling Heated Seat
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:52
                        Term 15 Off
                    Voltage: 12.20 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:52
                        Term 15 Off
                    Voltage: 12.20 V
02391 - Terminal 30 Reference
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:18:19
                        Term 15 Off
                    Voltage: 12.25 V
03266 - Control Circuit for Signal Horn
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:44:51
                        Term 15 Off
                    Voltage: 12.20 V
02738 - Bulb for Tail/Brake Light; Left
                    Reset counter: 100
                    Mileage: 160391 km
                    Date: 2017.08.12
                    Time: 21:56:52
                    Voltage: 12.15 V
02739 - Bulb for Tail/Brake Light; Right
                    Reset counter: 96
                    Mileage: 160204 km
                    Date: 2017.08.11
                    Time: 13:55:27
                    Voltage: 11.80 V
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__717 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDP6A8ANX
   Coding: 0012599
   VCID: 4E930FEDD919A13648-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 00000000008CCT
   Subsystem 3 - Serial number: 0013.03.120000300000650195ˇÜ63
   Subsystem 4 - Serial number: 650195ˇÜ6332MTS644460762 ˇÜ63
   Subsystem 5 - Serial number: 60762 ˇÜ6342MTS627450752 ˇÜ63
   Subsystem 6 - Serial number: 50752 ˇÜ6351HTS6MOECMAKJ ˇÜ63
   Subsystem 7 - Serial number: CMAKJ ˇÜ6361HTS639GCMAKR ˇÜ63
   Subsystem 8 - Serial number: CMAKR ˇÜ63727TS6R9DSNAKR ˇÜ63
   Subsystem 9 - Serial number: SNAKR ˇÜ63827TS6D6DSNAKJ ˇ
   Subsystem 10 - Serial number: SNAKJ ˇ
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120403201076
   Coding: 099A270000
   Shop #: WSC 00015 115 12345
   VCID: 6BD5A679824B741E4F-803E
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 970 T    HW: 3C8 920 970 T
   Component: KOMBI         H04 0609
   Coding: 230D01
   Shop #: WSC 05314 115 12345
   VCID: 3D715821ACBF2AAEA1-8068
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 185
                    Reset counter: 109
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:29
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:38:50
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 270312F2003204
   Coding: 461006
   Shop #: WSC 05314 123 12345
   VCID: 3E735F2DA9B931B6B8-806A
9 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:38:50
                    Fault Frequency: 184
                    Reset counter: 109
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:34
00380 - Special Vehicle Control Module (J608)
                    Fault Status: 01110100
                    Reset counter: 52
                    Mileage: 160118 km
                    Date: 2017.08.09
                    Time: 18:23:04
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 70
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:32
                    Reset counter: 207
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:34
01304 - Radio
                    Reset counter: 70
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:34
                    Reset counter: 207
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:34
02649 - Digital Radio Tuner
                    Reset counter: 207
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:34
02749 - Control Module / Control Head for Telephone (J738)
                    Reset counter: 52
                    Mileage: 160118 km
                    Date: 2017.08.09
                    Time: 18:23:05
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 377D4A09468300FE7B-8062
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0004679971
   Coding: 0004FF
   Shop #: WSC 05311 115 12345
   VCID: 6DD1A861BC5F7A2E51-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002826164
   Coding: 010498
68100 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:38:51
68105 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 52
                    Mileage: 160118 km
                    Date: 2017.08.09
                    Time: 18:23:03
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.303 1002
   Revision: 1AH03734    Serial number: 00120830103701
   Coding: 0000258
   VCID: 3C7755257FA523A696-8068
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1A910F800186407F7F021C1FF08A0F0E105B41
   Shop #: WSC 05311 123 08193
   Component: EZE_2         H41 1623
   Coding: 00030308
   VCID: 6FEDB269BE53883E63-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
                    Fault Frequency: 119
                    Reset counter: 70
                    Mileage: 155724 km
                    Date: 2017.06.20
                    Time: 12:11:30
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0004709960
   Coding: 0004FE
   VCID: 6ED3AF6DB159813668-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002824780
   Coding: 010498
          U1111 00 [008] - -
                    Reset counter: 107
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 21:38:51
          U1111 00 [009] - -
                    Reset counter: 52
                    Mileage: 160118 km
                    Date: 2017.08.09
                    Time: 18:23:03
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 7
                    Reset counter: 109
                    Mileage: 155998 km
                    Date: 2017.06.23
                    Time: 18:25:54
   Revision:   H19       Serial number: 00000000604161
   Coding: 0022156
   VCID: 3663470D4189F9F660-8062
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   Shop #: WSC 05311 115 00000
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
Address 56: Radio
Address 5D: Operations
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000109807
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 35614001948FF2EE69-8060
12656640 - Databus
          U1200 00 [008] - Defective
                    Reset counter: 109
                    Mileage: 160626 km
                    Date: 2017.08.15
                    Time: 20:53:35
8401152 - Radio Frequency Interference
          C105C 00 [008] -  -
                    Reset counter: 105
                    Mileage: 160582 km
                    Date: 2017.08.15
                    Time: 10:04:07
                    Vehicle speed: 56 km/h
                    Outside air temperature: 27 ∞C
                    Reception level antenna 1: 410 mV
                    Offset level antenna 1: 180 mV
End-------------------------(Elapsed Time: 03:18)--------------------------
          65 72
56-Radio -- Status: Malfunction 1110
                    Mileage: 160251 km
                    Date: 2017.08.11
                    Time: 17:41:28
                    RPM: 1439 /min
                    Load: 10.2 %
                    Speed: 59.0 km/h
                    Temperature: 99.0∞C
                    Temperature: 39.0∞C
                    Voltage: 13.589 V
   Coding: 0000024
   Coding: 0004495
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:55
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 281
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0010001008
   Revision: BD421001
   Coding: 00BF95
   Coding: 0F008C
   Coding: 0012599
   Coding: 099A270000
   Coding: 830000
   Coding: 230D01
   Coding: 461006
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:57
01304 - Radio
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:52:00
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:57
   Coding: 0004FF
   Slave Driver:
   Coding: 010498
   Coding: 0000258
   Coding: 00030308
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:55
   Coding: 0004FE
   Slave Passenger:
   Coding: 010498
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
End-------------------------(Elapsed Time: 03:08)--------------------------
Thursday,17,August,2017,13:17:01:52868
          65 72
Readiness: 1110 0101
   Coding: 0000024
   Coding: 0004495
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:58:46
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 281
                    Hex Value: 0x0000
   Revision: 00001K01
   Coding: 0010001008
   Revision: BD421001
   Coding: 00BF95
   Coding: 0F008C
   Coding: 0012599
   Coding: 099A270000
   Coding: 830000
   Coding: 230D01
   Coding: 461006
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:57
01304 - Radio
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:52:00
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 08:51:57
   Coding: 0004FF
   Slave Driver:
   Coding: 010498
   Coding: 0000258
   Coding: 00000208
                    Reset counter: 70
                    Mileage: 160852 km
                    Date: 2017.08.17
                    Time: 09:07:00
   Coding: 0004FE
   Slave Passenger:
   Coding: 010498
   Coding: 0022156
   Coding: 350000
   Coding: 350000
Address 56: Radio
HeyRobi
C?ID=60441
Also I did find this and tried some of the Passat codes..No luck.. No listing for a CC
Overview
Tim S
Original German
Model Names
Sheet 1: Tim S
Dec	Hex	Primary Vehicle	Secondary Vehicle	Lighting	Region	Details
1	01	BCM	default
2	02	VW Golf (VW360)
Halogen	RoW	TFL_0
3	03	VW Golf (VW360)
Halogen	NAR	TFL_0
4	04	VW Golf GTI (VW360)
Halogen	RoW	TFL_0_LED + LED_SBBR
5	05	VW Jetta (VW351)
Halogen	RoW	TFL_0
6	06	VW Jetta (VW351)
Halogen	NAR	TFL_0
7	07	VW Jetta (VW351C)
Halogen	China	TFL_0
8	08	VW Golf/Jetta Variant (VW362)
Halogen	RoW	TFL_0
9	09	VW Golf/Jetta Variant (VW362)
Halogen	NAR	TFL_0
10	0A	VW Scirocco (VW364) LHD
Halogen	RoW LHD	TFL_0
11	0B	VW Scirocco (VW364) RL
Halogen	RoW RHD	TFL_0
12	0C	VW Caddy Van (VW367)	VW Caddy Van (VN337)	Halogen	RoW	TFL_0
13	0D	VW Caddy Van (VW367)	VW Caddy Van (VN337)	Halogen	RoW/Ska	TFL_0_Ska
14	0E	VW Golf Plus (VW369)
Halogen	RoW	TFL_0
15	0F	SEAT Leon (SE350)	SEAT Altea XL II (SE352)	Xenon	NAR	TFL_0 2/7
16	10	SEAT Toledo (SE351)
Xenon	NAR	TFL_0 9/9
17	11	SEAT Leon (SE350)	SEAT Altea XL II (SE352)	Halogen	NAR	TFL_S 2/7
18	12	SEAT Toledo (SE351)
Halogen	NAR	TFL_0 9/9
19	13	VW Sharan (VW428)
Halogen	RoW	TFL_1
20	14	VW Sharan (VW428)
Xenon	RoW	TFL_1
21	15	VW Golf GTI (VW360)
Halogen	RoW	TFL_0 + LED SBBR
22	16	SEAT Leon (SE350)	SEAT Altea XL II (SE352)	Xenon	RoW	TFL_0 2/7
23	17	SEAT Toledo (SE351)
Xenon	RoW	TFL_0 9/9
24	18	SEAT Leon (SE350)	SEAT Altea XL II (SE352)	Halogen	RoW	TFL_S 2/7
25	19	SEAT Toledo (SE351)
Halogen	RoW	TFL_S 9
26	1A	Skoda Superb Combi (SK462)
Halogen
without TFL, DRL-LowBeams
27	1B	Skoda Superb (SK461)
Halogen
28	1C	Skoda Superb (SK461)
Halogen	RoW	separate TFL_1
29	1D	Skoda Superb (SK461)	Skoda Yeti (SK356)	Xenon	ASUV	TFL_Separate
30	1E	VW Golf (VW360)	VW Jetta (VW351)	Halogen	NAR	TFL_0 + SMR on SL-back
31	1F	VW Golf (VW360)
Halogen	NAR	TFL_0 + LED SBBR
32	20	VW Golf (VW360)
Halogen	NAR	TFL_0_LED
33	21	VW Golf (VW360)
Halogen	NAR	TFL_0_LED + LED_SBBR
34	22	VW Golf (VW360)
Halogen	RoW/Japan	Japan + LED_SBBR
35	23	Audi A3 (AU350PA)	VW Golf (VW360)	Halogen	NAR	TFL_0_LED + LED_SBBR
36	24	Audi A3 (AU350PA)	VW Golf/Jetta Variant (VW362)	Halogen	RoW	TFL_1
37	25	Audi A3 (AU350PA)	VW Scirocco (VW364)	Halogen	RoW/Ska LDH	TFL_0 LL_Ska
38	26	Audi A3 (AU350PA)	VW Scirocco (VW364)	Xenon	RoW/Ska RHD	TFL_0 RL_Ska
39	27	Audi A3 (AU350PA)	VW Tiguan (VW316)	Xenon	RoW/Ska	TFL_1_Ska
40	28	Audi A3 (AU350PA)	VW EOS (VW465)	Xenon	RoW/Ska	TFL_1_Ska
41	29	Audi A3 (AU350PA)	VW Golf/Jetta Variant (VW362)	Halogen	RoW/Ska	TFL_0_Ska
42	2A	Audi A3 SportBack (AU353PA)
Xenon / ECE	RoW	LED DRL with tail, AB2 PA 5door	?
43	2B	Audi A3 SportBack (AU353PA)
Xenon / ECE	RoW	LED DRL without tail, AB2 PA 5door	?
44	2C	Audi A3 SportBack (AU353PA)
45	2D	Audi A6 (AU356PA)
Halogen	RoW	TFL_0
46	2E	Audi A6 (AU356PA)
Xenon	RoW	TFL_0
47	2F	VW Tiguan (VW316)
Halogen / Xenon	RoW	TFL_0
48	30	VW Tiguan (VW316)
Halogen / Xenon	RoW	TFL_S
49	31	Skoda Superb Combi (SK462)
Halogen
separate TFL_1
50	32	Skoda Octavia (SK350)	Skoda Octavia RS (SK35x-RS)	Halogen	RHD	TFL_LED ROM from TFL
51	33	Skoda Octavia (SK350)	Skoda Octavia RS (SK35x-RS)	Halogen	LHD	TFL_LED ROM from TFL
52	34	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	RL	RL from TFL ROM 52 ROM from TFL
53	35	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	LHD	TFL_1.separat LL halogen-ROM from TFL
54	36	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	RL	DRL-LowBeams (S) (P)
55	37	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	LHD	DRL LHD-LowBeams (S) (P)
56	38	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	RL	TFL_SH
57	39	Skoda Octavia (SK350)	Skoda Octavia (SK351)	Halogen	LHD	TFL_SH
58	3A	Audi A1 (AU210)	VW Scirocco (VW364)	Halogen	RoW LHD	TFL_S
59	3B	Entfallen	VW Scirocco (VW364)	Xenon	RoW RHD	TFL_S
60	3C	VW Golf (VW360)
Xenon	RoW	TFL_S
61	3D	VW Golf (VW360)
Xenon	NAR	TFL_S
62	3E	VW Golf (VW360)
Halogen	NAR
63	3F	VW Golf (VW360)
Xenon	Ska	TFL_S LED_SBBR
64	40	VW Golf (VW360)
Halogen	RoW
65	41	VW Golf (VW360)
Xenon	RoW	PO_LED
66	42	VW Golf (VW360)
Xenon	Ska	TFL_S_LED
67	43	VW Golf (VW360)
Halogen	Ska	TFL_S LED_SBBR
68	44	VW Golf (VW360)
Xenon	RoW	LED_SBBR
69	45	VW Golf (VW360)
Halogen	Ska	TFL_0_S
70	46	VW Golf Plus (VW369)
Halogen	Ska	TFL_0_S
71	47	VW Golf Plus (VW369)
Xenon	RoW	PO_LED
72	48	VW Golf Plus (VW369)
Xenon	RoW	TFL_LED
73	49	VW Golf Plus (VW369)
Halogen	Ska	TFL_S
74	4A	VW Jetta (VW351)
Xenon	RoW	PO_LED
75	4B	VW Jetta (VW351)
Xenon	RoW	TFL _LED
76	4C	VW Jetta (VW351)
Xenon	NAR	TFL _LED
77	4D	VW Golf/Jetta Variant (VW362)
Xenon	RoW	PO_LED
78	4E	VW Golf/Jetta Variant (VW362)
Xenon	RoW	TFL_LED
79	4F	VW Golf/Jetta Variant (VW362)
Xenon	NAR	TFL_LED
80	50	VW Tiguan (VW316)
Halogen / Xenon	NAR	TFL_1
81	51	VW Tiguan (VW316)
Halogen / Xenon	NAR	TFL_S
82	52	VW EOS (VW465)
Halogen / Xenon	RoW	TFL_1
83	53	VW EOS (VW465)
84	54	VW EOS (VW465)
85	55	VW EOS (VW465)
86	56	Audi TT Coupe (AU354)	VW EOS (VW465)	Halogen	RoW	TFL_S 2 R
87	57	Audi TT Coupe (AU354)	VW EOS (VW465)	Halogen	NAR	TFL_S_II
88	58	Audi TT Coupe (AU354)
Xenon
LED DRL Choming + H SL
89	59	Audi TT Coupe (AU354)
Xenon
LED DRL POL + SL + KZL Choming H SL
90	5A	Skoda Octavia (SK35x)	Skoda Octavia RS (SK35x-RS)	Halogen / Xenon	RL	LED, TFL from Shutter	Skoda Octavia RS (SK35x-RS)-RL-LED DRL Shutter
91	5B	Skoda Octavia (SK35x)	Skoda Octavia RS (SK35x-RS)	Halogen / Xenon	LHD	LED, TFL from Shutter	SK35x LL-RS-LED DRL-ROM shutter
92	5C	VW EOS (VW465FL)
Halogen	RoW	TFL_1_LED 8TA
93	5D	VW EOS (VW465FL)
Xenon	RoW	TFL_1_LED 8TA
94	5E	VW EOS (VW465FL)
Halogen	RoW	TFL_1 8TC_8TD
95	5F	VW EOS (VW465FL)
Xenon	RoW	TFL_1_LED 8TC_8TD
96	60	VW EOS (VW465FL)
Halogen	NAR	TFL_1 8TA
97	61	VW EOS (VW465FL)
Xenon	NAR	TFL_1_Ska 8TA
98	62	VW EOS (VW465FL)
Halogen	RoW/Ska	TFL_1_Ska 8TC_8TD
99	63	VW EOS (VW465FL)
Xenon	RoW/Ska	LED_DRLs TFL_1 8TC_8TD
100	64	Audi R8
101	65	Audi R8
102	66	Audi R8
Halogen / Xenon	USA (SM 0W)	LED DRL without tail
103	67	Audi R8
Halogen / Xenon	USA (SM 0W)	LED DRL with tail
104	68	Audi R8
Xenon / ECE	RoW	Complete LED LED DRL without tail
105	69	Audi R8
Xenon / ECE	RoW	Complete LED, LED DRL with tail
106	6A	Audi R8
Halogen / Xenon	USA (SM 0W)	Complete LED, LED DRL without tail (LED tail without TFL)
107	6B	Audi R8
Halogen / Xenon	USA (SM 0W)	Complete LED, LED DRL with tail (LED rear TFL)
108	6C	Audi A1 (AU210)
Halogen / Xenon
TFL without tail, Halogen/Bulb 8.08.08
109	6D	Audi A1 (AU210)
Halogen / Xenon
TFL with tail, Halogen/ Bulb 8.08.08
110	6E	Audi A1 (AU210)
Halogen / Xenon
TFL without tail, Halogen/ LED 8.08.08
111	6F	Audi A1 (AU210)
Halogen / Xenon
TFL with tail, Halogen/ LED 8.08.08
112	70	Audi A1 (AU210)
Halogen / Xenon
LED TFL without tail, LED TFL/ Bulb 8.08.08
113	71	Audi A1 (AU210)
Halogen / Xenon
LED TFL with tail, LED TFL/ Bulb 8.08.08
114	72	Audi A1 (AU210)
Halogen / Xenon
LED TFL without tail, LED TFL/ LED 8.08.08
115	73	Audi A1 (AU210)
Halogen / Xenon
LED TFL with tail, LED TFL/ LED 8.08.08
116	74	Skoda Superb (SK461)
Halogen / Xenon	China	China without DRL SL with BL-function LED SBBR
117	75	Skoda Superb (SK461)
Halogen / Xenon	China	China without DRL / TFL-ABL SL without BL-function LED SBBR
118	76	Audi TT Coupe (NF) (AU354)
Halogen	NAR	separate TFL without SL in CHO
119	77	Audi TT Coupe (NF) (AU354)
Xenon	NAR	LED DRL + CHO SL
120	78	VW Scirocco (VW364)
Halogen / Xenon	RoW LHD	TFL_S
121	79	VW Scirocco (VW364)
Halogen / Xenon	RoW RHD	TFL_S
122	7A	Audi TT Coupe (NF) (AU354)
Halogen / Xenon	NAR	separate DRL with tail
123	7B	Audi TT Coupe (NF) (AU354)
Halogen / Xenon	NAR	LED DRL with tail
124	7C	Audi A1 (AU210)
Halogen / Xenon
TFL without tail, Halogen/ Bulb (dimmed DRL as taillight)
125	7D	Audi A1 (AU210)
Halogen / Xenon
TFL without tail, Halogen/ LED (dimmed DRL as taillight)
126	7E	Audi Q3 (AU316)	VW Jetta (VW351)	Halogen / Xenon	Südk.	TFL_0 (from 05)
127	7F	Audi Q3 (AU316)	VW Jetta (VW351)	Halogen / Xenon	Südk.	TFL_S (from 35)
128	80	Audi Q3 (AU316)	VW Scirocco (VW364)	Halogen / Xenon	RoW	TFL_0 without NSL
129	81	Audi Q3 (AU316)	VW Scirocco (VW364)	Halogen / Xenon	RoW	TFL_S without NSL
130	82	Audi Q3 (AU316)	VW Scirocco R-SCI (VW364)	Halogen / Xenon	LHD	TFL_1 8TC
131	83	Audi Q3 (AU316)	VW Scirocco R-SCI (VW364)	Halogen / Xenon	RHD	TFL_1 8TA/8TD
132	84	Audi Q3 (AU316)	VW Scirocco R-SCI (VW364)	Halogen / Xenon	Ska LHD	TFL_1 LHD_Ska 8TC
133	85	Audi Q3 (AU316)	VW Scirocco R-SCI (VW364)	Halogen / Xenon	Ska RHD	TFL_1 RL_Ska 8TA/8TD
134	86	VW Jetta (VW351)
Halogen / Xenon	RoW/Ska	TFL_0_Ska
135	87	VW Golf/Jetta Variant (VW352)	VW Golf/Jetta Variant (VW362)	Halogen / Xenon	RoW/Ska	TFL_0_Ska
136	88	VW Scirocco (VW364) LHD
Halogen / Xenon	RoW/Ska LDH	TFL_1 LL_Ska
137	89	VW Scirocco (VW364) RL
Halogen / Xenon	RoW/Ska RHD	TFL_1 RL_Ska
138	8A	VW Tiguan (VW416)	VW Tiguan (VW316)	Halogen / Xenon	RoW/Ska	TFL_1_Ska
139	8B	VW EOS (VW465)
140	8C	VW Jetta (VW361)
141	8D	VW Jetta (VW361)
142	8E	VW EOS (VW465FL)	VW Touran (VW368)	Halogen / Xenon	RoW	TFL_1
143	8F	VW EOS (VW465FL)	VW Touran (VW368)	Halogen / Xenon	RoW/Ska	TTFL_1_Ska
144	90	VW EOS (VW465FL)	VW Touran (VW368)	Halogen / Xenon	RoW	TFL_1_LED
145	91	VW EOS (VW465FL)	VW Touran (VW368)	Halogen / Xenon	RoW/Ska	TFL_1_LED_Ska
146	92	SEAT Alhambra (SE428)
Halogen	RoW	TFL_1
147	93	SEAT Alhambra (SE428)
Xenon	RoW	TFL_1
148	94	VW EOS (VW465)
Halogen / Xenon	NAR	TFL_S, 2 Reverse Lights
149	95	VW Caddy Van (VN337)
150	96	VW Passat (VW411)
151	97	VW Passat (VW411)
Halogen	NAR	TFL_S
152	98	VW Passat (VW411)
Halogen / Xenon	China	TFL_1
153	99	VW Passat (VW411)
Halogen / Xenon	China	TFL_S
154	9A	SEAT Leon (SE350)
Xenon	NAR	TFL_0
155	9B	SEAT Leon (SE350)
Halogen	NAR	TFL_S
156	9C	SEAT Leon (SE350)
Xenon	RoW	TFL_0
157	9D	SEAT Leon (SE350)
Halogen	RoW	TFL_S
ABL: Abblendlicht (low beam)
CHN: China
Gedimmt, ged. (Dimmed)
Heck (stern)
Komplett (totally, completely)
LL: Linkslenker (left hand drive)
Mit, m (with)
NAR: Nord-Amerika (North America Region)
NSL: Nebelschlusslicht (rear fog light)
Ohne, o. (without)
PO, POL: Positionslicht (position or parking light)
RDW: Rest der Welt (Rest of the World)
RFL: Rückfahrlicht (reversing light)
RL: Rechtslenker (right hand drive)
SBBR: Scluss, Brems, blinker, Rückfahr (tail, brake, turn signal, and reverse lights)
Separat, sep. (Separate)
SL: Schlusslicht (tail light)
TFL: Tagfahrlicht (daytime running lights)
XE: Xenon (Xenon)
TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
TFL_SH: TFL mit Shutter (daytime running lights via shutter)
TFL_LED: LED-Modul mit und Doppelfunktion PO TFL (LED module with dual function parking lights and daytime running lights)
TFL_0_S: Sonderlösung Skand., Vorhalt (special Scandinavia derivative solution)
PO_LED: LED-Modul, nur für PO genutzt (led module used only for parking lights)
Sheet 2: Original German
Dec	Hex
1	01	BCM default ROM 1
2	02	VW360 Halogen VW360 RdW TFL_0 ROM 2 VW360 VW360 halogen RdW TFL_0 Rom 2
3	03	VW360 Halogen VW360 NAR TFL_0 ROM 3 VW360 VW360 halogen NAR TFL_0 ROM 3
4	04	VW360 GTI Halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4 VW360 GTI halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4
5	05	VW351 Halogen VW351 RdW TFL_0 ROM 5 VW351 VW351 halogen RdW TFL_0 ROM 5
6	06	VW351 Halogen VW351 NAR TFL_0 ROM 6 VW351 VW351 halogen NAR TFL_0 ROM 6
7	07	VW351C Halogen VW351 CHN TFL_0 ROM 7 VW351C halogen VW351 CHN TFL_0 ROM 7
8	08	VW362 Halogen VW362 RdW TFL_0 ROM 8 VW362 VW362 halogen RdW TFL_0 ROM 8
9	09	VW362 Halogen VW362 NAR TFL_0 ROM 9 VW362 VW362 halogen NAR TFL_0 ROM 9
10	0A	VW364 LL Halogen VW364 RdW TFL_0 LL ROM 10 VW364 VW364 halogen LL LL ROW TFL_0 ROM 10
11	0B	VW364 RL Halogen VW364 RdW TFL_0 RL ROM 11 VW364 VW364 RL halogen RdW TFL_0 RL ROM 11
12	0C	VW367 Halogen VN337 RdW TFL_0 ROM 12 VW367 halogen VN337 RdW TFL_0 ROM 12
13	0D	VW368 Halogen VN337 RdW TFL_0_Ska ROM 13 VW368 halogen VN337 RdW TFL_0_Ska ROM 13
14	0E	VW369 Halogen VW369 RdW TFL_0 ROM 14 VW369 VW369 halogen RdW TFL_0 ROM 14
15	0F	SE350/2 Xenon XENON SE352/7 NAR TFL_0 XE ROM 15 SE350 / SE352 XENON Xenon 2 / 7 NAR TFL_0 XE ROM 15
16	10	SE351/9 Xenon XENON SE351/9 NAR TFL_0 XE ROM 16 SE351 / SE351 XENON Xenon 9 / 9 NAR TFL_0 XE ROM 16
17	11	SE350/2 Halogen Halogen SE352/7 NAR TFL_S ROM 17 SE350 / SE352 2 Halogen Halogen / 7 NAR TFL_S ROM 17
18	12	SE351/9 Halogen Halogen SE351/9 NAR TFL_S ROM 18 SE351 / SE351 9 Halogen Halogen / 9 NAR TFL_S ROM 18
19	13	VW428 Halogen VW428 RdW TFL_1 ROM 19 VW428 VW428 halogen RdW TFL_1 ROM 19
20	14	VW428 XENON VW428 RdW TFL_1 XE ROM 20 VW428 VW428 RdW TFL_1 XENON XE ROM 20
21	15	VW360 GTI Halogen "VW360 RdW TFL_0 +LED SBBR" ROM 21 VW360 GTI halogen "VW360 RdW TFL_0 + LED SBBR" ROM 21
22	16	SE350/2 Xenon XENON SE352/7 RdW TFL_0 XE ROM 22 SE350 / SE352 XENON Xenon 2 / 7 ROW TFL_0 XE ROM 22
23	17	SE351/9 Xenon XENON SE351/9 RdW TFL_0 XE ROM 23 SE351 / SE351 XENON Xenon 9 / 9 ROW TFL_0 XE ROM 23
24	18	SE350/2 Halogen Halogen SE352/7 RdW TFL_S ROM 24 SE350 / SE352 2 Halogen Halogen / 7 ROW TFL_S ROM 24
25	19	SE351/9 Halogen Halogen SE351/9 RdW TFL_S ROM 25 SE351 / SE351 9 Halogen Halogen / 9 ROW TFL_S ROM 25
26	1A	Halogen SK462 ohneTFL / TFL-ABL ROM 26 Halogen SK462 ohneTFL / TFL-ABL ROM 26
27	1B	SK461 Halogen SK461 ohne TFL / TFL-ABL ROM 27 SK461 SK461 halogen without TFL / DRL-ABL ROM 27
28	1C	SK461 Halogen SK461 RdW sep.TFL_1 ROM 28 SK461 SK461 halogen RdW sep.TFL_1 ROM 28
29	1D	SK461 XENON SK356 ASUV TFL_Sep ROM 29 SK461 SK356 XENON ASUV TFL_Sep ROM 29
30	1E	VW360 Halogen "VW351 NAR TFL_0 + SMR auf SL-hinten " ROM 30 VW360 halogen "VW351 NAR TFL_0 + SMR on SL-back" ROM 30
31	1F	VW360 Halogen "VW360 NAR TFL_0+LED SBBR" ROM 31 VW360 halogen "VW360 NAR TFL_0 + LED SBBR" ROM 31
32	20	VW360 Halogen VW360 NAR TFL_0_LED ROM 32 VW360 VW360 halogen NAR TFL_0_LED ROM 32
33	21	VW360 Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 33 VW360 halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 33
34	22	VW360 Halogen "VW360 RdW/Japan+LED_SBBR" ROM 34 VW360 halogen "VW360 ROW / Japan + LED_SBBR" ROM 34
35	23	AU350PA Halogen "VW360 NAR TFL_0_LED+LED_SBBR" ROM 35 AU350PA halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 35
36	24	AU350PA Halogen VW362 RdW TFL_1 ROM 36 AU350PA halogen VW362 RdW TFL_1 ROM 36
37	25	AU350PA Halogen VW364 RdW TFL_0 LL_Ska ROM 37 AU350PA halogen VW364 RdW TFL_0 LL_Ska ROM 37
38	26	AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38 AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38
39	27	AU350PA XENON VW316 RdW TFL_1_Ska ROM 39 AU350PA XENON VW316 RdW TFL_1_Ska ROM 39
40	28	AU350PA XENON VW465 RdW TFL_1_Ska ROM 40 AU350PA XENON VW465 RdW TFL_1_Ska ROM 40
41	29	AU353PA Halogen VW362 RdW TFL_0_Ska ROM 41 AU353PA halogen VW362 RdW TFL_0_Ska ROM 41
42	2A	AU353PA Halogen "TFL mit Heck, AB2 PA 5Türer ECE" ROM 42 AU353PA halogen "TFL rear, AB2 PA 5Doors ECE" ROM 42
43	2B	AU353PA XENON "LED TFL ohne Heck, AB2 PA 5Türer ECE" ROM 43 AU353PA XENON "LED TFL without Heck, PA AB2 5Doors ECE" ROM 43
44	2C	AU353PA XENON "LED TFL mit Heck, AB2 PA 5Türer ECE" ROM 44 AU353PA XENON "LED TFL rear, AB2 PA 5Doors ECE" ROM 44
45	2D	AU356PA Halogen AU356PA RdW TFL_0 ROM 45 AU356PA halogen AU356PA RdW TFL_0 ROM 45
46	2E	AU356PA XENON AU356PA RdW TFL_0 XE ROM 46 XENON XE AU356PA AU356PA RdW TFL_0 ROM 46
47	2F	VW316 Halogen/XENON VW316 RdW TFL_0 ROM 47 VW316 Halogen / Xenon VW316 RdW TFL_0 ROM 47
48	30	VW316 XENON Halogen/XENON VW316 RdW TFL_S ROM 48 VW316 XENON Halogen / Xenon VW316 RdW TFL_S ROM 48
49	31	SK462 Halogen SK462 separat TFL_1 ROM 49 SK462 SK462 halogen separately ROM TFL_1 49
50	32	SK350 Halogen SK35x-RS TFL_LED-RL aus TFL ROM 50 SK350 SK35x halogen-RS-RL TFL_LED ROM from TFL 50
51	33	SK350 Halogen SK35x-RS TFL_LED-LL aus TFL ROM 51 SK350 SK35x halogen-RS-LL TFL_LED ROM from TFL 51
52	34	SK350 Halogen SK351 TFL_1sep. SK350 SK351 TFL_1sep halogen. RL aus TFL ROM 52 RL ROM from TFL 52
53	35	SK350 Halogen SK351 TFL_1.sep LL ausTFL ROM 53 SK350 SK351 halogen TFL_1.sep LL ausTFL ROM 53
54	36	SK350 Halogen SK351 RL TFL-ABL(S) ROM 54 SK350 SK351 halogen RL TFL-ABL (P) ROM 54
55	37	SK350 Halogen SK351 LL TFL-ABL(S) ROM 55 SK350 SK351 halogen LL TFL-ABL (P) ROM 55
56	38	SK350 Halogen SK351 TFL_SH RL ROM 56 SK350 SK351 halogen TFL_SH RL ROM 56
57	39	SK350 Halogen SK351 TFL_SH LL ROM 57 SK350 SK351 halogen TFL_SH LL ROM 57
58	3A	AU210 Halogen VW364 RdW TFL_S LL ROM 58 AU210 halogen VW364 TFL_S ROW ROM 58
59	3B	entfallen XENON VW364 RdW TFL_S RL ROM 59 XENON account VW364 RdW TFL_S RL ROM 59
60	3C	VW360 XENON VW360 RdW XE TFL_S ROM 60 VW360 VW360 RdW XENON XE TFL_S ROM 60
61	3D	VW360 XENON VW360 NAR XE TFL_S ROM 61 VW360 VW360 NAR XENON XE TFL_S ROM 61
62	3E	VW360 Halogen VW360 NAR ROM 62 VW360 VW360 halogen NAR ROM 62
63	3F	VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63 VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63
64	40	VW360 Halogen VW360 RdW ROM 64 VW360 VW360 halogen ROW ROM 64
65	41	VW360 XENON VW360 RdW XE PO_LED ROM 65 VW360 VW360 RdW XENON XE PO_LED ROM 65
66	42	VW360 XENON VW360 Ska XE TFL_S_LED ROM 66 VW360 VW360 Ska XENON XE TFL_S_LED ROM 66
67	43	VW360 Halogen "VW360 Ska TFL_S LED_SBBR" ROM 67 VW360 halogen "VW360 Ska TFL_S LED_SBBR" ROM 67
68	44	VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68 VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68
69	45	VW360 Halogen VW360 Ska TFL_0_S ROM 69 VW360 VW360 halogen Ska TFL_0_S ROM 69
70	46	VW369 Halogen VW369 Ska TFL_0_S ROM 70 VW369 VW369 halogen Ska TFL_0_S ROM 70
71	47	VW369 XENON VW369 RdW XE PO_LED ROM 71 VW369 VW369 RdW XENON XE PO_LED ROM 71
72	48	VW369 XENON VW369 RdW XE TFL_LED ROM 72 VW369 VW369 RdW XENON XE TFL_LED ROM 72
73	49	VW369 Halogen VW369 Ska TFL_S ROM 73 VW369 VW369 halogen Ska TFL_S ROM 73
74	4A	VW351 XENON VW351 RdW XE PO_LED ROM 74 VW351 VW351 RdW XENON XE PO_LED ROM 74
75	4B	VW351 XENON VW351 RdW TFL _LED ROM 75 VW351 VW351 XENON RdW TFL _LED ROM 75
76	4C	VW351 XENON VW351 NAR TFL _LED ROM 76 VW351 VW351 XENON NAR TFL _LED ROM 76
77	4D	VW362 XENON VW362 RdW XE PO_LED ROM 77 VW362 VW362 RdW XENON XE PO_LED ROM 77
78	4E	VW362 XENON VW362 RdW XE TFL_LED ROM 78 VW362 VW362 RdW XENON XE TFL_LED ROM 78
79	4F	VW362 XENON VW362 NAR XE TFL_LED ROM 79 VW362 VW362 NAR XENON XE TFL_LED ROM 79
80	50	VW316 Halogen/XENON VW316 NAR TFL_1 ROM 80 VW316 Halogen / Xenon VW316 NAR TFL_1 ROM 80
81	51	VW316 Halogen/XENON VW316 NAR TFL_S ROM 81 VW316 Halogen / Xenon VW316 NAR TFL_S ROM 81
82	52	VW465 Halogen/XENON VW465 RdW TFL_1 ROM 82 VW465 Halogen / Xenon VW465 RdW TFL_1 ROM 82
83	53	VW465 Halogen/XENON VW465 NAR TFL_1 ROM 83 VW465 Halogen / Xenon VW465 NAR TFL_1 ROM 83
84	54	VW465 Halogen/XENON VW465 RdW TFL_S ROM 84 VW465 Halogen / Xenon VW465 RdW TFL_S ROM 84
85	55	VW465 Halogen/XENON VW465 NAR TFL_S ROM 85 VW465 Halogen / Xenon VW465 NAR TFL_S ROM 85
86	56	AU354 Halogen VW465 RdW TFL_S 2R ROM 86 AU354 halogen VW465 RdW TFL_S 2R ROM 86
87	57	AU354 Halogen VW465 NAR TFL_S_II ROM 87 AU354 halogen VW465 NAR TFL_S_II ROM 87
88	58	AU354 XENON "AU354 TT NF LED TFL+Choming H SL" ROM 88 AU354 XENON "AU354 TT NF LED TFL Choming + H SL" ROM 88
89	59	AU354 XENON "AU354 TT NF LED TFL+POL+SL+KZL+Choming H SL" ROM 89 AU354 XENON "AU354 TT NF LED TFL POL + + SL + + KZL Choming H SL" ROM 89
90	5A	SK35x Halogen/XENON SK35x-RS-RL TFL-LED aus Shutter ROM 90 SK35x Halogen / Xenon SK35x-RS-RL-LED TFL Shutter ROM 90
91	5B	SK35x Halogen/XENON SK35x-RS-LL TFL-LED aus Shutter ROM 91 SK35x Halogen / Xenon SK35x LL-RS-LED TFL-ROM from shutter 91
92	5C	VW465 FL Halogen "VW465FL RdW TFL_1 8TA" ROM 92 VW465 FL halogen "VW465FL RdW TFL_1 8TA" ROM 92
93	5D	VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" ROM 93 VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" ROM 93
94	5E	VW465 FL Halogen "VW465FL RdW TFL_1 8TC_8TD" ROM 94 VW465 FL halogen "VW465FL RdW TFL_1 8TC_8TD" ROM 94
95	5F	VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" ROM 95 VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" ROM 95
96	60	VW465 FL Halogen "VW465FL NAR TFL_1 8TA" ROM 96 VW465 FL halogen "VW465FL NAR TFL_1 8TA" ROM 96
97	61	VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" ROM 97 VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" ROM 97
98	62	VW465 FL Halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" ROM 98 VW465 FL Halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" ROM 98
99	63	VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" ROM 99 VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" ROM 99
100	64	R8 Halogen/XENON "LED TFL ohne Heck, R8 ECE" ROM 100 R8 Halogen / Xenon "LED TFL without tail, R8 ECE" ROM 100
101	65	R8 Halogen/XENON "LED TFL mit Heck, R8 ECE" ROM 101 R8 Halogen / Xenon "LED TFL rear, R8 ECE" ROM 101
102	66	R8 Halogen/XENON "LED TFL ohne Heck, R8 Halogen / Xenon "LED TFL without tail, R8 USA (SM 0W)" ROM 102 R8 USA (SM 0W) "ROM 102
103	67	R8 Halogen/XENON "LED TFL mit Heck, R8 Halogen / Xenon "LED TFL rear, R8 USA (SM 0W)" ROM 103 R8 USA (SM 0W) "ROM 103
104	68	R8 Halogen/XENON "Komplett LED, LED TFL o. Heck, R8 ECE " ROM 104 R8 Halogen / Xenon "Complete LED, LED TFL without a tail, R8 ECE" ROM 104
105	69	R8 Halogen/XENON "Komplett LED, LED TFL m. Heck, R8 ECE" ROM 105 R8 Halogen / Xenon "Complete LED, LED TFL m. Heck, R8 ECE" ROM 105
106	6A	R8 Halogen/XENON "Komplett LED, LED TFL ohne Heck, R8 Halogen / Xenon "Complete LED, LED tail without TFL, R8 USA (SM 0W)" ROM 106 R8 USA (SM 0W) "ROM 106
107	6B	R8 Halogen/XENON "Komplett LED, LED TFL mit Heck, R8 Halogen / Xenon "Complete LED, LED rear TFL, R8 USA (SM 0W)" ROM 107 R8 USA (SM 0W) "ROM 107
108	6C	AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 108 AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb 8:08:08" ROM 108
109	6D	AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ Bulb 8.08.08 " ROM 109 AU210 Halogen / Xenon "TFL rear, halogen AU210 / Bulb 8:08:08" ROM 109
110	6E	AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED 8.08.08 " ROM 110 AU210 Halogen / Xenon "TFL without Heck, AU210 halogen / LED 8:08:08" ROM 110
111	6F	AU210 Halogen/XENON "TFL mit Heck, AU210 Halogen/ LED 8.08.08 " ROM 111 AU210 Halogen / Xenon "TFL rear, AU210 halogen / LED 8:08:08" ROM 111
112	70	AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 112 AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / Bulb 8:08:08" ROM 112
113	71	AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ Bulb 8.08.08 " ROM 113 AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / Bulb 8:08:08" ROM 113
114	72	AU210 Halogen/XENON "TFL ohne Heck, AU210 LED TFL/ LED 8.08.08 " ROM 114 AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / LED 8:08:08" ROM 114
115	73	AU210 Halogen/XENON "TFL mit Heck, AU210 LED TFL/ LED 8.08.08 " ROM 115 AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / LED 8:08:08" ROM 115
116	74	SK461 China Halogen/XENON "SK461-China ohne TFL SL mit BL-Funktion LED SBBR" ROM 116 SK461 China Halogen / Xenon "SK461-China without TFL, SL, BL-function LED SBBR" ROM 116
117	75	SK461 China Halogen/XENON "SK461-China ohne TFL/TFL-ABL SL ohne BL-Funktion LED SBBR" ROM 117 SK461 China Halogen / Xenon "SK461-China without TFL / DRL SL-ABL without BL-function LED SBB
118	76	AU354 Halogen "AU354 TT NF NAR sep TFL ohne SL bei CHO" ROM 118 AU354 halogen "AU354 TT NF NAR sep TFL without SL in CHO" ROM 118
119	77	AU354 XENON "AU354 TT NF NAR LED TFL + CHO SL" ROM 119 AU354 XENON "AU354 TT NF NAR LED TFL CHO + SL" ROM 119
120	78	VW364 LL Halogen/XENON VW364 RdW TFL_S LL ROM 120 VW364 LL Halogen / Xenon VW364 RdW TFL_S LL ROM 120
121	79	VW364 RL Halogen/XENON VW364 RdW TFL_S RL ROM 121 VW364 RL Halogen / Xenon VW364 RdW TFL_S RL ROM 121
122	7A	AU354 Halogen/XENON " sep TFL mit Heck,TTNF, NAR" ROM 122 AU354 Halogen / Xenon "sep TFL rear, TTNF, NAR" ROM 122
123	7B	AU354 Halogen/XENON " LED TFL mit Heck,TTNF, NAR" ROM 123 AU354 Halogen / Xenon "LED TFL rear, TTNF, NAR" ROM 123
124	7C	AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ Bulb (ged. TFL als SL)" ROM 124 AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb (ged. TFL as SL)" ROM 124
125	7D	AU210 Halogen/XENON "TFL ohne Heck, AU210 Halogen/ LED (ged. TFL als SL)" ROM 125 AU210 Halogen / Xenon "DFL without Heck, AU210 halogen / LED (DFL ged. as SL)" ROM 125
126	7E	AU316 Halogen/XENON VW351 Südk. AU316 Halogen / Xenon VW351 Südk. TFL_0 (aus 05) ROM 126 TFL_0 (from 05) ROM 126
127	7F	AU316 Halogen/XENON VW351 Südk. AU316 Halogen / Xenon VW351 Südk. TFL_S (aus 35) ROM 127 TFL_S (from 35) ROM 127
128	80	AU316 Halogen/XENON VW364 RdW TFL_0 o. NSL ROM 128 AU316 Halogen / Xenon VW364 RdW TFL_0 o. NSL ROM 128
129	81	AU316 Halogen/XENON VW364 RdW TFL_S o. NSL ROM 129 AU316 Halogen / Xenon VW364 RdW TFL_S o. NSL ROM 129
130	82	AU316 Halogen / Xenon "VW364 R-SCI TFL_1 LL8TC" ROM 130
131	83	AU316 Halogen / Xenon "VW364 R-SCI TFL_1 RL 8TA/8TD" ROM 131 8TA/8TD "ROM 131
132	84	AU316 Halogen/XENON "VW364 R-SCI TFL_1 LL Ska 8TC" ROM 132 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 LL ska 8TC" ROM 132
133	85	AU316 Halogen/XENON "VW364 R-SCI TFL_1 RL Ska 8TA/8TD" ROM 133 AU316 Halogen / Xenon "VW364 R-SCI TFL_1 RL Ska 8TA/8TD" ROM 133
134	86	VW351 Halogen/XENON VW351 RdW TFL_0_Ska ROM 134 VW351 Halogen / Xenon VW351 RdW TFL_0_Ska ROM 134
135	87	VW352 Halogen/XENON VW362 RdW TFL_0_Ska ROM 135 VW352 Halogen / Xenon VW362 RdW TFL_0_Ska ROM 135
136	88	VW364 LL Halogen/XENON VW364 RdW TFL_1 LL_Ska ROM 136 VW364 LL Halogen / Xenon VW364 RdW TFL_1 LL_Ska ROM 136
137	89	VW364 RL Halogen/XENON VW364 RdW TFL_1 RL_Ska ROM 137 VW364 RL Halogen / Xenon VW364 RdW TFL_1 RL_Ska ROM 137
138	8A	VW416 Halogen/XENON VW316 RdW TFL_1_Ska ROM 138 VW416 Halogen / Xenon VW316 RdW TFL_1_Ska ROM 138
139	8B	VW465 Halogen/XENON VW465 RdW TFL_1_Ska ROM 139 VW465 Halogen / Xenon VW465 RdW TFL_1_Ska ROM 139
140	8C	VW361 Halogen/XENON VW361 RdW TFL_1 ROM 140 VW361 Halogen / Xenon VW361 RdW TFL_1 ROM 140
141	8D	VW361 Halogen/XENON VW361 NAR TFL_1 ROM 141 VW361 Halogen / Xenon VW361 NAR TFL_1 ROM 141
142	8E	VW465 FL Halogen/XENON VW368 RdW TFL_1 ROM 142 VW465 FL Halogen / Xenon VW368 RdW TFL_1 ROM 142
143	8F	VW465 FL Halogen/XENON VW368 RdW TFL_1_Ska ROM 143 VW465 FL Halogen / Xenon VW368 RdW TFL_1_Ska ROM 143
144	90	VW465 FL Halogen/XENON VW368 RdW TFL_1_LED ROM 144 VW465 FL Halogen / Xenon VW368 RdW TFL_1_LED ROM 144
145	91	VW465 FL Halogen/XENON VW368 RdW TFL_1_LED_Ska ROM 145 VW465 FL Halogen / Xenon VW368 RdW TFL_1_LED_Ska ROM 145
146	92	SE428 Halogen SE428 RdW TFL_1 ROM 146 SE428 SE428 halogen RdW TFL_1 ROM 146
147	93	SE428 XENON SE428 RdW TFL_1 XE ROM 147 SE428 SE428 RdW TFL_1 XENON XE ROM 147
148	94	VW465 Halogen/XENON VW465 TFL_S NAR /2RFL ROM 148 VW465 Halogen / Xenon VW465 TFL_S NAR / 2RFL ROM 148
149	95	VN337 Halogen/XENON VN337 RdW TFL_S ROM 149 VN337 Halogen / Xenon VN337 RdW TFL_S ROM 149
150	96	VW411 Halogen/XENON VW411 NAR TFL_1 ROM 150 VW411 Halogen / Xenon VW411 NAR TFL_1 ROM 150
151	97	VW411 Halogen VW411 NAR TFL_S ROM 151 VW411 VW411 halogen NAR TFL_S ROM 151
152	98	VW411 Halogen/XENON VW411 CHN TFL_1 ROM 152 VW411 Halogen / Xenon VW411 CHN TFL_1 ROM 152
153	99	VW411 Halogen/XENON VW411 CHN TFL_S ROM 153 VW411 Halogen / Xenon VW411 CHN TFL_S ROM 153
154	9A	SE350 XENON SE350 NAR TFL_0 XE ROM 154 SE350 SE350 NAR TFL_0 XENON XE ROM 154
155	9B	SE350 Halogen SE350 NAR TFL_S ROM 155 SE350 SE350 halogen NAR TFL_S ROM 155
156	9C	SE350 XENON SE350 RdW TFL_0 XE ROM 156 SE350 SE350 RdW TFL_0 XENON XE ROM 156
157	9D	SE350 Halogen SE350 RdW TFL_S ROM 157 SE350 SE350 halogen RdW TFL_S ROM 157
CHN: China
Heck (stern)
Mit, m (with)
Ohne, o. (without)
XE: Xenon (Xenon)
Sheet 3: model names
Secondary Vehicle
1	01	BCM
7	07	VW Jetta (VW351C)*
10	0A	VW Scirocco (VW364) LL
100	64	Audi R8
101	65	Audi R8
102	66	Audi R8
103	67	Audi R8
104	68	Audi R8
105	69	Audi R8
106	6A	Audi R8
107	6B	Audi R8
120	78	VW Scirocco (VW364) LL
121	79	VW Scirocco (VW364) RL
122	7A	Audi TT Coupe (AU354)
123	7B	Audi TT Coupe (AU354)
130	82	Audi Q3 (AU316)	VW Scirocco (VW364)
131	83	Audi Q3 (AU316)	VW Scirocco (VW364)
132	84	Audi Q3 (AU316)	VW Scirocco (VW364)
133	85	Audi Q3 (AU316)	VW Scirocco (VW364)
136	88	VW Scirocco (VW364) LL
hadez16
C?ID=289891
Please try from 7A to 7D
HeyRobi
C?ID=60441
Thanks for the reply.. But still not right. I tried several codes today but never found one that got it back to stock.
hadez16
C?ID=289891
Then find someone with VCP to fix it manually...
Jeronimo
C?ID=273786
If you don’t mind my asking what is “vcp”?
It is some other software from eastern Europe that allows direct editing of certain things in control modules.
RT won't do some of that stuff because we'd rather you brick your modules with someone else's tool. ;)
Dana
Western PA, USA
I believe the factory coding on 2012 model years was not zeroed (hidden) and configured to 7C or 76. If you didn't try either of those yet please do. Just make sure the battery voltage isn't extremely low while tinkering with Byte 18.
matociso
Verified VCDS-User
Slovakia
C?ID=329999
if you want I can help you with file from VPC from sharan 2016 with LED rear lights configuration (filename.bcm1) but you need to find somebody with VCP with knowledge how to use it, than you can modificate values in eeprom
btw how can I insert file to this forum?
matociso
Verified VCDS-User
Slovakia
C?ID=329999
VCDS is my favorite diagnostic tool, I´m pretty sure you can do it much better then VCP, how much work would be to configure lights like VPC? users can brick stuff anyway...
You cannot. This is intentional. We do not run a file-sharing service. But there are plenty of such services available on the Internet. ;)
lopat84
C?ID=125676
Is there really now way to find out what byte 18 should be ? Would vw dealer would know ? I can't believe it's that difficult as I've said one of these bordnetz had correct code but don't know which one it was.
matociso
Verified VCDS-User
Slovakia
C?ID=329999
find somebody with VCP in your area, I can send you file from sharan FL send me your mail in message if you want
lopat84
C?ID=125676
Could you send me by email ?
[e-mail address redacted]
lopat84
C?ID=125676
Thanks I got it. Should I edit it or write it as it is ? Can I use odis for this?
matociso
Verified VCDS-User
Slovakia
C?ID=329999
just edit your file, dont forget to backup your configuration before modification :) I dont have odis... just VCDS and VCP
