2011 skoda octavia drl problem
mattft86
C?ID=525197
The image you have posted is for a different ABS module and a different instrument cluster.
In the full autoscan you posted, byte 16 in the ABS controller is 34 and I believe bit 2 is TPMS so it's activated.
Ah i see so the tick box in the top pic dose not need to be ticked? It might not be byte 16 on mine but i have seen the same tick box but is unticked.
I can get a screen grab if needed
Also is there any way to recode my lights without a trip to m/d.
   #22
langers2k
C?ID=224085
To recode the lighting config, you need someone either VCP or dealer tools to check and correct the lighting config.
Have you got a drop in HID kit fitted?
I only ask as Module 9, byte 14, bit 3 appears to be checked which I wouldn't expect. The BCM uses the same output pins for controlling the bi-xenon shutter which are connected to the LED DRL on a MK2 FL vRS. I would try unchecking that and see if it helps...
   #23
mattft86
C?ID=525197
No aftermarkt lights are on the car when i unticked the bi-xenon shutter and did a lamp test the drls did not work.
I'll do another full scan and upload it
mattft86
C?ID=525197
Thursday,25,May,2017,16:51:54:05935
VCDS Version: 17.1.3.0 (x64)
VIN: TMBEF21Z6B2107168   License Plate:
Mileage: 95810km-59533mi   Repair Order:
Chassis Type: 1Z (7N0)
VIN: TMBEF21Z6B2107168   Mileage: 95810km-59533miles
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Revision: AAH18---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 73430 790 00084
   VCID: 79FE774D30CE7D89AE-802C
Readiness: 0110 0101
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 163B601C09220001680C06EA90210081340800
   VCID: 75E67B7DDCD619E9CA-8020
   Part No SW: 3T0 907 044 BD    HW: 3T0 907 044 BD
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 75E67B7DD4D619E9CA-8020
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 48000AB8A05BB1C04010008010000964430000AE524D8960808004040040
   VCID: 3878B2498B44A48111-806C
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 17011  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
00984 - Left Tail Light (M4)
                    Fault Status: 00101110
                    Reset counter: 249
                    Mileage: 95813 km
                    Date: 2011.10.16
                    Time: 09:18:11
                        Term 15 On
                    Voltage: 11.85 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Reset counter: 249
                    Mileage: 95813 km
                    Date: 2011.10.16
                    Time: 09:18:11
                    Reset counter: 249
                    Mileage: 95813 km
                    Date: 2011.10.16
                    Time: 09:19:56
                        Term 15 On
                    Voltage: 13.95 V
                        Term 50 Off
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC235WLP
   Coding: 0020788
   VCID: 3D76A35D646681A9C2-8068
   Subsystem 1 - Serial number: 6332MSME5B2218000
   Subsystem 2 - Serial number: 6342MSME5A360558E
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20110122301821
   Coding: 5080140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 77FA7175CEDA6BF9D8-8022
   Part No SW: 1Z0 920 903 L    HW: 1Z0 920 903 L
   Component: KOMBI         H05 0405
   Coding: 410A01
   Shop #: WSC 73430 031 00084
   VCID: 3E74A451A1609AB1DB-806A
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 150111F1000395
   Coding: 351303
   VCID: 30688A6963347CC159-8064
   Component: IMMO          H05 0405
   VCID: 6ADC58018D68C61157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2120
   Coding: 0000756
   Shop #: WSC 73430 790 00085
   VCID: 4898C2893BA4D40161-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 34608679572C40E13D-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479AC1B536BADB7968-8012
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0054
   Revision: 0A001001    Serial number: SKZ1Z3L9437719
   Coding: 050004000001
   VCID: 3566BB7D9C5659E90A-8060
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012565
   VCID: 326C8061AD384ED12F-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33628565522247D924-8066
End-------------------------(Elapsed Time: 01:58)--------------------------
image of my tpms. Sorry its added to my facebook my photobuckt is not working
   #25
langers2k
C?ID=224085
PR-7K3/7K4/7K5 are direct TPMS systems.
You almost certainly have PR-7K6/7K9 which is indirect and doesn't need byte 8, bit 8 checking.
When I last had a TPMS warning on my Octavia, it had dropped to 25 psi from 34 psi when the light came on.
mattft86
C?ID=525197
Right ok so thats one thing that may still work then.
I just got off the phone to the dealer and its going in for warranty to have the lights re'done. I take it they have software that can do it?
   #27
Warranty on a 2011 car? Did you recently buy it used from a Skoda dealer?
   #28
mattft86
C?ID=525197
   #29
langers2k
C?ID=224085
A Skoda dealer should have the tools to fix the lighting config, whether they know how to is a different question :)
   #30
mattft86
C?ID=525197
It's gone into Skoda themselves
   #31
Skoda UK or a Skoda dealer? Dealers are not Skoda, they are franchises.
It would be very unusual for Skoda UK to get directly involved with a 6 year old car.
mattft86
C?ID=525197
I'm not sure who they are I took the car to the dealer I got it from and they sent me round to a Skoda dealerships that has a workshop. They called me yesterday afternoon and said the control module was faulty and they were waiting for the Warranty company to authorise a replacement part
   #33
So you bought the car from a non-Skoda dealer - which means the warranty will be from a third party warranty company, and Skoda UK are not involved.
It's a small point, but it's important to understand the difference between a Manufacturer (Skoda Auto a.s.), an importer (Skoda UK), a franchised dealer and a non-franchised car seller.
   #34
mattft86
C?ID=525197
Not that it matters but I got the car from Caffyns ŠKODA Ashford
   #35
So are you saying that Caffyns Skoda Ashford don't have a workshop? If they do, they why did they send you to another Skoda dealer?
It sounds to me like you are being given the "runaround"... which isn't uncommon with UK Skoda dealers as their product knowledge is, in most but not all cases, very poor to non-existent.
   #36
mattft86
C?ID=525197
No that's who I brought it from but from the showroom round the other side. I didn't know the side I took the car back to was even there haha. I'll find out wed what's going on. It went in for a wobble at 70mph plus and oil around the turbo
   #37
Sounds like you're not having much luck - DRL problems, TPMS problems - and now a wobble plus oil round the turbo.
   #38
mattft86
C?ID=525197
Tell me about it but the tpms might be ok someone else said they lost almost 10 psi be for it went off I never lost that much. I'm hoping they've found the other problems though
   #39
mattft86
C?ID=525197
Well I picked my car up yesterday all fixed and didn't cost a penny. Thanks everyone that tried to help fix my problem.
   #40
langers2k
C?ID=224085
Can you add a new autoscan? Curious to see if there were any coding changes :)
