I purchased a T5 van which had crashed. I knew the previous owner had done some work - replacement steering wheel i think - at least it doesn't look like it's fired. Also passenger facia shows signs of having been opened.
I now want to fix all faults, back to a healthy and safe condition. I will purchase new/used(but good) seatbelt tensioners etc..
Question - will I need to replace the associated airbag sensors on the vehicle? or just the airbags and seat belt pre-tensioners as listed in the scan.
Thanks, Sean
Thanks, Sean
Tuesday,16,May,2017,16:18:28:63214
VCDS Version: 17.1.3.0 (x64)
VIN: License Plate: SEAT BELTS T5
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Control Module Part Number: 1C0 909 605 A
Component and/or Version: 3C AIRBAG VW51 0011
Software Coding: 13123
Work Shop Code: WSC 02736
VCID: 224BDFCDAE391F51DF-5106
10 Faults Found:
00595 - Crash Data Stored
35-00 - -
01214 - Crash Data for Belt Tensioner Stored
35-00 - -
32-10 - Resistance Too High - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00532 - Supply Voltage B+
33-10 - Resistance Too Low - Intermittent
29-10 - Short to Ground - Intermittent
28-10 - Short to Plus - Intermittent
