I bought a touareg 4.2tdi riddled with fault codes
Joris
C?ID=185465
I bought it with some front damage, but there are more problems. I made an autoscan, tried te delete as much codes as possible and ended up with still a lot of fault codes. Some worry me like the DPF error. Any advise where to start?
I already tried to do a service regen on the DPF but with no luck, it sais it cannot continue due to fault. I made sure all requirements were met, so coolant temp above 70C, handbrake deployed, hood closed, all consumers on. the dpf counters did get reset, dont know how that happened.
Also tried to recalibrate the parking brake with no luck. The coding was wrong, so I searched the forum for parking brake coding on the touareg and found this one. Now the parking brake works again, but it has to be recalibrated, but it will not do that.
I ordered a new steering angle sensor because it would not recalibrate anymore. Found a topic over here with the same issues, the ts solved it with a new steering angle sensor so fingers crossed..
Dinsdag,07,April,2020,16:53:30:11641
VCDS -- VAG/VAS Emulator onder Windows Loopt op Windows 10 x64
VCDS Versie: PRI 19.6.2.1
Data versie: 20191020 DS308.0
Chassisnummer: WVGZZZ7PZBD025545   Kenteken:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 20 28 34
          36 3C 42 46 52 53 55 56 5F 62 65 69 6C 6D 72 85 8B 8E 8F 90
Chassisnummer: WVGZZZ7PZBD025545   KM-stand: 80407km
01-Motor -- Status: Functioneert niet 0010
02-Autom. Transm. -- Status: OK 0000
03-ABS Remmen -- Status: Functioneert niet 0010
04-Stuurhoeksensor -- Status: OK 0000
05-Toegang/Start Id. -- Status: OK 0000
06-Stoel Geheugen,R -- Status: OK 0000
08-Airco/Verwarming -- Status: Functioneert niet 0010
09-Cent. Elect. -- Status: Functioneert niet 0010
0E-Media Speler 1 -- Status: OK 0000
10-Park/Stuurassist -- Status: Functioneert niet 0010
11-Motor II -- Status: Functioneert niet 0010
31-Motor Verbinding -- Status: Functioneert niet 0010
13-Auto Afst. Reg. -- Status: Wordt niet bereikt 0100
15-Airbags -- Status: Functioneert niet 0010
16-Stuurwiel -- Status: Functioneert niet 0010
17-Instrumenten -- Status: Functioneert niet 0010
18-Extr. Verwarming -- Status: Functioneert niet 0010
19-CAN Gateway -- Status: Functioneert niet 0010
20- 20-Groot Licht Ass. -- Status: Wordt niet bereikt 0100
28-Airco/Verw. achter -- Status: Functioneert niet 0010
34-Niveau Regeling -- Status: Functioneert niet 0010
36-Stoel Geheugen,L -- Status: OK 0000
3C-Baanwisselass. -- Status: OK 0000
42-Deur Electr. LV -- Status: Functioneert niet 0010
46-Comfortsysteem -- Status: Functioneert niet 0010
52-Deur Electr. RV -- Status: OK 0000
53-Handrem -- Status: Functioneert niet 0010
55-Xenon Niveau -- Status: Functioneert niet 0010
5F-Info Electr. -- Status: Functioneert niet 0010
62-Deur Electr. LA -- Status: OK 0000
65-Bandenspanning -- Status: Functioneert niet 0010
69-Aanhanger -- Status: OK 0000
6C-Achteruit Camera -- Status: Functioneert niet 0010
6D-Electr. Kofferd. -- Status: OK 0000
72-Deur Electr. RA -- Status: OK 0000
85-Camera -- Status: Functioneert niet 0010
8B-Adaptieve Cruise 2 -- Status: Functioneert niet 0010
8E-Beeldverwerking -- Status: Functioneert niet 0010
8F-Voorspan. Linksvoor  -- Status: Functioneert niet 0010
90-Voorspan. Rechtsvoor -- Status: Functioneert niet 0010
Adres 01: Motor (J623-CKDA)       Labels:. 057-907-409-CKD.clb
   Onderdeelnr. SW: 7P0 907 409     HW: 7P0 907 409
   Component: 4.2TDI EDC17  H17 0007
   Revisie: 52H17---
   Codering: 292A401A437E00020000
   Dealer #: WSC 59434 001 104857
   ASAM Dataset: EV_ECM42TDI1117P0907409 001016
   ROD: EV_ECM42TDI1117P0907409.rod
   VCID: 74E70023DF9656EFB2-8020
4 foutcodes gevonden:
11279 - Roetfilter cilinderrij 2
          P24A3 00 [167] - Roetbelasting te hoog
          MIL AAN - Niet Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Status: 00000001
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Motortoerental: 700.50 /min
                    Genorm. bel.waarde: 21.6 %
                    Rijsnelheid: 0 km/h
                    Koelvloeistoftemperatuur: 74 °C
                    Aanzuigluchttemperatuur: 29 °C
                    Buitenluchtdruk: 1020 mbar
                    Spanning contact 30: 14.620 V
                    Verleerteller na OBD: 40
                    Roetfilter: roetmassa gemeten: 3.43 g
                    Roetfilter: roetmassa berekend: 0.78 g
                    Roetfilter: afstand sinds laatste regeneratie: 0 m
                    Uitlaatgasvolumestroom in roetfilter: 51.3 m³/h
                    Uitlaatgastemperatuurvoeler 3: 122.3 °C
                    Roetfilter cilinderrij 2: roetmassa gemeten: 2.42 g
                    Uitlaatgastemp.voeler 3: cilinderrij 2: -273.1 °C
7150 - Stuurkolomelektronica
          P1698 00 [039] - Storinggeheugen afvragen
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Motortoerental: 688.50 /min
                    Genorm. bel.waarde: 27.8 %
                    Rijsnelheid: 0 km/h
                    Spanning contact 30: 14.640 V
                    CAN TimeOut teller - accuregelaar-Bits 0-7: 00000000
                    CAN status - motorregelapparaat-Bits 0-7: 00000000
                    Snelheidsregelsysteem: status-Bits 0-7: 11010100
                    CAN TimeOut teller - gateway-Bits 0-7: 00000000
                    CAN TimeOut teller - stuurinslag-Bits 0-7: 00001001
                    CAN TimeOut teller - parkeerrem-Bits 0-7: 00000000
                    CAN TimeOut teller - versn.bak-Bits 0-7: 00000000
4709 - Afstandsregeling
          U0235 00 [039] - Geen communicatie
          [Nieuwe functie! Uitgebreide UDS fout informatie is alleen beschikbaar bij de nieuwe interfaces]
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Motortoerental: 692.00 /min
                    Genorm. bel.waarde: 27.5 %
                    Rijsnelheid: 0 km/h
                    Begrenzing: gaspedaal: 0.0 Nm
                    CAN status - versn.bakregelapparaat-Bits 0-7: 00000000
                    CAN status - regelapparaat remmen 1-Bits 0-7: 00000000
                    CAN status - regelapparaat remmen 2-Bits 0-7: 00000000
                    ingeschakelde versnelling-Bits 0-7: 00000000
11281 - Roetfilter cilinderrij 2
          P2003 00 [039] - Onjuiste werking
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Rijsnelheid: 0 km/h
                    P Flt Ld dvol P Flt EG Flt B1 mp: 60.9 m³/h
                    Roetfilter cilinderrij 2: roetmassa berekend: 48.20 g
                    Exh p P Flt Diff B1: 8 hPa
                    Exh p P Flt Diff B2: 6 hPa
Gereedheid: 0 0 0 0 1
Adres 02: Autom. Transm. (J217)       Labels:| 0C8-927-750.clb
   Onderdeelnr. SW: 0C8 927 750 J    HW: 0C8 927 750 J
   Component: AL1000 AISIN  001 1822
   Serienummer:
   Codering: 001168
   Dealer #: WSC 99999 999 83333
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 3365C33F9A1811D76B-8066
Geen foutcodes gevonden.
Adres 03: ABS Remmen (J104)       Labels:* 7P0-907-379.clb
   Onderdeelnr. SW: 7P0 907 379 E    HW: 7P0 907 379 A
   Component: MK25A         H33 0416
   Revisie: --------    Serienummer: 432100010EC010
   Codering: 5B6B53C30B262F58DAF9CA97D0D7F4407700
   Dealer #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 3F8D9F0FA650C5B79F-806A
199176 - Sensor voor stuurhoek
          B1168 29 [137] - Signaal ongeldig
          MIL AAN - Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 13:49:09
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 18
199182 - Sensor voor stuurhoek
          B1168 04 [137] - Interne systeemfout
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 13:49:09
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 01 24
818436 - Databus ontbrekende info
          U1121 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 13:48:39
                    Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 00 00 00 01 20 34
337668 - Databus ontbrekende info
          U1121 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 13:48:39
                    Standard Freeze  Frame Dynamic: 00 3C 00 00 00 00 00 00 00 00 01 20 0E
Adres 05: Toegang/Start Id. (J393)       Labels:. 8K0-907-064-05.clb
   Onderdeelnr. SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
   Component: BCM2 2.0      H23 0208
   Revisie: 00002001
   Codering: 05860000000000000000
   VCID: 6FED0F4FBEB075374F-803A
   Subsysteem 1 - Onderdeelnr. SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serienummer: 2310000032123013
Adres 06: Stoel Geheugen,R (J521)       Labels: Geen
   Onderdeelnr. SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Revisie: AA000000    Serienummer: 00001002082708
   Codering: 0018330000004201000001010101202020202121202020
   VCID: 3467C023971616EF72-8060
Adres 08: Airco/Verwarming (J255)       Labels:| 7P6-907-040.clb
   Onderdeelnr. SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
   Component: Klima 4 Zonen H18 0613
   Codering: 38D6007E60
   VCID: 7CF72803F7C61EAFFA-8028
3 foutcodes gevonden:
0267 - Sensor voor koelmediumdruk en -temperatuur
          B10C2 21 [008] - Signaal Amplitude < minimum
          Geregeld - Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Prioriteit: 7
                    Fout Frequentie: 4
                    Reset Teller: 115
                    KM-stand: 80407 km
                    Datum: 2020.04.06
                    Tijd: 13:43:38
0410 - Functiebeperking wegens ongeldige informatie
          U1112 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:08:37
0519 - Stelmotor voor indirecte ventilatieklep links
          B12A1 31 [009] - Geen signaal
             Freeze frame:
                    Fout Prioriteit: 3
                    Fout Frequentie: 14
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:08:37
Adres 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
   Onderdeelnr. SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0083
   Revisie: 15012002    Serienummer: 00000000709595
   Codering: 22001011D1B45D010021000380005D0C431C67080A000241800000020000
   Dealer #: WSC 59434 001 1048576
   VCID: 2959215740D45B07D1-807C
   Subsysteem 1 - Onderdeelnr. SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    101113  31  0020
   Serienummer: 90243400101116055000
   Codering: 004DBD
   Subsysteem 2 - Onderdeelnr. SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serienummer: 10089124
   Codering: 035223
   Subsysteem 3 - Onderdeelnr. SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serienummer: 00000000002910100508
   Subsysteem 4 - Onderdeelnr. SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0275
   Serienummer: WA101803000000119127
   Codering: 010300
2 foutcodes gevonden:
00466 - Regelapparaat voor stuurkolomelektronica (J527)
            013 - AUB Storingsgeheugen afvragen
             Freeze frame:
                    Fout Status: 01101101
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.05
                    Tijd: 11:08:00
01771 - Regelapp. lichtbundelhoogteverstelling (J431)
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 8
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.06
                    Tijd: 16:49:00
Adres 0E: Media Speler 1 (R161)       Labels: Geen
   Onderdeelnr. SW: 4H0 035 108 B    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0140
   Revisie: AA001001
   Codering: 010000
   VCID: 1F4D3F8F0E90A5B7BF-804A
Adres 10: Park/Stuurassist (J446)       Labels:| 7P6-919-475.clb
   Onderdeelnr. SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revisie: --------    Serienummer: 38931031402002
   Codering: 518501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55A15DA7342C2FE7A5-8000
1112596 - Sensor voor parkeerhulp rechtsvoor
          B10FA 14 [009] - Onderbreking/kortsluiting met massa
             Freeze frame:
                    Fout Prioriteit: 3
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:07:01
1112340 - Sensor voor parkeerhulp rechtsvoor midden
          B10F9 14 [009] - Onderbreking/kortsluiting met massa
             Freeze frame:
                    Fout Prioriteit: 3
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:07:01
Adres 11: Motor II (J624)       Labels:. 057-907-409-CKD.clb
   Revisie: 52H17---
   ASAM Dataset: EV_ECM42TDI2117P0907409 001016
   ROD: EV_ECM42TDI2117P0907409.rod
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Motortoerental: 689.00 /min
                    Genorm. bel.waarde: 27.1 %
                    Rijsnelheid: 0 km/h
                    Buitenluchtdruk: 1030 mbar
                    Snelheidsregelsysteem: status-Bits 0-7: 00000000
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:28:41
                    Motortoerental: 694.50 /min
                    Genorm. bel.waarde: 23.1 %
                    Rijsnelheid: 0 km/h
Adres 13: Auto Afst. Reg.
Wordt niet bereikt
Adres 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Onderdeelnr. SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag007 H05 0023
   Revisie: --------    Serienummer: 003JX000SDKU
   Codering: 000000000000000000000000000000003037
   VCID: 408F9CF3DBAEBA4FE6-8014
   Ongevalsensor voor zij-airbag: bestuurderszijde:
   Serienummer: 3575LRB404P07EHK589K
   Ongevalsensor voor zij-airbag: bijrijderszijde:
   Serienummer: 3585LRB405R085FME8AQ
   Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
   Serienummer: 3515RRB404T053R4CHO-
   Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
   Serienummer: 3525RRB404T053R4B140
   Ongevalsensor voorairbag: bestuurderszijde:
   Serienummer: 3555NRB405T0QBGIEOOZ
   Ongevalsensor voorairbag: bijrijderszijde:
   Serienummer: 3565NRB405P0QBGIL16+
1 Fout Gevonden:
9437211 - Ontsteker voor bestuurdersairbag
          B1000 1B [137] - Weerstand te hoog
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    KM-stand: 80407 km
                    Datum: 2020.04.06
                    Tijd: 15:25:07
Adres 16: Stuurwiel (J527)       Labels:. 4H0-953-568.clb
   Onderdeelnr. SW: 4H0 953 568 B    HW: 7P6 953 507 G
   Component: Lenks.Modul   H08 0007
   Revisie: --------    Serienummer: 90815JK50002N
   Codering: 000C9D
   VCID: 326BC63B6D0218DF60-8066
00778 - Sensor stuurhoek (G85)
            014 - defekt
             Freeze frame:
                    Fout Status: 01101110
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.06
                    Tijd: 16:48:50
             Freeze frame:
                    (geen eenh.): 53.0
                    Tekst: 35950000461FFC1FFF
                    Temperatuur: -0.0°C
                    Zijdel. accel.: 195.84 m/s*2
                    Tekst: 3B95FF5F12F4042413
                    Temperatuur: -127.5°C
                    Absolute druk: 39.0 mbar
                    KM-stand: 51160 km
01426 - Bedieningseenheid in stuurwiel (E221)
            004 - Geen Signaal/Communicatie
             Freeze frame:
                    Fout Status: 01100100
                    Fout Prioriteit: 2
                    Fout Frequentie: 19
                    Reset Teller: 0
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.06
                    Tijd: 16:48:50
Adres 17: Instrumenten (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Onderdeelnr. SW: 7P6 920 881 A    HW: 7P6 920 881 A
   Component: Kombi         H12 0235
   Revisie: 10240060    Serienummer: 658211110593004
   Codering: 131733007F080008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3A7BEE1BBD72E09FA8-806E
16776960 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:04:52
16776961 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:04:52
Adres 18: Extr. Verwarming (J364)       Labels:. 8R0-265-105.clb
   Onderdeelnr. SW: 7P0 963 272 B    HW: 7P0 963 272 B
   Component: Standheizung  H23 0240
   Revisie: 56005006    Serienummer: 20101105111326
   Codering: 594200
   VCID: 3663FA2B816A04FF4C-8062
1 Fout Gevonden:
02251 - Kachel vergrendeld
             Freeze frame:
                    Fout Status: 01100000
                    Fout Prioriteit: 5
                    Fout Frequentie: 1
                    Reset Teller: 255
                    KM-stand: 79873 km
                    Tijd Indicatie: 0
                    Datum: 2018.02.14
                    Tijd: 14:44:26
             Freeze frame:
                    Temperatuur: 84.0°C
                    Temperatuur: 87.0°C
                    Voltage: 12.60 V
                        Regelpauze
                    Foutcode: 8
                    Temperatuur: 4.0°C
                    t/min: 654 /min
                        Nee
Adres 19: CAN Gateway (J533)       Labels:* Geen
   Onderdeelnr. SW: 7P6 907 530 D    HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5202
   Revisie: --------    Serienummer: 00000000056177
   Codering: 0001037D00
   Dealer #: WSC 131071 1023 2097151
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3979F117B874EB87A1-806C
   Regelapparaat voor accubewaking:
   Subsysteem 1 - Onderdeelnr. SW: 7P0 915 181 A    HW: 7P0 915 181
   Serienummer: 00000000005659328394
5701 - Regelapparaat voor grootlichthulp
          U1070 00 [009] - Geen communicatie
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:03:42
                    Spanning contact 30: 12.3 V
                    Spanning contact 15: 12.2 V
                    Regelapparaattemperatuur: 30 °C
                    Systeemstatus: Contact 15 aan
                    IN ESP_Stillstandsflag: no standstill detected
                    Motor draait: uit
                    IN ZAS_Kl_X: aan
                    status contact 15 via CAN: aan
                    Status contact 15: aan
                    Datenfeld: 0
4365 - Afstandsregeling
          U0235 00 [009] - Geen communicatie
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:03:42
                    Motor draait: uit
                    IN ZAS_Kl_X: aan
                    Datenfeld: 0
15360512 - Componentenbescherming actief
          U1101 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 1
                    Fout Frequentie: 9
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:15:01
                    Spanning contact 30: 12.2 V
                    Spanning contact 15: 12.1 V
                    Regelapparaattemperatuur: 33 °C
                    Motor draait: uit
                    IN ZAS_Kl_X: aan
                    Datenfeld: 0
Adres 20:  20-Groot Licht Ass.
Wordt niet bereikt
Adres 28: Airco/Verw. achter (E265)       Labels:* Geen
   Onderdeelnr. SW: 7P6 907 049 F    HW: 7P6 907 049 F
   Component: Klima Fond    H13 0613
   Dealer #: WSC 00000 000 00000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
1 Fout Gevonden:
0092 - Lokale databus
          U1030 00 [009] - Elektrische storing
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 14
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 11:02:03
Adres 34: Niveau Regeling (J197)       Labels:. 7P0-907-553.clb
   Onderdeelnr. SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revisie: 00000000    Serienummer: 00000103130040
   Codering: 15210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
0807 - Beperkte werking
          C10C2 00 [137] - -
             Freeze frame:
                    Fout Frequentie: 75
                    Reset Teller: 1
                    KM-stand: 524544 km
                    Datum: 2055.11.01
                    Tijd: 06:28:60
                    Default: 00
                    Default: 83
                    Default: 00
12656777 - Databus ontvangen storingswaarde
          U1123 00 [009] - -
             Freeze frame:
                    Fout Frequentie: 75
                    Reset Teller: 1
                    KM-stand: 524544 km
                    Datum: 2055.11.01
                    Tijd: 06:28:60
                    Default: 00
                    Default: 83
                    Default: 00
12656679 - Databus ontbrekende info
          U1121 00 [009] - -
             Freeze frame:
                    Fout Frequentie: 75
                    Reset Teller: 1
                    KM-stand: 524544 km
                    Datum: 2055.11.01
                    Tijd: 06:28:60
                    Default: 00
                    Default: 83
                    Default: 00
Adres 36: Stoel Geheugen,L (J136)       Labels: Geen
   Revisie: AA000000    Serienummer: 00001002194790
   Codering: 00183B0000004201000001010101202020202121202020
Adres 3C: Baanwisselass.        Labels: Redir Fout!
   Onderdeelnr. SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0110
   Revisie: 00H03000    Serienummer: 6PZ 010 316-01
   Codering: 0010151
   VCID: 7EF3220B29DA0CBFD4-802A
   Subsysteem 1 - Onderdeelnr.: 7P6 907 568
   Component: J770  SWA Slave H01 0110
   Subsysteem 2 - Serienummer: 6PZ 010 316-21
   Subsysteem 3 - Serienummer: 5F28.10.1000H010003C520137ÿ
   Subsysteem 4 - Serienummer: 520137ÿ
Adres 42: Deur Electr. LV (J386)       Labels:. 4H0-959-793.clb
   Onderdeelnr. SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revisie: --------    Serienummer: 0000107831282
   Codering: 011D1620DE00459205080003
   VCID: 3B75EB1FBA48D997B3-806E
03297 - Contactschakelaar in slotcilinder; bestuurderszijde
            008 - Onaannemelijk signaal
             Freeze frame:
                    Fout Status: 01101000
                    Fout Prioriteit: 3
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.05
                    Tijd: 11:00:05
02115 - Sloteenheid voor centr. vergrendeling
             Freeze frame:
                    Fout Prioriteit: 3
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.06
                    Tijd: 11:54:51
Adres 46: Comfortsysteem (J393)       Labels:. 4H0-907-064-46.clb
   Revisie: 00002001    Serienummer: 0137645683
   Codering: 019A1E2028B91095832006202F0000000000000000000000000000000000
   Subsysteem 1 - Onderdeelnr.: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsysteem 2 - Onderdeelnr.: 1K0 951 605 C
   Subsysteem 3 - Onderdeelnr. SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H05 0006
   Serienummer:     WOO1083540
   Codering: 191100
   Subsysteem 4 - Onderdeelnr. SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H06 0006
   Serienummer:     WOO1073381/
   Codering: 191100
1 Fout Gevonden:
01319 - Regelapparaat voor afstandsregeling (J428)
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.05
                    Tijd: 10:59:28
Adres 52: Deur Electr. RV (J387)       Labels:. 4H0-959-792.clb
   Onderdeelnr. SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revisie: --------    Serienummer: 0000110083759
   Codering: 011D1620DE00459205080000
Adres 53: Handrem (J540-)       Labels:| 7P0-907-801.clb
   Onderdeelnr. SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revisie: 00000000    Serienummer: A10A2000368
   Codering: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 3467C0239F1616EF72-8060
   Slave 1:
   Slave 3:
0025 - Geen basisafstelling
          B2010 F0 [008] - Afwijking ligt buiten verwachte gebied
             Freeze frame:
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:10:53
                    Voltage: 14.4 V
0024 - Geen basisafstelling
          B2010 00 [009] - -
             Freeze frame:
                    Fout Frequentie: 1
                    Voltage: 12.2 V
          U1121 00 [009] - -
             Freeze frame:
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 15:56:15
                    Voltage: 12.2 V
Adres 55: Xenon Niveau (J745)       Labels:. 7P6-907-357.clb
   Onderdeelnr. SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revisie: --------    Serienummer: --------------
   Codering: 012A00104F000200
   Subsysteem 1 - Onderdeelnr. SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0010
   Codering: 190000
   Subsysteem 2 - Onderdeelnr. SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Codering: 130000
13636608 - Regelapparaat verkeerd gecodeerd
          U1014 00 [137] - -
             Freeze frame:
                    Fout Prioriteit: 1
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 17:22:39
5276401 - Vermogensmodule koplamp rechts
          C1082 F1 [137] - Verkeerd gecodeerd
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 17:22:39
13705992 - Databus ontvangen storingswaarde
          U1123 00 [137] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 17:22:39
13705995 - Databus ontvangen storingswaarde
          U1123 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 30
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 17:22:39
Adres 56: Radio (R)       Labels: Redir Fout!
   Onderdeelnr. SW: 4G0 035 053 A    HW: 4G0 035 053
   Component: Radio U Basic H52 0050
   Revisie: AB001007    Serienummer: 050K-0A7529641
   Codering: 010005020100000001
   VCID: 1C3708831F86BEAF5A-8048
Adres 5F: Info Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Onderdeelnr. SW: 7P6 035 670     HW: 7P6 035 670
   Component: H-BNT-EU      H43 0203
   Revisie: --------    Serienummer: 478KB0A7526649
   Codering: 010100050040EBEF79102B0E00000003F0040101
   VCID: 72EB063BAD8258DFA0-8026
   Subsysteem 1 - Onderdeelnr.: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsysteem 2 - Onderdeelnr. SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H24 0045
   Serienummer: VWZ8Z9K2800GBJ
   Subsysteem 3 - Onderdeelnr. SW: 7P6 919 603     HW: 7P6 919 603
   Subsysteem 4 - Onderdeelnr.: 8R0 060 961
   Component: CD-Database  1886
1 Fout Gevonden:
03157 - Beperkte werking wegens communicatiestoring
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 2
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Tijd Indicatie: 0
                    Datum: 2020.04.05
                    Tijd: 10:55:02
             Freeze frame:
                    Bin. bits: 00000000 00100000
                    Bin. bits: 00001000 00000000
                    Bin. bits: 00000000 00000000
Adres 62: Deur Electr. LA (J388)       Labels:. 4H0-959-795.clb
   Onderdeelnr. SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revisie: --------    Serienummer: 0000110119070
   Codering: 011C16200000259005080000
   VCID: 3A7BEE1BB572E09FA8-806E
Adres 65: Bandenspanning (J502)       Labels: 3Y0-907-273.clb
   Onderdeelnr. SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serienummer: 10000000016059
   ROD: EV_RDKBERU25_VW52.rod
1 Fout Gevonden:
8402177 - Systeem uitgeschakeld
          C106D 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 7
                    Fout Frequentie: 1
                    Reset Teller: 39
                    KM-stand: 79872 km
                    Datum: 2018.03.14
                    Tijd: 12:24:58
Adres 69: Aanhanger (J345)       Labels: Redir Fout!
   Onderdeelnr. SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revisie: 5A001001    Serienummer: 00008200796325
   Codering: 0100000000000000
Adres 6C: Achteruit Camera (J928)       Labels:| 7P6-907-441-V1.clb
   Onderdeelnr. SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Component: TopView       H05 0097
   Revisie: 11001001    Serienummer: 82330010114871
   Codering: 0100000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
5 foutcodes gevonden:
13701890 - Databus ontvangen storingswaarde
          U1123 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:51:55
                    Spanning contact 30: 12.1 V
                    Status contact 15: Contact 15 aan
9616922 - Voedingsspanning afstandscontrolecamera voor
          B1284 14 [009] - Onderbreking/kortsluiting met massa
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 42
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:51:55
9616433 - Kabel voor videosignaal van afstandscontrolecamera voor
          B1278 01 [009] - Electrische storing
             Freeze frame:
                    Fout Prioriteit: 3
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:51:55
9616790 - Afstandscontrolecamera voor
          B127C 54 [009] - Kalibratie niet aanwezig
             Freeze frame:
                    Fout Prioriteit: 5
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:51:56
10489856 - Geen basisafstelling
          B2010 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 2
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:51:56
Adres 6D: Electr. Kofferd. (----)       Labels:| 7N0-959-107.clb
   Onderdeelnr. SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revisie: 09145444    Serienummer: 310000028
   Codering: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
Adres 72: Deur Electr. RA (J389)       Labels:. 4H0-959-795.clb
   Component: TSG HR        H09 0162
   Revisie: --------    Serienummer: 0000110119376
Adres 85: Camera (J852)       Labels:| 7P6-907-217.clb
   Onderdeelnr. SW: 7P6 907 217 A    HW: 7P6 907 217
   Component: DPC-SG        H22 0033
   Revisie: --------    Serienummer: 262130025421000
   Codering: ED070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 387FF413837EF28F5E-806C
   Slave 1:
   Subsysteem 1 - Onderdeelnr.: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serienummer: 000000003020741_1011
0723 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:57:09
                    Buitentemperatuur: -41.5 °C
                    Regelapparaattemperatuur: 31.0 °C
0724 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:57:09
Adres 8B: Adaptieve Cruise 2        Labels:. 4H0-907-561.clb
   Onderdeelnr. SW: 7P6 907 541 A    HW: 7P6 907 541
   Revisie: J428     Serienummer: 00000000000000
   Codering: 05
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526_001.rod
10 foutcodes gevonden:
94720 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:43:45
95232 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 3
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:47:36
                    Regelapparaattemperatuur: 28 °C
                    Spanning contact 15: 0.000 V
38912 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:41:11
                    Regelapparaattemperatuur: 24 °C
38656 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 115
                    KM-stand: 80384 km
                    Datum: 2000.00.00
                    Tijd: 00:00:00
21760 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 115
                    KM-stand: 80407 km
                    Datum: 2020.04.06
                    Tijd: 16:48:16
77312 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:41:10
77568 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 75
                    KM-stand: 80407 km
                    Datum: 2020.04.07
                    Tijd: 16:41:11
105472 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [000] - -
          Geregeld - Niet Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Status: 00000000
                    Fout Prioriteit: 0
                    Fout Frequentie: 0
                    Reset Teller: 0
                    KM-stand: 23 km
                    Datum: 2020.04.07
                    Tijd: 16:43:45
0000 - ROD - Onbekende Fout Code
          - 00 [000]
          - 00 [009]
Adres 8E: Beeldverwerking (J851)       Labels:| 7P6-907-107.clb
   Onderdeelnr. SW: 7P6 907 107 A    HW: 7P6 907 107
   Component: BV-SG         H28 0031
   Serienummer: 000040192709107
   Codering: 0AA03E000000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
   VCID: 3663FA2B896A04FF4C-8062
0012 - Beperkte werking
          U1400 00 [008] - door onderspanning
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 3
                    Reset Teller: 111
                    KM-stand: 80262 km
                    Datum: 2018.08.29
                    Tijd: 05:11:32
                    Buitentemperatuur: 11.0 °C
                    Spanning contact 15: 7.9 V
                    Regelapparaattemperatuur: 12.0 °C
0045 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 19
                    Reset Teller: 71
                    KM-stand: 80175 km
                    Datum: 2018.07.08
                    Tijd: 09:26:51
                    Buitentemperatuur: 11.5 °C
                    Spanning contact 15: 11.8 V
                    Regelapparaattemperatuur: 24.0 °C
0046 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 19
                    Reset Teller: 71
                    KM-stand: 80175 km
                    Datum: 2018.07.08
                    Tijd: 09:26:51
Adres 8F: Voorspan. Linksvoor  (J854)       Labels: 4H0-980-94x-RGS.clb
   Onderdeelnr. SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Codering: 006606000317037F00033811594097000000
   Dealer #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169C937600423C719-8064
12583680 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:50:12
12583693 - Functiebeperking wegens ontbrekende informatie
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:50:12
12584197 - Functiebeperking door ontvangen storingwaarde
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:50:12
15360768 - Componentenbescherming actief
          U1101 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 1
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:50:12
Adres 90: Voorspan. Rechtsvoor (J855)       Labels: 4H0-980-94x-RGS.clb
   Onderdeelnr. SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Codering: 00660600031F037F00033811594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326BC63B650218DF60-8066
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:49:33
          U1111 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:49:33
          U1113 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:49:33
          U1101 00 [009] - -
             Freeze frame:
                    Fout Prioriteit: 1
                    Fout Frequentie: 1
                    Reset Teller: 74
                    KM-stand: 80407 km
                    Datum: 2020.04.05
                    Tijd: 10:49:33
Einde----------------------(Tijd verstreken: 07:19)------------------------
I hope it is not a problem that it is in Dutch, My vcds version is in Dutch.
Thanx!
For the purpose of posting data in this forum, you can download the standard English version from this page. It will happily co-exist on with the Dutch translation you are currently using.
In addition, please Get Verified.
PS: Moving from General VW/Audi Repair (which is for questions that don't involve VCDS) to New User section.
Joris
C?ID=185465
Got verified..
Steering angle sensor came in and it calibrated, so that works.
New scan in English:
Wednesday,08,April,2020,15:08:32:11641
VCDS Version: 20.4.0.1 (x64)
VIN: WVGZZZ7PZBD025545   License Plate:
VIN: WVGZZZ7PZBD025545   Mileage: 80407km-49962miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 0100
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CKDA)       Labels:. 057-907-409-CKD.clb
   Part No SW: 7P0 907 409     HW: 7P0 907 409
   Revision: 52H17---
   Coding: 292A401A437E00020000
   Shop #: WSC 59434 001 104857
   VCID: 74E70023DF96562616-8020
11279 - Particle Filter (Bank 2)
          P24A3 00 [167] - Excessive Soot Accumulation
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:46:18
                    Coolant temperature: 20 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.020 V
                    Particle filter: soot mass measured: 2.89 g
                    Particle filter: soot mass calculated: 1.14 g
                    Particle filter: kilometers since last regeneration: 0 m
                    Exhaust gas jet volume in particle filter: 150.0 m³/h
                    Exh.gas temp.sen 3: 21.9 °C
                    Particle filter bank 2: soot mass measured: 2.14 g
                    Exhaust temperature sensor 3: bank 2: -273.1 °C
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:46:18
                    CAN status - engine control module-Bits 0-7: 00000000
                    Cruise Control System (CCS): status-Bits 0-7: 11010100
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    selected gear-Bits 0-7: 00000000
11281 - Particulate Trap Bank 2
          P2003 00 [039] - Efficiency Below Threshold
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:46:18
                    P Flt Ld dvol P Flt EG Flt B1 mp: 45.0 m³/h
                    Particle filter bank 2: soot mass calculated: 48.55 g
                    Exh p P Flt Diff B1: 4 hPa
                    Exh p P Flt Diff B2: 2 hPa
   Part No SW: 0C8 927 750 J    HW: 0C8 927 750 J
   Coding: 001168
   Shop #: WSC 99999 999 83333
   VCID: 3365C33F9A18111ECF-8066
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 E    HW: 7P0 907 379 A
   Revision: --------    Serial number: 432100010EC010
   Coding: 5B6B53C30B262F58DAF9CA97D0D7F4407700
   Shop #: WSC 31414 790 00001
   VCID: 3F8D9F0FA650C57E3B-806A
818436 - Databus
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:47:15
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 34
337668 - Databus
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:47:15
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 01 20 0E
   Part No SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
   Coding: 05860000000000000000
   VCID: 6FED0F4FBEB075FEEB-803A
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2310000032123013
   Revision: AA000000    Serial number: 00001002082708
   Coding: 0018330000004201000001010101202020202121202020
   VCID: 3467C02397161626D6-8060
   Part No SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
   Coding: 38D6007E60
   VCID: 7CF72803F7C61E665E-8028
0519 - Positioning Motor for Left Indirect Vent Flap
          B12A1 31 [009] - No Signal
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:48:47
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000000709595
   Coding: 22001011D1B45D010021000380005D0C431C67080A000241800000020000
   Shop #: WSC 59434 001 1048576
   VCID: 2959215740D45BCE75-807C
   Serial number: 90243400101116055000
   Coding: 004DBD
   Serial number: 10089124
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Serial number: 00000000002910100508
   Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Serial number: WA101803000000119127
   Coding: 010300
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 B    HW: 4H0 035 108
   Revision: AA001001
   VCID: 1F4D3F8F0E90A57E1B-804A
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Revision: --------    Serial number: 38931031402002
   Coding: 518501
   VCID: 55A15DA7342C2F2E01-8000
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [009] - Open or Short to Ground
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:49:50
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [009] - Open or Short to Ground
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:49:50
Address 11: Engine II (J624)       Labels:. 057-907-409-CKD.clb
   Revision: 52H17---
          U0235 00 [039] - -
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:46:18
                    Voltage terminal 30: 12.040 V
                    Cruise Control System (CCS): status-Bits 0-7: 00000000
Address 13: Auto Dist. Reg
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Revision: --------    Serial number: 003JX000SDKU
   Coding: 000000000000000000000000000000003037
   VCID: 408F9CF3DBAEBA8642-8014
   Serial number: 3575LRB404P07EHK589K
   Serial number: 3585LRB405R085FME8AQ
   Serial number: 3515RRB404T053R4CHO-
   Serial number: 3525RRB404T053R4B140
   Serial number: 3555NRB405T0QBGIEOOZ
   Serial number: 3565NRB405P0QBGIL16+
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JD90001D
   Coding: 000C9D
   VCID: 326BC63B6D021816C4-8066
   Serial number: 0012780
   Part No SW: 7P6 920 881 A    HW: 7P6 920 881 A
   Revision: 10240060    Serial number: 658211110593004
   Coding: 131733007F080008000004
   VCID: 3A7BEE1BBD72E0560C-806E
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:51:57
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:51:57
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
   Revision: 56005006    Serial number: 20101105111326
   Coding: 594200
   VCID: 3663FA2B816A0436E8-8062
02251 - Heater Unit Locked
                    Mileage: 79873 km
                    Date: 2018.02.14
                    Time: 14:44:26
                    Temperature: 84.0°C
                    Temperature: 87.0°C
                    Voltage: 12.60 V
                        Ctrl. Pause
                    Error Code: 8
                    Temperature: 4.0°C
                    RPM: 654 /min
                        No
   Part No SW: 7P6 907 530 D    HW: 7P6 907 530
   Revision: --------    Serial number: 00000000056177
   Coding: 0001037D00
   VCID: 3979F117B874EB4E05-806C
   Serial number: 00000000005659328394
5701 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:52:53
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 29 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:52:53
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 20: High Beam Assist.
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 F    HW: 7P6 907 049 F
   Coding: 0000000000
   ROD: EV_AirCondiHeck_VW52.rod
0092 - Local Databus
          U1030 00 [009] - Electrical Malfunction
                    Fault Frequency: 19
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 11:02:03
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Revision: 00000000    Serial number: 00000103130040
   Coding: 15210001
0840 - Comfort limitation
          C10D7 00 [137] - -
                    Fault Frequency: 75
                    Reset counter: 1
                    Mileage: 661248 km
                    Date: 2068.03.22
                    Time: 25:04:60
                    Default: 00
                    Default: 70
                    Default: 00
12656679 - Databus
                    Fault Frequency: 75
                    Reset counter: 1
                    Mileage: 661248 km
                    Date: 2068.03.22
                    Time: 25:04:60
                    Default: 00
                    Default: 70
                    Default: 00
   Revision: AA000000    Serial number: 00001002194790
   Coding: 00183B0000004201000001010101202020202121202020
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Revision: 00H03000    Serial number: 6PZ 010 316-01
   Coding: 0010151
   VCID: 7EF3220B29DA0C7670-802A
   Subsystem 1 - Part No: 7P6 907 568
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F28.10.1000H010003C520137ÿ
   Subsystem 4 - Serial number: 520137ÿ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Revision: --------    Serial number: 0000107831282
   Coding: 011D1620DE00459205080003
   VCID: 3B75EB1FBA48D95E17-806E
03297 - Switch in Lock Cylinder; Driver Side
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 11:00:05
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.06
                    Time: 11:54:51
   Revision: 00002001    Serial number: 0137645683
   Coding: 019A1E2028B91095832006202F0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Serial number:     WOO1083540
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Serial number:     WOO1073381/
   Coding: 191100
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:59:28
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Revision: --------    Serial number: 0000110083759
   Coding: 011D1620DE00459205080000
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Revision: 00000000    Serial number: A10A2000368
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 3467C0239F161626D6-8060
   Slave 1:
   Slave 3:
0024 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:55:52
                    Voltage: 11.8 V
12656679 - Databus
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:55:37
                    Voltage: 11.8 V
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Coding: 012A00104F000200
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Coding: 190000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
          U1014 00 [137] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 17:22:39
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 17:22:39
13705992 - Databus
                    Reset counter: 115
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 17:22:39
13705995 - Databus
                    Fault Frequency: 37
                    Reset counter: 115
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 17:22:39
   Part No SW: 4G0 035 053 A    HW: 4G0 035 053
   Revision: AB001007    Serial number: 050K-0A7529641
   Coding: 010005020100000001
   VCID: 1C3708831F86BE66FE-8048
   Part No SW: 7P6 035 670     HW: 7P6 035 670
   Revision: --------    Serial number: 478KB0A7526649
   Coding: 010100050040EBEF79102B0E00000003F0040101
   VCID: 72EB063BAD82581604-8026
   Subsystem 1 - Part No: 8R0 060 884 R
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Serial number: VWZ8Z9K2800GBJ
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:55:02
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Revision: --------    Serial number: 0000110119070
   Coding: 011C16200000259005080000
   VCID: 3A7BEE1BB572E0560C-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Serial number: 10000000016059
8402177 - System Switched Off
          C106D 00 [009] - -
                    Reset counter: 39
                    Mileage: 79872 km
                    Date: 2018.03.14
                    Time: 12:24:58
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Revision: 5A001001    Serial number: 00008200796325
   Coding: 0100000000000000
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Revision: 11001001    Serial number: 82330010114871
   Coding: 0100000001010000010102000000
9616922 - Supply Voltage for Front Surroundings Camera
          B1284 14 [009] - Open or Short to Ground
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:56:14
                    Voltage terminal 30: 11.8 V
9616433 - Video Signal Line for Front Surroundings Camera
          B1278 01 [009] - Electrical Failure
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:56:14
9616790 - Front Surroundings Camera
          B127C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:56:14
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:56:14
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Revision: 09145444    Serial number: 310000028
   Coding: 0533314003
   Revision: --------    Serial number: 0000110119376
   Part No SW: 7P6 907 217 A    HW: 7P6 907 217
   Coding: ED070000
   VCID: 387FF413837EF246FA-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Serial number: 000000003020741_1011
0723 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 115
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:57:09
                    Outside air temperature: -41.5 °C
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 31.0 °C
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:57:09
Address 8B: Adaptive Cruise 2        Labels:. 4H0-907-561.clb
   Part No SW: 7P6 907 541 A    HW: 7P6 907 541
   Revision: J428     Serial number: 00000000000000
   Coding: 05
10 Faults Found:
94720 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:59:16
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 0.000 V
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 15:02:58
                    Control Module temperature: 26 °C
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
38912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
38656 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
21760 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
77312 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
77568 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
                    Reset counter: 75
                    Mileage: 80407 km
                    Date: 2020.04.08
                    Time: 14:57:33
0000 - ROD - Unknown Error Code
          - 00 [000]
          - 00 [009]
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 A    HW: 7P6 907 107
   Serial number: 000040192709107
   Coding: 0AA03E000000
   ROD: EV_BTR_002.rod
   VCID: 3663FA2B896A0436E8-8062
0012 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 111
                    Mileage: 80262 km
                    Date: 2018.08.29
                    Time: 05:11:32
                    Outside air temperature: 11.0 °C
                    Voltage terminal 15: 7.9 V
                    Control Module temperature: 12.0 °C
0045 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 21
                    Reset counter: 115
                    Mileage: 80175 km
                    Date: 2018.07.08
                    Time: 09:26:51
                    Outside air temperature: 11.5 °C
                    Control Module temperature: 24.0 °C
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 19
                    Reset counter: 71
                    Mileage: 80175 km
                    Date: 2018.07.08
                    Time: 09:26:51
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 006606000317037F00033811594097000000
   Shop #: WSC 00001 790 00001
   ROD: EV_RGS_L_VW52.rod
   VCID: 3169C9376004230EBD-8064
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:50:12
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:50:12
12584197 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 115
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:50:12
15360768 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:50:12
   Coding: 00660600031F037F00033811594097000000
   ROD: EV_RGS_R_VW52.rod
   VCID: 326BC63B65021816C4-8066
          U1111 00 [009] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:49:33
          U1111 00 [009] - -
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:49:33
          U1113 00 [008] - -
                    Reset counter: 115
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:49:33
                    Reset counter: 74
                    Mileage: 80407 km
                    Date: 2020.04.05
                    Time: 10:49:33
End-------------------------(Elapsed Time: 07:10)--------------------------
filled out the form, installed english version :thumbs:
I will post a new scan later
OK, moving this to Car Repair Support.
So looking at that scan, a lot of "Missing Message" faults. These are not surprising since your 13 - Auto Dist. Reg and your 20 - High Beam Assist modules are both off-line. Have you got wiring diagrams for this vehicle yet?
is the PSI sensor signal line clear?
Have you tried chemical removal or manual remediation of the DPF yet and verify the PSI sensor is working or reporting properly by correlating to other bank with mighty vac?
Did you know some have had good luck with a reverse flow enema using emulsifiers injected up the tail pipes and empty out forward OXS with a block plate installed to stop ingress to engine and turbo charger?
Joris
C?ID=185465
I have the reparaturleitfaden electrische anlage in pdf, but am not the best in reading those diagrams. Can i upload pdf's to the forum?
Joris
C?ID=185465
I bought 2 bottles of dpf cleaner to throw in the tank, and am going to try that first.
Joris
C?ID=185465
another question, in adress 34 level control there are faults with very high milage reading and 50 years in the future, if I erase those they come back immediately. The air suspension seems to work fine. Any idea how to get rid of those?
The second one ("Missing Messages") is due to the ACC being off-line. I would assume this is also triggering the first one.
Joris
C?ID=185465
I tried to get ACC back online, no luck yet. Did get the parking assist fixed, including topview.
Today I receive the goods to change de brake pads front and rear, so the parking brake error should be history too. Found a youtube video how to grind the pads in and recalibrate the airgap for het parking brake. Hopfully it works.
Joris
C?ID=185465
Made a log with various sensors, are de 02 sensor readings strange? Does not matter if the engine runs or not, unplugging them while running makes no difference at all.
                Address 01: Engine  (7P0 907 409 )
12:24:23
  IDE00558   Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor) 0.350 Lambda / 0.000 V
  IDE03582   Temperature sensor for engine temperature management 24.7 °C
  IDE04369   Exhaust temperature sensor 3: bank 2 48.6 °C
  IDE04395   Exhaust temperature sensor 1: bank 2 105.9 °C
  IDE04675   O2 sensor 1 bank 1: air flow volume 0.0 g
  IDE04824   O2 sensor 1 bank 2: air flow volume 3276.7 g
