DSG ERROR GOLF 7 2012
trioauto
Malawi
Hi Guys,
please assit on the below fault, we have also recently bought the HEX 2 and VCDS in order to get this care sortred and back on the road, hoping the issue isnt major.
Monday,04,November,2019,10:55:27:13642
VIN: WVWZZZAUZDW029152   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZAUZDW029152   Mileage: 93620km-58172miles
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4530
   Revision: 00043014    Serial number: CU501409156854
   Shop #: WSC 00078 790 12345
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 76B41CFEE8446917E3B-8022
10703 - Gear 7
          P073C 00 [010] - Not Selectable
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 10:49:52
                    Engine speed: 4159.75 /min
                    Engine torque: 920 Nm
                    Vehicle speed: 255 km/h
                    Control Module temperature: 215 °C
                    CURRENT pressure: 7.0 bar
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 100.0 %
                    DTC memory status: 65280
End----------(Elapsed Time: 01:27, VBatt start/end: 13.7V/13.7V)-----------
Monday,04,November,2019,11:09:25:13642
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                Address 02: Auto Trans       Labels: 0CW-927-769.CLB
Control Module Part Number: 0CW 300 045     HW: 0AM 927 769 G
  Component and/or Version: GSG DQ200-MQB H43 4530
           Software Coding: 0014
            Work Shop Code: WSC 00078 790 12345
              ASAM Dataset: EV_TCMDQ200021 001001 (VW37)
10697 - Gear 1
          P072C 00 [010] - Not Selectable
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 11:08:58
                    Engine speed: 12863.75 /min
                    CURRENT pressure: 10.0 bar
                    Driving position: N
10704 - Gear R
          P072B 00 [010] - Not Selectable
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 11:09:07
                    CURRENT pressure: 13.5 bar
                    Driving position: N
PetrolDave
Westbury, UK
C?ID=1423
It would help if you post the full unedited VCDS Auto-Scan not just a couple of short edited sections - the details of the other ECUs will likely provide some extra information.
trioauto
Malawi
]Monday,04,November,2019,12:18:21:13642
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 7862
   Revision: WAH08---
   Coding: 01250032232405083000
   Shop #: WSC 27202 001 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016G 002011
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 26140CBE7864599793B-8072
Readiness: 1110 0001
10704 - Gear R
          P072B 00 [008] - Not Selectable
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 12:08:16
                    Engine speed: 2367.75 /min
                    CURRENT pressure: 11.0 bar
                    Driving position: N
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA8AA1202212750378060501C52980510448C0608094F3002A502AC1
   Shop #: WSC 28856 001 1048576
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7DA603D2CD723A4FA21-8028
0297 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 8
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:25
          C1146 02 [009] - Signal Failure
                    Fault Frequency: 9
                    Reset counter: 224
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:34
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0186354857
   Coding: 030C0C
   VCID: 79AE17C2D95A066F8E9-802C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00120014200100011005000012101800
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 3634DCFEA8C4291723B-8062
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 223
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:24
          B10CD 00 [009] - -
                    Reset counter: 224
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:24
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011231000887
   Coding: 03111A46C24122FB0FA44080B10C0728180A000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46D4AC3ED824B997B3B-8012
   Component: WWS    110929  042 0551
   Serial number:         111216120620
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y12M10D25H11M54S55S4
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY1226417T3
   Serial number: 00000000000055195252
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO18053731
   Coding: 181901
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131226403218
   Coding: 0131061051
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3D26C3D28DF2FA4FE21-8068
13637426 - Databus
                    Reset counter: 9
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:24
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Serial number: 003M1R00GJRT
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4ACC980ECC3C5DF7573-801E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945     HW: 5G0 980 945
   Component: BeltPretRevFL  H07 0022
   Serial number: 34120599B22101240406
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946     HW: 5G0 980 946
   Component: BeltPretRevFR  H07 0022
   Serial number: 34120598B22101240580
   Subsystem 3 - Part No SW: -----------    HW: 480 003 010 12
   Serial number: 3576700000086A3D0C0.
   Subsystem 4 - Part No SW: -----------    HW: 480 002 910 12
   Serial number: 3586700000046B4D0C0-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 911 12
   Serial number: 3516502B70D63B324231
   Subsystem 6 - Part No SW: -----------    HW: 480 400 911 12
   Serial number: 35265029B0D19C4611FJ
   Subsystem 7 - Part No SW: -----------    HW: 480 400 211 12
   Serial number: 3556502A70D19C4190CI
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 9
                    Mileage: 93620 km
                    Date: 2019.11.03
                    Time: 00:26:24
   Part No SW: 5Q0 953 507 BK    HW: 5Q0 953 549
   Revision: --------    Serial number: 2009120003006A
   Coding: 0400
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 00587A26BA8057A7C97-8054
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         235 0555
   Coding: 27A401182B90000801086A00040000
   VCID: 65964BB245E2928F5A1-8030
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1109
   Revision: --------    Serial number: 0000141398
   Coding: 030100042B086400EF00064E1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 3430E6F6BEB83B071DF-8060
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H12 0034
   Serial number: 02120003955190080291
   Coding: 290000
   Serial number: 3192518401
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 12000211922002
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B225EAFB367C3FC45-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593 A
   Component: TSG FS        H12 0006
   Serial number: 18101200010044
   Coding: 003B1220D001048000001000
   VCID: 3FDAB9DA87FEE85FF0D-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000314032
   Coding: 0D0000
   Coding: 83
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592 A
   Component: TSG BFS       H12 0006
   Serial number: 16101200010272
   Coding: 003B1020DE01048000801000
   VCID: 3E24C4DE80F4E157FBB-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000306571
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E00000B010200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
End----------(Elapsed Time: 01:21, VBatt start/end: 12.7V/12.7V)-----------
trioauto
Malawi
OK, will post the full version
myounus
Northwest UK
C?ID=321059
Hi
Can you use ensure the battery is sufficiently charged, use the function 'clear all DTC's' and then re-run a scan.
trioauto
Malawi
Monday,04,November,2019,17:11:10:13642
   Revision: WAH08---
10697 - Gear 1
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 17:09:15
                    Engine speed: 12095.75 /min
                    CURRENT pressure: 8.5 bar
                    Driving position: N
   Coding: 030C0C
   Revision: 00001K06
                    Reset counter: 224
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 17:08:01
   Coding: 0E4DD5
   Coding: 00A8DD
   Sun Roof:
   Coding: 181901
   Coding: 0131061051
   Coding: 0400
   Coding: 290000
   Coding: 0D0000
   Coding: 83
   Coding: 050000
   Coding: 2E0000
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 045     HW: 5G0 035 045
   Component: MU-H-N-RW     H40 0061
   Serial number: A061H0C7506182
   Coding: 02730007FF00000021110001001000001F0100060100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 5DE663526DB2DA4F821-8008
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M23005R9
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1007
          B201A 00 [009] - -
                    Reset counter: 224
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 17:08:06
                    Voltage terminal 30: 14.2 V
                    Status_Software_Version_Management-SW_VersMgtInfo: A   DUV101/ABT
2563 - Navigation System
          B126C F1 [009] - Navigation Database Missing
                    Reset counter: 224
                    Mileage: 93620 km
                    Date: 2019.11.04
                    Time: 17:08:03
End----------(Elapsed Time: 01:26, VBatt start/end: 14.1V/14.2V)-----------
PetrolDave
Westbury, UK
C?ID=1423
10697 - Gear 1
Mileage: 93620 km
Date: 2019.11.04
Time: 17:09:15
Driving position: N
B201A 00 [009] - -
Reset counter: 224
Mileage: 93620 km
Date: 2019.11.04
Time: 17:08:06
Seems like the engine rpm, torque and vehicle speed are being seen incorrectly by the TCM?
Side issue - looks like you've updated the firmware of 5F and haven't cleared the resulting SVM error, see below.
1) 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
2) Note your current coding
3) Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
4) Calculation: (current coding) Xor C9D2
5) Change the adaptation channel to the new code (Don't be surprised if it changes back to the original coding, this is normal!)
6) VCDS main screen, 'Auto-Scan'
7) Check for fault codes on all modules and clear the DTCs
Note that VCDS displays your code in 'xx xx' format (small letters and a space character).
You have to remove the space before you calculate your new code.
When you enter your new (calculated) code, insert the space again and use lower cases.
EXAMPLE (don't use these values):
'1a 1a' (original coding of the adaptation channel)
1A1A Xor C9D2 equals D3C8
Enter it as 'd3 c8'
If your original code starts with zero(s) just remove them before calculating (i.e. 0A fb=AFB).
If the new (calculated) code is less than 4 characters, insert zeros in the beginning (i.e. FBB=0f bb).
OP is now Verified, moving to Car Repair Support.
Have any parts in this car been replaced?
trioauto
Malawi
Ok Im gonna give this shot in the morning as its 6:30pm here in Malawi. Will
Keep you posted... thanks
trioauto
Malawi
We have a VW dealer in Malawi, that pretty much fails at everything u ask them to do, anyway to give you exact info on this car here goes:
Client called us 8 weeks ago, saying her car wouldnt engage in gear, we sent out our recovery truck to collect it and bring it over to our auto shop for investigations. At the time we used our Launch x431 diagnostic system which pointed to the Mechatronics being faulty. pump pressure too low, changed dsg oil to see if that would help but it didnt.
Since our VW dealer didn’t have parts and techs to do this job (the techs left due to greener pastures) we decided to send the whole box with the Mechatronic to South Africa, where an approved VW DSG shop confirmed it needed and Mechatronic replaced, so we got that replaced at a crazy price... the Gearbox was then sent back to us a few weeks ago and was meant to be plug and play, but till date we are struggling to get this car sorted.
The company that installed the Mechatronic is confident that they have done all required and so they also are lost as to what this issue may be..
Golftwincharged
Guyana
C?ID=320847
another fail DSG7 BOX ; common fault is mech unit valve body, and gearbox selector fork ; sounds like the shop didnt do a good job ,troubleshoot as follows :
1. use vcds "The Removal Position Basic Setting group number is 062"
2. Remove mechatronic unit (7 bolts to be removed)
3. confirm the Reverse and 6th Gear selector fork in the Gearbox is not stuck (damaged bearings)
- all four selector forks need to move in three positions (Gear|Neutral|Gear), the upper left is the concerned fork 6 and reverse, usually it cannot move the the further left (reverse gear) bearings damaged failing to move.
IF CONFIRMED ALL SELECTOR FORKS ARE OK:
4. the Mechatronic unit valvebody has the problem, simple interchange tcm to another mech unit valve body and installed mechatronic unit correctly according to Repair manual.
5. one litre mech unit hydraulic fluid and 2 litre 75W gear oil .
GOOD LUCK!
trioauto
Malawi
Thanks For the Above, i removed the mechatronic as instructed and checked accordingly. i can confirm the fork for R and 7 isn't stuck in the gear box though I did find it a little stiff though compared to the others.. maybe that is an issue?
Golftwincharged
Guyana
C?ID=320847
no! once it moves your okay, the fact that it moves not a problem, the lever tool T10407 is applied those forks will feel with tension, if you disengage the lever tool, and check the forks are way more easy to move :) , time to get a new Mech unit Valve-body.
trioauto
Malawi
Sorry for the silence, sooooo.... we got a brand new mechatronic and TCU, precoded from VW South Africa, arrived late this afternoon, plugged it all in and gave it a try.... no luck... same error, gear not selectable.... i have a gut feeling the clutch isnt engaging at all.. meeds shimming maybe? i cant think of anything else after replacing the TCU and Mechatronic...
Any ideas?
myounus
Northwest UK
C?ID=321059
Can you post another scan, am keen to seen the readings by the TCM.
Golftwincharged
Guyana
C?ID=320847
what are the current codes now? is the magnets inside gearbox in-tact?
trioauto
Malawi
Sorry for the very very late reply... the TCU coding was the issue, dealer sorted it in 2 hours...delivered the car to client after testing it for 4 days and made sure no errors popped up on VCDS.
Thank you all
Have an awesome 2020!!
So what was the correct coding? Do you have a scan of it in its final, road-worthy condition?
