Saturday,13,October,2018,11:25:44:30801
VCDS Version: 18.9.0.1
Dealer/Shop Name: Avtomehanika J**** H*****, s.p.
VIN: WAUZZZ4G0CN106543 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56 5F
62 6D 72 8F 90
VIN: WAUZZZ4G0CN106543 Mileage: 167651km-104173miles
Address 01: Engine (J623-CGLC) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2746
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 04730 995 106411
ASAM Dataset: EV_ECM20TDI01103L906018LA 003010
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 74E32FE0DFC37EEAC2-8020
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 06A087016005E1809B00
VCID: 3667D5E8893F2CFA3C-8062
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Coding: 03A93006000000000000
VCID: 76E715E8C1BF6CFAFC-8022
Component: J764 ELV MLB H39 0046
Serial number: 2311000234758006
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 21
Mileage: 167651 km
Date: 2018.10.13
Time: 10:51:02
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0063
Serial number: 18121100040588
Coding: 34020008A0
ASAM Dataset: EV_AirCondiBasisUDS 002039
VCID: 23411CBC2AADA952EB-8076
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BM HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0111
Revision: 19012002 Serial number: 00000001165644
Coding: 2600201040349F608481008480001D0CCF9C870826090101800004602100
VCID: 74E32FE0D7C37EEAC2-8020
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111121 H35 0051
Serial number: 111209201241
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11563881
Coding: 02532C
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 06 12 2011 00000378
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103152000000517750
Coding: 020300
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 491882E5000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901134401213
Coding: 080207
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B71C4DCB21DF192C3-806E
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG004LFNF
Coding: 30323436313230303031554A304C34473053
Serial number: 3575HRB404V1082GA9B%
Serial number: 3585HRB405H11FPIA0AA
Serial number: 3515JRB40610U2UUFOA8
Serial number: 3525JRB40670U2UUD9A+
Serial number: 3554VRB40590U2UUIGS0
Serial number: 3564VRB404P0U2UU50FH
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111214001256
Coding: 000015
VCID: 306BE3F0635B02CA66-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 931 N HW: 4G8 920 931 N
Component: TDieRdw H79 0416
Revision: 28460
1 Serial number: 658161211592020
Coding: 13A410000B010008030000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 397DDED4B821C382D1-806C
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000345256
Coding: 00CD074400
ROD: EV_GatewUDS_AU57.rod
VCID: 3463EFE09F433EEA02-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790408570
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11343000442011200181
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000019859886
Coding: 0058130000006001000001010101102030303232203232
Shop #: WSC 02311 785 00200
VCID: 77F918ECC6B515F2E7-8022
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42034ZUT0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D55FA847C696F224D-8078
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011F16205E00628002080002
Shop #: WSC 02312 785 00200
VCID: 428FB938DDF7805A80-8016
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0006259027
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326FE9F8655730DA10-8066
Revision: 00002001 Serial number: 0166076255
Coding: 0100062020B934C083200904080104000000000000000000000000000000
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 418DB634D8F19B4299-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000210134
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5FF1984D87781AA8-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 111213-0002-006
Coding: 112296101002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C53F7804773662A5A-8078
Part No SW: 4G0 035 056 E HW: 4G0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 230LZ0B7518640
Coding: 010003020100000001
VCID: 23411CBC22ADA952EB-8076
Part No SW: 4G0 035 670 G HW: 4G0 035 670 A
Component: H-BNT-EU H48 0484
Revision: -------- Serial number: 428L00B7535506
Coding: 050100010002E1ED4510AB3E00000003000001000000000000
VCID: 275908AC56954572B7-8072
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB94007WZE
Subsystem 3 - Part No SW: 4G1 919 710 C HW: 4G1 919 710 C
Component: E380 BDT C7 H11 0204
Serial number: 90349KKU0000P
Component: CD-Database 3638
03278 - Functionality Limited due to Missing Messages
Reset counter: 21
Mileage: 167651 km
Date: 2018.10.13
Time: 10:50:23
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000100
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
VCID: 4483BF20C7E38E6AB2-8010
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 335100097
Coding: 097205C011
Shop #: WSC 01998 000 1048576
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
0049 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 21
Mileage: 167651 km
Date: 2018.10.13
Time: 11:06:23
Voltage terminal 30: 11.84 V
0114 - Load Space Cover
B12EF 54 [137] - Missing Calibration / Basic Setting
Reset counter: 0
Mileage: 167651 km
Date: 2018.10.13
Time: 11:08:04
Voltage terminal 30: 11.97 V
Component: TSG HR H04 0212
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316DE6F460510BC269-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 04:56)--------------------------
