2014 VW Jetta S, 2.0 Manual, Code 00287 right rear speed senser
blue968
C?ID=293958
HI,
Im a back yard mech and apologize for lack of any terminology
Scanned car and got a 00287 rear right speed sensor code
Removed both rear Spees sensors ( left side just for comparison) Probed Right side has .5 Volts, Probed Left side and had 12V. Still on Left side I found the constant 12V (think it was black wire) then moved my lead to opposite wire and probed it w/1 lead on multi meter, 2nd lead to chassis ground and set to Millivolt scale and turned wheel Very slowly and can clearly see millivolt signal. to take it 1 step further I did same procedure for front left wheel and almost the same readings.
Went back to problem wheel, right rear and had only .5 volts with no millivolt signal.
I also cked the 2 fuses under the hood on drivers side i think they were F16 & F23 and they were both good
Today I am going to pull back interior apart and locate Speed sesnser inside the car and probe there to see if i have 12v to rule out an broken wire leading to the sensor and do a better visual ck for any rodent damage to wires.
Im leaning towards a bad ABS module? If module is bad can VCDS program a used junk yard ABS module or doe stealership have to program it? And if so any idea how much that should cost? I can replace the module myself just may need a Bleeding procedure
Any thoughts or test I can I can perform would be greatly appreciated
Thank you
Monday,23,March,2020,08:49:30:65532
VCDS Version: 19.6.2.2  HEX-NET CB: 0.4508.4
VIN: 3VW1K7AJ5EM432129   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: 3VW1K7AJ5EM432129   Mileage: 128320km-79734miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 AD    HW: 06G 906 055 B
   Component: 2.0l 85 KW       01 1302
   Revision: T5H06---    Serial number:
   Coding: 0001012
   VCID: 6B9615104A7A0C1760-803E
               U1017 - 000 -
                    Mileage: 116559 km
                    Date: 2019.06.17
                    Time: 21:01:29
                    Temperature: 71.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.446 V
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Revision: 00H46001
   Coding: A14B200C492508FC850C04E692221061A1100012
   Shop #: WSC 23111 002 1048576
   VCID: 04445EAC87E4E36F81-8050
                    Reset counter: 223
                    Mileage: 128327 km
                    Date: 2014.08.12
                    Time: 18:24:16
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 16390
                    Count: 50688
                    Count: 1024
                    Count: 3
                    Reset counter: 223
                    Mileage: 128327 km
                    Date: 2014.08.12
                    Time: 18:24:07
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 80
                    Count: 50688
                    Count: 1024
                    Count: 3
   Part No SW: 5C0 820 047 BK    HW: 5C0 820 047 BK
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000002090942
   Shop #: WSC 00066 790 07030
   VCID: 6A9810144580151F1B-803E
   Part No SW: 5C0 937 086 J    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H34 0411
   Revision: B0034001    Serial number: 06013081140220
   Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300010002000
   VCID: 3326CD7092CA94D768-8066
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Serial number: 14102585140306173954
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Serial number: 14102584140306194357
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Serial number: 14102587140305175623
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Serial number: 14102586140312213121
   Coding: 800000
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD03RKC2
   Coding: 00004138
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74A40E6CDF44D3EFB1-8020
   Serial number: 6940000Y1400013PT50Z
   Coding: 303032
   Serial number: 3572MSME69137E41ZZZ
   Serial number: 3582MSME60227B41ZZZR
   Serial number: 3516KSME5941622BZZZT
   Serial number: 3526KSME2C30632BZZZT
   Serial number: 3556LSME4735332BZZZW
   Serial number: 3566LSME351B332BZZZY
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 224
                    Mileage: 128327 km
                    Date: 2020.03.21
                    Time: 14:30:49
   Part No SW: 5C6 920 953     HW: 5C6 920 953
   Component: KOMBI         H04 0809
   Coding: 270A01
   VCID: 6A9810148D80151F1B-803E
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B0034001
   Coding: 102200
   VCID: 70AC027CA35CEFCF55-8024
   Component: IMMO          H04 0809
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H03 0006
   Revision: -----07S    Serial number: VWZ4Z6P3755149
   Coding: 05000400010006
   Shop #: WSC 00066 790 00123
   VCID: 23063D30222A045798-8076
End----------(Elapsed Time: 00:59, VBatt start/end: 12.9V/12.8V)-----------
Hi and welcome.
Although MK60EC1 modules fail with some regularity, this doesn't fit the pattern.
Yes, assuming a replacement module is an appropriate/correct one for the car, you can do it with VCDS.
However I'd strongly suggest verifying all wiring (including its ability to carry current) before you conclude that it needs a module.
Oh, and: Are the sensors on both sides the same? It's not clear to me from what you wrote whether you swapped sensors side-to-side.
blue968
C?ID=293958
thank you for the reply
To answer your question the 2 sensors are not physically the same there is a left and right sensor due to the angle of the connection, other than that they behave the same way.
I only went to the left rear only for a properly functioning sensor for reference on how the right side should be working.
Does anybody have a wiring diagram or a test procedure? I have not verified voltage from inside the car before it exits the wheel well to rule out any broken connections from that point.
What would be a common symptom of a bad ABS module?
Thank you
blue968
C?ID=293958
Update,
wanted to thank everyone for help however in dealing with this I have spoke to many people and you get people who ask if the there is gas in the tank or if the oil has been changed??? Really!!!! Anyway I apologize for ranting :banghead::banghead:
OK to help someone, What I found under the passenger side rear door under foot sill (piece of trim molding that covers the carpet edge to the body) sorry not sure what to call that?? Anyway underneath that piece thats were all the wiring is and wiring leading out to right rear speed sensor. VW thought it would be a great idea not only to change the color of the wiring from Grey to black and blue to brown but to make a splice right there. What I ended up doing was pulling the big plug at the ABS module up at front of car (What Bitch that was) and check continuity of the wring from plug to rear speed sensor and found and open. Started pulling everything apart and VIOLA I found the broken splice in the back.
Im not a mechanic but as I mentioned in 1st post I set my volt meter to DC Volts and measure a good reading sensor Left rear (only for a reference to see how a good speed sensor should read) and had 12V between the 2 wires in the sensor connector. Then I took 1 lead of my meter and placed it on the body (good ground) and other lead of meter to 1 of the 2 wires on the speed sensor wiring testing each wire. I found 1 wire was constant 12V and the other wire sent a Millivolt signal to ABS module. When I found the milivolt wire I turned the wheel VERY slowly and I could see the voltage change sending signal telling me the hub was good ( think its called a reluctor). Now I talked to another person and they said it was suppose to send A/C voltage but I was able to read on DC voltage so Im not sure if what I did it correct but it worked for me.
Then I went back to right rear sensor connector which was giving me the fault, I tested between 2 wires (black & Brown) and had no voltage!!! After troubleshooting described above and repaired broken wire I then had 12V, problem solved
Hope this helps someone else, I know If i had this info it would have saved me a LOT of time and not wasting time on checking the oil :thanks:
NZDubNurd
New Zealand
C?ID=230482
Well done on the find.
It's DC voltage, but it steps high and low, which is sort of like half-wave rectified AC voltage (Not really though :D)
It funny how many people think they're car savvy... they seem to be the same ones who can feel the extra power from new oil and changing the oil and all the filters may possibly fix the conrod poking out of the block etc :facepalm:
