- Joined
- Dec 5, 2014
- Messages
- 543
- Reaction score
- 269
- Location
- Windsor UK
- VCDS Serial number
- C?ID=334979
We replaced the Engine ECU on this car this week with a used unit.
All is well now except the Aircon.
The compressor wont cut in. Reason for Compressor Shut off is Either 12 or 15 not sure now but came up as Engine ECU.
As it was working fine before we are hoping it may just be a coding issue but we don't know for sure.
I see refrigerant pressure at 8 bar, it is the same if I put Gauges on it.
The Fans can be activated via Output tests - this car has 2 fans, front wheel drive, has ABS & Airbags. 5 speed manual
Any help or pointers will be gratefully received
thank you.
Sunday,07,July,2019,16:00:14:36704
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4505.4
VIN: WVWZZZ1KZ4W120626 License Plate: CHRIS
Mileage: 284830km-176985mi Repair Order: 123
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ4W120626 Mileage: 284830km-176985miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 0000SG 5645
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0000031
Shop #: WSC 00000 028 00001
VCID: 221D16CDD8C70717A89-8076
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021121
Shop #: WSC 01279 785 00200
VCID: 3A2DCEAD50576FD7909-806E
Part No: 1K0 820 047 CB
Component: Climatic PQ35 080 0201
VCID: 66954ADD746F3B37041-8032
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000604041
Coding: E4890F0600041800001400001400000000
VCID: 3FDBBFB94B754AFFA77-806A
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Subsystem 2 - Part No: 1K0 955 559 K Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 002 0505
Coding: 00217125
Part No SW: 1K0 909 605 A HW: 1K0 909 605 A
Component: 0M AIRBAG VW8 022 0500
Revision: 04022000 Serial number: 0033FD0A6W51
Coding: 0012365
Shop #: WSC 01268 785 00200
VCID: 2A0DFEEDA0F7DF57E09-807E
Subsystem 1 - Serial number: 6332MSME1E053302
Subsystem 2 - Serial number: 6342MSME6D633602
Subsystem 3 - Serial number: 6351HSME7A407C01
Subsystem 4 - Serial number: 6361HSME77510102
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000022
VCID: 3039EC85862BA5872ED-8064
Part No: 1K0 920 950 L
Component: KOMBIINSTRUMENT VDD 3556
Coding: 0001401
Shop #: WSC 12345 123 45725
VCID: 313FE9818D21AC8F213-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2600104304069D
Coding: 3D0F0B40070003
VCID: 270B07D9B3E5E23FFF7-8072
Component: IMMO 3556
Shop #: WSC 06402 785 00200
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0116
Coding: 0000052
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.2 1301
VCID: 2F3BEFF99B15BA7F377-807A
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8405485BC69010CC
Shop #: WSC 01236 785 00200
VCID: 79AF11A115D1A4CFD93-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Subsystem 3 - Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0040400
VCID: 2D07F5F19119C86F05B-8078
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C01F8F5AA03C167125-8078
End----(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
thank you.
