VW Golf 2004 UK Car - Aircon Issue
Dr Sheldon
Windsor UK
HC433554 (2nd hand?)
We replaced the Engine ECU on this car this week with a used unit.
All is well now except the Aircon.
The compressor wont cut in. Reason for Compressor Shut off is Either 12 or 15 not sure now but came up as Engine ECU.
As it was working fine before we are hoping it may just be a coding issue but we don't know for sure.
I see refrigerant pressure at 8 bar, it is the same if I put Gauges on it.
The Fans can be activated via Output tests - this car has 2 fans, front wheel drive, has ABS & Airbags. 5 speed manual
Sunday,07,July,2019,16:00:14:36704
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWZZZ1KZ4W120626   License Plate: CHRIS
Mileage: 284830km-176985mi   Repair Order: 123
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ4W120626   Mileage: 284830km-176985miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 B    HW: 028 101 147 8
   Component: R4 1,9L EDC 0000SG  5645
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000031
   Shop #: WSC 00000 028 00001
   VCID: 221D16CDD8C70717A89-8076
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0021121
   Shop #: WSC 01279 785 00200
   VCID: 3A2DCEAD50576FD7909-806E
   Part No: 1K0 820 047 CB
   Component: Climatic PQ35   080 0201
   VCID: 66954ADD746F3B37041-8032
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000604041
   Coding: E4890F0600041800001400001400000000
   VCID: 3FDBBFB94B754AFFA77-806A
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD0A6W51
   Coding: 0012365
   Shop #: WSC 01268 785 00200
   VCID: 2A0DFEEDA0F7DF57E09-807E
   Subsystem 1 - Serial number: 6332MSME1E053302
   Subsystem 2 - Serial number: 6342MSME6D633602
   Subsystem 3 - Serial number: 6351HSME7A407C01
   Subsystem 4 - Serial number: 6361HSME77510102
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000022
   VCID: 3039EC85862BA5872ED-8064
   Part No: 1K0 920 950 L
   Component: KOMBIINSTRUMENT VDD 3556
   Coding: 0001401
   Shop #: WSC 12345 123 45725
   VCID: 313FE9818D21AC8F213-8064
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2600104304069D
   Coding: 3D0F0B40070003
   VCID: 270B07D9B3E5E23FFF7-8072
   Component: IMMO                3556
   Shop #: WSC 06402 785 00200
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0116
   Coding: 0000052
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.2       1301
   VCID: 2F3BEFF99B15BA7F377-807A
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485BC69010CC
   Shop #: WSC 01236 785 00200
   VCID: 79AF11A115D1A4CFD93-802C
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
   VCID: 2D07F5F19119C86F05B-8078
            000 -  -
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C01F8F5AA03C167125-8078
End----(Elapsed Time: 00:59, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
Any help or pointers will be gratefully received
thank you.
NostraJackAss
Gets activated by SVM or adaptation/coding?
This is why data transfer!
How about 0000032
Dr Sheldon
Windsor UK
Hi ~Jack and thank you for the prompt reply.
Had a good look this morning and 0000071 is the magic number.
Climatronic all singing & dancing now. Superb start to the week !!!
Once again thank you.
