New user retrofitting MFSW help needed
dale h
New Member
Hi all,
I have a 2009 Audi A5 with a non MFSW basic steering wheel.
I have fitted a MFSW with paddles and what I think is the correct slip ring 8K0953568F I have used Vcds to code the new angle sensor and select MFSW with paddles.
Airbag is fine no errors
Horn works.
MFSW buttons light up but don’t work
Paddles light up but don’t work.
Any help would be great.
[/URL][/IMG]
Mari
C?ID=150535
Start posting a complete and unedited autoscan...
dale h
New Member
Saturday,28,March,2020,13:05:48:24439
VIN: WAUZZZ8F6AN012942   License Plate: D8LCS
Mileage: 86420km-53698mi   Repair Order:
Chassis Type: 8F-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 26 2E 42 46 52 53 56 62 72 77
VIN: WAUZZZ8F6AN012942   Mileage: 86420km-53698miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0006
   Revision: E1H15---
   Coding: 011C000C02070060
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS8K2907115P A01008
   ROD: EV_ECM20AVS.rod
   VCID: 3C21356466EE5097D5D-8068
7150 - Please Check DTC Memory of Steering Wheel Electronics
          P1698 00 [032] - -
                    Mileage: 86420 km
                    Date: 2009.05.28
                    Time: 20:00:14
                    Coolant temperature: 66 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 11.921 V
7788 - Software Incompatibility with Instrument Panel Control Module
          U0323 00 [047] - -
                    Mileage: 86420 km
                    Date: 2009.05.28
                    Time: 20:00:16
Readiness: 1110 0100
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AC    HW: 0AW 927 156 H
   Component: 0AW 20TFSIRdW H02 0004
   Revision: --H02---    Serial number: 0000000622
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381.rod
   VCID: 74B1DD440E3ED8D7DDD-8020
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 080500
   Shop #: WSC 02391 823 56573
   VCID: 025D8B9C440AE667DF1-8056
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 215
                    Mileage: 86421 km
                    Date: 2009.05.29
                    Time: 17:15:23
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0032
                    Hex Value: 0x3392
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DC    HW: 8K0 907 064 DC
   Component: BCM2 1.1      H02 0326
   Coding: 011300
   Shop #: WSC 02399 823 56573
   VCID: 74B1DD440EBED8D7DDD-8020
   Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
   Serial number: 0816000040328017
   Serial number: 0209000068751007
   Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
   Component: KLIMA 1 ZONE  H08 0171
   Revision: B0000000    Serial number: 01011020090405
   Coding: 64070000
   Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
   Component: BCM1 1.0      H19 0253
   Revision: 05019001    Serial number: 00000000025294
   Coding: 2600D0910014AE010009000000005D5D4C09028800010001000000
   Shop #: WSC 00482 210 80117
   VCID: 30391154BA26A4F7795-8064
   Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 290909  H05 0021
   Serial number: SWF09090295146
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002309090301
                    Reset counter: 215
                    Mileage: 86420 km
                    Date: 2009.05.28
                    Time: 20:30:00
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655     HW: 8F0 959 655
   Component: AirbagVW-AU10 H10 0430
   Serial number: 003A4D0615ED
   Coding: 30363635353130303030554A305238463053
   Shop #: WSC 02135 785 00200
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 75B7E0400544C1DFEA3-8020
   Serial number: 6334MSME4B03256CG
   Serial number: 6344MSME4B026C50E
   Serial number: 6352QSME053D08107
   Serial number: 6362QSME223B4912C
   Serial number: 63732SME033E1914Y
   Serial number: 63832SME05525076U
   Revision: --------    Serial number: 90319IKB000BF
   Coding: 000030
   Shop #: WSC 06335 123 12345
   VCID: 3D2738607D74599FE23-8068
                    Reset counter: 214
                    Mileage: 86421 km
                    Date: 2009.05.28
                    Time: 23:15:58
                    Reset counter: 215
                    Mileage: 86421 km
                    Date: 2009.05.29
                    Time: 17:14:12
   Part No SW: 8T0 920 950 P    HW: 8T0 920 950 P
   Component: KOMBIINSTR.   H32 0253
   Revision: 00000000    Serial number: BX6433C59
   Coding: 2347180002002600010000
   VCID: 45D7508015A4115FBA3-8010
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G09926840C
   Coding: 00C303
   VCID: 50F971D4DAE6C4F7195-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0170
   Serial number: 19090EFB100909
                    Reset counter: 0
                    Mileage: 86420 km
                    Date: 2009.05.28
                    Time: 19:39:34
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Text: FF30752C80220001
                    (no units): 29879.0
                    Reset counter: 0
                    Mileage: 86421 km
                    Date: 2009.05.28
                    Time: 20:37:20
                    Bin. Bits:    10000
                    Voltage: 12.60 V
                    Count: 7
                    Bin. Bits:    10000
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 0
                    Mileage: 86421 km
                    Date: 2009.05.29
                    Time: 00:41:00
                    Reset counter: 0
                    Mileage: 86421 km
                    Date: 2009.05.29
                    Time: 04:41:00
                    Bin. Bits:    00000
                    Voltage: 12.10 V
                    Count: 17
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H09 0170
   ASAM Dataset: EV_ElectRoofContr 001007
   ROD: EV_ElectRoofContr.rod
   VCID: 71BFD450712CEDFF36B-8024
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020202
   VCID: 78A9E97412D6BCB7F15-802C
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009390296
   Coding: 011042724009330C03
   Revision: 00002001    Serial number: 0121939024
   Coding: 011B07A2003900200230038000000000
   Subsystem 1 - Part No: 8P7 951 177
   Component: DWA-Sensor  H03 0040
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009365137
   Coding: 011042324009330C03
   VCID: 44D14D841E9E2857ADD-8010
   Revision: 00000003    Serial number: 10000000332788
   VCID: 34311D444E3E98D71DD-8060
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H04 0310
   Revision: 00000007    Serial number: AUZ5Z6I1280411
   Coding: 050204830403CD028159870902
   Shop #: WSC 00055 022 12345
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 213
                    Mileage: 86420 km
                    Date: 2009.05.28
                    Time: 19:27:43
   Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102005371
   Coding: 010002324009370C03
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102005332
Address 77: Telephone
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
dale h
New Member
can anyone help?
its driving me mad :confused:
PetrolDave
Westbury, UK
C?ID=1423
I think you need to get the Component Protection cleared in #09 and #19 as a first step.
dale h
New Member
That’s next on my list but can’t see me getting it done anytime soon due to all garages with the Odis diagnostics shut.
Was hoping to try and figure out why my MFSW wasn’t working as I don’t think the component protection restricts this but I could be wrong
darkchina811
ITALY
C?ID=333184
you don't think CP restricts a function based on what assumption? my car was acting very funny when CP triggered due to replacing modules. nobody really know which or what function gets cut/restricted.
golfi_vend
Tartu, Estonia
C?ID=195131
Module 16 clearly tells it's unhappy about coding. Why's that?
dale h
New Member
like i say could be wrong......
hopefully get it removed when audi re open
Viking
C?ID=151455
not sure, ive coded it but no joy
Well, it says incorrect coding so looks like you coded it incorrectly. That's the place to start for me, get it coded correctly.
