DTC description and freeze frame
stanley121
New Member
Poland
hxn6d61-00001b-e1508f-a0fdb6-tqicap-5d4d
I have a few question about scan report in Audi A6. Mileage: 86822km-53948mi
For example, VCDS read fault in Engine module:
13272 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
Mileage: 81982 km
Date: 2019.11.19
Time: 13:01:15
My questions:
1. Faults status (color green) is not the same as fault desctription (color red). Why?
This Fault status value: 00000001- active By using desctription from forum.
Is different from this:
2. My thinking is correct?:
MIL ON - Confirmed - Tested Since Memory Clear- it is a moment when the fault was record
Fault Status: 00000001- it is a moment when I do the scan with VCDS
That is right?
3. Fault Status: 00000001 Means that fault is active. Is it still active since when it was recorded in 2019.11.19 time 13:01:15
4. Have you newest dectription for value: [237] -? And VCDS Fault Anathomy>
On forum is only old.
Best regards
The stuff in red comes from the bits in the [237].
The Freeze-Frame data, including the status and priority is pulled separately from the fault code itself.
stanley121
New Member
Poland
Hi, I know that.
I don't know:
MIL ON - Confirmed - Tested Since Memory Clear- it is a moment when the fault was record?
Fault Status: 00000001- it is a moment when I do the scan with VCDS?
It looks like this parameters: [237] and Fault Status display values in different moments in the DTC.
Could you not cross check by creating and clearing DTC's and counting the last time stamp to answer your own question?
Get verified & JPPSG yet?
